hurricanehrndz 149 Posted November 13, 2014 Posted November 13, 2014 No, no ports allocated and cannot connect. I've been researching docker commands and tried this: docker run -d -p 1900:1900 -p 7359:7359 -p 8096:8096 mediabrowser/mbserver Once it started up, it's connectible on port 8096. I've stopped and removed the image and will re-run it with /var/mbdata:/config to prevent any future problems. I also realise now that the -v lines are mappings for directory visibility within the docker environment & not mediabrowser mappings, so I only need a single one for the /media directory. The port mappings shouldn't be required if you had use the direct --net=host. --net=host tells docker to share the same network stack as the host machine. I'm glad its working for you too. DLNA works better when the network stack is shared. You might want to try again. This could be another selinux issue.
rjenkins 1 Posted November 13, 2014 Posted November 13, 2014 (edited) selinux is set to permissive so should not be interfering. I'd guess it's an oddity with EL7 - I've found mention of odd port mapping bugs in other docker projects. I cleaned the image out and reloaded with -p port mappings. I could then connect but no media on the machine when trying to add media directories.. It appears Mediabrowser is not built to follow symlinks, which could be a serious problem for some people. Deleted and rebuilt again, using individual 1:1 -v mappings for all the array mount points & I can now add media locations. It's presently building the library, which on the windows machine takes a couple of hours. It will be interesting to see how it goes on this machine that has direct access to the drives. Edited November 13, 2014 by rjenkins
rjenkins 1 Posted November 14, 2014 Posted November 14, 2014 (edited) Further update: With the explicit port maps and all the storage mount points passed through in the initial command, Mediabrowser starts and I can see the media from other client machines. However, next to nothing works - I once got a non-HD movie to play using the ipad client. Other than that, I can't get anything to play using Mediabrowser classic on other machines. I either get a blank screen or a "cannot play this file" message. If I try to play music, the error is a bit clearer - it says the file does not exist and shows a path/filename starting with C:\ and the local (to the media server) path to the file. This would presumably work if the server was on the same windows machine as the client, but not with a remote / linux server. Again, I guess I'm missing something but I don't know what.. ps. I can play music / tv / movies via a web browser from another machine. Edited November 13, 2014 by rjenkins
hurricanehrndz 149 Posted November 19, 2014 Posted November 19, 2014 TZ is your timezone variable. http://www.cyberciti.biz/faq/linux-unix-set-tz-environment-variable/
Luke 42241 Posted November 19, 2014 Author Posted November 19, 2014 Thanks. I've updated the download page to indicate what TZ refers to
Guest scokar Posted November 19, 2014 Posted November 19, 2014 Luke: Can you please edit the first post to reflect the "/config" command line instead of "ProgramData-Server"? Main download page Docker info: Can someone fill in the missing parameter for TZ or document it: "... docker run -d --net=host -v {DataPath}:/config -v {MediaPath}:/media -e TZ= --name=mbserver mediabrowser/mbserver ..." Thanks :-)
grimy55 2 Posted November 20, 2014 Posted November 20, 2014 Hi all, and many thanks for this option to use mediabrowser through docker. I have an issue running the container with the new command. My run command is: docker run -d --net=host -v /home/admin/config:/config -v /mnt/ARCHE/public:/media -e TZ="America/Chicago" --name=mbserver mediabrowser/mbserver The container does not start. My mbserver Docker logs are: $ docker logs mbserver Unhandled Exception: System.UnauthorizedAccessException: Access to the path "/config/logs" is denied. at System.IO.Directory.CreateDirectoriesInternal (System.String path) [0x00000] in <filename unknown>:0 at System.IO.Directory.CreateDirectory (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.Logging.NlogManager.ReloadLogger (LogSeverity level) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00000] in <filename unknown>:0 [ERROR] FATAL UNHANDLED EXCEPTION: System.UnauthorizedAccessException: Access to the path "/config/logs" is denied. at System.IO.Directory.CreateDirectoriesInternal (System.String path) [0x00000] in <filename unknown>:0 at System.IO.Directory.CreateDirectory (System.String path) [0x00000] in <filename unknown>:0 at MediaBrowser.Common.Implementations.Logging.NlogManager.ReloadLogger (LogSeverity level) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Mono.MainClass.Main (System.String[] args) [0x00000] in <filename unknown>:0 Any idea?
