simonk83 7 Posted April 3, 2017 Posted April 3, 2017 Do you use your Windows Server only for emby? If so, you could decide to build a Linux-Container under your proxmox host and install emby into this LXC. Maybe an alternative to the fat Windows Server... Greetings Hoppel Hi I probably should to be honest, but I like the idea of having a Windows machine available (I don't have any in the house otherwise), and I figure server should be nice and stable at least. I am going to have a couple of linux containers for other stuff though 1
adamnmcc 1 Posted April 26, 2017 Posted April 26, 2017 Before i even bother trying, would a docker swarm on a cluster of raspberry pi's share transcoding accross the swarm if the media where to be set up on an NFS mount? i know one Pi wouldn't cope with Transcoding on the fly, but a cluster of 4-6 of them might? Or am i barking up the wrong tree here? 1
Luke 42243 Posted April 26, 2017 Author Posted April 26, 2017 Before i even bother trying, would a docker swarm on a cluster of raspberry pi's share transcoding accross the swarm if the media where to be set up on an NFS mount? i know one Pi wouldn't cope with Transcoding on the fly, but a cluster of 4-6 of them might? Or am i barking up the wrong tree here? I haven't heard of anyone trying that but it sounds interesting.
adamnmcc 1 Posted April 26, 2017 Posted April 26, 2017 hmmm, well i guess there's only one way to find out..
adamnmcc 1 Posted April 29, 2017 Posted April 29, 2017 seems its not currently possible. Docker swarm will install the same software on multiple Nodes, but it wont distribute the transcoding. Although it doesn't seem an impossibility to distribute the transcoding, i just need to figure out how to implement it with Emby..
skurvy_pirate 2 Posted May 15, 2017 Posted May 15, 2017 The latest Docker build has the same Emby version (3.2.15) so it thinks it still has to upgrade.
hurricanehrndz 149 Posted May 16, 2017 Posted May 16, 2017 The docker image depends on the Linux repository unfortunately due to the maintenance of the build service this weekend the update took longer to publish than we would have liked. Sorry for any troubles.
hurricanehrndz 149 Posted May 16, 2017 Posted May 16, 2017 ffmpeg was updated to the latest git release, the start script has been updated to not hard code the ffmpeg binaries. Users should now be able to supply whichever ffmpeg version better suits there need. You can place a newer ffmpeg version within the container by mounting a volume with the version you wish to make accessible to the container. 2
skurvy_pirate 2 Posted May 16, 2017 Posted May 16, 2017 ffmpeg was updated to the latest git release, the start script has been updated to not hard code the ffmpeg binaries. Users should now be able to supply whichever ffmpeg version better suits there need. You can place a newer ffmpeg version within the container by mounting a volume with the version you wish to make accessible to the container. Awesome!
Marv 9 Posted June 1, 2017 Posted June 1, 2017 Hi, using this container with unRAID. Just got the following log entry after upgrading to the latest version. Cannot open assembly '/usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe': No such file or directory. My Emby server is just stuck (even after rebooting). Is there another update comming to fix this?
WonkoTheSane 13 Posted June 1, 2017 Posted June 1, 2017 Hi, using this container with unRAID. Just got the following log entry after upgrading to the latest version. Cannot open assembly '/usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe': No such file or directory. My Emby server is just stuck (even after rebooting). Is there another update comming to fix this? I'm facing the same problem. Hoping for a fix for this as well.
mgworek 134 Posted June 1, 2017 Posted June 1, 2017 Updated my unraid docker 30 mins ago. Had no problems starting. Library scan is taking forever. Its been awhile since it took this long.
anderbytes 141 Posted June 1, 2017 Posted June 1, 2017 @@Luke, I updated my Emby via Docker Image to latest 3.2.19.0 and it won't start the service at all. The container runs, but no Emby runs inside it.
hurricanehrndz 149 Posted June 1, 2017 Posted June 1, 2017 Thanks guy, sorry. The image was being updated when the build system, triggered a new build unexpectedly. A new image will be push shortly. 1
anderbytes 141 Posted June 1, 2017 Posted June 1, 2017 (edited) Thanks guy, sorry. The image was being updated when the build system, triggered a new build unexpectedly. A new image will be push shortly. Its working again, but the version is 17 instead of the latest 19. UPDATE: and for some reason I can't update it manually, too. Edited June 1, 2017 by anderbytes
hurricanehrndz 149 Posted June 1, 2017 Posted June 1, 2017 Its working again, but the version is 17 instead of the latest 19. UPDATE: and for some reason I can't update it manually, too. Thanks. Will look into it.
hurricanehrndz 149 Posted June 1, 2017 Posted June 1, 2017 Its working again, but the version is 17 instead of the latest 19. UPDATE: and for some reason I can't update it manually, too. Both the issues should now be resolved.
