skybird1980 0 Posted July 27, 2018 Posted July 27, 2018 (edited) Since last Docker update i get periodly Errors in the log, i will add my logs: // fixed- the problem is open media vault 4 - if i use host mode for the docker network it get's this errors. if i use bridge mode it works. embyserver.txt Edited July 27, 2018 by skybird1980
BobbyDing 56 Posted July 28, 2018 Posted July 28, 2018 (edited) Having issues with latest unraid docker. Any ideas? (See last posts). https://lime-technology.com/forums/topic/43743-new-emby-docker/?page=16 Thanks (Sorry for them lame post, I'm away from home without access to the machine) Edited July 28, 2018 by BobbyDing
Luke 42243 Posted July 28, 2018 Author Posted July 28, 2018 Hi @@BobbyDing, can you please describe what your issue is? thanks.
BobbyDing 56 Posted July 28, 2018 Posted July 28, 2018 The container starts, then stops on its own a minute or two later. I'm not very linux savy, but the end of the log file shows a kill command being executed. I assume that's whats shutting down the container. Looks like I'm not alone with the issue. Thanks Luke
Luke 42243 Posted July 28, 2018 Author Posted July 28, 2018 Can you please attach the emby server log? thanks.
BobbyDing 56 Posted July 28, 2018 Posted July 28, 2018 (edited) There are also some "socket" errors in the unraid logs. I know thats a network issue, but I don't know if it's related. Edited July 28, 2018 by BobbyDing
BobbyDing 56 Posted July 28, 2018 Posted July 28, 2018 Two things. I'm away from home and won't be home for 12 hours, and I don't know how to get into the container to get the logs ( since I can't get to the servers web page). I use putty to access the shares. How would I get into the container with putty? If it's not too much to ask. Thanks!
BobbyDing 56 Posted July 28, 2018 Posted July 28, 2018 OK. Sorry. just remembered logs should be in appdata folder. attached is todays I hope. Bit rough doing this remotely from a tablet. Let me know if you need something different.
BobbyDing 56 Posted July 28, 2018 Posted July 28, 2018 oops. selected file but forgot to attach. embyserver-63668338578.7z
Luke 42243 Posted July 28, 2018 Author Posted July 28, 2018 Ok I think this is related to the audiodb music fetcher. I'm going to push an update later today to try and resolve it. Thanks.
BobbyDing 56 Posted July 29, 2018 Posted July 29, 2018 Hi. Is there a way to force the unraid version of emby-server to install the previous version instead of the latest? If so, is there a list of previous version numbers for the Dockers? Thanks!!
ben-nl 1 Posted July 29, 2018 Posted July 29, 2018 Version numbers of emby server https://github.com/MediaBrowser/Emby.Releases/releases You can change this in embyserver template. Example Repository: emby/embyserver:3.5.0.0 1
bungee91 133 Posted July 29, 2018 Posted July 29, 2018 (edited) Having issues with latest unraid docker. Any ideas? (See last posts). https://lime-technology.com/forums/topic/43743-new-emby-docker/?page=16 Thanks (Sorry for them lame post, I'm away from home without access to the machine) Same, just started happening. Running stable version (3.5.1) Logs attached, dies within minutes. @@Luke is there anything I can disable/modify to fix this until you push an update with the fix (considering it is completely unusable at this time)? Thanks for the help! From the docker container logs, I get a bunch of these errors. [matroska,webm @ 0x644b40] Format matroska,webm detected