hurricanehrndz 149 Posted November 20, 2014 Posted November 20, 2014 Docker runs with default uid 99 and gid 100. Ensure the directory is owned by uid 99 and gid 100. 1
Guest scokar Posted November 25, 2014 Posted November 25, 2014 Docker Vulnerability in versions older than 1.3.2: http://www.openwall.com/lists/oss-security/2014/11/24/5
emko 6 Posted November 26, 2014 Posted November 26, 2014 (edited) Docker crashes after a while The underlying Task is already in one of the three final states: RanToCompletion, Faulted, or Canceled.System.InvalidOperationExceptionat System.Threading.Tasks.TaskCompletionSource`1[system.Int32].SetException (IEnumerable`1 exceptions) [0x00000] in <filename unknown>:0at System.Threading.Tasks.TaskCompletionSource`1[system.Int32].SetException (System.Exception exception) [0x00000] in <filename unknown>:0at System.Threading.Tasks.TaskFactory`1[system.Int32].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0at System.Threading.Tasks.TaskFactory`1+<FromAsyncBeginEnd>c__AnonStorey5`3[system.Int32,System.Byte[],System.Int32,System.Int32].<>m__0 (IAsyncResult l) [0x00000] in <filename unknown>:0at System.Net.WebAsyncResult.CB (System.Object unused) [0x00000] in <filename unknown>:0 any ideas? Version 3.0.5424.1 another crash log The task has already completed System.InvalidOperationExceptionat System.Runtime.CompilerServices.AsyncTaskMethodBuilder.SetException (System.Exception exception) [0x00000] in <filename unknown>:0at System.IO.Stream+<CopyToAsync>c__async0.MoveNext () [0x00000] in <filename unknown>:0at (wrapper unbox) System.IO.Stream/<CopyToAsync>c__async0:MoveNext ()at System.Threading.Tasks.AwaiterActionContinuation.Execute () [0x00000] in <filename unknown>:0at System.Threading.Tasks.Task.ProcessCompleteDelegates () [0x00000] in <filename unknown>:0at System.Threading.Tasks.Task.HandleGenericException (System.AggregateException e) [0x00000] in <filename unknown>:0at System.Threading.Tasks.Task.TrySetException (System.AggregateException aggregate, Boolean cancellation, Boolean observed) [0x00000] in <filename unknown>:0at System.Threading.Tasks.TaskCompletionSource`1[system.Int32].TrySetException (IEnumerable`1 exceptions) [0x00000] in <filename unknown>:0at System.Threading.Tasks.TaskCompletionSource`1[system.Int32].SetException (IEnumerable`1 exceptions) [0x00000] in <filename unknown>:0at System.Threading.Tasks.TaskCompletionSource`1[system.Int32].SetException (System.Exception exception) [0x00000] in <filename unknown>:0at System.Threading.Tasks.TaskFactory`1[system.Int32].InnerInvoke (System.Threading.Tasks.TaskCompletionSource`1 tcs, System.Func`2 endMethod, IAsyncResult l) [0x00000] in <filename unknown>:0at System.Threading.Tasks.TaskFactory`1+<FromAsyncBeginEnd>c__AnonStorey5`3[system.Int32,System.Byte[],System.Int32,System.Int32].<>m__0 (IAsyncResult l) [0x00000] in <filename unknown>:0at System.Net.WebAsyncResult.CB (System.Object unused) [0x00000] in <filename unknown>:0 Edited November 26, 2014 by emko
StevenDTX 15 Posted December 16, 2014 Posted December 16, 2014 (edited) New Docker install and I cannot connect to the internet (or the mb3admin.com servers) from within the Docker apparently. It works just fine from the host unRAID server. Check for application updates failed. 2 minutes ago Error getting response stream (Write: The authentication or decryption has failed.): SendFailure root@nas:/mnt/cache/appdata# wget http://www.mb3admin.com/admin/service/MB3ServerNotifications.json --2014-12-16 09:51:30-- http://www.mb3admin.com/admin/service/MB3ServerNotifications.json Resolving www.mb3admin.com (www.mb3admin.com)... 104.28.22.116, 104.28.23.116, 2600:3c02::f03c:91ff:fe6e:540 Connecting to www.mb3admin.com (www.mb3admin.com)|104.28.22.116|:80... connected. HTTP request sent, awaiting response... 200 OK Length: 13557 (13K) [application/json] Saving to: ‘MB3ServerNotifications.json’ 100%[==========================================================================================>] 13,557 --.