feardamhan 6 Posted October 2, 2017 Posted October 2, 2017 @@feardamhan It's good to go now. Hi Again Sorry if I am doing something thick here. When I try to install the service I now get this: pi@debian8:~$ sudo docker run -it --rm -v /etc/systemd/system:/target emby/embyserver instl service [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] 03-upgrade-onetime: executing... [cont-init.d] 03-upgrade-onetime: exited 0. [cont-init.d] 04-fix_dllmaps-onetime: executing... [cont-init.d] 04-fix_dllmaps-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Installing emby-server Service... sed: can't read /target/emby-server.service: No such file or directory sed: can't read /target/emby-server.service: No such file or directory sed: can't read /target/emby-server.service: No such file or directory sed: can't read /target/emby-server.service: No such file or directory Please run: sudo systemctl daemon-reload To start run: sudo systemctl start emby-server@$USERNAME instl exited 0 [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. dirname: write error: Broken pipe [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. pi@debian8:~$ Any thoughts?
hurricanehrndz 149 Posted October 2, 2017 Posted October 2, 2017 Hi Again Sorry if I am doing something thick here. When I try to install the service I now get this: pi@debian8:~$ sudo docker run -it --rm -v /etc/systemd/system:/target emby/embyserver instl service [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] 03-upgrade-onetime: executing... [cont-init.d] 03-upgrade-onetime: exited 0. [cont-init.d] 04-fix_dllmaps-onetime: executing... [cont-init.d] 04-fix_dllmaps-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Installing emby-server Service... sed: can't read /target/emby-server.service: No such file or directory sed: can't read /target/emby-server.service: No such file or directory sed: can't read /target/emby-server.service: No such file or directory sed: can't read /target/emby-server.service: No such file or directory Please run: sudo systemctl daemon-reload To start run: sudo systemctl start emby-server@$USERNAME instl exited 0 [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. dirname: write error: Broken pipe [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. pi@debian8:~$ Any thoughts? Weird. I never got that, let me do some more testing.
hurricanehrndz 149 Posted October 2, 2017 Posted October 2, 2017 Okay, there is an issue. A will push a fix soon.
feardamhan 6 Posted October 3, 2017 Posted October 3, 2017 (edited) Okay please try again. Still not working for me. Let me know if I did anything wrong here. I did a docker pull to grab the latest image (confirmed the time on it was not long before your message above) the ran the following commands (output below) Commands ************ pi@debian8:~$ sudo docker run -it --rm -v /usr/local/bin:/target emby/embyserver instl pi@debian8:~$ sudo docker run -it --rm -v /etc/systemd/system:/target emby/embyserver instl service pi@debian8:~$ ls -l /etc/systemd/system pi@debian8:~$ sudo systemctl enable emby-server@${USERNAME} Commands with inline output ***************************** pi@debian8:~$ sudo docker run -it --rm -v /usr/local/bin:/target emby/embyserver instl [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] 03-upgrade-onetime: executing... [cont-init.d] 03-upgrade-onetime: exited 0. [cont-init.d] 04-fix_dllmaps-onetime: executing... [cont-init.d] 04-fix_dllmaps-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Installing emby-server... instl exited 0 [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. grep: write error: Broken pipe [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. pi@debian8:~$ sudo docker run -it --rm -v /etc/systemd/system:/target emby/embyserver instl service [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] 03-upgrade-onetime: executing... [cont-init.d] 03-upgrade-onetime: exited 0. [cont-init.d] 04-fix_dllmaps-onetime: executing... [cont-init.d] 04-fix_dllmaps-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Installing emby-server Service... Please run: sudo systemctl daemon-reload To start run: sudo systemctl start emby-server@$USERNAME instl exited 0 grep: write error: Broken pipe [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. pi@debian8:~$ ls -l /etc/systemd/system total 32 lrwxrwxrwx 1 root root 40 Sep 4 23:46 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service -rw-r--r-- 1 root root 327 Oct 3 21:23 emby-server@.service drwxr-xr-x 2 root root 4096 Sep 4 23:43 getty.target.wants drwxr-xr-x 2 root root 4096 Sep 12 21:03 multi-user.target.wants drwxr-xr-x 2 root root 4096 Sep 4 23:43 network-online.target.wants drwxr-xr-x 2 root root 4096 Sep 4 23:46 printer.target.wants drwxr-xr-x 2 root root 4096 Sep 12 21:03 sockets.target.wants lrwxrwxrwx 1 root root 31 Sep 4 23:46 sshd.service -> /lib/systemd/system/ssh.service drwxr-xr-x 2 root root 4096 Sep 4 23:44 sysinit.target.wants lrwxrwxrwx 1 root root 35 Sep 4 23:43 syslog.service -> /lib/systemd/system/rsyslog.service drwxr-xr-x 2 root root 4096 Sep 4 23:43 timers.target.wants pi@debian8:~$ sudo systemctl enable emby-server@${USERNAME} The unit files have no installation config (WantedBy, RequiredBy, Also, Alias settings in the [install] section, and DefaultInstance for template units). This means they are not meant to be enabled using systemctl. Possible reasons for having this kind of units are: 1) A unit may be statically enabled by being symlinked from another unit's .wants/ or .requires/ directory. 2) A unit's purpose may be to act as a helper for some other unit which has a requirement dependency on it. 3) A unit may be started when needed via activation (socket, path, timer, D-Bus, udev, scripted systemctl call, ...). 4) In case of template units, the unit is meant to be enabled with some instance name specified. Edited October 3, 2017 by feardamhan