only with low score of 1, misdetection possible! [matroska,webm @ 0x644b40] Read error at pos. 1 (0x1) [matroska,webm @ 0x644b40] EBML header parsing failed file:/mnt/user/Tv_Shows/The Orville/Season 1/The.Orville.S01E01.Old.Wounds.mkv: Invalid data found when processing input ffprobe version 4.0.1 Copyright (c) 2007-2018 the FFmpeg developers built with gcc 6.3.0 (crosstool-NG crosstool-ng-1.23.0) configuration: --enable-cross-compile --cross-prefix=x86_64-pc-linux-gnu- --cc=x86_64-pc-linux-gnu-gcc --cxx=x86_64-pc-linux-gnu-g++ --arch=x86_64 --prefix=/home/embybuilder/Buildbot-master/x64/ffmpeg-x64/staging --pkg-config=pkg-config --disable-doc --disable-ffplay --disable-xlib --enable-fontconfig --enable-gnutls --enable-gpl --enable-iconv --enable-libass --enable-libfreetype --enable-libfribidi --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libwebp --enable-libx264 --enable-libzvbi --enable-version3 --extra-libs='-ldl -lexpat -lfreetype -lfribidi -lfontconfig -liconv -lpng -luuid -lz -lvorbis -logg -lnettle -lhogweed -lgmp -laddns-samba4 -lasn1util-samba4 -lauthkrb5-samba4 -lCHARSET3-samba4 -lcliauth-samba4 -lcli-cldap-samba4 -lcli-ldap-common-samba4 -lcli-nbt-samba4 -lcli-smb-common-samba4 -lcom_err -lcommon-auth-samba4 -ldbwrap-samba4 -ldcerpc-binding -ldcerpc-samba-samba4 -lflag-mapping-samba4 -lgenrand-samba4 -lgensec-samba4 -lgse-samba4 -lgssapi_krb5 -llibcli-lsa3-samba4 -llibsmb-samba4 -linterfaces-samba4 -liov-buf-samba4 -lk5crypto -lkrb5 -lkrb5samba-samba4 -lkrb5support -lldb -lldbsamba-samba4 -lmessages-dgm-samba4 -lmessages-util-samba4 -lmsghdr-samba4 -lmsrpc3-samba4 -lndr -lndr-krb5pac -lndr-nbt -lndr-samba-samba4 -lndr-standard -lreplace-samba4 -lsamba-cluster-support-samba4 -lsamba-credentials -lsamba-debug-samba4 -lsamba-errors -lsamba-hostconfig -lsamba-modules-samba4 -lsamba-security-samba4 -lsamba-sockets-samba4 -lsamba-util -lsamba3-util-samba4 -lsamdb -lsamdb-common-samba4 -lsecrets3-samba4 -lserver-id-db-samba4 -lserver-role-samba4 -lsmbconf -lsmbd-shim-samba4 -lsmb-transport-samba4 -lsocket-blocking-samba4 -lsys-rw-samba4 -ltalloc -ltalloc-report-samba4 -ltdb -ltdb-wrap-samba4 -ltevent -ltevent-util -ltime-basic-samba4 -lutil-cmdline-samba4 -lutil-reg-samba4 -lutil-setid-samba4 -lutil-tdb-samba4 -lwbclient -lwinbind-client-samba4 -ldrm' --target-os=linux --enable-shared --disable-static --enable-libsmbclient --enable-cuda --enable-cuvid --enable-nvenc --enable-vaapi libavutil 56. 14.100 / 56. 14.100 libavcodec 58. 18.100 / 58. 18.100 libavformat 58. 12.100 / 58. 12.100 libavdevice 58. 3.100 / 58. 3.100 libavfilter 7. 16.100 / 7. 16.100 libswscale 5. 1.100 / 5. 1.100 libswresample 3. 1.100 / 3. 1.100 libpostproc 55. 1.100 / 55. 1.100 [matroska,webm @ 0x644b40] Format matroska,webm detected only with low score of 1, misdetection possible! [matroska,webm @ 0x644b40] Read error at pos. 1 (0x1) Then these socket errors, then shutdown. file:/mnt/user/Tv_Shows/The Mick/Season 2/The.Mick.S02E19.The.Dance.720p.mkv: Invalid data found when processing input UnhandledException System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer. ---> System.Net.Sockets.SocketException: Connection reset by peer --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token) at System.Net.FixedSizeReader.ReadPacketAsync(Stream transport, AsyncProtocolRequest request) at System.Net.Security.SslState.ThrowIfExceptional() at System.Net.Security.SslState.CheckThrow(Boolean authSuccessCheck, Boolean