-K/s in 0.007s 2014-12-16 09:51:30 (1.88 MB/s) - ‘MB3ServerNotifications.json’ saved [13557/13557] 2014-12-16 09:43:48 [15] | Info, Main, Media Browser Server started 2014-12-16 09:43:48 [15] | 2014-12-16 09:43:48 [15] | Info, Main, Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /config 2014-12-16 09:43:48 [15] | Info, Main, Server: nas 2014-12-16 09:43:48 [15] | Info, Main, Operating system: Unix 3.17.4.0 2014-12-16 09:43:48 [15] | Info, Main, Processor count: 4 2014-12-16 09:43:48 [15] | Info, Main, 64-Bit OS: True 2014-12-16 09:43:48 [15] | Info, Main, 64-Bit Process: True 2014-12-16 09:43:48 [15] | Info, Main, Program data path: /config 2014-12-16 09:43:48 [15] | Info, Main, Mono: 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1) 2014-12-16 09:43:48 [15] | Info, Main, Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe 2014-12-16 09:43:48 [15] | Info, Main, *** WHEN REPORTING ISSUES PLEASE INCLUDE THE ENTIRE LOG FILE. *** 2014-12-16 09:43:48 [15] | appHost.Init 2014-12-16 09:43:48 [15] | Info, App, Application version: 3.0.5462.0 2014-12-16 09:43:48 [15] | Info, App, Application configuration: 2014-12-16 09:43:48 [15] | {"EnableUPnP":true,"PublicPort":8096,"HttpServerPortNumber":8096,"EnableInternetProviders":true,"SeasonZeroDisplayName":"Specials","SaveLocalMeta":false,"EnableLocalizedGuids":false,"PreferredMetadataLanguage":"en","MetadataCountryCode":"US","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"RealtimeMonitorDelay":30,"EnableDashboardResponseCaching":true,"EnableTvDbUpdates":false,"EnableTmdbUpdates":false,"EnableFanArtUpdates":false,"ImageSavingConvention":"Compatible","EnablePeoplePrefixSubFolders":true,"MediaEncodingQuality":"Auto","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type 2014-12-16 09:43:48 [15] | ":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"Di 2014-12-16 09:43:48 [15] | sabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableDebugEncodingLogging":false,"EnableAutomaticRestart":true,"EnableRealtimeMonitor":true,"PathSubstitutions":[],"UICulture":"en-us","DownMixAudioBoost":2,"PeopleMetadataOptions":{"DownloadActorMetadata":true,"DownloadDirectorMetadata":true,"DownloadProducerMetadata":false," 2014-12-16 09:43:48 [15] | DownloadWriterMetadata":false,"DownloadComposerMetadata":false,"DownloadOtherPeopleMetadata":false,"DownloadGuestStarMetadata":false},"FindInternetTrailers":true,"InsecureApps7":["Chromecast","iOS","Unknown app","MediaPortal","Media Portal","iPad","iPhone","Roku"],"SaveMetadataHidden":false,"PlaylistImagesDeleted":true,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":false} 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Api, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.WebDashboard, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Model, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Common, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Controller, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Providers, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Common.Implementations, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Server.Implementations, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.MediaEncoding, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Dlna, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, Ap 2014-12-16 09:43:48 [15] | p, Loading MediaBrowser.LocalMetadata, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.XbmcMetadata, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.IsoMounting.Linux, Version=1.0.5131.24779, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Server.Mono, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, App, Loading MediaBrowser.Server.Startup.Common, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:43:48 [15] | Info, SqliteUserRepository, Sqlite 3.8.2 opening /config/data/users.db 2014-12-16 09:43:48 [15] | Info, SqliteItemRepository, Sqlite 3.8.2 opening /config/data/chapters.db 2014-12-16 09:43:48 [15] | Info, SqliteItemRepository, Sqlite 3.8.2 opening /config/data/mediainfo.db 