mastrmind11 722 Posted November 8, 2018 Posted November 8, 2018 So its connected directly to my server, and with emby server on docker it only allows me to map 2 folders, i can map any 2 on the drive that all works fine, my problem is im not sure how to map a 3rd one, i tried following the command from the docker website (" -v /storage/path:/data/additional") and it works fine if all my files were on the server directly, however theyre not, and its not possible since my folder is far too big to be stored completely on the server itself. I think i need to map the external drive to /storage somehow, as its currently mapped to /var/media but im not sure how to do that. Thanks for the help. I'm not sure what you mean by "map any 2 on the drive". What do you mean "map"? How do you get at these folders outside emby? In any event, it sounds like you haven't actually mounted the drive but instead let the OS mount them via the UI? Google "how to mount a USB drive in linux" and follow the instructions, then in your docker run command, point your volumes to that mountpoint. That should do it.
brunz95 0 Posted November 8, 2018 Posted November 8, 2018 I'm not sure what you mean by "map any 2 on the drive". What do you mean "map"? How do you get at these folders outside emby? In any event, it sounds like you haven't actually mounted the drive but instead let the OS mount them via the UI? Google "how to mount a USB drive in linux" and follow the instructions, then in your docker run command, point your volumes to that mountpoint. That should do it. Thanks mate that seemed to do it! thanks again.
Jafterdark 0 Posted November 19, 2018 Posted November 19, 2018 https://hub.docker.com/r/emby/embyserver/ i did this now how do i give it permissions to access the network drives for folders
mastrmind11 722 Posted November 19, 2018 Posted November 19, 2018 https://hub.docker.com/r/emby/embyserver/ i did this now how do i give it permissions to access the network drives for folders Well which UID and GID did you use in the docker command? Presumably you used ones that have access to the shared media. If not, you either need to add the UID/GID to have r/w access to your media, or you should find a user that has r/w access to your media and rerun the docker command using the corresponding UID and GID.
Luke 42243 Posted November 19, 2018 Author Posted November 19, 2018 Emby Server for Arm64 is now available ! https://emby.media/community/index.php?/topic/65476-emby-server-for-arm64-now-available/ Thanks.
Jafterdark 0 Posted November 20, 2018 Posted November 20, 2018 I'm having a problem with very slow/lag using it in a docker container it seems like the interface pulls up pretty quick but once I start to click on movies that just take forever is anybody else experiencing this you could be just my machines not powerful enough I have a Dell i3 8 gigs of RAM 120 solid state Dell mini optiplex 9020
mastrmind11 722 Posted November 20, 2018 Posted November 20, 2018 I'm having a problem with very slow/lag using it in a docker container it seems like the interface pulls up pretty quick but once I start to click on movies that just take forever is anybody else experiencing this you could be just my machines not powerful enough I have a Dell i3 8 gigs of RAM 120 solid state Dell mini optiplex 9020 I believe images are cached on demand, so if this is a fresh install w/ new libraries, it could be that. What's your CPU/memory profile on your server while this is happening?
Jafterdark 0 Posted November 20, 2018 Posted November 20, 2018 (edited) Accidentally double posted Edited November 20, 2018 by Jafterdark
Jafterdark 0 Posted November 22, 2018 Posted November 22, 2018 (edited) This is how i ended up installing emby in docker and mounting the the network drivesif anyone need it sudo docker run -d --restart always --volume /path/to/programdata:/config --volume mymovies1:/mnt/share1 --volume mymovies2:/mnt/share2 --device /dev/dri/renderD128 --publish 8096:8096 --publish 8920:8920 --env UID=1000 --env GID=100 --env GIDLIST=100 emby/embyserver:latestTo mount network share folder in Docker sudo docker volume create --driver local --opt type=cifs --opt device=//youriptoserver/yoursharefolder/ --opt o=username=****,youruser=yourpassword,file_mode=0777,dir_mode=0777 --name mymovies2 Edited November 24, 2018 by Jafterdark
Genetik57 0 Posted November 29, 2018 Posted November 29, 2018 (edited) @@Luke Hi, The docker repository is not available root@rock64:~# docker pull emby/embyserver_arm64v8 Using default tag: latest Error response from daemon: manifest for emby/embyserver_arm64v8:latest not found And I can not find the repository in the Docker plugin of my OpenMediaVault system. On the other hand the directory for the version amd64, armv7 & armv7_neon is visible but the version arm64_v8 no Edited November 29, 2018 by Genetik57
alucryd 318 Posted November 29, 2018 Posted November 29, 2018 There's no latest tag yet, please use the beta tag instead. 1
Genetik57 0 Posted November 29, 2018 Posted November 29, 2018 There's no latest tag yet, please use the beta tag instead. Work fine, thanks my friend +1
skurvy_pirate 2 Posted December 9, 2018 Posted December 9, 2018 Having troubles getting the container to start when the system reboots. I set "--restart always" in the run command and it looks like the container is up when the OS comes up and I do a container ls (along with some other containers). But after about 10 seconds it goes away and I have to manually issue another run command for it to come back. Anyone seen this before?