hurricanehrndz 149 Posted October 3, 2017 Posted October 3, 2017 (edited) Run printenv to make sure your shell has defined USERNAME otherwise replace it with whatever user your wanting to run the service as, such as: systemctl enable --now emby-server@pi Additionally, if you follow the readme on github, you will notice that you should first start emby without the help of systemd, in order to setup the volumes you wish to make accessible to the container emby-server Edited October 3, 2017 by hurricanehrndz
hurricanehrndz 149 Posted October 3, 2017 Posted October 3, 2017 PS the grep pipe error is not an issue, the container is just trying to start the services which are not really required. If it bothers you, you can run the command like this: docker run -it --rm -v /etc/systemd/system:/target --entrypoint bash emby/embyserver instl service
feardamhan 6 Posted October 3, 2017 Posted October 3, 2017 PS the grep pipe error is not an issue, the container is just trying to start the services which are not really required. If it bothers you, you can run the command like this: docker run -it --rm -v /etc/systemd/system:/target --entrypoint bash emby/embyserver instl service Ok. Reset my VM back to pre-emby and went again. the container was deployed, and started manually successfully, but when I reboot the VM, the docker emby container doesn't start automatically. Output below (note USERNAME was not in printenv, so I used USER, which was) Let me know if I made a mess of anything! pi@debian8:~$ sudo docker run -it --rm -v /usr/local/bin:/target emby/embyserver instl Unable to find image 'emby/embyserver:latest' locally latest: Pulling from emby/embyserver 020190e11b50: Pull complete c4d4f7ecb5e4: Pull complete 764fad16103e: Pull complete 7ac0e67be9f0: Pull complete 12b0aec238f2: Pull complete Digest: sha256:5c18709d18e29fe82d2c1719326f66a0088313f704ada230f23f4482d598fbd5 Status: Downloaded newer image for emby/embyserver:latest [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] 03-upgrade-onetime: executing... [cont-init.d] 03-upgrade-onetime: exited 0. [cont-init.d] 04-fix_dllmaps-onetime: executing... [cont-init.d] 04-fix_dllmaps-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Installing emby-server... instl exited 0 [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. grep: write error: Broken pipe [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. pi@debian8:~$ /usr/local/bin/emby-server No existing user volumes for: emby-server. Pleae enter full paths you want accessible from within the container Enter one entry per line. Enter "done" or Ctrl+D when finished /mount/media done Starting emby-server... Unable to find image 'emby/embyserver:x86_64' locally x86_64: Pulling from emby/embyserver Digest: sha256:5c18709d18e29fe82d2c1719326f66a0088313f704ada230f23f4482d598fbd5 Status: Downloaded newer image for emby/embyserver:x86_64 953bd30a64607aa91b407725b612e21fbde624f6ca9592e42c4aab2dcc74579e pi@debian8:~$ sudo docker run -it --rm -v /etc/systemd/system:/target emby/embyserver instl service [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] 03-upgrade-onetime: executing... [cont-init.d] 03-upgrade-onetime: exited 0. [cont-init.d] 04-fix_dllmaps-onetime: executing... [cont-init.d] 04-fix_dllmaps-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Installing emby-server Service... Please run: sudo systemctl daemon-reload To start run: sudo systemctl start emby-server@$USERNAME instl exited 0 [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. dirname: write error: Broken pipe [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. pi@debian8:~$ ls -l /etc/systemd/system total 32 lrwxrwxrwx 1 root root 40 Sep 4 23:46 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service -rw-r--r-- 1 root root 327 Oct 3 22:21 emby-server@.service drwxr-xr-x 2 root root 4096 Sep 4 23:43 getty.target.wants drwxr-xr-x 2 root root 4096 Oct 3 21:56 multi-user.target.wants drwxr-xr-x 2 root root 4096 Sep 4 23:43 network-online.target.wants drwxr-xr-x 2 root root 4096 Sep 4 23:46 printer.target.wants drwxr-xr-x 2 root root 4096 Oct 3 21:56 sockets.target.wants lrwxrwxrwx 1 root root 31 Sep 4 23:46 sshd.service -> /lib/systemd/system/ssh.service drwxr-xr-x 2 root root 4096 Sep 4 23:44 sysinit.target.wants lrwxrwxrwx 1 root root 35 Sep 4 23:43 syslog.service -> /lib/systemd/system/rsyslog.service drwxr-xr-x 2 root root 4096 Sep 4 23:43 timers.target.wants pi@debian8:~$ sudo systemctl enable emby-server@${USER} Created symlink /etc/systemd/system/multi-user.target.wants/emby-server@pi.service → /etc/systemd/system/emby-server@.service.
feardamhan 6 Posted October 3, 2017 Posted October 3, 2017 Is it anything to do with the :x86_64 tag ?