2014-12-16 09:43:48 [15] | Info, SqliteFileOrganizationRepository, Sqlite 3.8.2 opening /config/data/fileorganization.db 2014-12-16 09:43:48 [15] | Info, AuthenticationRepository, Sqlite 3.8.2 opening /config/data/authentication.db 2014-12-16 09:43:48 [15] | Info, SyncRepository, Sqlite 3.8.2 opening /config/data/sync4.db 2014-12-16 09:43:49 [15] | Info, App, HttpClientManager.GetTempFileResponse url: http://ffmpeg.gusari.org/static/64bit/ffmpeg.static.64bit.latest.tar.gz 2014-12-16 09:44:02 [15] | Info, App, Extracting ffmpeg from /config/cache/temp/933a65a8-781f-40bf-a717-9e56f0b232d5.tmp 2014-12-16 09:44:02 [15] | Info, App, Extracting /config/cache/temp/933a65a8-781f-40bf-a717-9e56f0b232d5.tmp to /config/cache/temp/7c38e914-d8da-44ed-b093-16b9890fe529 2014-12-16 09:44:03 [15] | Info, App, FFMpeg: /config/ffmpeg/20140716/ffmpeg 2014-12-16 09:44:03 [15] | Info, App, FFProbe: /config/ffmpeg/20140716/ffprobe 2014-12-16 09:44:03 [15] | Info, App, HttpClientManager.GetTempFileResponse url: https://github.com/MediaBrowser/MediaBrowser.Resources/raw/master/ffmpeg/ARIALUNI.7z 2014-12-16 09:44:03 [15] | Info, ImageProcessor, libwebp version: 0.4.1 2014-12-16 09:44:03 [15] | Info, ActivityRepository, Sqlite 3.8.2 opening /config/data/activitylog.db 2014-12-16 09:44:03 [15] | Info, SqliteDisplayPreferencesRepository, Sqlite 3.8.2 opening /config/data/displaypreferences.db 2014-12-16 09:44:03 [15] | Info, SqliteItemRepository, Sqlite 3.8.2 opening /config/data/library.db 2014-12-16 09:44:03 [15] | Info, SqliteProviderInfoRepository, Sqlite 3.8.2 opening /config/data/refreshinfo.db 2014-12-16 09:44:03 [15] | Info, SqliteUserDataRepository, Sqlite 3.8.2 opening /config/data/userdata_v2.db 2014-12-16 09:44:03 [15] | Info, SqliteNotificationsRepository, Sqlite 3.8.2 opening /config/data/notifications.db 2014-12-16 09:44:04 [15] | Info, App, Requesting administrative access to authorize http server 2014-12-16 09:44:04 [15] | Info, HttpServer, Calling ServiceStack AppHost.Init 2014-12-16 09:44:04 [15] | 2014-12-16 09:44:05 [15] | Info, ServiceStackHost, Initializing Application took 16442.721ms 2014-12-16 09:44:05 [15] | Info, ServerManager, Loading Http Server 2014-12-16 09:44:05 [15] | Info, HttpServer, Adding HttpListener prefix http://+:8096/mediabrowser/ 2014-12-16 09:44:05 [15] | Running startup tasks 2014-12-16 09:44:05 [15] | Info, App, Core startup complete 2014-12-16 09:44:05 [15] | Error launching url: System.ComponentModel.Win32Exception: Cannot find the specified file 2014-12-16 09:44:05 [15] | at System.Diagnostics.Process.Start_shell (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) [0x00000] in <filename unknown>:0 2014-12-16 09:44:05 [15] | at System.Diagnostics.Process.Start_common (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) [0x00000] in <filename unknown>:0 2014-12-16 09:44:05 [15] | at System.Diagnostics.Process.Start () [0x00000] in <filename unknown>:0 2014-12-16 09:44:05 [15] | at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Start () 2014-12-16 09:44:05 [15] | at MediaBrowser.Server.Startup.Common.Browser.BrowserLauncher.OpenUrl (System.String url, ILogger logger) [0x00000] in <filename unknown>:0 2014-12-16 09:44:05 [15] | Cannot find the specified file 2014-12-16 09:44:05 [15] | Error, App, Error launching url: http://localhost:8096/mediabrowser/web/wizardstart.html 2014-12-16 09:44:05 [15] | Cannot find the specified file 2014-12-16 09:44:05 [15] | System.ComponentModel.Win32Exception 2014-12-16 09:44:05 [15] | at System.Diagnostics.Process.Start_shell (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) [0x00000] in <filename unknown>:0 2014-12-16 09:44:05 [15] | at System.Diagnostics.Process.Start_common (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) [0x00000] in <filename unknown>:0 2014-12-16 09:44:05 [15] | at System.Diagnostics.Process.Start () [0x00000] in <filename unknown>:0 2014-12-16 09:44:05 [15] | at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Start () 2014-12-16 09:44:05 [15] | at