Luke 42243 Posted December 9, 2018 Author Posted December 9, 2018 Having troubles getting the container to start when the system reboots. I set "--restart always" in the run command and it looks like the container is up when the OS comes up and I do a container ls (along with some other containers). But after about 10 seconds it goes away and I have to manually issue another run command for it to come back. Anyone seen this before? did the first one produce any server log?
skurvy_pirate 2 Posted December 9, 2018 Posted December 9, 2018 did the first one produce any server log? 2018-12-09 00:02:34.740 Info Main: Application path: /system/EmbyServer.dll 2018-12-09 00:02:34.750 Info Main: Emby Command line: /system/EmbyServer.dll -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.4.0.140 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: /config Application directory: /system 2018-12-09 00:02:34.974 Info App: Application version: 3.5.3.0 2018-12-09 00:02:34.976 Info App: Loading assemblies 2018-12-09 00:02:35.004 Info App: File /config/plugins/OpenSubtitles.dll has version 1.0.2.0 2018-12-09 00:02:35.006 Info App: File /system/plugins/OpenSubtitles.dll has version 1.0.2.0 2018-12-09 00:02:35.006 Info App: File /config/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 2018-12-09 00:02:35.007 Info App: File /system/plugins/Emby.Server.CinemaMode.dll has version 1.0.2.0 2018-12-09 00:02:35.007 Info App: File /config/plugins/IMVDb.dll has version 1.0.1.0 2018-12-09 00:02:35.007 Info App: File /system/plugins/IMVDb.dll has version 1.0.1.0 2018-12-09 00:02:35.018 Info App: Loading OpenSubtitles, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/OpenSubtitles.dll 2018-12-09 00:02:35.018 Info App: Loading MBBackup, Version=1.2.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/MBBackup.dll 2018-12-09 00:02:35.018 Info App: Loading Emby.Server.CinemaMode, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Server.CinemaMode.dll 2018-12-09 00:02:35.018 Info App: Loading MediaBrowser.Plugins.Trailers, Version=1.1.6.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Mediabrowser.Plugins.Trailers.dll 2018-12-09 00:02:35.018 Info App: Loading Emby.Kodi.SyncQueue, Version=2.0.3.0, Culture=neutral, PublicKeyToken=null from /config/plugins/Emby.Kodi.SyncQueue.dll 2018-12-09 00:02:35.018 Info App: Loading IMVDb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null from /config/plugins/IMVDb.dll 2018-12-09 00:02:35.018 Info App: Loading MediaBrowser.Api, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.018 Info App: Loading MediaBrowser.WebDashboard, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.018 Info App: Loading MediaBrowser.Model, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.018 Info App: Loading MediaBrowser.Common, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.018 Info App: Loading MediaBrowser.Controller, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.018 Info App: Loading MediaBrowser.Providers, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading Emby.Photos, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading Emby.Server.Implementations, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading Emby.Server.MediaEncoding, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading Emby.Dlna, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading MediaBrowser.LocalMetadata, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading Emby.Notifications, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading Emby.Server.Connect, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.019 Info App: Loading Emby.Server.Sync, Version=3.5.3.0, Culture=neutral, PublicKeyToken=null 2018-12-09 00:02:35.173 Info SqliteUserRepository: Sqlite version: 3.24.0 2018-12-09 00:02:35.174 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-12-09 00:02:35.205 Info SqliteUserRepository: Default journal_mode for /config/data/users.db is wal 2018-12-09 00:02:35.207 Info SqliteUserRepository: PRAGMA synchronous=1 2018-12-09 00:02:35.225 Info AuthenticationRepository: Default journal_mode for /config/data/authentication.db is wal 2018-12-09 00:02:35.225 Info AuthenticationRepository: PRAGMA synchronous=1 2018-12-09 00:02:35.297 Info ActivityRepository: Default journal_mode for /config/data/activitylog.db is wal 2018-12-09 00:02:35.297 Info ActivityRepository: PRAGMA synchronous=1 2018-12-09 00:02:35.300 Info SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is wal 2018-12-09 00:02:35.300 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2018-12-09 00:02:35.422 Info SqliteItemRepository: Default journal_mode for /config/data/library.db is wal 2018-12-09 00:02:35.422 Info SqliteItemRepository: PRAGMA synchronous=1 2018-12-09 00:02:35.505 Info App: Emby.Kodi.SyncQueue IS NOW STARTING!!! 