hurricanehrndz 149 Posted October 3, 2017 Posted October 3, 2017 (edited) Is it anything to do with the :x86_64 tag ? Yup that does seem to be an issue, what architecture are you on. ps there seems to be a lot small bugs affecting to you. Dam! PS latest and x86_64 should always be the same image. What is the home directory of pi? Edited October 3, 2017 by hurricanehrndz
hurricanehrndz 149 Posted October 3, 2017 Posted October 3, 2017 Does the service start via systemd? sudo systemctl start emby-server@pi
feardamhan 6 Posted October 4, 2017 Posted October 4, 2017 Does the service start via systemd? sudo systemctl start emby-server@pi Nope. Doesn't throw an error but doesn't start it. Home directory for my user 'pi' is /home/pi. Architecture is x86 as its Debian on a fusion VM on Mac. The /usr/local/bin/emby-server command always throws the error re the x86_64 (and grabs another image) unless I use that tag with the first run command i.e. sudo docker run -it --rm -v /usr/local/bin:/target emby/embyserver:x86_64 instl
hurricanehrndz 149 Posted October 4, 2017 Posted October 4, 2017 Weird, I have never experienced this issue before. You can run it successfully manually though? Sent from my ONEPLUS A3000 using Tapatalk
feardamhan 6 Posted October 4, 2017 Posted October 4, 2017 Yep. If I run /usr/local/bin/emby-server I can hit the emby server webpage wizard
feardamhan 6 Posted October 4, 2017 Posted October 4, 2017 Any issue perhaps with the versions I am testing with (Debian 9?) Should I drop back to Debian 8? At the end we are messing with debian startup procedures here rather than internal emby stuff? One more question.....apologies if the answer is obvious. I have other containers (for instance portainer) that starts automatically. It as a restart always policy Why does emby need a run --rm vs a run --restart always?
hurricanehrndz 149 Posted October 4, 2017 Posted October 4, 2017 Run --rm is only for install purposes. Not necessary to keep container after the install steps are done. Debian 8 and 9 are very similar. What is the output of systemctl status emby-sever@pi Sent from my ONEPLUS A3000 using Tapatalk
feardamhan 6 Posted October 4, 2017 Posted October 4, 2017 Run --rm is only for install purposes. Not necessary to keep container after the install steps are done. Debian 8 and 9 are very similar. What is the output of systemctl status emby-sever@pi Sent from my ONEPLUS A3000 using Tapatalk So I had reset my environment to pre-emby state and started again. Based on what I saw so far, I tried the following commands emby (x86_64) ******************* docker run -it --rm -v /usr/local/bin:/target emby/embyserver:x86_64 instl /usr/local/bin/emby-server docker run -it --rm -v /etc/systemd/system:/target --entrypoint bash emby/embyserver:x86_64 instl service ls -l /etc/systemd/system systemctl enable emby-server@${USER} And now....its working. Note: the lack of 'sudo' in my commands. Before I did the above, I added my user to the docker group, so I didn't have to sudo each time. Attached is the output of the commands. The material difference I saw was in what happens when I run systemctl enable emby-server@${USER}.....I needed to supply my password twice as is reloaded the daemon. Not sure why this is working. Any insight? #working output below pi@debian8:~$ docker run -it --rm -v /usr/local/bin:/target emby/embyserver:x86_64 instl Unable to find image 'emby/embyserver:x86_64' locally x86_64: Pulling from emby/embyserver 020190e11b50: Pull complete c4d4f7ecb5e4: Pull complete 764fad16103e: Pull complete 7ac0e67be9f0: Pull complete 12b0aec238f2: Pull complete Digest: sha256:5c18709d18e29fe82d2c1719326f66a0088313f704ada230f23f4482d598fbd5 Status: Downloaded newer image for emby/embyserver:x86_64 [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] 03-upgrade-onetime: executing... [cont-init.d] 03-upgrade-onetime: exited 0. [cont-init.d] 04-fix_dllmaps-onetime: executing... [cont-init.d] 04-fix_dllmaps-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Installing emby-server... instl exited 0 grep: write error: Broken pipe [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. pi@debian8:~$ /usr/local/bin/emby-server No existing user volumes for: emby-server. Pleae enter full paths you want accessible from within the container Enter one entry per line. Enter "done" or Ctrl+D when finished /mount/media done Starting emby-server... 65fb6a725cafacc454c850a23cc459b608746745193060d30a64607aa91b4077 pi@debian8:~$ docker run -it --rm -v /etc/systemd/system:/target --entrypoint bash emby/embyserver:x86_64 instl service Installing emby-server Service... Please run: sudo systemctl daemon-reload To start run: sudo systemctl start emby-server@$USERNAME pi@debian8:~$ ls -l /etc/systemd/system total 32 lrwxrwxrwx 1 root root 40 Sep 4 23:46 dbus-org.freedesktop.Avahi.service -> /lib/systemd/system/avahi-daemon.service -rw-r--r-- 1 root root 327 Oct 4 14:32 emby-server@.service drwxr-xr-x 2 root root 4096 Sep 4 23:43 getty.target.wants drwxr-xr-x 2 root root 4096 Oct 3 21:56 multi-user.target.wants drwxr-xr-x 2 root root 4096 Sep 4 23:43 network-online.target.wants drwxr-xr-x 2 root root 4096 Sep 4 23:46 printer.target.wants drwxr-xr-x 2 root root 4096 Oct 3 21:56 sockets.target.wants lrwxrwxrwx 1 root root 31 Sep 4 23:46 sshd.service -> /lib/systemd/system/ssh.service drwxr-xr-x 2 root root 4096 Sep 4 23:44 sysinit.target.wants lrwxrwxrwx 1 root root 35 Sep 4 23:43 syslog.service -> /lib/systemd/system/rsyslog.service drwxr-xr-x 2 root root 4096 Sep 4 23:43 timers.target.wants pi@debian8:~$ systemctl enable emby-server@${USER} ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-unit-files === Authentication is required to manage system service or unit files. Authenticating as: pi,,, (pi) Password: ==== AUTHENTICATION COMPLETE === Created symlink /etc/systemd/system/multi-user.target.wants/emby-server@pi.service → /etc/systemd/system/emby-server@.service. ==== AUTHENTICATING FOR org.freedesktop.systemd1.reload-daemon === Authentication is required to reload the systemd state. Authenticating as: pi,,, (pi) Password: ==== AUTHENTICATION COMPLETE ===
