bradford 9 Posted August 8, 2016 Posted August 8, 2016 I currently have Emby running on Windows and it runs flawlessly. So I'm about to setup a new home server based on Proxmox, which supports docker containers and virtual machines (KVM). I am trying to decide whether I run Emby in docker, which in concept I definitely prefer, however the issues posted in this thread make me a little worried. Is the docker/linux version of Emby stable or should I just save myself some grief and use a Windows VM? When I migrated from Plex I tried the linux version of Emby (this was over a year ago I think) and it was pretty unstable. I'd love for it to be like Sonarr, which is rock solid and mono-based. Thanks!
anderbytes 141 Posted August 8, 2016 Posted August 8, 2016 @@Luke, can you tell me if builds in https://hub.docker.com/r/emby/embyserver/builds are updated manually? I'm waiting for today's stable to appear there... but not even latests Betas were published... :-/
ice pube 20 Posted August 8, 2016 Posted August 8, 2016 I currently have Emby running on Windows and it runs flawlessly. So I'm about to setup a new home server based on Proxmox, which supports docker containers and virtual machines (KVM). I am trying to decide whether I run Emby in docker, which in concept I definitely prefer, however the issues posted in this thread make me a little worried. Is the docker/linux version of Emby stable or should I just save myself some grief and use a Windows VM? When I migrated from Plex I tried the linux version of Emby (this was over a year ago I think) and it was pretty unstable. I'd love for it to be like Sonarr, which is rock solid and mono-based. Thanks! I switched from a Windows 10 server to unraid, and it has been great. No issues at all with the emby setup, everything transitioned over great.
reyes136 2 Posted August 10, 2016 Posted August 10, 2016 I was running win10 on a ASRock C2750D4I with 16G of ECC ram and a ssd os disk, I had emby installed to server blu ray rips and my hdhr prime over the internet. This worked good with great video quality from the rips and hdhr. I could to 2 clients at hd transcoding using about 80% cpu. I then switched the system to Unraid with 2 SSD cache drives, I loaded the emby docker and now streams randomly drop, and hdhr streams are very block with green blocks and audio stuttering. Also I can only stream to 1 client which runs at 80% to 90%. The docker runs stable without crashes but I think running in a docker takes a bit of performance away. Hopefully emby just needs to be optimized a litle more for docker. I also moved my unraid system to a i5 4 core 8 thread 3.9G processor and had the same issues.
wedgekc 12 Posted August 31, 2016 Posted August 31, 2016 I'm new to docker but my emby container has been great. I would like to use hardware acceleration on my intel gpu but it doesn't work using docker. From a quick check, it seems possible to pass-through the intel gpu to the container by including the drivers in the container and passing the correct arguments when starting the container. Has anyone done anything like this or are there any plans to implement it? 1
Sergio 4 Posted August 31, 2016 Posted August 31, 2016 And with those updates, installing a new container would be required or it will be a normal updater script task? I never done anything but executing the update script since I installed the container. Should I be renewing it periodically? Enviado desde mi A0001 mediante Tapatalk
hurricanehrndz 149 Posted August 31, 2016 Posted August 31, 2016 I'm new to docker but my emby container has been great. I would like to use hardware acceleration on my intel gpu but it doesn't work using docker. From a quick check, it seems possible to pass-through the intel gpu to the container by including the drivers in the container and passing the correct arguments when starting the container. Has anyone done anything like this or are there any plans to implement it?I will see if I can update the container and the wrapper script for intel gpu. Sent from my ONE E1005 using Tapatalk 1
wedgekc 12 Posted September 1, 2016 Posted September 1, 2016 I will see if I can update the container and the wrapper script for intel gpu. Sent from my ONE E1005 using Tapatalk Thanks, that would be awesome.
anderbytes 141 Posted September 1, 2016 Posted September 1, 2016 I will see if I can update the container and the wrapper script for intel gpu. Sent from my ONE E1005 using Tapatalk Other HW options (ex: vaapi) also need implementation for Docker?