2018-12-09 00:02:35.507 Info App: Emby.Kodi.SyncQueue: Creating DB Repository... 2018-12-09 00:02:35.651 Info App: Emby.Kodi.SyncQueue: SyncAPI Created and Listening at "/Emby.Kodi.SyncQueue/{UserID}/{LastUpdateDT}/GetItems?format=json" - {LastUpdateDT} must be a UTC DateTime formatted as yyyy-MM-ddTHH:mm:ssZ 2018-12-09 00:02:35.651 Info App: Emby.Kodi.SyncQueue: SyncAPI Created and Listening at "/Emby.Kodi.SyncQueue/{UserID}/GetItems?LastUpdateDT={LastUpdateDT}&format=json" - {LastUpdateDT} must be a UTC DateTime formatted as yyyy-MM-ddTHH:mm:ssZ 2018-12-09 00:02:35.651 Info App: Emby.Kodi.SyncQueue: The following parameters also exist to filter the results: 2018-12-09 00:02:35.651 Info App: Emby.Kodi.SyncQueue: filter=movies,tvshows,music,musicvideos,boxsets 2018-12-09 00:02:35.651 Info App: Emby.Kodi.SyncQueue: Results will be included by default and only filtered if added to the filter query... 2018-12-09 00:02:35.651 Info App: Emby.Kodi.SyncQueue: the filter query must be lowercase in both the name and the items... 2018-12-09 00:02:35.713 Info HttpServer: Calling ServiceStack AppHost.Init 2018-12-09 00:02:35.993 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2018-12-09 00:02:35.993 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2018-12-09 00:02:36.168 Info Skia: SkiaSharp version: 1.60.0.0 2018-12-09 00:02:36.173 Info App: Emby.Kodi.SyncQueue.Task: Retention Task Scheduled! 2018-12-09 00:02:36.196 Info TaskManager: Daily trigger for Configuration Backup set to fire at 12/9/18 12:10:00 AM, which is 7.39672371833333 minutes from now. 2018-12-09 00:02:36.200 Info TaskManager: Daily trigger for Remove Old Sync Data set to fire at 12/10/18 12:01:00 AM, which is 1438.396657625 minutes from now. 2018-12-09 00:02:36.203 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 12/9/18 2:00:00 AM, which is 117.396601923333 minutes from now. 2018-12-09 00:02:36.212 Info TaskManager: Daily trigger for Rotate log file set to fire at 12/10/18 12:00:00 AM, which is 1437.39646674833 minutes from now. 2018-12-09 00:02:36.222 Info MediaEncoder: FFMpeg: /bin/ffmpeg 2018-12-09 00:02:36.222 Info MediaEncoder: FFProbe: /bin/ffprobe 2018-12-09 00:02:36.223 Info MediaEncoder: Validating media encoder at /bin/ffmpeg 2018-12-09 00:02:36.225 Info MediaEncoder: Running /bin/ffmpeg -decoders 2018-12-09 00:02:36.310 Info MediaEncoder: Decoder available: mpeg2video 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: h264_cuvid 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: hevc_cuvid 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: mpeg2_cuvid 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: mpeg4_cuvid 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: vc1_cuvid 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: vp8_cuvid 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: vp9_cuvid 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: ac3 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: aac 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: mp3 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: h264 2018-12-09 00:02:36.311 Info MediaEncoder: Decoder available: hevc 2018-12-09 00:02:36.312 Info MediaEncoder: Running /bin/ffmpeg -encoders 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: libx264 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: aac 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: libmp3lame 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: libopus 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: libvorbis 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: srt 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: h264_nvenc 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: hevc_nvenc 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: h264_vaapi 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: hevc_vaapi 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: libwebp 2018-12-09 00:02:36.335 Info MediaEncoder: Encoder available: ac3 2018-12-09 00:02:36.336 Info MediaEncoder: Running /bin/ffmpeg -protocols 2018-12-09 00:02:36.358 Info MediaEncoder: Encoder validation complete 2018-12-09 00:02:36.359 Info MediaEncoder: ffmpeg supported protocols: async,cache,concat,crypto,data,ffrtmphttp,file,ftp,gopher,hls,http,httpproxy,https,mmsh,mmst,pipe,rtmp,rtmps,rtmpt,rtmpts,rtp,srtp,subfile,tcp,tls,udp,udplite,unix,smb 2018-12-09 00:02:36.360 Info App: ServerId: e51c0421b4d9407e8e8359c8abb04f32 2018-12-09 00:02:36.407 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint 2018-12-09 00:02:36.408 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.000674 seconds 2018-12-09 00:02:36.408 