shutdownCheck) at System.Net.Security.SslState.CheckOldKeyDecryptedData(Memory`1 buffer) at System.Net.Security.SslState.HandleQueuedCallback(Object& queuedStateRequest) at System.Net.Security.SslState.FinishHandshakeRead(Int32 newState) at System.Net.Security.SslState.FinishHandshake(Exception e, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.RehandshakeCompleteCallback(IAsyncResult result) at System.Net.LazyAsyncResult.Complete(IntPtr userToken) at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken) at System.Net.AsyncProtocolRequest.CompleteUserWithError(Exception e) at System.Net.FixedSizeReader.ReadPacketAsync(Stream transport, AsyncProtocolRequest request) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) --- End of stack trace from previous location where exception was thrown --- at System.Threading.ThreadPoolWorkQueue.Dispatch() System.IO.IOException at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.GetResult(Int16 token) at System.Net.FixedSizeReader.ReadPacketAsync(Stream transport, AsyncProtocolRequest request) at System.Net.Security.SslState.ThrowIfExceptional() at System.Net.Security.SslState.CheckThrow(Boolean authSuccessCheck, Boolean shutdownCheck) at System.Net.Security.SslState.CheckOldKeyDecryptedData(Memory`1 buffer) at System.Net.Security.SslState.HandleQueuedCallback(Object& queuedStateRequest) at System.Net.Security.SslState.FinishHandshakeRead(Int32 newState) at System.Net.Security.SslState.FinishHandshake(Exception e, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.RehandshakeCompleteCallback(IAsyncResult result) at System.Net.LazyAsyncResult.Complete(IntPtr userToken) at System.Net.LazyAsyncResult.ProtectedInvokeCallback(Object result, IntPtr userToken) at System.Net.AsyncProtocolRequest.CompleteUserWithError(Exception e) at System.Net.FixedSizeReader.ReadPacketAsync(Stream transport, AsyncProtocolRequest request) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) --- End of stack trace from previous location where exception was thrown --- at System.Threading.ThreadPoolWorkQueue.Dispatch() InnerException: System.Net.Sockets.SocketException System.Net.Sockets.SocketException (104): Connection reset by peer [cont-finish.d] executing container finish scripts... [cont-finish.d] done. Edited August 1, 2018 by bungee91
bungee91 133 Posted July 29, 2018 Posted July 29, 2018 (edited) Version numbers of emby server https://github.com/MediaBrowser/Emby.Releases/releases You can change this in embyserver template. Example Repository: emby/embyserver:3.5.0.0 I tried this solution for now, thanks for the recommendation! No dice, same issue with 3.5.0.0, with no other changes to the host/UnRaid, everything else stable. Edit: I see the other posts in the Linux forum with the same issue, for now I've deleted my Music collection from Emby (I never use it anyhow), and if that resolves this for now, then great. Edited July 29, 2018 by bungee91
BobbyDing 56 Posted July 30, 2018 Posted July 30, 2018 How/where do you delete music selection if the container isn't running? Thanks!!
bungee91 133 Posted July 30, 2018 Posted July 30, 2018 How/where do you delete music selection if the container isn't running? Thanks!! Mine was running, and I deleted it prior to it force closing.
Luke 42243 Posted July 30, 2018 Author Posted July 30, 2018 I'm going to be pushing a 3.5.2 server release that for now will just remove the audiodb metadata providers. We will get them added back for 3.6. Thanks.
