hurricanehrndz 149 Posted October 3, 2016 Posted October 3, 2016 Okay, issue is with docker build service. I will need to open an issue with them to hopefully get it resolved. Please use the internal update mechanism to update the container for now. `docker exec ${name} update`
Pancho 9 Posted October 4, 2016 Posted October 4, 2016 Working perfectly. Thanks Hurricane for the quick turn around.
Pancho 9 Posted October 13, 2016 Posted October 13, 2016 (edited) Yes there seems to be an issue with the last build. I will try and get build up soon. Thank you for reporting the issue. PS if you notice that it does not update after removing and adding please check the tags on docker. If you notice that it has been more than 4 hrs since the release and a new docker has not been built. Please report the issue here so that we can get things resolved. Thank you for letting us know about the issue. Hurricane, 3.0.8000 Server was released earlier today. I checked the tags on docker for the latest/stable release, but both show they have not been updated in 9/10 days. In your prior post, you requested to notify you after 4 hours of a server release if the new docker update is not available. Same issue as before, I cannot pull it the 3.0.8000 version down to my Unraid server (ver. 6.2.1). Can you check to see if there is an issue on the build side? Thanks. Pancho Edited October 13, 2016 by Pancho
hurricanehrndz 149 Posted October 13, 2016 Posted October 13, 2016 There is an issue with docker hub, there build service has been terrible lately Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted October 13, 2016 Posted October 13, 2016 Use the internal method of updating Sent from my ONEPLUS A3000 using Tapatalk
Pancho 9 Posted October 13, 2016 Posted October 13, 2016 I used the internal command: docker exec EmbyServer update and I am upgraded to 3.0.8000 Thanks. Pancho
hurricanehrndz 149 Posted October 13, 2016 Posted October 13, 2016 No worries. if you read the wiki you can set a cron job, I will update the container to also update on first launch from now on. docker hub is just becoming a mess to deal with.
teiva 18 Posted October 16, 2016 Posted October 16, 2016 (edited) Ubuntu Server 16.04.1 SAMBA version 4.3.11 Windows 10 client (Bash/Putty) Emby 3.08000 OR 3.0.8100.0 (depending on time of day) Docker 1.12.2 Emby server keeps rolling back to 3.08000 when I reboot my server box. To re-upgrade back to 3.0.8100 after every reboot I have to... 1. docker exec emby-server update 2. restart emby server via webpage GUI I have installed the systemd service file. This is unexpected behavior, right? Edited October 16, 2016 by teivalp
hurricanehrndz 149 Posted October 16, 2016 Posted October 16, 2016 Not really, behavior is expected. I have actually be putting a lot of thought to this lately, since docker hub has been unreliable. I will address these concerns soon. Sent from my ONEPLUS A3000 using Tapatalk 1
teiva 18 Posted October 16, 2016 Posted October 16, 2016 Thanks for the reply. What thread or feed should I subscribe to so that I see your announcement?
hurricanehrndz 149 Posted October 16, 2016 Posted October 16, 2016 I'll announce here Sent from my ONEPLUS A3000 using Tapatalk
Sergio 4 Posted October 29, 2016 Posted October 29, 2016 My installation finally got broken, perhaps you can give me a hand to recover it (or perhaps will be better use a fresh container?) My emby was giving me recurrent errors while playing my favourite series. It'll stop playing suddenly and jump to next episode, or bring my server to insane high cpu while idling. I noticed that despite the cron update job it was still on 7th version number so i manually tried to update it using the internal command. That done nothing, so I entered the docker and ran an upgrade and dist upgrade (an amount of packages where hold back) During those commands some packages where uninstalled. Now my emby installation does not reproduce video files and directly throws errors and gives up after third attempt. Should i install the missing packages or try a fresh container? What are the requeried video decoding pkgs? I saw something like xxxx245 was uninstalled. Tnx.
hurricanehrndz 149 Posted October 29, 2016 Posted October 29, 2016 As long as you have your config file in a volume outside the container, why wouldn't you do a fresh container. There are no decoding packages. Ffmpeg static releases are used instead. Sent from my ONEPLUS A3000 using Tapatalk
Sergio 4 Posted October 29, 2016 Posted October 29, 2016 The only inconvenience I have with this approach is that I'm using Openmediavault and I depend on the interface for docker. I'm so clumsy with it.
hurricanehrndz 149 Posted October 29, 2016 Posted October 29, 2016 (edited) Ah.. well how did you set it up the first time? Sent from my ONEPLUS A3000 using Tapatalk Edited October 29, 2016 by hurricanehrndz
Sergio 4 Posted October 29, 2016 Posted October 29, 2016 Oh, it has an interface for creation. The problem is that after that, it doesn't show the same options/data you specified before. As OMV has it's own requirements, I remember having to create a share inside the share with the same name for emby to see my media. Enviado desde mi A0001 mediante Tapatalk
hurricanehrndz 149 Posted October 29, 2016 Posted October 29, 2016 Hmm, sounds like openmedia vault needs work on the interface to make it easier for users to update and re-create containers. I'm not familiar with openmedia vault. What I can tell you is that other NAS os have options for templates that create the container. The developers usually put a list of environment variables that can be adjusted in order to modify how and with what permissions the container runs. I know because I created those templates for unRAID and rockstor. Is there no options with documentation that talks about UID and GID and volumes. Or even updating options for containers Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted October 29, 2016 Posted October 29, 2016 Should look very similar to this http://i.imgur.com/4FDQUlg.png Sent from my ONEPLUS A3000 using Tapatalk
Sergio 4 Posted October 29, 2016 Posted October 29, 2016 For example, I just pulled the newer version of the image, and it left me with the newer, and a blank repository entry for the old. Enviado desde mi A0001 mediante Tapatalk
Sergio 4 Posted October 29, 2016 Posted October 29, 2016 OMV doesn't have option for updating or changing a container parameters. You must destroy the container. Enviado desde mi A0001 mediante Tapatalk
Sergio 4 Posted October 29, 2016 Posted October 29, 2016 That's what I have. But I'm not sure if something is missing. Bridge in OMV was giving plenty of errors. Enviado desde mi A0001 mediante Tapatalk
hurricanehrndz 149 Posted October 29, 2016 Posted October 29, 2016 Well as long as when you setup it up the first time you ensure to give it a volume for config you should be fine. Rund docker inspect of your current emby container and ensure that the config volume is mounted. Please look into the details for the emby container. Adjust the variables so that emby runs with the right uid and gid. Sent from my ONEPLUS A3000 using Tapatalk
hurricanehrndz 149 Posted October 29, 2016 Posted October 29, 2016 (edited) It should be fine. Permissions might give you an issue since you never set the APP_UID and APP_GID environment variables. The config volume is mounted so your settings will persist after destruction and recreation. Please the wiki entry for docker. Sent from my ONEPLUS A3000 using Tapatalk Edited October 29, 2016 by hurricanehrndz
Sergio 4 Posted October 29, 2016 Posted October 29, 2016 That's just the point. I set app_uid and app_gid but they don't appear when cloning. Enviado desde mi A0001 mediante Tapatalk