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2018-12-09 00:02:36.555 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.147109 seconds 2018-12-09 00:02:36.555 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2018-12-09 00:02:36.557 Info App: Loading data from /config/data/connect.txt 2018-12-09 00:02:36.560 Info App: Loading data from /config/data/wan.dat 2018-12-09 00:02:36.574 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0184479 seconds 2018-12-09 00:02:36.574 Info App: Core startup complete 2018-12-09 00:02:36.574 Info App: Post-init migrations complete 2018-12-09 00:02:36.574 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-12-09 00:02:36.574 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 5.37E-05 seconds 2018-12-09 00:02:36.574 Info App: Starting entry point MBBackup.ServerEntryPoint 2018-12-09 00:02:36.574 Info App: Entry point completed: MBBackup.ServerEntryPoint. Duration: 5.93E-05 seconds 2018-12-09 00:02:36.574 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-12-09 00:02:36.574 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 4.67E-05 seconds 2018-12-09 00:02:36.574 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2018-12-09 00:02:36.574 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0002342 seconds 2018-12-09 00:02:36.574 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-12-09 00:02:36.574 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 4.95E-05 seconds 2018-12-09 00:02:36.575 Info App: Starting entry point MediaBrowser.Plugins.Trailers.EntryPoint 2018-12-09 00:02:36.575 Info App: Entry point completed: MediaBrowser.Plugins.Trailers.EntryPoint. Duration: 0.0006528 seconds 2018-12-09 00:02:36.575 Info App: Starting entry point Emby.Kodi.SyncQueue.EntryPoints.LibrarySyncNotification 2018-12-09 00:02:36.576 Info App: Emby.Kodi.SyncQueue: LibrarySyncNotification Startup... 2018-12-09 00:02:36.576 Info App: Entry point completed: Emby.Kodi.SyncQueue.EntryPoints.LibrarySyncNotification. Duration: 0.0012593 seconds 2018-12-09 00:02:36.576 Info App: Starting entry point Emby.Kodi.SyncQueue.EntryPoints.UserSyncNotification 2018-12-09 00:02:36.577 Info App: Emby.Kodi.SyncQueue: UserSyncNotification Startup... 2018-12-09 00:02:36.577 Info App: Entry point completed: Emby.Kodi.SyncQueue.EntryPoints.UserSyncNotification. Duration: 0.0004926 seconds 2018-12-09 00:02:36.577 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2018-12-09 00:02:36.577 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 2.94E-05 seconds 2018-12-09 00:02:36.577 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2018-12-09 00:02:36.577 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0002422 seconds 2018-12-09 00:02:36.577 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2018-12-09 00:02:36.580 Info App: Loading live tv data from /config/data/livetv/timers 2018-12-09 00:02:36.667 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 192.168.1.250 2018-12-09 00:02:36.732 Info App: Creating recording timer for ea966fe59fbafadda99b1d9880793135, Alaskan Bush People. Timer will fire in 1859.38780074667 minutes 2018-12-09 00:02:36.732 Info App: Creating recording timer for b63ee7a9eb90a8c9f43b3e7f1665db72, The Conners. Timer will fire in 4557.387790815 minutes 2018-12-09 00:02:36.915 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.3374173 seconds 2018-12-09 00:02:36.915 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2018-12-09 00:02:36.915 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0004809 seconds 2018-12-09 00:02:36.915 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2018-12-09 00:02:36.950 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.0350594 seconds 2018-12-09 00:02:36.950 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2018-12-09 00:02:36.951 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0009269 seconds 2018-12-09 00:02:36.951 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding 2018-12-09 00:02:36.952 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.0005507 seconds 2018-12-09 00:02:36.952 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2018-12-09 00:02:36.952 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0002416 seconds 2018-12-09 00:02:36.952 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2018-12-09 00:02:36.954 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0013289 seconds 2018-12-09 00:02:36.954 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier 2018-12-09 00:02:36.955 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0012525 seconds 2018-12-09 00:02:36.955 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2018-12-09 00:02:36.957 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0026114 seconds 2018-12-09 