hurricanehrndz 149 Posted October 4, 2017 Posted October 4, 2017 By design we created with security in mind. If you want to run it as root, su and the commands should work as well. Sent from my ONEPLUS A3000 using Tapatalk 1
feardamhan 6 Posted October 6, 2017 Posted October 6, 2017 By design we created with security in mind. If you want to run it as root, su and the commands should work as well. Sent from my ONEPLUS A3000 using Tapatalk We'll I'm delighted I got it functioning. No doubt I will have fun with the pi implementation, but I learned a lot. Thanks to @@hurricanehrndz for time and effort! 1
peterpeter 0 Posted October 8, 2017 Posted October 8, 2017 Hello, i have a short question. Is the Emby version in the Docker Container automatically updated? My emby server "message me" there is a new Version of Emby available, a few hours later I take a look at the web interface and emby server "said" your emby is up-to-date.
Luke 42243 Posted October 8, 2017 Author Posted October 8, 2017 Hello, i have a short question. Is the Emby version in the Docker Container automatically updated? My emby server "message me" there is a new Version of Emby available, a few hours later I take a look at the web interface and emby server "said" your emby is up-to-date. We haven't added that for the Docker version but there are ways to have Docker automatically update images once available. Perhaps you did something like that and you've forgotten about it? Thanks.
r.ellis@cavads.com 0 Posted October 9, 2017 Posted October 9, 2017 Afternoon.... I have been running OMV2. I went to OMV3 the other day installed docker CE. I have installed the Emby docker file... now i can not get it to play i dont know what to do next... 2017-10-09 20:23:23.917 Info Main: Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.9.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (Stable 4.8.1.0/22a39d7 Sun Oct 1 17:55:43 UTC 2017) Processor count: 4 Program data path: /config Application directory: /usr/lib/emby-server/bin2017-10-09 20:23:24.814 Info App: Application version: 3.2.33.02017-10-09 20:23:24.886 Info App: Application configuration: {"EnableUPnP":true,"PublicPort":8096,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":false,"EnableLocalizedGuids":true,"EnableNormalizedItemByNameIds":true,"IsPortAuthorized":true,"EnableCaseSensitiveItemIds":true,"DisableLiveTvChannelUserDataName":true,"PreferredMetadataLanguage":"en","MetadataCountryCode":"AU","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"LibraryMonitorDelay":60,"EnableDashboardResponseCaching":true,"ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":["FanArt"],"ImageFetcherOrder":[]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":["TheAudioDB"],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":["TheAudioDB"],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"BoxSet","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Thumb","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":["TheMovieDb"],"MetadataFetcherOrder":[],"DisabledImageFetchers":["FanArt"],"ImageFetcherOrder":[]},{"ItemType":"Episode","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280},{"Type":"Primary","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":["The Open Movie Database","TheMovieDb"],"MetadataFetcherOrder":[],"DisabledImageFetchers":["The Open Movie Database","TheMovieDb"],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableAutomaticRestart":true,"SkipDeserializationForBasicTypes":true,"UICulture":"en-us","SaveMetadataHidden":false,"ContentTypes":[],"RemoteClientBitrateLimit":0,"SharingExpirationDays":30,"SchemaVersion":0,"EnableAnonymousUsageReporting":true,"EnableFolderView":false,"EnableGroupingIntoCollections":false,"DisplaySpecialsWithinSeasons":true,"DisplayCollectionsView":false,"LocalNetworkAddresses":[],"CodecsUsed":[],"EnableChannelView":false,"EnableExternalContentInSuggestions":true,"RequireHttps":false,"IsBehindProxy":false,"ImageExtractionTimeoutMs":0,"PathSubstitutions":[],"EnableSimpleArtistDetection":true,"EnableDebugLevelLogging":true,"EnableAutoUpdate":true,"LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":true}2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.Api, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.WebDashboard, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.Model, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.Common, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.Controller, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.Providers, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading Emby.Photos, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading Emby.Server.Implementations, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.LocalMetadata, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.Server.Mono, Version=3.2.33.