mediaGuy 8 Posted March 13, 2016 Posted March 13, 2016 Having an issue upgrading my plugin ("Update Now" doesn't do anything) and getting info on plugins from the catalog (circle keeps spinning). Error when updating: 2016-03-13 11:53:06.5821 Error HttpServer: Error processing request for /emby/Packages/Installed/Emby.Kodi%20Sync%20Queue?updateClass=Release&AssemblyGuid=undefined&version=1.0.5904.13042 *** Error Report *** Version: 3.0.5882.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /Restart.sh -restartargs Operating system: Unix 3.10.35.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /config Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 04:04:55 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Error: NameResolutionFailure ServiceStack.HttpError No Stack Trace Available Error when entering catalog: 2016-03-13 11:47:04.4335 Error InstallationManager: Error updating package cache *** Error Report *** Version: 3.0.5882.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -ffmpeg /usr/bin/ffmpeg -ffprobe /usr/bin/ffprobe -restartpath /Restart.sh -restartargs Operating system: Unix 3.10.35.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /config Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Thu Dec 3 04:04:55 UTC 2015) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Error: NameResolutionFailure MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<GetTempFileResponse>c__async7.MoveNext () <0x410625c0 + 0x016e3> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x7f638134b6d0 + 0x00029> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x7f63813496b0 + 0x000a7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x7f6381349630 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x7f63813495e0 + 0x0003a> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x7f6381349d10 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<GetTempFile>c__async6.MoveNext () <0x41061f40 + 0x00182> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x7f638134b6d0 + 0x00029> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x7f63813496b0 + 0x000a7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x7f6381349630 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x7f63813495e0 + 0x0003a> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x7f6381349d10 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.Updates.InstallationManager+<UpdateCachedPackages>c__async2.MoveNext () <0x41061180 + 0x00683> in <filename unknown>:0 InnerException: System.Net.WebException Error: NameResolutionFailure at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x40e0f9c0 + 0x001ab> in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (IAsyncResult iar, System.Func`2 endFunction, System.Action`1 endAction, System.Threading.Tasks.Task`1 promise, Boolean requiresSynchronization) <0x7f63813d84f0 + 0x00088> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x7f638134b6d0 + 0x00029> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x7f63813496b0 + 0x000a7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x7f6381349630 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x7f63813495e0 + 0x0003a> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x7f6381349d10 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<GetTempFileResponse>c__async7.MoveNext () <0x410625c0 + 0x008e6> in <filename unknown>:0
ciss 4 Posted March 16, 2016 Posted March 16, 2016 (edited) guys, sorry to ask such a noob question, but is there an easy idiot-proof tutorial to install emby on docker on synology ds716+? I'd love to use it with my devices, but installing it without docker isnt possible (braswell not supported yet). Edited March 16, 2016 by ciss
Luke 42242 Posted March 16, 2016 Author Posted March 16, 2016 guys, sorry to ask such a noob question, but is there an easy idiot-proof tutorial to install emby on docker on synology ds716+? I'd love to use it with my devices, but installing it without docker isnt possible (braswell not supported yet). If you're using docker, it should be the same as any other Docker install of Emby Server. Have you checked our Docker instructions on the website? http://emby.media/linux-server.html It also has a link to a wiki article that you might find helpful. Thanks.