Martum 2 Posted July 30, 2018 Posted July 30, 2018 (edited) I have a problem with the current version of the docker release.3.5.x Versions are not connecting to the internet anymoreLooking at the logs I see a lot of SSL errors. First I thought it was temporarily or my internet connection but when I roll back to 3.4.1 everything works again.The container is connected with bridge mode, haven't tried host mode yet.Here are two example errors: Error App: Error registering with Connect*** Error Report ***Version: 3.5.2.0Command line: /system/EmbyServer.dll -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3Operating system: Unix 4.4.0.13164-Bit OS: True64-Bit Process: TrueUser Interactive: TrueProcessor count: 2Program data path: /configApplication directory: /systemSystem.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest)--- End of stack trace from previous location where exception was thrown ---at System.Net.Security.SslState.ThrowIfExceptional()at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult)at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result)at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult)at System.Net.Security.SslStream.<>c.b__47_1(IAsyncResult iar)at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)--- End of stack trace from previous location where exception was thrown ---at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)--- End of inner exception stack trace ---at Emby.Server.Connect.ConnectManager.UpdateServerRegistration(String wanApiAddress, String localAddress)at Emby.Server.Connect.ConnectManager.UpdateConnectInfoInternal(CancellationToken cancellationToken)System.Net.Http.HttpRequestExceptionat Emby.Server.Connect.ConnectManager.UpdateServerRegistration(String wanApiAddress, String localAddress)at Emby.Server.Connect.ConnectManager.UpdateConnectInfoInternal(CancellationToken cancellationToken)InnerException: System.Security.Authentication.AuthenticationExceptionSystem.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest)--- End of stack trace from previous location where exception was thrown ---at System.Net.Security.SslState.ThrowIfExceptional()at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult)at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result)at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult)at System.Net.Security.SslStream.<>c.b__47_1(IAsyncResult iar)at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)--- End of stack trace from previous location where exception was thrown ---at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest)--- End of stack trace from previous location where exception was thrown ---at System.Net.Security.SslState.ThrowIfExceptional()at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult)at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result)at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult)at System.Net.Security.SslStream.<>c.b__47_1(IAsyncResult iar)at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)--- End of stack trace from previous location where exception was thrown ---at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.018445 secondsInfo App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizardInfo App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.0021371 secondsInfo App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEventsInfo App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0013177 secondsInfo App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPointInfo App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0078063 secondsInfo App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPointInfo App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0111107 secondsInfo App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifierInfo App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.0006835 secondsInfo App: Starting entry point Emby.Server.Implementations.Devices.DeviceManagerEntryPointInfo App: Entry point completed: Emby.Server.Implementations.Devices.DeviceManagerEntryPoint. Duration: 0.0057869 secondsInfo App: Starting entry point Emby.Server.Implementations.Collections.CollectionManagerEntryPointInfo App: Entry point completed: Emby.Server.Implementations.Collections.CollectionManagerEntryPoint. Duration: 0.0050293 secondsInfo App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPointInfo App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0111814 secondsInfo App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPointInfo App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.0029142 secondsInfo App: Starting entry point Emby.Notifications.NotificationsInfo App: Entry point completed: Emby.Notifications.Notifications. Duration: 0.0019701 secondsInfo App: Starting entry point MediaBrowser.XbmcMetadata.EntryPointInfo App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.0006576 secondsInfo App: Starting entry point Emby.Security.PluginSecurityManagerInfo App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.0001811 secondsInfo App: Starting entry point Emby.Server.Sync.SyncManagerEntryPointInfo App: Sqlite version: 3.24.0Info App: Sqlite compiler options: COMPILER=gcc-6.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1Info App: Default journal_mode for /config/data/sync14.db is walInfo App: PRAGMA synchronous=1Error HttpClient: Error getting response from https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog*** Error Report ***Version: 3.5.2.0Command line: /system/EmbyServer.dll -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3Operating system: Unix 4.4.0.13164-Bit OS: True64-Bit Process: TrueUser Interactive: TrueProcessor count: 2Program data path: /configApplication directory: /systemSystem.