Luke 42243 Posted December 21, 2019 Author Posted December 21, 2019 It only shows 3.5.3.0. I force update, it does not go above that. How do I trigger a full install of the latest version? When I click on it it shows the following repository: emby/embyserver:3.5.3.0 Strange because 4.3.1 is available here: https://hub.docker.com/r/emby/embyserver/tags
strike 2 Posted December 21, 2019 Posted December 21, 2019 It only shows 3.5.3.0. I force update, it does not go above that. How do I trigger a full install of the latest version? When I click on it it shows the following repository: emby/embyserver:3.5.3.0 Just change the repository to emby/embyserver:latest
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 Just change the repository to emby/embyserver:latest Done, "Emby Server is upgrading your database. Please try again shortly."... Now we wait...
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 (edited) Done, "Emby Server is upgrading your database. Please try again shortly."... Now we wait... Version 4.0.1.0 Emby server started fine, logged in, now rescanning all libraries Edited December 21, 2019 by gnollo
Happy2Play 9811 Posted December 21, 2019 Posted December 21, 2019 Done, "Emby Server is upgrading your database. Please try again shortly."... Now we wait... How long did you wait before refreshing browser? I would assume the update from 3.5.3.0 to current would take awhile for the database changes to apply. Looks like you basically stepped back to older versions to upgrade.
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 Under transcoding there is an option to "Enable hardware acceleration when available". Should I enable it? Motherboard: Gigabyte Technology Co., Ltd. - G33-DS3R Processor: Intel® Core™2 Quad CPU @ 2.833 GHz
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 How long did you wait before refreshing browser? I would assume the update from 3.5.3.0 to current would take awhile for the database changes to apply. Looks like you basically stepped back to older versions to upgrade. 10 minutes I think
Happy2Play 9811 Posted December 21, 2019 Posted December 21, 2019 (edited) Under transcoding there is an option to "Enable hardware acceleration when available". Should I enable it? Motherboard: Gigabyte Technology Co., Ltd. - G33-DS3R Processor: Intel® Core™2 Quad CPU @ 2.833 GHz What processor? Looks like Q95xx onboard (Intel GMA 3100) But that appears to be quite old hardware, so it wouldn't make any difference. Edited December 21, 2019 by Happy2Play
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 What processor? Looks like Q95xx onboard (Intel GMA 3100) But that appears to be quite old hardware, so it wouldn't make any difference. Intel Q9550 Core 2 Quad Processor - 2.83 GHz,12MB L2 Cache,1333MHz FSB,Socket LGA775 Sent from my SM-A520F using Tapatalk
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 Scanned the library, which completed, but I am guessing that the database upgrade / update will take a whole lot longer on about 4500 movies. I see metadata missing (all saved locally using MCM), movies which I added to the server on 29 September, and that have an Added Date of the same day in the movie.xml file, are now showing at the top of the library in terms of data added on emby, also show as date added today. I will give it 24 hours and see if the database improves.
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 (edited) Emby server stopped. I didn't stop it... "Emby Server is upgrading your database. Please try again shortly." when I try to connect to it again. Edited December 21, 2019 by gnollo
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 And it stops again. This it's exactly what happened last time I upgraded outside the autoupgrade process. Unstable server. Only solution last time was to nuke and start from fresh. Long painful process. Damn. Sent from my SM-A520F using Tapatalk
Happy2Play 9811 Posted December 21, 2019 Posted December 21, 2019 Scanned the library, which completed, but I am guessing that the database upgrade / update will take a whole lot longer on about 4500 movies. I see metadata missing (all saved locally using MCM), movies which I added to the server on 29 September, and that have an Added Date of the same day in the movie.xml file, are now showing at the top of the library in terms of data added on emby, also show as date added today. I will give it 24 hours and see if the database improves. Hard to remember back to 3.5.3 but you do have the xml metadata plugin, correct? If not your xml metadata will not be read. And it stops again. This it's exactly what happened last time I upgraded outside the autoupgrade process. Unstable server. Only solution last time was to nuke and start from fresh. Long painful process. Damn. Sent from my SM-A520F using Tapatalk I would assume we will need to see server logs.
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 Did not have the metadata plugin. Log for the server attached emby docker log 21-12.txt
Luke 42243 Posted December 21, 2019 Author Posted December 21, 2019 Did not have the metadata plugin. Log for the server attached Is this our official Docker? https://emby.media/docker-server.html
gnollo 17 Posted December 21, 2019 Posted December 21, 2019 (edited) When I click on more info, it goes to https://registry.hub.docker.com/u/emby/embyserver/ How can I tell if is is official? All I did was to change the repository to emby/embyserver:latest When I click on support, it takes me to https://forums.unraid.net/topic/43743-new-emby-docker/ Edited December 21, 2019 by gnollo
gnollo 17 Posted December 22, 2019 Posted December 22, 2019 forced update to 4.3.1.0. Scan still running and docker also still up.
gnollo 17 Posted December 22, 2019 Posted December 22, 2019 it has not stopped since, so I figure that the update fixed the issue. Installing the XML plugin to see if it makes a difference, as the movies from the past still appear as the latest movies, which needs fixing. Sort by date order is unusable for me at the moment.
gnollo 17 Posted December 22, 2019 Posted December 22, 2019 XML plugin and refresh did not fix it. How do I force it to look at the XML? Example: Bandits (2001) turns into a 2019 "Words Of Bandits" documentary. XML attached movie.zip
NikeSwe 122 Posted December 22, 2019 Posted December 22, 2019 (edited) I see the the new beta build 4.4.0.3 but no new Docker image built for it.Edit: Available now. Edited December 22, 2019 by NikeSwe
gnollo 17 Posted December 23, 2019 Posted December 23, 2019 XML plugin and refresh did not fix it. How do I force it to look at the XML? Example: Bandits (2001) turns into a 2019 "Words Of Bandits" documentary. XML attached Well, I didn't realise that xml is no longer used by Emby, and that now nfo is the way to go. I use the MCM app to download and store metadata locally, you can convert the xml into nfo quickly, tested on the folder, scanned, and it fixed the issue above. The rating is incorrect though, it displays Rated R, when it should be PG-13, that is a MCM issue though. As this is not a docker issue per se, I will continue this discussion in this xml thread instead https://emby.media/community/index.php?/topic/57025-xml-nfo-questions/
Luke 42243 Posted December 23, 2019 Author Posted December 23, 2019 Well, I didn't realise that xml is no longer used by Emby, and that now nfo is the way to go. I use the MCM app to download and store metadata locally, you can convert the xml into nfo quickly, tested on the folder, scanned, and it fixed the issue above. The rating is incorrect though, it displays Rated R, when it should be PG-13, that is a MCM issue though. As this is not a docker issue per se, I will continue this discussion in this xml thread instead https://emby.media/community/index.php?/topic/57025-xml-nfo-questions/ We'll help you in your xml topic. Thanks.
NikeSwe 122 Posted December 25, 2019 Posted December 25, 2019 Something wrong with the docker builds? 4.4.0.4-beta build is missing?
Luke 42243 Posted December 25, 2019 Author Posted December 25, 2019 Please use the testing area for beta related discussion. Thanks !