ciss 4 Posted March 16, 2016 Posted March 16, 2016 (edited) Thanks, Im new to docker also, I only installed it to install emby. Here is my output: login as: factium factium@192.168.xxx's password: factium@DiskStation:~$ sudo -i root@DiskStation:~# docker run -it --rm -v /usr/local/bin:/target -e "APP_USER=factium" \ > emby/embyserver instl [s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 01-conf-onetime: executing... [cont-init.d] 01-conf-onetime: exited 0. [cont-init.d] 02-user-onetime: executing... [cont-init.d] 02-user-onetime: exited 0. [cont-init.d] done. [services.d] starting services [services.d] done. Installing emby-server... Updating user to factium... instl exited 0 [cont-finish.d] executing container finish scripts... [cont-finish.d] done. [s6-finish] syncing disks. [s6-finish] sending all processes the TERM signal. [s6-finish] sending all processes the KILL signal and exiting. root@DiskStation:~# /usr/local/bin/emby-server /usr/local/bin/emby-server: line 14: getent: command not found /usr/local/bin/emby-server: line 15: getent: command not found Cleaning up stopped emby-server instances... /usr/local/bin/emby-server: line 36: docker: command not found We could not find existing settings for your media files. Pleae enter the parent directories of your media files, one entry per line. Enter "done" when finished /volume1/MOVIES/films /volume1/MOVIES/shows done Starting emby-server... /usr/local/bin/emby-server: line 130: docker: command not found root@DiskStation:~# /usr/local/bin/emby-server /usr/local/bin/emby-server: line 14: getent: command not found /usr/local/bin/emby-server: line 15: getent: command not found Cleaning up stopped emby-server instances... /usr/local/bin/emby-server: line 36: docker: command not found Starting emby-server... /usr/local/bin/emby-server: line 130: docker: command not found root@DiskStation:~# factium is administrator Some other questions, please bear with me - do I have to run the image container wizzard in docker before or after I run these commands? - how do I map folders exactly in "Volume" tab Add file / folder "/volume1/docker/emby/config" and corresponding Map path "/config" "/volume1/MOVIES" Map path "/media" is this correct? - third tab "Environment" from what I read on docker, how do I find which user uses which - APP_UID=? -e APP_GID=? Many thanks!! Thanks for your guidance! Edited March 16, 2016 by ciss
Bushy82 4 Posted March 17, 2016 Posted March 17, 2016 Hi ciss, I've got Emby running in a docker container on a Synology 415+. For me, i set it all up in the docker gui within DSM. The implemented funcitonality isn't 100%, but for downloading and installing the container and getting it up and running, it works. Updating required using SSH to get a cli for docker, but that's a challenge for future-ciss. See this post for my container settings. Adding the Auto_update variable does nothing. All the volumes you create for docker to use, and the media folders need to have permissions set up within DSM. Happy to help if you've got any other specific questions.
ciss 4 Posted March 17, 2016 Posted March 17, 2016 (edited) Thank you @@bushy I've uninstalled docker, reinstalled, I've done this exactly oer your screenshot, still when I launch shortcut "http://192.168.1.151:8096/?launchParam=data%3D%255Bobject%2520Object%255D" It says "This site can’t be reached 192.168.1.151 refused to connect." I allowed ports in firewall. Could you Export your container settings maybe and help a noob out? I tried embyserver:latest and embyserver:beta, still no dice. Edited March 17, 2016 by ciss
ciss 4 Posted March 17, 2016 Posted March 17, 2016 (edited) here is my log, I got these errors: Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe Cannot find the specified file Warn, Connect, Cannot update Emby Connect information without a WanApiAddress Info, SsdpHandler, MultiCast socket created Error launching url: Cannot find the specified file Cannot find the specified file Error, App, Error launching url: http://localhost:8096/web/wizardstart.html Info, App, Loading MediaBrowser.XbmcMetadata, Version=3.0.5882.0, Culture=neutral, PublicKeyToken=null stdout 09:46:15 Info, App, Loading MediaBrowser.IsoMounting.Linux, Version=1.0.5131.24779, Culture=neutral, PublicKeyToken=null stdout 09:46:15 Info, App, Loading MediaBrowser.Server.Mono, Version=3.0.5882.0, Culture=neutral, PublicKeyToken=null stdout 09:46:15 Info, App, Loading MediaBrowser.Server.Startup.Common, Version=3.0.5882.0, Culture=neutral, PublicKeyToken=null stdout 09:46:16 Info, SqliteUserRepository, Sqlite 3.10.2 opening /config/data/users.db stdout 09:46:16 Info, SqliteFileOrganizationRepository, Sqlite 