wedgekc 12 Posted September 2, 2016 Posted September 2, 2016 Other HW options (ex: vaapi) also need implementation for Docker? I was talking about vaapi for intel. From what I understand, Quicksync is a real hassle on linux. If I understand correctly, vaapi is pretty much baked in already. I also checked the ffmpeg build in the docker container and it appears to support vaapi already. ffmpeg -encoders 2>/dev/null | grep vaapi V..... h264_vaapi H.264/AVC (VAAPI) (codec h264) V..... hevc_vaapi H.265/HEVC (VAAPI) (codec hevc) V..... mjpeg_vaapi MJPEG (VAAPI) (codec mjpeg) I think vaapi should be good to go once the drivers are added to the container. I believe the other options are for nvidia hardware acceleration.
TrainAss 22 Posted September 4, 2016 Posted September 4, 2016 I've run in to an issue that has me stumped. I'm running Emby Server (dev) 3.1.6052.31460 via Docker. I have set up access to all my media folders (movies and TV Shows) plus my games. My media plays just fine, however when trying to play a game via emulator, Emby Theater (Windows 10) just spins. I have GameBrowser III setup correctly, the consoles show up properly and all the games are showing correctly too. Emby Docker has R/W access to all of its folders. I've also tried setting up the path substitution in the server console and pointed it to the actual shared folder and the results are the same. Emby Theater won't start the required emulator and game. Everything else is working flawlessly. The emulator that I've tried is zSNES and SNES9x (64bit) on Win10. Docker info The server logs and some screenshots are all attached. Anyone have any ideas about my issue?
LongMan 117 Posted September 11, 2016 Posted September 11, 2016 @@Luke. FreeNas 10 is replacing Jails with Docker containers. Testing is occurring now and it would be good to have Emby's Docker image included in the FreeNAs respository. Plex is already included. Cheers, LongMan
Luke 42243 Posted September 11, 2016 Author Posted September 11, 2016 @@Luke. FreeNas 10 is replacing Jails with Docker containers. Testing is occurring now and it would be good to have Emby's Docker image included in the FreeNAs respository. Plex is already included. Cheers, LongMan Good info, thanks. I wonder if our regular Docker image could be added in it's current form. I would think so.
LongMan 117 Posted September 11, 2016 Posted September 11, 2016 It should. They just took the most popular Plex Docker Image and place it in their repo. I was able to download and run your docker image using the FreeNas 10 CLI. I am just learning to use Docker so the experience is tedious compare to running the plugin or even the Plex image that is in their repo. I suspect there are many people who wouldn't be able to do it from the CLI, so getting it into their repo would make it much easier, because it could be done from the web interface. The best time to get it in, is now, while they are trying to expand their offerings. I suspect an email or forum post, pointing them to the image, might do the trick. Cheers, LongMan
Luke 42243 Posted September 12, 2016 Author Posted September 12, 2016 Thanks for the tip ! Were you able to successfully use the server this way? In other words, run through the setup wizard, add a library, play a video?
LongMan 117 Posted September 12, 2016 Posted September 12, 2016 Unfortunately no. My DockerFu is minimal to non existent. Actually, i only as much as I need to survive Linux and FreeBSD and using cli. Hence, I am sure I am not doing something right. I copied the first command to the console in boot2docker and it fetched the image. I can see the image with docker images. Install Emby Server docker run -it --rm -v /usr/local/bin:/target emby/embyserver instl However, when I try the second command Run Emby Server /usr/local/bin/emby-server I get -sh: /usr/local/bin/emby-server: not found Any help is greatly appreciated. Cheers, LongMan
hurricanehrndz 149 Posted September 12, 2016 Posted September 12, 2016 Unfortunately no. My DockerFu is minimal to non existent. Actually, i only as much as I need to survive Linux and FreeBSD and using cli. Hence, I am sure I am not doing something right. I copied the first command to the console in boot2docker and it fetched the image. I can see the image with docker images. Install Emby Server docker run -it --rm -v /usr/local/bin:/target emby/embyserver instl However, when I try the second command Run Emby Server /usr/local/bin/emby-server I get -sh: /usr/local/bin/emby-server: not found Any help is greatly appreciated. Cheers, LongMan The script is built for normal running servers not nas devices. Best is to have a template created. I would look at it when I get a chance, it might be a while though.