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest)--- End of stack trace from previous location where exception was thrown ---at System.Net.Security.SslState.ThrowIfExceptional()at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult)at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result)at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult)at System.Net.Security.SslStream.<>c.b__47_1(IAsyncResult iar)at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)--- End of stack trace from previous location where exception was thrown ---at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)--- End of inner exception stack trace ---at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)at System.Threading.Tasks.ValueTask`1.get_Result()at System.Net.Http.HttpConnectionPool.CreateConnectionAsync(HttpRequestMessage request, CancellationToken cancellationToken)at System.Threading.Tasks.ValueTask`1.get_Result()at System.Net.Http.HttpConnectionPool.WaitForCreatedConnectionAsync(ValueTask`1 creationTask)at System.Threading.Tasks.ValueTask`1.get_Result()at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken)at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)at System.Net.Http.HttpClient.FinishSendAsyncUnbuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts)at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod)System.Net.Http.HttpRequestExceptionat System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)at System.Threading.Tasks.ValueTask`1.get_Result()at System.Net.Http.HttpConnectionPool.CreateConnectionAsync(HttpRequestMessage request, CancellationToken cancellationToken)at System.Threading.Tasks.ValueTask`1.get_Result()at System.Net.Http.HttpConnectionPool.WaitForCreatedConnectionAsync(ValueTask`1 creationTask)at System.Threading.Tasks.ValueTask`1.get_Result()at System.Net.Http.HttpConnectionPool.SendWithRetryAsync(HttpRequestMessage request, Boolean doRequestAuth, CancellationToken cancellationToken)at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)at System.Net.Http.DecompressionHandler.SendAsync(HttpRequestMessage request, CancellationToken cancellationToken)at System.Net.Http.HttpClient.FinishSendAsyncUnbuffered(Task`1 sendTask, HttpRequestMessage request, CancellationTokenSource cts, Boolean disposeCts)at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod)InnerException: System.Security.Authentication.AuthenticationExceptionSystem.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest)--- End of stack trace from previous location where exception was thrown ---at System.Net.Security.SslState.ThrowIfExceptional()at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult)at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result)at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult)at System.Net.Security.SslStream.<>c.b__47_1(IAsyncResult iar)at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)--- End of stack trace from previous location where exception was thrown ---at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest)at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest)--- End of stack trace from previous location where exception was thrown ---at System.Net.Security.SslState.ThrowIfExceptional()at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult)at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result)at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult)at System.Net.Security.SslStream.<>c.b__47_1(IAsyncResult iar)at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)--- End of stack trace from previous location where exception was thrown ---at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken) When I am home I can provide more logs if needed. Is there any reason why on https://github.com/MediaBrowser/Emby/releases there are no notes for 3.5.1 and 3.5.2? The docker tag "latest" is also linking to 3.5.0. Is anything above still beta or unstable? Edited July 30, 2018 by Martum
alucryd 318 Posted July 30, 2018 Posted July 30, 2018 The latest tag is pointing to 3.5.2.0, and https is working fine with it. What are you running it on?
Martum 2 Posted July 30, 2018 Posted July 30, 2018 The latest tag is pointing to 3.5.2.0, and https is working fine with it. What are you running it on? Thanks for confirming that. I changed my docker-compose file to emby/embyserver:latest and it was 3.5.0 again. But when I pulled the image manually via docker pull it got 3.5.2 One Problem solved thanks to you. Curious why it did not update the image itself though. The other problem was solved also while checking the compose.yml I've had a wrongly set SSL_CERT-FILE under environment. Is there any documentation what this does and how to set it up? I pointed it to the SSL certificate of my server, I guess that was wrong but had no consequences on 3.4.1 For Information: Ubuntu 16.04.5 LTS Docker 18.06.0-ce Docker-Compose 1.22.0 The container is running behind Traefik reverse proxy with letsencrypt certificate
alucryd 318 Posted July 30, 2018 Posted July 30, 2018 Glad you got it working. I believe we weren't relying on that variable in 3.4.x, but now we do and it's part of the Dockerfile. As for docker compose, I've never touched the thing, I don't know why it doesn't pull the correct latest tag.
BobbyDing 56 Posted July 30, 2018 Posted July 30, 2018 Hi. Had? Issue playing any videos from Ruku remotely today. Sent logs via Roku upload. User Grandma. Issues around 2:45 eastern. I am away from home but can upload more logs later if required. Thanks, Bobby
Luke 42243 Posted July 30, 2018 Author Posted July 30, 2018 Hi. Had? Issue playing any videos from Ruku remotely today. Sent logs via Roku upload. User Grandma. Issues around 2:45 eastern. I am away from home but can upload more logs later if required. Thanks, Bobby Hi, the first thing to do would be to describe the issue that you're having. Thanks !
BobbyDing 56 Posted July 31, 2018 Posted July 31, 2018 Hi Luke. Sorry. Quite right. No files were playing from the latest unraid server. Home or remote. I deleted and then re installed the libraries and it's all good now. Thanks for the quick response!!
