nobody01 89 Posted June 5, 2018 Posted June 5, 2018 (edited) Log attached. SSL errors now resolved, incorrect config for me. Scrap that SSL errors for mb3admin.com 2018-06-05 22:06:21.452 Info HttpClient: POST https://mb3admin.com/admin/service/registration/validate 2018-06-05 22:06:21.735 Error HttpClient: Error getting response from https://mb3admin.com/admin/service/registration/validate *** Error Report *** Version: 3.4.1.11 Command line: /system/EmbyServer.dll -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.9.0.6 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: /config Application directory: /system System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. embyserver.txt Edited June 5, 2018 by jaketame
andyblac644 69 Posted June 5, 2018 Posted June 5, 2018 @@Luke latest fails to start. any ideas EmbyServer.html
andyblac644 69 Posted June 6, 2018 Posted June 6, 2018 @@andyblac644 Weird, how about now? same mate. EmbyServer.html
alucryd 318 Posted June 6, 2018 Posted June 6, 2018 Both latest and beta work fine here. @@Luke ever seen this error before?
Outcazt 2 Posted June 6, 2018 Posted June 6, 2018 Both latest and beta work fine here. @@Luke ever seen this error before? Latest Beta works fine here...
andyblac644 69 Posted June 6, 2018 Posted June 6, 2018 Both latest and beta work fine here. @@Luke ever seen this error before? I'm on synology docker.
mgworek 134 Posted June 6, 2018 Posted June 6, 2018 Thanks, It’s running now. Some issues so far: - I’m getting lots of spinning load icons. - Dashboard is not displaying correctly ( blank sections followed by loading icon) - Web app is not as bad but Android App is not responding for admin console Cheers I was having similar errors. Web app was not loading everything, browsing libraries was slow. AppleTV app just sat there loading. When it finally loaded, it just sat there while trying to load libraries. Restarts didn't help. I went back to latest and everything was working. This was on unraid. I will try again tonight and get logs.
andyblac644 69 Posted June 6, 2018 Posted June 6, 2018 I'm getting SSL error with 3.4.1.1 any ideas ? 2018-06-06 15:32:14.180 Error App: Error registering with Connect *** Error Report *** Version: 3.4.1.1 Command line: /system/EmbyServer.dll -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 3.10.105.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 8 Program data path: /config Application directory: /system System.Net.Http.HttpRequestException: The SSL connection could not be established, see inner exception. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslState.ThrowIfExceptional() at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsClientAsync>b__47_1(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Connect.ConnectManager.UpdateServerRegistration(String wanApiAddress, String localAddress) at Emby.Server.Connect.ConnectManager.UpdateConnectInfoInternal(CancellationToken cancellationToken) System.Net.Http.HttpRequestException at Emby.Server.Connect.ConnectManager.UpdateServerRegistration(String wanApiAddress, String localAddress) at Emby.Server.Connect.ConnectManager.UpdateConnectInfoInternal(CancellationToken cancellationToken) InnerException: System.Security.Authentication.AuthenticationException System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure. at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslState.ThrowIfExceptional() at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsClientAsync>b__47_1(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken) at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, ExceptionDispatchInfo exception) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartSendBlob(Byte[] incoming, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.StartReadFrame(Byte[] buffer, Int32 readBytes, AsyncProtocolRequest asyncRequest) at System.Net.Security.SslState.PartialFrameCallback(AsyncProtocolRequest asyncRequest) --- End of stack trace from previous location where exception was thrown --- at System.Net.Security.SslState.ThrowIfExceptional() at System.Net.Security.SslState.InternalEndProcessAuthentication(LazyAsyncResult lazyResult) at System.Net.Security.SslState.EndProcessAuthentication(IAsyncResult result) at System.Net.Security.SslStream.EndAuthenticateAsClient(IAsyncResult asyncResult) at System.Net.Security.SslStream.<>c.<AuthenticateAsClientAsync>b__47_1(IAsyncResult iar) at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization) --- End of stack trace from previous location where exception was thrown --- at System.Net.Http.ConnectHelper.EstablishSslConnectionAsyncCore(Stream stream, SslClientAuthenticationOptions sslOptions, CancellationToken cancellationToken)
alucryd 318 Posted June 6, 2018 Posted June 6, 2018 3.4.1.1 is old, we're at 3.4.1.11 now, please update.
andyblac644 69 Posted June 6, 2018 Posted June 6, 2018 (edited) 3.4.1.1 is old, we're at 3.4.1.11 now, please update. I can't it does not work with synology docker as above so as it is now my emby server is broken , I cannot add any new media, please help fix it. Edited June 6, 2018 by andyblac644
Luke 42243 Posted June 6, 2018 Author Posted June 6, 2018 We haven't been testing the docker package on synology, sorry. You'll need to provide more detail.
andyblac644 69 Posted June 6, 2018 Posted June 6, 2018 We haven't been testing the docker package on synology, sorry. You'll need to provide more detail. logs above. 3.4.1.11 does not start at all, and now I have reinstalled 3.4.1.1 it has SSL issues. both log above.
Luke 42243 Posted June 6, 2018 Author Posted June 6, 2018 What if you try a fresh install of the latest beta?
andyblac644 69 Posted June 6, 2018 Posted June 6, 2018 What if you try a fresh install of the latest beta? as I said fails to startup. EmbyServer.html
Luke 42243 Posted June 6, 2018 Author Posted June 6, 2018 Ok like I've said before this is not officially supported on synology so I don't have answers right now. You'll need to stay on the older version or use dedicated synology package for emby. Thanks.
Luke 42243 Posted June 6, 2018 Author Posted June 6, 2018 Going forward, please keep all beta related discussion in the testing area of the community. Thanks.
andyblac644 69 Posted June 6, 2018 Posted June 6, 2018 (edited) Going forward, please keep all beta related discussion in the testing area of the community. Thanks. just tried Stabled Release again SSL issues.... embyserver-4.txt Edited June 6, 2018 by Luke
Luke 42243 Posted June 6, 2018 Author Posted June 6, 2018 Yes, please keep all beta related discussion in the testing area. Thanks.
orbitron 0 Posted June 7, 2018 Posted June 7, 2018 Docker showed there was an update to the image/container. I updated this morning and am now seeing a lot of these errors every time a HTTP call is made. System.TypeInitializationException: The type initializer for 'System.Net.Http.CurlHandler' threw an exception. ---> System.TypeInitializationException: The type initializer for 'Http' threw an exception. ---> System.TypeInitializationException: The type initializer for 'HttpInitializer' threw an exception. ---> System.DllNotFoundException: Unable to load DLL 'System.Net.Http.Native': The specified module or one of its dependencies could not be found. embyserver-log.txt
orbitron 0 Posted June 7, 2018 Posted June 7, 2018 Please try updating again. Thanks. That did it! Thanks!