Narnian 2 Posted September 30, 2016 Posted September 30, 2016 Could I please get a poll or something of a list of people using emby on docker and why? Then what platform ? For example unsaid Linux arm. Synology nas. Thanks I'm using Docker on Lime tech Unraid server plus. I can't get my android to login to the server it tells me to upgrade to the latest release of Emby. Docker says it's up to date Server says to manually upgrade and restart the server. If I could, I would that's why I got the Docker. I use it to avoid this kind of thing I am limited in my understanding.
ecrispy 38 Posted September 30, 2016 Posted September 30, 2016 I'm sort of new to Docker and Linux, I'm planning to move my current Emby running as Windows service to a docker under Linux VM (which will also have other services). Have some simple questions - - what Linux OS would you recommend for the VM (it will run under Hyper-V). I don't think this matters that much, I will just pick Ubuntu server by default if no opinons - how do people autostart/run as service in Linux. Have seen some references to systemd/initd, seems like it varies with distro - what do people use to manage docker in general, just cmd line? I'd like to use a web based gui which I can use from outside the VM
hurricanehrndz 149 Posted September 30, 2016 Posted September 30, 2016 I'm using Docker on Lime tech Unraid server plus. I can't get my android to login to the server it tells me to upgrade to the latest release of Emby. Docker says it's up to date Server says to manually upgrade and restart the server. If I could, I would that's why I got the Docker. I use it to avoid this kind of thing I am limited in my understanding. Just remove the container and re-added using lime-tech webinterface, use the "my-" template it should work without issue.
Pancho 9 Posted October 3, 2016 Posted October 3, 2016 (edited) I can also confirm that I cannot update my Unraid docker Emby server from Version 3.0.7200.0 from 3.0.7300. This has happened numerous times in the past year, and when the 'Check For Updates' option did not work, I would either manually force the update or edit the docker and hit SAVE. Like the post above, nothing is working. Correct if I am wrong, removing the container and re-adding (using the 'my-template' which only saves your path/port settings) will require setting up the Emby configuration all over again (or does it use the same config if the appdata path is the same)? Edited October 3, 2016 by Pancho
hurricanehrndz 149 Posted October 3, 2016 Posted October 3, 2016 I can also confirm that I cannot update my Unraid docker Emby server from Version 3.0.7200.0 from 3.0.7300. This has happened numerous times in the past year, and when the 'Check For Updates' option did not work, I would either manually force the update or edit the docker and hit SAVE. Like the post above, nothing is working. Correct if I am wrong, removing the container and re-adding (using the 'my-template' which only saves your path/port settings) will require setting up the Emby configuration all over again (or does it use the same config if the appdata path is the same)? Yes there seems to be an issue with the last build. I will try and get build up soon. Thank you for reporting the issue. PS if you notice that it does not update after removing and adding please check the tags on docker. If you notice that it has been more than 4 hrs since the release and a new docker has not been built. Please report the issue here so that we can get things resolved. Thank you for letting us know about the issue.
hurricanehrndz 149 Posted October 3, 2016 Posted October 3, 2016 Yes there seems to be an issue with the last build. I will try and get build up soon. Thank you for reporting the issue. PS if you notice that it does not update after removing and adding please check the tags on docker. If you notice that it has been more than 4 hrs since the release and a new docker has not been built. Please report the issue here so that we can get things resolved. Thank you for letting us know about the issue. Issue confirmed. It seems like there was an error with docker's build service. Please see the build log. I will try and re-trigger a build, otherwise I will need to start looking into the hubs open bugs to try track the issue down.