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:24.953 Info App: Loading MediaBrowser.IsoMounting.Linux, Version=1.0.6307.26031, Culture=neutral, PublicKeyToken=null2017-10-09 20:23:25.243 Info SqliteUserRepository: Sqlite version: 3.18.02017-10-09 20:23:25.244 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-7.2.1 20170901 [gcc-7-branch revision 251580],DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_SYNCHRONOUS=2,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS5,ENABLE_JSON1,ENABLE_LOAD_EXTENSION,ENABLE_RTREE,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,OMIT_LOOKASIDE,SECURE_DELETE,SYSTEM_MALLOC,THREADSAFE=12017-10-09 20:23:25.418 Info SqliteUserRepository: Default journal_mode for /config/data/users.db is wal2017-10-09 20:23:25.420 Info SqliteUserRepository: PRAGMA synchronous=12017-10-09 20:23:25.492 Info AuthenticationRepository: Default journal_mode for /config/data/authentication.db is wal2017-10-09 20:23:25.492 Info AuthenticationRepository: PRAGMA synchronous=12017-10-09 20:23:25.596 Info SharingRepository: Default journal_mode for /config/data/shares.db is wal2017-10-09 20:23:25.596 Info SharingRepository: PRAGMA synchronous=12017-10-09 20:23:25.696 Info ActivityRepository: Default journal_mode for /config/data/activitylog.db is wal2017-10-09 20:23:25.696 Info ActivityRepository: PRAGMA synchronous=12017-10-09 20:23:25.731 Info SqliteDisplayPreferencesRepository: Default journal_mode for /config/data/displaypreferences.db is wal2017-10-09 20:23:25.732 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=12017-10-09 20:23:25.867 Info SqliteItemRepository: Default journal_mode for /config/data/library.db is wal2017-10-09 20:23:25.867 Info SqliteItemRepository: PRAGMA synchronous=12017-10-09 20:23:25.993 Info SqliteNotificationsRepository: Default journal_mode for /config/data/notifications.db is wal2017-10-09 20:23:25.993 Info SqliteNotificationsRepository: PRAGMA synchronous=12017-10-09 20:23:26.050 Debug XmlSerializer: Deserializing file /config/config/users/882dbf3182734e7d9075948f626ef8bc/policy.xml2017-10-09 20:23:26.234 Debug XmlSerializer: Deserializing file /config/config/encoding.xml2017-10-09 20:23:26.334 Info HttpServer: Calling ServiceStack AppHost.Init2017-10-09 20:23:26.655 Info ServerManager: Loading Http Server2017-10-09 20:23:26.657 Info HttpServer: Adding HttpListener prefix http://+:8096/2017-10-09 20:23:26.658 Info HttpServer: Adding HttpListener prefix https://+:8920/2017-10-09 20:23:26.851 Debug App: [LinuxMount] System PATH is currently set to [/bin:/usr/bin].2017-10-09 20:23:26.851 Debug App: [LinuxMount] System path separator is [:].2017-10-09 20:23:26.851 Debug App: [LinuxMount] Mount point root is [/tmp/Emby].2017-10-09 20:23:26.851 Info App: [LinuxMount] Using version of [sudo] located at [/usr/bin/sudo].2017-10-09 20:23:26.851 Info App: [LinuxMount] Using version of [mount] located at [/bin/mount].2017-10-09 20:23:26.851 Info App: [LinuxMount] Using version of [umount] located at [/bin/umount].2017-10-09 20:23:26.860 Error Main: Skia not available. Will try next image processor. libSkiaSharp.so2017-10-09 20:23:26.996 Info ImageMagick: ImageMagick version: ImageMagick 6.9.6-6 Q8 x86_64 2017-10-01 http://www.imagemagick.org2017-10-09 20:23:27.113 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/2c66a88b-ca43-e565-d7f8-099f825478f1.js2017-10-09 20:23:27.118 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/2c66a88b-ca43-e565-d7f8-099f825478f1.js2017-10-09 20:23:27.184 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/13e82435-eb8f-2cdc-78c9-e106fb7edd05.js2017-10-09 20:23:27.185 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/13e82435-eb8f-2cdc-78c9-e106fb7edd05.js2017-10-09 20:23:27.189 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 10/10/2017 02:00:00, which is 336.546884433333 minutes from now.2017-10-09 20:23:27.189 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/c623dbe7-7c91-ebed-cb4c-80409cdb79ee.js2017-10-09 20:23:27.189 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/c623dbe7-7c91-ebed-cb4c-80409cdb79ee.js2017-10-09 20:23:27.215 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/c27fda37-dfb6-e39b-e141-191aaa1c3060.js2017-10-09 20:23:27.216 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/c27fda37-dfb6-e39b-e141-191aaa1c3060.js2017-10-09 20:23:27.225 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/6330ee8f-b4a9-57f3-3981-f89aa78b030f.js2017-10-09 20:23:27.226 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/6330ee8f-b4a9-57f3-3981-f89aa78b030f.js2017-10-09 20:23:27.257 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/1cc2f60a-05be-fec8-b153-2ac44630a00f.js2017-10-09 20:23:27.257 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/1cc2f60a-05be-fec8-b153-2ac44630a00f.js2017-10-09 20:23:27.276 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/241d4fcb-19a1-d557-ee62-428e411da609.js2017-10-09 20:23:27.276 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/241d4fcb-19a1-d557-ee62-428e411da609.js2017-10-09 20:23:27.280 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/1c8ede62-c521-bea0-bf85-1344f5b8ca40.js2017-10-09 20:23:27.281 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/1c8ede62-c521-bea0-bf85-1344f5b8ca40.js2017-10-09 20:23:27.290 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/c3f01167-5d86-8fcc-11e2-78b847523ef5.js2017-10-09 20:23:27.291 