MediaBrowser.Server.Startup.Common.Browser.BrowserLauncher.OpenUrl (System.String url, ILogger logger) [0x00000] in <filename unknown>:0 2014-12-16 09:44:05 [15] | 2014-12-16 09:44:05 [15] | Info, Dlna, SSDP service started 2014-12-16 09:46:03 [15] | Info, Main, Media Browser Server started 2014-12-16 09:46:03 [15] | 2014-12-16 09:46:03 [15] | Info, Main, Command line: /opt/mediabrowser/MediaBrowser.Server.Mono.exe -programdata /config 2014-12-16 09:46:03 [15] | Info, Main, Server: nas 2014-12-16 09:46:03 [15] | Info, Main, Operating system: Unix 3.17.4.0 2014-12-16 09:46:03 [15] | Info, Main, Processor count: 4 2014-12-16 09:46:03 [15] | Info, Main, 64-Bit OS: True 2014-12-16 09:46:03 [15] | Info, Main, 64-Bit Process: True 2014-12-16 09:46:03 [15] | Info, Main, Program data path: /config 2014-12-16 09:46:03 [15] | Info, Main, Mono: 3.2.8 (Debian 3.2.8+dfsg-4ubuntu1) 2014-12-16 09:46:03 [15] | Info, Main, Application Path: /opt/mediabrowser/MediaBrowser.Server.Mono.exe 2014-12-16 09:46:03 [15] | Info, Main, *** WHEN REPORTING ISSUES PLEASE INCLUDE THE ENTIRE LOG FILE. *** 2014-12-16 09:46:03 [15] | appHost.Init 2014-12-16 09:46:03 [15] | Info, App, Application version: 3.0.5462.0 2014-12-16 09:46:03 [15] | Info, App, Application configuration: 2014-12-16 09:46:03 [15] | {"EnableUPnP":true,"PublicPort":8096,"HttpServerPortNumber":8096,"EnableInternetProviders":true,"SeasonZeroDisplayName":"Specials","SaveLocalMeta":false,"EnableLocalizedGuids":false,"PreferredMetadataLanguage":"en","MetadataCountryCode":"US","SortReplaceCharacters":[".","+","%"],"SortRemoveCharacters":[",","&","-","{","}","'"],"SortRemoveWords":["the","a","an"],"MinResumePct":5,"MaxResumePct":90,"MinResumeDurationSeconds":300,"RealtimeMonitorDelay":30,"EnableDashboardResponseCaching":true,"EnableTvDbUpdates":false,"EnableTmdbUpdates":false,"EnableFanArtUpdates":false,"ImageSavingConvention":"Compatible","EnablePeoplePrefixSubFolders":true,"MediaEncodingQuality":"Auto","MetadataOptions":[{"ItemType":"Book","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Movie","ImageOptions":[{"Type 2014-12-16 09:46:03 [15] | ":"Backdrop","Limit":3,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Disc","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Series","ImageOptions":[{"Type":"Backdrop","Limit":2,"MinWidth":1280},{"Type":"Art","Limit":0,"MinWidth":0},{"Type":"Primary","Limit":1,"MinWidth":0},{"Type":"Banner","Limit":1,"MinWidth":0},{"Type":"Thumb","Limit":1,"MinWidth":0},{"Type":"Logo","Limit":1,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicAlbum","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Disc","Limit":0,"MinWidth":0}],"Di 2014-12-16 09:46:03 [15] | sabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"MusicArtist","ImageOptions":[{"Type":"Backdrop","Limit":1,"MinWidth":1280},{"Type":"Banner","Limit":0,"MinWidth":0},{"Type":"Art","Limit":0,"MinWidth":0}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]},{"ItemType":"Season","ImageOptions":[{"Type":"Backdrop","Limit":0,"MinWidth":1280}],"DisabledMetadataSavers":[],"LocalMetadataReaderOrder":[],"DisabledMetadataFetchers":[],"MetadataFetcherOrder":[],"DisabledImageFetchers":[],"ImageFetcherOrder":[]}],"EnableDebugEncodingLogging":false,"EnableAutomaticRestart":true,"EnableRealtimeMonitor":true,"PathSubstitutions":[],"UICulture":"en-us","DownMixAudioBoost":2,"PeopleMetadataOptions":{"DownloadActorMetadata":true,"DownloadDirectorMetadata":true,"DownloadProducerMetadata":false," 2014-12-16 09:46:03 [15] | DownloadWriterMetadata":false,"DownloadComposerMetadata":false,"DownloadOtherPeopleMetadata":false,"DownloadGuestStarMetadata":false},"FindInternetTrailers":true,"InsecureApps7":["Chromecast","iOS","Unknown app","MediaPortal","Media Portal","iPad","iPhone","Roku"],"SaveMetadataHidden":false,"PlaylistImagesDeleted":true,"EnableDebugLevelLogging":false,"EnableAutoUpdate":true,"SystemUpdateLevel":"Release","LogFileRetentionDays":3,"RunAtStartup":false,"IsStartupWizardCompleted":false} 