3.10.2 opening /config/data/fileorganization.db stdout 09:46:16 Info, AuthenticationRepository, Sqlite 3.10.2 opening /config/data/authentication.db stdout 09:46:17 Info, SyncRepository, Sqlite 3.10.2 opening /config/data/sync14.db stdout 09:46:17 Info, ImageMagick, ImageMagick version: ImageMagick 6.9.2-8 Q8 x86_64 2016-02-12 http://www.imagemagick.org stdout 09:46:17 Info, ImageProcessor, ImageProcessor started with 4 max concurrent image processes stdout 09:46:17 Info, App, FFMpeg: /bin/ffmpeg stdout 09:46:17 Info, App, FFProbe: /bin/ffprobe stdout 09:46:17 Info, SharingRepository, Sqlite 3.10.2 opening /config/data/shares.db stdout 09:46:17 Info, ActivityRepository, Sqlite 3.10.2 opening /config/data/activitylog.db stdout 09:46:17 Info, SqliteDisplayPreferencesRepository, Sqlite 3.10.2 opening /config/data/displaypreferences.db stdout 09:46:18 Info, SqliteItemRepository, Sqlite 3.10.2 opening /config/data/library.db stdout 09:46:18 Info, SqliteProviderInfoRepository, Sqlite 3.10.2 opening /config/data/refreshinfo.db stdout 09:46:18 Info, SqliteUserDataRepository, Sqlite 3.10.2 opening /config/data/userdata_v2.db stdout 09:46:18 Info, SqliteNotificationsRepository, Sqlite 3.10.2 opening /config/data/notifications.db stdout 09:46:18 Info, App, Requesting administrative access to authorize http server stdout 09:46:19 Warn, Connect, Cannot update Emby Connect information without a WanApiAddress stdout 09:46:19 Info, HttpServer, Calling ServiceStack AppHost.Init stdout 09:46:29 Info, ServiceStackHost, Initializing Application took 12061.31ms stdout 09:46:30 Info, ServerManager, Loading Http Server stdout 09:46:30 Info, HttpServer, attempting to load pfx: /config/ssl/cert_9c31b7884ea5475c8687970fc5996297.pfx stdout 09:46:30 Info, HttpServer, Adding HttpListener prefix http://+:8096/ stdout 09:46:30 Info, HttpServer, Adding HttpListener prefix https://+:8920/ stdout 09:46:31 Running startup tasks stdout 09:46:31 Info, App, ServerId: a4aaa37f1bf741c8a644c9aab4a94d67 stdout 09:46:31 Info, App, Core startup complete stdout 09:46:31 Warn, Connect, Cannot update Emby Connect information without a WanApiAddress stdout 09:46:31 Warn, Connect, Cannot update Emby Connect information without a WanApiAddress stdout 09:46:32 Info, SsdpHandler, MultiCast socket created stdout 09:46:32 Error launching url: Cannot find the specified file stdout 09:46:32 Cannot find the specified file stdout 09:46:32 Error, App, Error launching url: http://localhost:8096/web/wizardstart.html stdout 09:46:32 *** Error Report *** stdout 09:46:32 Version: 3.0.5882.0 stdout 09:46:32 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh stdout 09:46:32 Operating system: Unix 3.10.77.0 stdout 09:46:32 Processor count: 4 stdout 09:46:32 64-Bit OS: True stdout 09:46:32 64-Bit Process: True stdout 09:46:32 Program data path: /config stdout 09:46:32 Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Tue Jan 19 01:36:09 UTC 2016) stdout 09:46:32 Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe stdout 09:46:32 Cannot find the specified file stdout 09:46:32 System.ComponentModel.Win32Exception stdout 09:46:32 at System.Diagnostics.Process.Start_shell (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) <0x4146c780 + 0x002ab> in <filename unknown>:0 stdout 09:46:32 at System.Diagnostics.Process.Start_common (System.Diagnostics.ProcessStartInfo startInfo, System.Diagnostics.Process process) <0x4129b320 + 0x000a3> in <filename unknown>:0 stdout 09:46:32 at System.Diagnostics.Process.Start () <0x4129b2b0 + 0x00047> in <filename unknown>:0 stdout 09:46:32 at (wrapper remoting-invoke-with-check) System.Diagnostics.Process:Start () stdout 09:46:32 at MediaBrowser.Server.Startup.Common.Browser.BrowserLauncher.OpenUrl (System.String url, ILogger logger) <0x4146bad0 + 0x0015b> in <filename unknown>:0 stdout 09:46:32 stdout 09:46:32 Info, IDeviceDiscovery, Creating SSDP listener on 172.17.0.2 stdout 09:46:32 Info, IDeviceDiscovery, Creating SSDP listener on 127.0.0.1 stdout 09:46:57 stdout 09:46:57 Session terminated, killing shell...[cont-finish.d] executing container finish scripts... stdout 09:46:57 [cont-finish.d] done. stdout 09:46:57 [s6-finish] syncing disks. stdout 09:46:57 [s6-finish] sending all processes the TERM signal. stdout 09:46:57 ...killed. stdout 09:47:00 [s6-finish] sending all processes the KILL signal and exiting Edited March 17, 2016 by ciss
Bushy82 4 Posted March 17, 2016 Posted March 17, 2016 what port do you have mapped to 8096 in the container? 1
ciss 4 Posted March 17, 2016 Posted March 17, 2016 Doh!!! Thanks! I had the ports on auto! Now I re-mapped them and I'm in the interface!! I'll let you know my progress.