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/c3f01167-5d86-8fcc-11e2-78b847523ef5.js2017-10-09 20:23:27.291 Info TaskManager: Daily trigger for Start new log file set to fire at 10/10/2017 00:00:00, which is 216.545140416667 minutes from now.2017-10-09 20:23:27.291 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/3145e441-d9ba-27fc-391e-7ee15face581.js2017-10-09 20:23:27.292 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/3145e441-d9ba-27fc-391e-7ee15face581.js2017-10-09 20:23:27.294 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/7a7448c2-61fa-47f3-46b4-c061a5d5c163.js2017-10-09 20:23:27.295 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/7a7448c2-61fa-47f3-46b4-c061a5d5c163.js2017-10-09 20:23:27.361 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/a27c5425-9520-b2e5-c509-def68c8f4c45.js2017-10-09 20:23:27.361 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/a27c5425-9520-b2e5-c509-def68c8f4c45.js2017-10-09 20:23:27.369 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/9be21c93-4ee4-4926-9f41-b7c2b4d4d1d7.js2017-10-09 20:23:27.369 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/9c4589c7-1219-6c27-894f-665a58cc42e3.js2017-10-09 20:23:27.370 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/9c4589c7-1219-6c27-894f-665a58cc42e3.js2017-10-09 20:23:27.370 Debug JsonSerializer: Deserializing file /config/config/ScheduledTasks/8542b8a0-0478-ef9d-9a59-0e7f2e3b62da.js2017-10-09 20:23:27.370 Debug JsonSerializer: Deserializing file /config/data/ScheduledTasks/8542b8a0-0478-ef9d-9a59-0e7f2e3b62da.js2017-10-09 20:23:27.377 Info MediaEncoder: FFMpeg: /config/ffmpeg/20170308/ffmpeg2017-10-09 20:23:27.377 Info MediaEncoder: FFProbe: /config/ffmpeg/20170308/ffprobe2017-10-09 20:23:27.377 Info MediaEncoder: Validating media encoder at /config/ffmpeg/20170308/ffmpeg2017-10-09 20:23:27.381 Info MediaEncoder: Running /config/ffmpeg/20170308/ffmpeg -decoders2017-10-09 20:23:27.432 Info MediaEncoder: Running /config/ffmpeg/20170308/ffmpeg -encoders2017-10-09 20:23:27.433 Info MediaEncoder: Encoder validation complete2017-10-09 20:23:27.442 Info App: ServerId: 0cbf50201bf94fbf8ab4a3a89379f4e62017-10-09 20:23:27.442 Info App: Core startup complete2017-10-09 20:23:27.442 Info App: Post-init migrations complete2017-10-09 20:23:27.474 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint2017-10-09 20:23:27.476 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 6.3E-05 seconds2017-10-09 20:23:27.476 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint2017-10-09 20:23:27.477 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.001045 seconds2017-10-09 20:23:27.477 Info App: Starting entry point Emby.Server.Implementations.TV.CleanMissingEpisodesEntryPoint2017-10-09 20:23:27.477 Info App: Entry point completed: Emby.Server.Implementations.TV.CleanMissingEpisodesEntryPoint. Duration: 0.000447 seconds2017-10-09 20:23:27.477 Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications2017-10-09 20:23:27.480 Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.003031 seconds2017-10-09 20:23:27.480 Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier2017-10-09 20:23:27.481 Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.000578 seconds2017-10-09 20:23:27.481 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint2017-10-09 20:23:27.481 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.000195 seconds2017-10-09 20:23:27.481 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint2017-10-09 20:23:27.485 Info App: Loading live tv data from /config/data/livetv/timers2017-10-09 20:23:27.485 Debug JsonSerializer: Deserializing file /config/data/livetv/timers.json2017-10-09 20:23:27.489 Debug XmlSerializer: Deserializing file /config/config/livetv.xml2017-10-09 20:23:27.667 Debug XmlSerializer: Deserializing file /config/root/default/TV/options.xml2017-10-09 20:23:27.686 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.204454 seconds2017-10-09 20:23:27.686 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup2017-10-09 20:23:27.931 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.245374 seconds2017-10-09 20:23:27.931 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint2017-10-09 20:23:27.932 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.000405 seconds2017-10-09 20:23:27.932 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding2017-10-09 20:23:27.975 Debug PortMapper: Starting NAT discovery2017-10-09 20:23:27.977 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.045467 seconds2017-10-09 20:23:27.977 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake2017-10-09 20:23:27.978 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.00022 seconds2017-10-09 20:23:27.978 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier2017-10-09 20:23:27.979 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.001335 seconds2017-10-09 20:23:27.979 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LoadRegistrations2017-10-09 20:23:27.979 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LoadRegistrations. Duration: 0.000234 seconds2017-10-09 20:23:27.979 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier2017-10-09 20:23:27.980 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.001084 seconds2017-10-09 20:23:27.980 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier2017-10-09 20:23:27.982 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.001832 seconds2017-10-09 20:23:27.982 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard2017-10-09 