00:02:36.958 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2018-12-09 00:02:36.958 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.00056 seconds 2018-12-09 00:02:36.958 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2018-12-09 00:02:36.959 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0003998 seconds 2018-12-09 00:02:36.959 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint 2018-12-09 00:02:36.960 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0014292 seconds 2018-12-09 00:02:36.960 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint 2018-12-09 00:02:36.962 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0021008 seconds 2018-12-09 00:02:36.962 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2018-12-09 00:02:36.962 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0001546 seconds 2018-12-09 00:02:36.962 Info App: Starting entry point Emby.Server.Implementations.Devices.DeviceManagerEntryPoint 2018-12-09 00:02:36.964 Info App: Entry point completed: Emby.Server.Implementations.Devices.DeviceManagerEntryPoint. Duration: 0.001334 seconds 2018-12-09 00:02:36.964 Info App: Starting entry point Emby.Server.Implementations.Collections.CollectionManagerEntryPoint 2018-12-09 00:02:36.965 Info App: Entry point completed: Emby.Server.Implementations.Collections.CollectionManagerEntryPoint. Duration: 0.0014896 seconds 2018-12-09 00:02:36.965 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint 2018-12-09 00:02:36.969 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0037397 seconds 2018-12-09 00:02:36.969 Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint 2018-12-09 00:02:36.972 Info LibraryMonitor: Watching directory /media/triforce/Media/Videos/Recorded/Movies 2018-12-09 00:02:37.009 Info LibraryMonitor: Watching directory /media/triforce/Media/Videos/Movies 2018-12-09 00:02:37.081 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2018-12-09 00:02:37.095 Info LibraryMonitor: Watching directory /media/triforce/Media/Videos/Recorded/TV 2018-12-09 00:02:37.109 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.1400043 seconds 2018-12-09 00:02:37.109 Info App: Starting entry point Emby.Notifications.Notifications 2018-12-09 00:02:37.110 Info App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.0007192 seconds 2018-12-09 00:02:37.110 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint 2018-12-09 00:02:37.110 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.000211 seconds 2018-12-09 00:02:37.110 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-12-09 00:02:37.110 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 4.19E-05 seconds 2018-12-09 00:02:37.110 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2018-12-09 00:02:37.115 Info App: Sqlite version: 3.24.0 2018-12-09 00:02:37.115 Info App: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2018-12-09 00:02:37.123 Info App: Default journal_mode for /config/data/sync14.db is wal 2018-12-09 00:02:37.124 Info App: PRAGMA synchronous=1 2018-12-09 00:02:37.126 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.0155824 seconds 2018-12-09 00:02:37.126 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2018-12-09 00:02:37.128 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0017606 seconds 2018-12-09 00:02:37.128 Info App: All entry points have started 2018-12-09 00:02:37.947 Info LibraryMonitor: Watching directory /media/triforce/Media/Videos/TV 2018-12-09 00:02:39.211 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2018-12-09 00:02:39.212 Info TaskManager: Queueing task PluginUpdateTask 2018-12-09 00:02:39.213 Info TaskManager: StartupTrigger fired for task: Check for application updates 2018-12-09 00:02:39.213 Info TaskManager: Queueing task SystemUpdateTask 2018-12-09 00:02:39.218 Info TaskManager: Executing Check for application updates 2018-12-09 00:02:39.218 Info TaskManager: Executing Check for plugin updates 2018-12-09 00:02:39.269 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2018-12-09 00:02:39.286 Info TaskManager: ExecuteQueuedTasks 2018-12-09 00:02:39.309 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2018-12-09 00:02:39.309 Info TaskManager: ExecuteQueuedTasks 2018-12-09 00:02:40.941 Info LibraryMonitor: Watching directory /media/triforce/Media/Audio/Music 2018-12-09 00:02:49.063 Info HttpServer: HTTP GET http://192.168.1.250:8096/dlna/e51c0421b4d9407e8e8359c8abb04f32/description.xml. UserAgent: python-requests/2.20.1 2018-12-09 00:02:49.089 Info HttpServer: HTTP Response 200 to 192.168.1.250. Time: 27ms. http://192.168.1.250:8096/dlna/e51c0421b4d9407e8e8359c8abb04f32/description.xml
Luke 42243 Posted December 9, 2018 Author Posted December 9, 2018 And then the log just stopped after that?