Bushy82 4 Posted March 17, 2016 Posted March 17, 2016 Nice one! Once i got to there, the next challenge was getting it to read/write to the volumes, including the config volume. Check your permissions in DSM - you need to allow the local user group read write access to the mapped folders.
ciss 4 Posted March 17, 2016 Posted March 17, 2016 (edited) yes, well, it seems there is no user "appuser" nor a group containing it on my syno. do I have to create it? Or is there a set of commands I could use with putty? Thanks again, much appreciate your help!! Edited March 17, 2016 by ciss
Bushy82 4 Posted March 17, 2016 Posted March 17, 2016 I didn't create any specific users, but i wasn't particularly concerned with security. My NAS and Emby are not exposed to the internet, and i trust my local wifi.Having said that, in DSM, go to control panel>Shared Folder. Find your embyconfig folder click edit, then choose permissions and then use the drop down to get to local groups (as opposed to local users). My understanding, and i could be wrong but it does seem to work, is that docker runs as a local user, so you need to grant the 'users' group under local users read/write permissions to the config folder, as well as to the media folders (if you want emby to update artwork and nfos and such. Hope that helps. 1
ciss 4 Posted March 17, 2016 Posted March 17, 2016 (edited) Thanks it helps, but that gives all users access to my media folder, which is not an option for me. What I noticed, the folder "docker" has write/read access already, I need to figure out what is the user name which uses emby, to give that particular one access to my media. According to this link I need to figure out this "I found the Synology group that had access to this volume (not users as reported above) and set the GID of that group to APP_GID and Emby in the container is now able to view the contents of the directories." I used winscp and navigated to passwd and group files, but I dont see any "appuser" on that list. Better yet, is there a putty command to change the default user to one I choose myself? For example, I have an user "apps" which handles all my media apps' permissions: sonarr, couchpotato, headphones, nzbdrone, jackett etc. Can I use this user? If yes, what would be the command to change emby user to "apps". Bushy, you have been most helpful, thank you once again. LE: I'm a poor windows guy, first time using putty and the like LE2: from group file, what seems new are the following groups: avahi:x:84: bind:x:53: daemon:x:2:daemon,root dbus:x:81: dovecot:x:143:dovecot http:x:1023: log:x:19:root lp:x:7:lp ntp:x:87: rpc:x:32: smmsp:x:25: wheel:x:10:admin Any hints? Edited March 17, 2016 by ciss
ciss 4 Posted March 17, 2016 Posted March 17, 2016 (edited) Solved it! Many thanks to corey and bushy! This is how I solved my permission problem. =============== I think I can help then. The first step is to figure out which group on your Synology has write access to your media folders. After that SSH into your Synology and run a command like follows replacing "home" with your group name: ds716nas> cat /etc/group | grep home home:x:65536:familypc,mediaserver,coreyrmbp The value in the output above, 65536, is the GID. Set that to the APP_GID parameter and you should be able to read/write from these shares now. I hope this helps! Edited March 17, 2016 by ciss
Cobra 6 Posted March 21, 2016 Posted March 21, 2016 (edited) I am having similar struggles with permissions with the official emby docker running on unraid. Not sure if anyone else here is using a docker with unraid but I would be interested in their feedback if so. Everything is working great overall with the exception of QuickSync transcoding inside of a docker. I have my video share passed to the docker container and emby writes recordings here without a problem. I have tried changing share type from private to public and has not made a difference for this. When I browse to the emby Recordings in Windows and click on the security tab to see the file permissions I see the following users/permissions. Everyone - allow read only nobody (Unix User\nobody) - allow read and write users (Unix Group\users) allow read However, when I look at the permissions of one of the folders inside Series that get created for a recording the above users are also created but no security is assigned to the folder. My goal is to use mcebuddy to remove commercials and delete the original file but the delete portion seems to be a problem even if I use a public share. I am using the default docker config of APP_UID 99 and APP_GID 100 on the container. Is there something I am missing to give unraid host permissions to delete files? emby can delete the recording files fine but it will still leave the empty series folders. I am unable to delete the series files or folders through windows. My non-emby files on this share have the same users but have read/write access. As expected I cannot change permissions through windows. Edited March 21, 2016 by Cobra
hurricanehrndz 149 Posted March 22, 2016 Posted March 22, 2016 This is not a docker setting, I believe this has to do with how your shares are setup. It might be best to ask for help in lime-techs forums. I will try and help you the best I can but no promises. What is the uid and gid ownership of the folders your are trying to delete?