20:23:27.983 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.000201 seconds2017-10-09 20:23:27.983 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents2017-10-09 20:23:27.984 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.001307 seconds2017-10-09 20:23:27.984 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint2017-10-09 20:23:27.988 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.003934 seconds2017-10-09 20:23:27.988 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint2017-10-09 20:23:27.990 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.001459 seconds2017-10-09 20:23:27.990 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier2017-10-09 20:23:27.992 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.00268 seconds2017-10-09 20:23:27.992 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint2017-10-09 20:23:27.993 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.000913 seconds2017-10-09 20:23:27.993 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint2017-10-09 20:23:27.995 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.001489 seconds2017-10-09 20:23:27.995 Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint2017-10-09 20:23:27.996 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.000694 seconds2017-10-09 20:23:27.996 Info App: Starting entry point Emby.Dlna.DlnaProfileEntryPoint2017-10-09 20:23:27.996 Info App: Entry point completed: Emby.Dlna.DlnaProfileEntryPoint. Duration: 7.6E-05 seconds2017-10-09 20:23:27.996 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint2017-10-09 20:23:28.027 Info HttpClient: HttpClientManager GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog2017-10-09 20:23:28.029 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Default.xml2017-10-09 20:23:28.076 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Denon AVR.xml2017-10-09 20:23:28.080 Debug XmlSerializer: Deserializing file /config/config/dlna/system/DirecTV HD-DVR.xml2017-10-09 20:23:28.093 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Dish Hopper-Joey.xml2017-10-09 20:23:28.109 Debug XmlSerializer: Deserializing file /config/config/dlna/system/LG Smart TV.xml2017-10-09 20:23:28.113 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Linksys DMA2100.xml2017-10-09 20:23:28.119 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Marantz.xml2017-10-09 20:23:28.129 Debug XmlSerializer: Deserializing file /config/config/dlna/system/MediaMonkey.xml2017-10-09 20:23:28.137 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Panasonic Viera.xml2017-10-09 20:23:28.157 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Popcorn Hour.xml2017-10-09 20:23:28.160 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Samsung Smart TV.xml2017-10-09 20:23:28.170 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sharp Smart TV.xml2017-10-09 20:23:28.180 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Blu-ray Player 2013.xml2017-10-09 20:23:28.182 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Blu-ray Player 2014.xml2017-10-09 20:23:28.190 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Blu-ray Player 2015.xml2017-10-09 20:23:28.192 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Blu-ray Player 2016.xml2017-10-09 20:23:28.200 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Blu-ray Player.xml2017-10-09 20:23:28.202 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Bravia (2010).xml2017-10-09 20:23:28.210 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Bravia (2011).xml2017-10-09 20:23:28.218 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Bravia (2012).xml2017-10-09 20:23:28.237 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Bravia (2013).xml2017-10-09 20:23:28.241 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony Bravia (2014).xml2017-10-09 20:23:28.251 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony PlayStation 3.xml2017-10-09 20:23:28.267 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Sony PlayStation 4.xml2017-10-09 20:23:28.271 Debug XmlSerializer: Deserializing file /config/config/dlna/system/WDTV Live.xml2017-10-09 20:23:28.274 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Xbox 360.xml2017-10-09 20:23:28.281 Debug XmlSerializer: Deserializing file /config/config/dlna/system/Xbox One.xml2017-10-09 20:23:28.291 Debug XmlSerializer: Deserializing file /config/config/dlna/system/foobar2000.xml2017-10-09 20:23:28.336 Debug XmlSerializer: Deserializing file /config/config/dlna.xml2017-10-09 20:23:28.373 Debug NetworkManager: Querying interface: lo. Type: Loopback. Status: Unknown2017-10-09 20:23:28.374 Debug NetworkManager: Querying interface: eth0. Type: Ethernet. Status: Up2017-10-09 20:23:28.386 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.390247 seconds2017-10-09 20:23:28.386 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint2017-10-09 20:23:28.386 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.000203 seconds2017-10-09 20:23:28.387 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint2017-10-09 20:23:28.387 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.000792 seconds2017-10-09 20:23:28.387 Info App: Starting entry point Emby.Security.PluginSecurityManager2017-10-09 20:23:28.388 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.000105 seconds2017-10-09 20:23:28.388 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint2017-10-09 20:23:28.389 Info App: Loading data from /config/data/connect.txt2017-10-09 