andyblac644 69 Posted April 23, 2018 Posted April 23, 2018 (edited) Whats that Scrreen from? "playback reporting" plugin by @ Edited April 23, 2018 by andyblac644
aptalca 71 Posted April 23, 2018 Posted April 23, 2018 (edited) @@Luke I'm supporting the libreelec addon that manages the emby docker I just realized that emby no longer provides tags for the armv7 and aarch64 builds (ie. emby/embyserver:armv7) and instead there are two separate repos for arm and arm with neon?!? Can you clarify what the differences are? Also is there no longer an aarch64 docker build? Thanks Edited April 23, 2018 by aptalca
Luke 42243 Posted April 23, 2018 Author Posted April 23, 2018 @@Luke I'm supporting the libreelec addon that manages the emby docker I just realized that emby no longer provides tags for the armv7 and aarch64 builds (ie. emby/embyserver:armv7) and instead there are two separate repos for arm and arm with neon?!? Can you clarify what the differences are? Also is there no longer an aarch64 docker build? Thanks That is the way our build developer prefers to handle it, so that's why we separated it. The neon version is optimized for cpu's that support the neon instruction set, so it will fail on devices that don't. We don't currently have aarch64 support because there is no Microsoft runtime for it. You can follow our discussion with MS here: https://github.com/dotnet/core-setup/issues/3100 That topic is about armel but it's the same issue trying to build the runtime for any architecture that they don't provide one for.
aptalca 71 Posted April 23, 2018 Posted April 23, 2018 I see. Thanks for the prompt response. I guess I'll have to figure out whether to go with neon or no neon
Luke 42243 Posted April 23, 2018 Author Posted April 23, 2018 Both ffmpeg and the skia image processing library support neon optimizations so it is a nice improvement. We will probably be adding another package at some point for neon v2 cpu's.
ken-ji 0 Posted May 5, 2018 Posted May 5, 2018 (edited) Any Ideas how I can debug this? Info App: All entry points have started Illegal instruction [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. using the latest tag docker image under unRAID It keeps crashing and crashing.... I've attached the last two logs see it makes any sense. embyserver-63661128769.txt embyserver-63661128701.txt Edited May 5, 2018 by ken-ji
Luke 42243 Posted May 5, 2018 Author Posted May 5, 2018 Any Ideas how I can debug this? Info App: All entry points have started Illegal instruction [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. using the latest tag docker image under unRAID It keeps crashing and crashing.... I've attached the last two logs see it makes any sense. Do you have any movie collections?
ken-ji 0 Posted May 6, 2018 Posted May 6, 2018 (edited) Yes, I removed a bunch of plugins at once and now I'm not sure which one is causing the crashes. But it could be the Auto Boxsets. Also, I see that the latest embyserver image was just updated. How exactly are the version/tags updated? I don't understand how the images are tagged updated. I mean latest as of yesterday was emby/embyserver 3.4.0.0 d1dd1768bb0a 30 hours ago 208MB But now emby/embyserver latest a3e9c0259c8a 2 hours ago 208MB Should I be using the exact version I want and keep it there until the next release version is announced? The docker management system in unRAID simply checks if the Image ID in the repository is updated and then prompts the user to upgrade. Edited May 6, 2018 by ken-ji
alucryd 318 Posted May 6, 2018 Posted May 6, 2018 Sometimes the latest tag gets rebuilt for hotfixes or just because the build system had to be restarted. Both latest and 3.4.0.0 should be at a3e9c0259c8a, you can keep pointing to the latest tag, it will always be the latest stable.
NNate 10 Posted May 6, 2018 Posted May 6, 2018 (edited) In the older docker we had a UMASK parameter that could control the file permissions of metadata files, etc that Emby would create. It looks like that's now gone and all files are being created with 644 permission making it impossible for other users to delete the files. Could we bring back UMASK or have another way to control file permissions? Edited May 6, 2018 by NNate
geaves 13 Posted May 16, 2018 Posted May 16, 2018 Having recently upgraded my OMV, I decided to redeploy Emby in Docker, this works fine, but it's not displaying any Plugins under Catalogue. Any pointers appreciated.
geaves 13 Posted May 16, 2018 Posted May 16, 2018 Having recently upgraded my OMV, I decided to redeploy Emby in Docker, this works fine, but it's not displaying any Plugins under Catalogue. Any pointers appreciated. Sorted!!