Cobra 6 Posted March 22, 2016 Posted March 22, 2016 This is not a docker setting, I believe this has to do with how your shares are setup. It might be best to ask for help in lime-techs forums. I will try and help you the best I can but no promises. What is the uid and gid ownership of the folders your are trying to delete? Thank you for offering to help but I am happy to report the problem is solved, you were right it was permission related. I had created a new unraid user and have my share setup as a private share. By default the docker container has APP_UID default value of 99. As you suggested I looked a permissions on the unraid host and found my user account had UID of 1000. I simply changed the docker config value for APP_UID to 1000 and left the default APP_GID as 100 and that was all that was needed. I now see the added unraid user on the files/folders with read/write access that was not there before. All is working great now. Thanks for pointing me in the right direction, much appreciated.
vigilian 1 Posted March 31, 2016 Posted March 31, 2016 if I do a symlink in a folder to access another one which is not in the volume I specified at installation, is it able to access it? because to me it doesn't seem to... How do I add volumes definitely ? I mean without rerun installation or without the docer run command? since we have to run it by the command emby-server now
hurricanehrndz 149 Posted March 31, 2016 Posted March 31, 2016 if I do a symlink in a folder to access another one which is not in the volume I specified at installation, is it able to access it? because to me it doesn't seem to... How do I add volumes definitely ? I mean without rerun installation or without the docer run command? since we have to run it by the command emby-server now Please edit the following file: ~/.emby-server/.embydockervolumes Follow the existing format. Symlinks will not work in order to add new volumes to the container.
vigilian 1 Posted March 31, 2016 Posted March 31, 2016 Please edit the following file: ~/.emby-server/.embydockervolumes Follow the existing format. Symlinks will not work in order to add new volumes to the container. don't find it it's /home/user/.emby-server? because I do'nt find it? or Should I resintall it completely?
hurricanehrndz 149 Posted March 31, 2016 Posted March 31, 2016 Well did you place the appconfig somewhere else, also the permissions might be set to root so please run an ls as root Sent from my D6603 using Tapatalk
ciss 4 Posted March 31, 2016 Posted March 31, 2016 Hey guys, I'm running emby on my docker on syno 716+, no problems until today (or maybe yesterday). I can see the movies, no problem, but there are some errors now: - app itself and trakt.tv failed to update. Sync library to trakt.tv failed. a minute ago Error: NameResolutionFailure Check for application updates failed. a minute ago One or more errors occurred. - some tv shows imported from sonarr dont have metadata. What could cause this? Where can I read logs? I enabled debug log, but I dont know where to look. Any suggestions? Thanks!
