alucryd 318 Posted January 8, 2018 Posted January 8, 2018 (edited) Neither the mono version nor the netcore version which is in the process of replacing the mono version do. Also Microsoft will probably never release a dotnet runtime for armv6, this architecture is too outdated for them to care, they don't even provide official support for armv7 softfp. Edited January 8, 2018 by alucryd
skybird1980 0 Posted January 12, 2018 Posted January 12, 2018 todays docker update seams bugged, server is restarting allways. docker image size ist 139 MB - last Build was 193 mb. so something went wrong?
Luke 42243 Posted January 12, 2018 Author Posted January 12, 2018 @@skybird1980 - how to report a problem. thanks !
skybird1980 0 Posted January 12, 2018 Posted January 12, 2018 oh yes. since emby container is not startet i can only paste the log of the container. standard_init_linux.go:195: exec user process caused "exec format error" no more info
alucryd 318 Posted January 12, 2018 Posted January 12, 2018 (edited) One of my builds failed, and the latest tag was overwritten by an arm image, I'm currently rebuilding, should be all good again shortly. Edited January 12, 2018 by alucryd
alucryd 318 Posted January 12, 2018 Posted January 12, 2018 Latest is back to normal, apologies for the inconvenience, but that was for a good cause, the arm image(s) are now fully functional
Luke 42243 Posted January 17, 2018 Author Posted January 17, 2018 Hi everyone, we have an announcement for the next release of Emby Server on Docker. As you may know, the current Docker image ships with a custom launcher script. Our next release will completely rework our Docker container to be based on Microsoft .NET Core, which means no more mono (yes !). We will not be preserving this launcher script, so means you'll need to start emby server using vanilla docker methods on the command line, or from your Unraid web interface if you're using it from Unraid. Please let us know if you have any questions about this. Thanks !
flowlee 1 Posted January 18, 2018 Posted January 18, 2018 The current docker image seems to be broken. After starting I get the following error message: Cannot open assembly '/usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe': No such file or directory. Does this have to do with the transition from mono to .NET core?
Luke 42243 Posted January 18, 2018 Author Posted January 18, 2018 The current docker image seems to be broken. After starting I get the following error message: Cannot open assembly '/usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe': No such file or directory. Does this have to do with the transition from mono to .NET core? What version? We haven't actually made the change yet.
flowlee 1 Posted January 18, 2018 Posted January 18, 2018 The docker image version is x86_64_3.2.60.0. Do you have any idea what could have caused the error if it is not related to mono?
Luke 42243 Posted January 18, 2018 Author Posted January 18, 2018 The docker image version is x86_64_3.2.60.0. Do you have any idea what could have caused the error if it is not related to mono? Is that the complete ouput? can we see everything? thanks.
flowlee 1 Posted January 18, 2018 Posted January 18, 2018 Upon further inspection it seems to be related to the new version not being found. [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] 03-upgrade-onetime: executing... Updating emby-server... Found version: 3.2.70.0 % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 9 0 9 0 0 0 0 --:--:-- 1:11:35 --:--:-- 17 End-of-central-directory signature not found. Either this file is not a zipfile, or it constitutes one disk of a multi-part archive. In the latter case the central directory and zipfile comment will be found on the last disk(s) of this archive. unzip: cannot find zipfile directory in one of /var/tmp/emby.zip or /var/tmp/emby.zip.zip, and cannot find /var/tmp/emby.zip.ZIP, period. Archive: /var/tmp/emby.zip % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 512 100 512 0 0 512 0 0:00:01 --:--:-- 0:00:01 3240 [cont-init.d] 03-upgrade-onetime: exited 0. [cont-init.d] 04-fix_dllmaps-onetime: executing... [cont-init.d] 04-fix_dllmaps-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Cannot open assembly '/usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe': No such file or directory.
Luke 42243 Posted January 18, 2018 Author Posted January 18, 2018 yea because we turned off the autobuild for docker right now while we make this transition, and also, going forward you will need to use standard docker update procedures.
flowlee 1 Posted January 18, 2018 Posted January 18, 2018 (edited) Okay, so while the old launcher script is still in the latest docker image how can I get it to work with autobuild being disabled? Edit: Nevermind, see below. Edited January 18, 2018 by flowlee
Luke 42243 Posted January 18, 2018 Author Posted January 18, 2018 Can you give it a try again? thanks.
flowlee 1 Posted January 18, 2018 Posted January 18, 2018 It seems to be working fine now! Thank you very much!