20:23:28.400 Info HttpServer: WS ws://172.16.200.21:8096/embywebsocket?api_key=76f0fe7e721346498ab8556bf06de74f&deviceId=348D94C804AC43AA865918938A894490. UserAgent:2017-10-09 20:23:28.402 Debug HttpServer: Web socket connection allowed2017-10-09 20:23:28.428 Warn SessionWebSocketListener: Unable to determine session based on url: /embywebsocket?api_key=76f0fe7e721346498ab8556bf06de74f&deviceId=348D94C804AC43AA865918938A8944902017-10-09 20:23:28.432 Info App: Loading data from /config/data/wan.dat2017-10-09 20:23:28.449 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.061859 seconds2017-10-09 20:23:28.450 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint2017-10-09 20:23:28.452 Info App: Sqlite version: 3.18.02017-10-09 20:23:28.452 Info App: Sqlite compiler options: COMPILER=gcc-7.2.1 20170901 [gcc-7-branch revision 251580],DEFAULT_SYNCHRONOUS=2,DEFAULT_WAL_SYNCHRONOUS=2,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS5,ENABLE_JSON1,ENABLE_LOAD_EXTENSION,ENABLE_RTREE,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,OMIT_LOOKASIDE,SECURE_DELETE,SYSTEM_MALLOC,THREADSAFE=12017-10-09 20:23:28.456 Info HttpServer: HTTP POST http://172.16.200.21:8096/emby/Sessions/Capabilities/Full?format=json. UserAgent: 2017-10-09 20:23:28.463 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 172.16.200.212017-10-09 20:23:28.470 Info App: Default journal_mode for /config/data/sync14.db is wal2017-10-09 20:23:28.470 Info App: PRAGMA synchronous=12017-10-09 20:23:28.472 Debug Dlna: Device Added MediaServer - 0cbf50201bf94fbf8ab4a3a89379f4e6 - http://172.16.200.21:8096/dlna/0cbf50201bf94fbf8ab4a3a89379f4e6/description.xml2017-10-09 20:23:28.472 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.022765 seconds2017-10-09 20:23:28.472 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint2017-10-09 20:23:28.473 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.000331 seconds2017-10-09 20:23:28.473 Info App: Starting entry point Emby.Security.PluginSecurityManager2017-10-09 20:23:28.473 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 5.9E-05 seconds2017-10-09 20:23:28.473 Info App: All entry points have started2017-10-09 20:23:28.475 Debug Dlna: Rebroadcast Interval = 00:00:30, Next Broadcast At = 00:00:302017-10-09 20:23:28.487 Info HttpServer: HTTP GET http://172.16.200.21:8096/dlna/0cbf50201bf94fbf8ab4a3a89379f4e6/description.xml. UserAgent: Linux/2.6.37-3.2, UPnP/1.0, DLNADOC/1.50 2017-10-09 20:23:28.487 Info HttpServer: HTTP GET http://172.16.200.21:8096/dlna/0cbf50201bf94fbf8ab4a3a89379f4e6/description.xml. UserAgent: Linux/2.6.37-3.2, UPnP/1.0, DLNADOC/1.50 2017-10-09 20:23:28.502 Debug Dlna: No matching device profile found. HOST=172.16.200.21:8096, DATE=Mon, 09 Oct 2017 09:23:29 GMT, CONNECTION=close, USER-AGENT=Linux/2.6.37-3.2, UPnP/1.0, DLNADOC/1.502017-10-09 20:23:28.502 Debug Dlna: No matching device profile found. HOST=172.16.200.21:8096, DATE=Mon, 09 Oct 2017 09:23:29 GMT, CONNECTION=close, USER-AGENT=Linux/2.6.37-3.2, UPnP/1.0, DLNADOC/1.502017-10-09 20:23:28.513 Info HttpServer: HTTP Response 200 to 172.16.200.128. Time: 25ms. http://172.16.200.21:8096/dlna/0cbf50201bf94fbf8ab4a3a89379f4e6/description.xml2017-10-09 20:23:28.513 Info HttpServer: HTTP Response 200 to 172.16.200.128. Time: 26ms. http://172.16.200.21:8096/dlna/0cbf50201bf94fbf8ab4a3a89379f4e6/description.xml2017-10-09 20:23:28.525 Info HttpServer: HTTP SUBSCRIBE http://172.16.200.21:8096/dlna/0cbf50201bf94fbf8ab4a3a89379f4e6/contentdirectory/events. UserAgent: 2017-10-09 20:23:28.527 Info HttpServer: HTTP Response 200 to 172.16.200.128. Time: 2ms. http://172.16.200.21:8096/dlna/0cbf50201bf94fbf8ab4a3a89379f4e6/contentdirectory/events2017-10-09 20:23:28.527 Info App: App Activity: app: Kodi, version: 2.3.49, deviceId: 348D94C804AC43AA865918938A894490, deviceName: Kodi (localhost)2017-10-09 20:23:28.677 Debug JsonSerializer: Deserializing file /config/data/devices/578bead5c6a393bb80a7286eb1d2067d/device.json2017-10-09 20:23:28.689 Debug JsonSerializer: Deserializing file /config/data/devices/644ccdcb296ebaeaaf055bd85baed0d1/device.json2017-10-09 20:23:28.734 Debug JsonSerializer: Deserializing file /config/data/devices/7287e652d37ba32d944a910377c289b4/device.json2017-10-09 20:23:28.752 Debug JsonSerializer: Deserializing file /config/data/devices/ddf6e25838fabbb4f652b3544e17a432/device.json2017-10-09 20:23:28.853 Error HttpServer: Error processing request
mezz64 14 Posted October 17, 2017 Posted October 17, 2017 Just wanted to give a heads up that the Docker beta container has not been updated in 15 days, it was being rebuilt every night. Also, any roadmap for moving the docker container over to .Net core now that the MAC release has been switched over?
hurricanehrndz 149 Posted October 17, 2017 Posted October 17, 2017 Thanks for the heads up. I will get the builds going again. No timeline for netcore yet. Sent from my ONEPLUS A3000 using Tapatalk
kodibart 0 Posted October 19, 2017 Posted October 19, 2017 Hi I was running docker server on kodi 17 (libreELEC version from Raybuntu) and updated to kodi alpha 18 Raybuntu. Is emby docker server supposed to be working as it is working on kodi 17. I seem to have some issues This evening I wanted to watch an episode but all my tv show posters dissapeared after I saw in the upper right corner of the screen something like deleting synchron. I can't rememer the exact phrase. I checked and all of my data on the NAS is still there.