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Api, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.WebDashboard, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Model, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Common, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Controller, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Providers, Ver 2014-12-16 09:46:03 [15] | sion=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Common.Implementations, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Server.Implementations, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.MediaEncoding, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Dlna, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.LocalMetadata, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.XbmcMetadata, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.IsoMounting.Linux, Version=1.0.5131.24779, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Server.Mono, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, App, Loading MediaBrowser.Server.Startup.Common, Version=3.0.5462.0, Culture=neutral, PublicKeyToken=null 2014-12-16 09:46:03 [15] | Info, SqliteUserRepository, Sqlite 3.8.2 opening /config/data/users.db 2014-12-16 09:46:03 [15] | Info, SqliteItemRepository, Sqlite 3.8.2 opening /config/data/chapters.db 2014-12-16 09:46:03 [15] | Info, SqliteItemRepository, Sqlite 3.8.2 opening /config/data/mediainfo.db 2014-12-16 09:46:03 [15] | Info, SqliteFileOrganizationRepository, Sqlite 3.8.2 opening /config/data/fileorganization.db 2014-12-16 09:46:03 [15] | Info, AuthenticationRepository, Sqlite 3.8.2 opening /config/data/authentication.db 2014-12-16 09:46:03 [15] | Info, SyncRepository, Sqlite 3.8.2 opening /config/data/sync4.db 2014-12-16 09:46:03 [15] | Info, App, FFMpeg: /config/ffmpeg/20140716/ffmpeg 2014-12-16 09:46:03 [15] | Info, App, FFProbe: /config/ffmpeg/20140716/ffprobe 2014-12-16 09:46:03 [15] | Info, ImageProcessor, libwebp version: 0.4.1 2014-12-16 09:46:03 [15] | Info, ActivityRepository, Sqlite 3.8.2 opening /config/data/activitylog.db 2014-12-16 09:46:03 [15] | Info, SqliteDisplayPreferencesRepository, Sqlite 3.8.2 opening /config/data/displaypreferences.db 2014-12-16 09:46:03 [15] | Info, SqliteItemRepository, Sqlite 3.8.2 opening /config/data/library.db 2014-12-16 09:46:03 [15] | Info, SqliteProviderInfoRepository, Sqlite 3.8.2 opening /config/data/refreshinfo.db 2014-12-16 09:46:03 [15] | Info, SqliteUserDataRepository, Sqlite 3.8.2 opening /config/data/userdata_v2.db 2014-12-16 09:46:03 [15] | Info, SqliteNotificationsRepository, Sqlite 3.8.2 opening /config/data/notifications.db 2014-12-16 09:46:03 [15] | Info, App, Requesting administrative access to authorize http server 2014-12-16 09:46:03 [15] | Info, HttpServer, Calling ServiceStack AppHost.Init 2014-12-16 09:46:04 [15] | Info, ServiceStackHost, Initializing Application took 1003.967ms 2014-12-16 09:46:04 [15] | Info, ServerManager, Loading Http Server 2014-12-16 09:46:04 [15] | Info, HttpServer, Adding HttpListener prefix http://+:8096/mediabrowser/ 2014-12-16 09:46:04 [15] | Running startup tasks 2014-12-16 09:46:05 [15] | Info, App, Core startup complete 2014-12-16 09:46:05 [15] | Error launching url: System.ComponentModel.Win32Exception: Cannot find the specified file 2014-12-16 09:46:05 [15] | at System.Diagnostics.Process.Start_shell (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) [0x00000] in <filename unknown>:0 2014-12-16 09:46:05 [15] | at System.Diagnostics.Process.Start_common (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) [0x00000] in <filename unknown>:0 2014-12-16 09:46:05 [15] | at System.Diagnostics.Process.Start () [0x00000] in <filename unknown>:0 2014-12-16 09:46:05 [15] | at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Start () 2014-12-16 09:46:05 [15] | at MediaBrowser.Server.Startup.Common.Browser.BrowserLauncher.OpenUrl (System.String url, ILogger logger) [0x00000] in <filename unknown>:0 2014-12-16 09:46:05 [15] | Cannot find the specified file 2014-12-16 09:46:05 [15] | Error, App, Error launching url: http://localhost:8096/mediabrowser/web/wizardstart.html 2014-12-16 09:46:05 [15] | Cannot find the specified file 2014-12-16 09:46:05 [15] | System.ComponentModel.Win32Exception 2014-12-16 09:46:05 [15] | at System.Diagnostics.Process.Start_shell (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) [0x00000] in <filename unknown>:0 2014-12-16 09:46:05 [15] | at System.Diagnostics.Process.Start_common (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) [0x00000] in <filename unknown>:0 2014-12-16 09:46:05 [15] | at System.Diagnostics.Process.Start () [0x00000] in <filename unknown>:0 2014-12-16 09:46:05 [15] | at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Start () 2014-12-16 09:46:05 [15] | at MediaBrowser.Server.Startup.Common.Browser.BrowserLauncher.OpenUrl (System.String url, ILogger logger) [0x00000] in <filename unknown>:0 2014-12-16 09:46:05 [15] | 2014-12-16 09:46:05 [15] | Info, Dlna, SSDP service started Edited December 16, 2014 by StevenDTX
hurricanehrndz 149 Posted December 16, 2014 Posted December 16, 2014 Yes this is a mediabrowser error, not specific to docker. There should be an update shortly please try again then and report back.
StevenDTX 15 Posted December 16, 2014 Posted December 16, 2014 Yes this is a mediabrowser error, not specific to docker. There should be an update shortly please try again then and report back. Thank you for the quick response!
jacob.alberty 0 Posted January 27, 2015 Posted January 27, 2015 Would it be feasable to call a firstrun.sh from start.sh using something like: if [ -e /firstrun.sh ] then /firstrun.sh rm -f /firstrun.sh fi firstrun.sh could then look like #!/bin/sh usermod -u ${USER_ID:-99} mediabrowser groupmod -g ${GROUP_ID:-100} mediabrowser usermod -g ${GROUP_ID:-100} mediabrowser envtpl /etc/circus.d/MediaBrowser.ini.tpl --allow-missing This would open up using USER_ID and GROUP_ID as configurable parameters to allow the docker container to be configured to match the host systems file permissions. If no GROUP_ID or USER_ID is specified it will give a small usermod: no changes error message on first boot due to trying to reuse the groups set by run. but beyond that the file firstrun.sh is removed and behavior will mimic the old behavior when no GROUP_ID or USER_ID set other than not trying to recreate MediaBrowser.ini every start (so no error message about that) but if GROUP_ID and USER_ID are passed using -e with docker run then it will set the mediabrowser user and/or group to whatever is specified and then have circusd launch mediabrowser using that user and group.
hurricanehrndz 149 Posted January 27, 2015 Posted January 27, 2015 Would it be feasable to call a firstrun.sh from start.sh using something like: if [ -e /firstrun.sh ] then /firstrun.sh rm -f /firstrun.sh fi firstrun.sh could then look like #!/bin/sh usermod -u ${USER_ID:-99} mediabrowser groupmod -g ${GROUP_ID:-100} mediabrowser usermod -g ${GROUP_ID:-100} mediabrowser envtpl /etc/circus.d/MediaBrowser.ini.tpl --allow-missing This would open up using USER_ID and GROUP_ID as configurable parameters to allow the docker container to be configured to match the host systems file permissions. If no GROUP_ID or USER_ID is specified it will give a small usermod: no changes error message on first boot due to trying to reuse the groups set by run. but beyond that the file firstrun.sh is removed and behavior will mimic the old behavior when no GROUP_ID or USER_ID set other than not trying to recreate MediaBrowser.ini every start (so no error message about that) but if GROUP_ID and USER_ID are passed using -e with docker run then it will set the mediabrowser user and/or group to whatever is specified and then have circusd launch mediabrowser using that user and group. Yes it would be. Thank you for the suggestion, I will get right on it. 1
hurricanehrndz 149 Posted January 29, 2015 Posted January 29, 2015 Just to let you know, it might be a little longer just because I'm studying for exams right now.