mgworek 134 Posted May 16, 2018 Posted May 16, 2018 Are the beta versions still getting updated? I am still on 3.4.1.1-beta. I removed my docker and image and pulled down a fresh beta but its still 3.4.1.1 Thanks
andyblac644 69 Posted May 16, 2018 Posted May 16, 2018 Are the beta versions still getting updated? I am still on 3.4.1.1-beta. I removed my docker and image and pulled down a fresh beta but its still 3.4.1.1 Thanks hasn't been updated in 8 days, possibly due to DotNet 2.1 ? 1
Luke 42243 Posted May 16, 2018 Author Posted May 16, 2018 Yes the docker beta is currently paused. We'll get it sorted out soon. Thanks. 2
mgworek 134 Posted May 16, 2018 Posted May 16, 2018 Thanks for the info. I just wanted to make sure it wasn't something on my end.
mediacowboy 438 Posted May 19, 2018 Posted May 19, 2018 Can someone help me, I am fairly new to the docker emby and for some reason emby is not detecting newly added media with real-time monitoring? It does detect the media when a library scan is performed. I know it's not detected because of I have notifications turned on for media and do not get them until a new full library scan is performed. I do have real-time monitoring turned on for all my libraries.
Luke 42243 Posted May 19, 2018 Author Posted May 19, 2018 Can someone help me, I am fairly new to the docker emby and for some reason emby is not detecting newly added media with real-time monitoring? It does detect the media when a library scan is performed. I know it's not detected because of I have notifications turned on for media and do not get them until a new full library scan is performed. I do have real-time monitoring turned on for all my libraries. Did you setup your libraries using unc \\ paths, or smb paths by chance?
mediacowboy 438 Posted May 19, 2018 Posted May 19, 2018 (edited) Did you setup your libraries using unc \\ paths, or smb paths by chance? Neither I believe. I am using docker compose volumes: - /mnt/media:/Media libraries are pointed to each media category respectively. /Media/TV = TV /Media/Movies = Movies Etc.. I do have samba running but only use it for coping media to and from server and it is outside the emby container/docker. Edited May 19, 2018 by mediacowboy
Luke 42243 Posted May 19, 2018 Author Posted May 19, 2018 Why do you feel the realtime monitor isn't working?
mediacowboy 438 Posted May 19, 2018 Posted May 19, 2018 (edited) Why do you feel the realtime monitor isn't working? Because new media is not added until I do a full library scan. I have added media to my server but did not see it or get notified until several hours later when the full library scan kicked off. Host OS is Ubuntu 18.04 with MergerFS for pooling of hard drives. Each Hard drive is formatted as ext4. I don't know if any if that makes a difference since emby really can't see it but wanted to listed it just in case. Drive1 (/mnt/disk1)-----\ Drive2 (/mnt/disk1)----\| Drive3 (/mnt/disk1)---\|| Drive4 (/mnt/disk1)---+++---/mnt/Media (MergerFS) : /Media Drive5 (/mnt/disk1)---/|| ^ Drive6 (/mnt/disk1)----/| | Drive7 (/mnt/disk1)-----/ Docker Before you ask if I am sure it is on I am. I have double check all the libraries. Took a screen shot of the movies library. Edited May 19, 2018 by mediacowboy
mediacowboy 438 Posted May 20, 2018 Posted May 20, 2018 (edited) @@Luke I am not sure what you would be looking for in the logs but I am uploading a few different one. embyserver-63662140679.zip Edited May 20, 2018 by mediacowboy
Luke 42243 Posted May 20, 2018 Author Posted May 20, 2018 Which one is from the timeframe that you added new content? And what content was that and what time of day? thanks.
mediacowboy 438 Posted May 20, 2018 Posted May 20, 2018 (edited) Luke, listed below is a couple TV shows that I add that were not picked up until a full library scan. I have also attached what I believe to be the log from that night. 9:34 PM - Marvel's Agents of S.H.I.E.L.D. 5x22 (110) The End 9:19 PM - BattleBots (2015) 3x02 Are You Yeti to Rumble? 8:47 PM - Bering Sea Gold 10x08 Every Ounce Counts 8:35 PM - Blindspot 3x22 (67) In Memory 8:34 PM - Once Upon a Time (2011) 7x22 (155) Leaving Storybrooke 8:19 PM - Hawaii Five-0 8x25 Waiho Wale Kahiko embyserver-63662284800.zip Edited May 20, 2018 by mediacowboy