cyrenbyren 12 Posted January 20, 2018 Posted January 20, 2018 (edited) i'm having trouble upgrading to amd64_3.2.70.2 from x86_64_3.2.60.0. i'm running emby on rancher, and i have been updating simply by pulling the latest image and that has been working well so far. with this latest version however it doesn't seem like emby is starting up. the only logs i get are: 1/20/2018 11:58:25 AM[s6-init] making user provided files available at /var/run/s6/etc...exited 0. 1/20/2018 11:58:25 AM[s6-init] ensuring user provided files have correct perms...exited 0. 1/20/2018 11:58:25 AM[fix-attrs.d] applying ownership & permissions fixes... 1/20/2018 11:58:25 AM[fix-attrs.d] done. 1/20/2018 11:58:25 AM[cont-init.d] executing container initialization scripts... 1/20/2018 11:58:25 AM[cont-init.d] done. 1/20/2018 11:58:25 AM[services.d] starting services 1/20/2018 11:58:25 AM[services.d] done. rolling back works, luckily. has there been any breaking changes that require some manual fiddling? Edited January 20, 2018 by cyrenbyren
alucryd 318 Posted January 20, 2018 Posted January 20, 2018 What command are you using to start the container ?
cyrenbyren 12 Posted January 21, 2018 Posted January 21, 2018 (edited) i have not entered any custom entry points, so it should be using the default from the dockerfile. EDIT: i checked the command from "docker ps", and it shows the same as the earlier version: "/.r/r /init" Edited January 21, 2018 by cyrenbyren
strike 2 Posted January 21, 2018 Posted January 21, 2018 (edited) So I have updated to the new docker version, thanks btw! But I'm having some issues. I'm unable to play anything at all from any browser, I just get "playback error, no compatible streams are currently available..." I've been able to locate the issue tho. The issue is with the temporary transcoding path. I'm using unRAID and I have configured emby to move the transcoding to RAM by mapping /tmp/emby to /transcode inside the container. In my emby transcode settings then have /transcode as the transcoding path. This have been working great since I started using emby, but for some reason, it stopped working with the latest version. If I just set the transcoding path to the default path everything works fine. Any idea why how I can get this working again? Instead of having to use my cache disk which has limited space to work with.. I have some logs for you, the 2 first are when I can't play anything and the next 2 are when everything is working fine. server-63652140046-error.txt ffmpeg-transcode-2e2606be-e12b-45ff-9c05-a37cba48c8f0-error.txt server-63652140557-success.txt ffmpeg-remux-9b423cde-dfed-4adb-a134-66f5ace8f1ea-success.txt Edited January 21, 2018 by strike
alucryd 318 Posted January 21, 2018 Posted January 21, 2018 i have not entered any custom entry points, so it should be using the default from the dockerfile. EDIT: i checked the command from "docker ps", and it shows the same as the earlier version: "/.r/r /init" I wasn't asking about the entrypoint, I'd like to know the whole docker run command. FYI the log mentions the service started fine, what makes you say it doesn't work? If the service didn't run as expected, you'd see something along those lines: [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting.
alucryd 318 Posted January 21, 2018 Posted January 21, 2018 So I have updated to the new docker version, thanks btw! But I'm having some issues. I'm unable to play anything at all from any browser, I just get "playback error, no compatible streams are currently available..." I've been able to locate the issue tho. The issue is with the temporary transcoding path. I'm using unRAID and I have configured emby to move the transcoding to RAM by mapping /tmp/emby to /transcode inside the container. In my emby transcode settings then have /transcode as the transcoding path. This have been working great since I started using emby, but for some reason, it stopped working with the latest version. If I just set the transcoding path to the default path everything works fine. Any idea why how I can get this working again? Instead of having to use my cache disk which has limited space to work with.. I have some logs for you, the 2 first are when I can't play anything and the next 2 are when everything is working fine. What are the permissions on /tmp/emby? By default the new container runs as the daemon user, uid 2 and gid 2. You can customize the UID, GID and GIDLIST env variables inside the container as described on docker hub, by using the -e flag on the docker run command.
strike 2 Posted January 21, 2018 Posted January 21, 2018 I have the container running as uid 1000 and gid 100 and permissions for /tmp/emby is 775. So it has read/write access
alucryd 318 Posted January 21, 2018 Posted January 21, 2018 I have the container running as uid 1000 and gid 100 and permissions for /tmp/emby is 775. So it has read/write access 775 doesn't give you write access if the directory doesn't belong to uid 1000 or gid 100. How are you setting the uid/gid? This has changed between the mono and netcore version.