deaerator 2 Posted February 26, 2015 Posted February 26, 2015 I came back to the fold and decided to install the docker. My only issue is where is the restart button. when the docker updates and requires a restart; I can't find the restart button.
hurricanehrndz 149 Posted February 26, 2015 Posted February 26, 2015 There is no automated updates on linux. For docker updates, re-pull from repo from time to time.
deaerator 2 Posted February 26, 2015 Posted February 26, 2015 The only reason i ask is when i install a new plugin, it keeps asking me to restart the server. I recall that there was a server restart button under servers setting.
thefirstofthe300 292 Posted February 28, 2015 Posted February 28, 2015 The only reason i ask is when i install a new plugin, it keeps asking me to restart the server. I recall that there was a server restart button under servers setting.Do to the way that security in Linux works, the server isn't actually able to restart itself so it was removed for the Linux builds. Plus, it would mess up the service if you started the server using a service (systemd or sysv init).
grimy55 2 Posted February 28, 2015 Posted February 28, 2015 (edited) I'm having this error with the last build (2015-02-22). It sounds to happen more or less randomly after a restart of the Docker container. Any thoughts? $ docker logs mbserver --> start.sh script running... ---> Starting circus... 2015-02-28 09:18:50 circus[1] [INFO] Starting master on pid 1 2015-02-28 09:18:50 circus[1] [INFO] Arbiter now waiting for commands 2015-02-28 09:18:50 circus[1] [INFO] MediaBrowser started Stacktrace: Native stacktrace: Stacktrace: Native stacktrace: mono() [0x4b73d8] mono() [0x50f13b] mono() [0x423d22] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f500f6a7340] /lib/x86_64-linux-gnu/libpthread.so.0(pthread_mutex_lock+0x4) [0x7f500f6a1414] mono() [0x4c1c47] [0x4053aae6] Debug info from gdb: ================================================================= Got a SIGSEGV while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= Stacktrace: Native stacktrace: mono() [0x4b73d8] mono() [0x50f13b] mono() [0x423d22] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x7f2aed67f340] Debug info from gdb: ================================================================= Got a SIGSEGV while executing native code. This usually indicates a fatal error in the mono runtime or one of the native libraries used by your application. ================================================================= Update: I've upgraded Docker from v1.0.1 (from the default Ubuntu repo) to v1.5 (from the Docker repo). Don't have the issue anymore. Update2: Well, actually, this is coming back. I'm opening a dedicated thread. Edited March 4, 2015 by grimy55
grimy55 2 Posted March 5, 2015 Posted March 5, 2015 I've noticed the Mono package that comes with the Docker container is v3.2.8 (actually the version provided in the official Ubuntu Trusty depo). Some users have reported some incompatibilities between this old Mono v3.2.8 and the newer Mediabrowser version. It might also be the cause of the issue I reported above and there. Is it planned to modify the official Mediabrowser container to come with a newer version of Mono (the mono-project provides installation instructions for Trusty)? Thanks for your good work.
hurricanehrndz 149 Posted March 7, 2015 Posted March 7, 2015 I've noticed the Mono package that comes with the Docker container is v3.2.8 (actually the version provided in the official Ubuntu Trusty depo). Some users have reported some incompatibilities between this old Mono v3.2.8 and the newer Mediabrowser version. It might also be the cause of the issue I reported above and there. Is it planned to modify the official Mediabrowser container to come with a newer version of Mono (the mono-project provides installation instructions for Trusty)? Thanks for your good work. Yes. I'm working on getting imagemagic working and at the same time I will try and update mono. Please be patient. I've been busy rebuilding my development and unraid server.
hurricanehrndz 149 Posted March 7, 2015 Posted March 7, 2015 Do to the way that security in Linux works, the server isn't actually able to restart itself so it was removed for the Linux builds. Plus, it would mess up the service if you started the server using a service (systemd or sysv init). The service can be restarted using docker exec command. I will post it soon once the new update is released. Everyone please withhold from updating until I say the update is ready for docker. Feel free to follow me on twitter carlos_techbyte