ciss 4 Posted March 31, 2016 Posted March 31, 2016 Found the log. Can you spot anything? Thanks. 2016-03-31 19:45:15.8161 Error TaskManager: Error *** Error Report *** Version: 3.0.5882.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.10.77.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /config Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Tue Jan 19 01:36:09 UTC 2016) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe One or more errors occurred. MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x41e5d360 + 0x0175b> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () <0x41e571d0 + 0x006eb> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<Get>c__async0.MoveNext () <0x41ebbd50 + 0x0015f> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.Updates.GithubUpdater+<CheckForUpdateResult>c__async0.MoveNext () <0x41f60270 + 0x003e3> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.ApplicationHost+<CheckForApplicationUpdate>c__asyncF.MoveNext () <0x41f5f430 + 0x0037f> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Server.Implementations.ScheduledTasks.SystemUpdateTask+<Execute>c__async0.MoveNext () <0x41f5db40 + 0x00473> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () <0x41c16370 + 0x00013> in <filename unknown>:0 at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker+<ExecuteInternal>c__async2.MoveNext () <0x41f42920 + 0x0077b> in <filename unknown>:0 InnerException: System.AggregateException One or more errors occurred. at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x41e5d360 + 0x00fab> in <filename unknown>:0 InnerException: System.Net.WebException Aborted. at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x41f001c0 + 0x0019f> in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (IAsyncResult iar, System.Func`2 endFunction, System.Action`1 endAction, System.Threading.Tasks.Task`1 promise, Boolean requiresSynchronization) <0x41effa90 + 0x00093> in <filename unknown>:0 2016-03-31 19:45:15.8161 Info TaskManager: Check for application updates Failed after 0 minute(s) and 20 seconds 2016-03-31 19:45:15.8551 Debug NotificationManager: Sending notification via Dashboard Notifications to user appuser 2016-03-31 19:45:15.8551 Info ServerManager: Sending web socket message NotificationAdded 2016-03-31 19:45:15.8560 Info ServerManager: Sending web socket message ScheduledTaskEnded 2016-03-31 19:45:15.8560 Info TaskManager: ExecuteQueuedTasks 2016-03-31 19:45:16.0817 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/Notifications/ebe5c8d7440d44f79635f008043a8a3e/Summary. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:16.0868 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 5ms. http://me.factium.com:51940/emby/Notifications/ebe5c8d7440d44f79635f008043a8a3e/Summary 2016-03-31 19:45:18.0915 Info App: ScheduledTasksWebSocketListener stop transmitting over websocket to 172.17.0.1:40182 2016-03-31 19:45:18.1022 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/ScheduledTasks/7717368eb904db8e2522240726ba251a. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:18.1087 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 7ms. http://me.factium.com:51940/emby/ScheduledTasks/7717368eb904db8e2522240726ba251a 2016-03-31 19:45:20.3383 Info App: SessionInfoWebSocketListener Begin transmitting over websocket to 172.17.0.1:40182 2016-03-31 19:45:20.3383 Info App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 172.17.0.1:40182 2016-03-31 19:45:20.3438 Info App: ActivityLogWebSocketListener Begin transmitting over websocket to 172.17.0.1:40182 2016-03-31 19:45:20.3493 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3535 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3535 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 4ms. http://me.factium.com:51940/emby/Sessions 2016-03-31 19:45:20.3535 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3567 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/News/Product?StartIndex=0&Limit=7. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3580 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 4ms. http://me.factium.com:51940/emby/System/Info 2016-03-31 19:45:20.3594 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/DisplayPreferences/dashboard?userId=ebe5c8d7440d44f79635f008043a8a3e&client=dashboard. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3594 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2016-03-30T19%3A44%3A44.679Z. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3654 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 9ms. http://me.factium.com:51940/emby/News/Product?StartIndex=0&Limit=7 2016-03-31 19:45:20.3668 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 7ms. http://me.factium.com:51940/emby/DisplayPreferences/dashboard?userId=ebe5c8d7440d44f79635f008043a8a3e&client=dashboard 2016-03-31 19:45:20.3683 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 9ms. http://me.factium.com:51940/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2016-03-30T19%3A44%3A44.679Z 2016-03-31 19:45:20.3745 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 21ms. http://me.factium.com:51940/emby/ScheduledTasks 2016-03-31 19:45:20.3998 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.4032 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.4067 Info HttpClient: HttpClientManager GET: https://api.github.com/repos/MediaBrowser/Emby/releases 2016-03-31 19:45:20.5026 Info HttpClient: HttpClientManager.GetTempFileResponse url: http://www.mb3admin.com/admin/service/MB3Packages.json 2016-03-31 19:45:20.5050 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 105ms. http://me.factium.com:51940/emby/Packages/Updates?PackageType=UserInstalled