WonkoTheSane 13 Posted June 1, 2017 Posted June 1, 2017 It's working again for me on unraid. The version I'm seeing is Version 3.2.17.0.
anderbytes 141 Posted June 1, 2017 Posted June 1, 2017 Both the issues should now be resolved. On the latest image I managed to update manually to v19, but it still started as v17
hurricanehrndz 149 Posted June 1, 2017 Posted June 1, 2017 Can you please reconfirm because I published a new one and when the build being executed I specifically saw version 3.2.19.0 being downloaded. Sent from my ONEPLUS A3000 using Tapatalk
HumanPanda 6 Posted June 2, 2017 Posted June 2, 2017 Am getting the following. Is this because of 3.2.19.0? Maybe a plugin? This is on unRAID. 2017-06-02 00:29:13.1742 Info Main: Emby Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.9.30.0 64-Bit OS: True 64-Bit Process: True Mono: 5.0.1.1 (2017-02/5077205 Wed May 31 10:26:21 UTC 2017) Processor count: 8 Program data path: /config Application directory: /usr/lib/emby-server/bin 2017-06-02 00:29:13.2264 Info ImageMagick: ImageMagick version: ImageMagick 6.9.6-6 Q8 x86_64 2017-05-31 http://www.imagemagick.org 2017-06-02 00:29:13.5422 Info App: Application version: 3.2.19.0 2017-06-02 00:29:13.7596 Info App: Application configuration: {"EnableUPnP":false,"EnableSimpleSortNameHandling":false,"PublicPort":80,"PublicHttpsPort":8920,"HttpServerPortNumber":8096,"HttpsPortNumber":8920,"EnableHttps":true,"EnableLocalizedGuids":true,"EnableNormalizedItemByNameIds":false,"CertificatePath":"/unraid/appdata/letsencrypt/keys/letsencrypt/privkey.pfx","IsPortAuthorized":true,"EnableCaseSensitiveItemIds":false,"DisableLiveTvChannelUserDataName":false,"MetadataPath":"/mnt/user/EmbyConfig/Metadata","SeasonZeroDisplayName":"Specials","PreferredMetadataLanguage":"en","MetadataCountryCode":"US","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"LibraryMonitorDelay":60,"EnableDashboardResponseCaching":false,"DashboardSourcePath":"","ImageSavingConvention":"Compatible","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["MusicBrainz","TheAudioDB","last.fm"],"DisabledImageFetchers":[],"ImageFetcherOrder":["FanArt","TheAudioDB","last.fm","Image Extractor"]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"BoxRear","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Box","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Menu","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":0,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["TV Maze","TheMovieDb","AniDB"],"DisabledImageFetchers":[],"ImageFetcherOrder":["TheTVDB","FanArt","TV Maze","AniDB","AniList"]},{"ItemType":"Movie","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"BoxRear","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Box","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Menu","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":["Emby Xml","Nfo"],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["TheMovieDb","The Open Movie Database"],"DisabledImageFetchers":[],"ImageFetcherOrder":["TheMovieDb","FanArt","The Open Movie Database","Screen Grabber"]},{"ItemType":"Episode","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"BoxRear","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Box","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Menu","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":["Emby Xml","Nfo"],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["TheTVDB","TV Maze","AniDB","TheMovieDb","The Open Movie Database"],"DisabledImageFetchers":[],"ImageFetcherOrder":["TheTVDB","TheMovieDb","Screen Grabber","The Open Movie Database"]},{"ItemType":"Series","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"BoxRear","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Box","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Menu","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":["Emby Xml","Nfo"],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["TheTVDB","TV Maze","AniDB","AniList","TheMovieDb","The Open Movie Database"],"DisabledImageFetchers":[],"ImageFetcherOrder":["TheTVDB","FanArt","AniDB","AniList","TheMovieDb"]},{"ItemType":"MusicVideo","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"BoxRear","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Box","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Menu","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":["Emby Xml","Nfo"],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["TheMovieDb"],"DisabledImageFetchers":[],"ImageFetcherOrder":["TheMovieDb","FanArt","Screen Grabber"]},{"ItemType":"Trailer","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"AdultVideo","ImageOptions":[{"Type":"Backdrop","Limit":3,"MinWidth":1280}],"DisabledMetadataSavers":["Emby Xml"],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Video","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"BoxRear","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Box","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Menu","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":["Emby Xml","Nfo"],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":["Screen