skurvy_pirate 2 Posted December 9, 2018 Posted December 9, 2018 Yeah, it is really weird. It seems to happen always right around that same point when LibraryMonitor tasks start going. And docker doesn't restart the container either which is odd.
Haxy 11 Posted December 13, 2018 Posted December 13, 2018 Hi all, I found two bugs in docker container: 1. TZ env. variable is not respected in the docker image: I set "TZ = Europe/Warsaw" but In Emby dashboard I still see GMT-2 time zone 2. Every time I restart the Emby from the dashboard I get: "Check for plugin updates failed" "Connection to https://www.mb3admin.com/admin/service/EmbyPackages.json timed out at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, Boolean withAutoUpdateEnabled, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)"
mastrmind11 722 Posted December 13, 2018 Posted December 13, 2018 Hi all, I found two bugs in docker container: 1. TZ env. variable is not respected in the docker image: I set "TZ = Europe/Warsaw" but In Emby dashboard I still see GMT-2 time zone 2. Every time I restart the Emby from the dashboard I get: "Check for plugin updates failed" "Connection to https://www.mb3admin.com/admin/service/EmbyPackages.json timed out at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, Boolean withAutoUpdateEnabled, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options)" check your outbound firewall
Haxy 11 Posted December 13, 2018 Posted December 13, 2018 check your outbound firewall Sure, I have rule on my firewall: „block Emby plugins update check on restart”
sluggo45 47 Posted December 16, 2018 Posted December 16, 2018 Sure, I have rule on my firewall: „block Emby plugins update check on restart” Instead of sarcasm maybe check why your server can't reach https://www.mb3admin.com/admin/service/EmbyPackages.json because that is why plugin updates fail 95% of the time. A likely place to start would be your firewall.
nekromantik 24 Posted December 20, 2018 Posted December 20, 2018 hi all running emby server beta container on bridged mode on my server. however the URL for Emby plugins is only getting resolved as a IPv6 address and so failing to connect as my network has no IPV6 enabled. All other URLs resolve correctly to IPv4 addresses. The interface has both IPv4 and 6 IPs. any hints?
Luke 42243 Posted December 20, 2018 Author Posted December 20, 2018 hi all running emby server beta container on bridged mode on my server. however the URL for Emby plugins is only getting resolved as a IPv6 address and so failing to connect as my network has no IPV6 enabled. All other URLs resolve correctly to IPv4 addresses. The interface has both IPv4 and 6 IPs. any hints? Others may respond here. I will use your topic about this: https://emby.media/community/index.php?/topic/66837-emby-server-beta-docker-and-plugin-catalogue Thanks.
apefray 4 Posted December 23, 2018 Posted December 23, 2018 (edited) Hi, I've been using Emby Docker on Unraid for nearly two years, and for the last 18 - 20 months all has worked superbly (a minor issue on the Live TV M3U, but other than that it has worked flawlessly). However for the past 2 months I have been getting random crashes in Emby Docker (twice today, unhandled exception logs attached). Anyone have any idea why this is happening as its spoiling what is a great product. Is this happening to anyone else, is it really unique to me (usually is). What can I do to fix it? Im running Emby Docker Version 3.5.3.0 on Unraid Version: 6.6.3 and I believe this started when I updated Emby Docker to the latest version. I don't believe it happened on the previous version, but equally, I could be wrong. I remember reading about disabling a plug-in (audiodb) from this link: https://emby.media/community/index.php?/topic/62313-bug-systemnetsocketssocketexception-since-352/ Which I've done, but as you can see from the logs, It's still happening. Cheers Log2.txt Log1.txt Edited December 23, 2018 by apefray