Grabber"]},{"ItemType":"Person","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"BoxRear","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Box","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Menu","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["TheMovieDb","AniDB"],"DisabledImageFetchers":[],"ImageFetcherOrder":["TheMovieDb","TheTVDB","AniDB"]},{"ItemType":"BoxSet","ImageOptions":[{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Art","Limit":1,"MinWidth":0},{"Type":"BoxRear","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Box","Limit":1,"MinWidth":0},{"Type":"Disc","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0},{"Type":"Menu","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Screenshot","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":["TheMovieDb"],"DisabledImageFetchers":[],"ImageFetcherOrder":["TheMovieDb","FanArt"]}],"EnableAutomaticRestart":true,"SkipDeserializationForBasicTypes":false,"SkipDeserializationForAudio":false,"ServerName":"Media-Server","WanDdns":"example.com","UICulture":"en-us","SaveMetadataHidden":false,"ContentTypes":[],"RemoteClientBitrateLimit":125000000,"SharingExpirationDays":30,"SchemaVersion":109,"EnableAnonymousUsageReporting":false,"EnableStandaloneMusicKeys":false,"EnableFolderView":false,"EnableGroupingIntoCollections":false,"DisplaySpecialsWithinSeasons":true,"DisplayCollectionsView":true,"LocalNetworkAddresses":[],"CodecsUsed":[],"Migrations":["5767","5767.1","MediaBrowser.Server.Startup.Common.Migrations.OmdbEpisodeProviderMigration","MediaBrowser.Server.Startup.Common.Migrations.MovieDbEpisodeProviderMigration","FolderViewSettingMigration","CollectionGroupingMigration","CollectionsViewMigration","LibraryScan6","GuideRefresh2","GuideRefresh3"],"EnableChannelView":false,"EnableExternalContentInSuggestions":false,"ImageExtractionTimeoutMs":0,"PathSubstitutions":[],"EnableSimpleArtistDetection":true,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"LogFileRetentionDays":3,"RunAtStartup":true,"IsStartupWizardCompleted":true,"CachePath":"/mnt/user/EmbyCache"} 2017-06-02 00:29:13.7752 Info App: Loading AutoBoxSets, Version=1.1.0.6, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Kodi.SyncQueue, Version=1.4.6275.42963, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading GenreCleaner, Version=1.0.2.5, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MBBackup, Version=1.0.1.13, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.Anime, Version=1.1.5949.43110, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.PushBulletNotifications, Version=3.0.6143.20390, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.RottenTomatoes, Version=3.0.6134.23469, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.SmtpNotifications, Version=3.0.6178.37996, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.TimeLord, Version=16.10.26.1413, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.TimeLordMovies, Version=16.10.26.1413, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.TvMazeProvider, Version=3.0.6145.24751, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.Trailers, Version=1.0.6150.25153, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Statistics, Version=1.0.6352.33834, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Plugins.StudioCleaner, Version=3.0.6192.25583, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading YTrailers, Version=1.1.1.3, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MovieThemeSongs, Version=1.1.5.1, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MovieThemeVideos, Version=1.1.5.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading ThemeSongs, Version=1.1.4.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading ThemeVideos, Version=1.1.5.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Api, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.WebDashboard, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Model, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Common, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Controller, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Providers, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Photos, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Common.Implementations, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.MediaEncoding, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.LocalMetadata, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.XbmcMetadata, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.Server.Mono, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading MediaBrowser.IsoMounting.Linux, Version=1.0.6307.26031, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7752 Info App: Loading Emby.Server.Core, Version=3.2.19.0, Culture=neutral, PublicKeyToken=null 2017-06-02 00:29:13.7996 Error Main: UnhandledException *** Error Report *** Version: 3.2.19.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 4.9.30.0 64-Bit OS: True 64-Bit Process: True Mono: 5.0.1.1 (2017-02/5077205 Wed May 31 10:26:21 UTC 2017) Processor count: 8 Program data path: /config Application directory: /usr/lib/emby-server/bin System.AggregateException: One or more errors occurred. ---> System.NullReferenceException: Object reference not set to an instance of an object at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].GetTypes (System.Reflection.Assembly assembly) [0x0003d] in <a7def6295c174553a0365db65d969283>:0 at System.Linq.Enumerable+SelectManySingleSelectorIterator`2[TSource,TResult].MoveNext () [0x00051] in <6203235e612f49bb9ef4216386e8db0c>:0 at System.Linq.Enumerable+WhereEnumerableIterator`1[TSource].ToArray () [0x00033] in <6203235e612f49bb9ef4216386e8db0c>:0 at System.Linq.Enumerable.ToArray[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <6203235e612f49bb9ef4216386e8db0c>:0 at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].DiscoverTypes () [0x00097] in <a7def6295c174553a0365db65d969283>:0 at Emby.Common.Implementations.BaseApplicationHost`1+<Init>d__104[TApplicationPathsType].MoveNext () [0x0010c] in <a7def6295c174553a0365db65d969283>:0 --- End of inner exception stack trace --- at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, System.Int32 millisecondsTimeout, System.Threading.CancellationToken cancellationToken) [0x001d1] in <e1bc5338205147aba27a42de00cadcf8>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, System.Int32 millisecondsTimeout) [0x00000] in <e1bc5338205147aba27a42de00cadcf8>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks) [0x00000] in <e1bc5338205147aba27a42de00cadcf8>:0 at MediaBrowser.Server.Mono.MainClass.RunApplication (Emby.Server.Implementations.ServerApplicationPaths appPaths, MediaBrowser.Model.Logging.ILogManager logManager, Emby.Server.Implementations.StartupOptions options) [0x0011f] in <94d1f6bd6c744dd79b1e6ba64d101c0d>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00084] in <94d1f6bd6c744dd79b1e6ba64d101c0d>:0 ---> (Inner Exception #0) System.NullReferenceException: Object reference not set to an instance of an object at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].GetTypes (System.Reflection.Assembly assembly) [0x0003d] in <a7def6295c174553a0365db65d969283>:0 at System.Linq.Enumerable+SelectManySingleSelectorIterator`2[TSource,TResult].MoveNext () [0x00051] in <6203235e612f49bb9ef4216386e8db0c>:0 at System.Linq.Enumerable+WhereEnumerableIterator`1[TSource].ToArray () [0x00033] in <6203235e612f49bb9ef4216386e8db0c>:0 at System.Linq.Enumerable.ToArray[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <6203235e612f49bb9ef4216386e8db0c>:0 at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].DiscoverTypes () [0x00097] in <a7def6295c174553a0365db65d969283>:0 at Emby.Common.Implementations.BaseApplicationHost`1+<Init>d__104[TApplicationPathsType].MoveNext () [0x0010c] in <a7def6295c174553a0365db65d969283>:0 <--- System.AggregateException at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, System.Int32 millisecondsTimeout, System.Threading.CancellationToken cancellationToken) [0x001d1] in <e1bc5338205147aba27a42de00cadcf8>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks, System.Int32 millisecondsTimeout) [0x00000] in <e1bc5338205147aba27a42de00cadcf8>:0 at System.Threading.Tasks.Task.WaitAll (System.Threading.Tasks.Task[] tasks) [0x00000] in <e1bc5338205147aba27a42de00cadcf8>:0 at MediaBrowser.Server.Mono.MainClass.RunApplication (Emby.Server.Implementations.ServerApplicationPaths appPaths, MediaBrowser.Model.Logging.ILogManager logManager, Emby.Server.Implementations.StartupOptions options) [0x0011f] in <94d1f6bd6c744dd79b1e6ba64d101c0d>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00084] in <94d1f6bd6c744dd79b1e6ba64d101c0d>:0 InnerException: System.NullReferenceException System.NullReferenceException: Object reference not set to an instance of an object at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].GetTypes (System.Reflection.Assembly assembly) [0x0003d] in <a7def6295c174553a0365db65d969283>:0 at System.Linq.Enumerable+SelectManySingleSelectorIterator`2[TSource,TResult].MoveNext () [0x00051] in <6203235e612f49bb9ef4216386e8db0c>:0 at System.Linq.Enumerable+WhereEnumerableIterator`1[TSource].ToArray () [0x00033] in <6203235e612f49bb9ef4216386e8db0c>:0 at System.Linq.Enumerable.ToArray[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <6203235e612f49bb9ef4216386e8db0c>:0 at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].DiscoverTypes () [0x00097] in <a7def6295c174553a0365db65d969283>:0 at Emby.Common.Implementations.BaseApplicationHost`1+<Init>d__104[TApplicationPathsType].MoveNext () [0x0010c] in <a7def6295c174553a0365db65d969283>:0 at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].GetTypes (System.Reflection.Assembly assembly) [0x0003d] in <a7def6295c174553a0365db65d969283>:0 at System.Linq.Enumerable+SelectManySingleSelectorIterator`2[TSource,TResult].MoveNext () [0x00051] in <6203235e612f49bb9ef4216386e8db0c>:0 at System.Linq.Enumerable+WhereEnumerableIterator`1[TSource].ToArray () [0x00033] in <6203235e612f49bb9ef4216386e8db0c>:0 at System.Linq.Enumerable.ToArray[TSource] (System.Collections.Generic.IEnumerable`1[T] source) [0x0001f] in <6203235e612f49bb9ef4216386e8db0c>:0 at Emby.Common.Implementations.BaseApplicationHost`1[TApplicationPathsType].DiscoverTypes () [0x00097] in <a7def6295c174553a0365db65d969283>:0 at Emby.Common.Implementations.BaseApplicationHost`1+<Init>d__104[TApplicationPathsType].MoveNext () [0x0010c] in <a7def6295c174553a0365db65d969283>:0