Luke 42242 Posted March 31, 2016 Author Posted March 31, 2016 Found the log. Can you spot anything? Thanks. 2016-03-31 19:45:15.8161 Error TaskManager: Error *** Error Report *** Version: 3.0.5882.0 Command line: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartpath /usr/lib/emby-server/restart.sh Operating system: Unix 3.10.77.0 Processor count: 4 64-Bit OS: True 64-Bit Process: True Program data path: /config Mono: 4.2.1 (Stable 4.2.1.102/6dd2d0d Tue Jan 19 01:36:09 UTC 2016) Application Path: /usr/lib/emby-server/bin/MediaBrowser.Server.Mono.exe One or more errors occurred. MediaBrowser.Model.Net.HttpException at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x41e5d360 + 0x0175b> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsync>c__async1.MoveNext () <0x41e571d0 + 0x006eb> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<Get>c__async0.MoveNext () <0x41ebbd50 + 0x0015f> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.Updates.GithubUpdater+<CheckForUpdateResult>c__async0.MoveNext () <0x41f60270 + 0x003e3> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Server.Startup.Common.ApplicationHost+<CheckForApplicationUpdate>c__asyncF.MoveNext () <0x41f5f430 + 0x0037f> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Server.Implementations.ScheduledTasks.SystemUpdateTask+<Execute>c__async0.MoveNext () <0x41f5db40 + 0x00473> in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () <0x41c16370 + 0x00013> in <filename unknown>:0 at MediaBrowser.Common.Implementations.ScheduledTasks.ScheduledTaskWorker+<ExecuteInternal>c__async2.MoveNext () <0x41f42920 + 0x0077b> in <filename unknown>:0 InnerException: System.AggregateException One or more errors occurred. at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () <0x41f7bba0 + 0x0002b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) <0x41f7b7a0 + 0x000c7> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) <0x41f7b710 + 0x0006b> in <filename unknown>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) <0x41c163a0 + 0x0003b> in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () <0x41c4e9a0 + 0x00017> in <filename unknown>:0 at MediaBrowser.Common.Implementations.HttpClientManager.HttpClientManager+<SendAsyncInternal>c__async4.MoveNext () <0x41e5d360 + 0x00fab> in <filename unknown>:0 InnerException: System.Net.WebException Aborted. at System.Net.HttpWebRequest.EndGetResponse (IAsyncResult asyncResult) <0x41f001c0 + 0x0019f> in <filename unknown>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (IAsyncResult iar, System.Func`2 endFunction, System.Action`1 endAction, System.Threading.Tasks.Task`1 promise, Boolean requiresSynchronization) <0x41effa90 + 0x00093> in <filename unknown>:0 2016-03-31 19:45:15.8161 Info TaskManager: Check for application updates Failed after 0 minute(s) and 20 seconds 2016-03-31 19:45:15.8551 Debug NotificationManager: Sending notification via Dashboard Notifications to user appuser 2016-03-31 19:45:15.8551 Info ServerManager: Sending web socket message NotificationAdded 2016-03-31 19:45:15.8560 Info ServerManager: Sending web socket message ScheduledTaskEnded 2016-03-31 19:45:15.8560 Info TaskManager: ExecuteQueuedTasks 2016-03-31 19:45:16.0817 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/Notifications/ebe5c8d7440d44f79635f008043a8a3e/Summary. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:16.0868 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 5ms. http://me.factium.com:51940/emby/Notifications/ebe5c8d7440d44f79635f008043a8a3e/Summary 2016-03-31 19:45:18.0915 Info App: ScheduledTasksWebSocketListener stop transmitting over websocket to 172.17.0.1:40182 2016-03-31 19:45:18.1022 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/ScheduledTasks/7717368eb904db8e2522240726ba251a. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:18.1087 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 7ms. http://me.factium.com:51940/emby/ScheduledTasks/7717368eb904db8e2522240726ba251a 2016-03-31 19:45:20.3383 Info App: SessionInfoWebSocketListener Begin transmitting over websocket to 172.17.0.1:40182 2016-03-31 19:45:20.3383 Info App: ScheduledTasksWebSocketListener Begin transmitting over websocket to 172.17.0.1:40182 2016-03-31 19:45:20.3438 Info App: ActivityLogWebSocketListener Begin transmitting over websocket to 172.17.0.1:40182 2016-03-31 19:45:20.3493 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3535 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3535 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 4ms. http://me.factium.com:51940/emby/Sessions 2016-03-31 19:45:20.3535 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3567 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/News/Product?StartIndex=0&Limit=7. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3580 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 4ms. http://me.factium.com:51940/emby/System/Info 2016-03-31 19:45:20.3594 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/DisplayPreferences/dashboard?userId=ebe5c8d7440d44f79635f008043a8a3e&client=dashboard. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3594 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2016-03-30T19%3A44%3A44.679Z. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.3654 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 9ms. http://me.factium.com:51940/emby/News/Product?StartIndex=0&Limit=7 2016-03-31 19:45:20.3668 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 7ms. http://me.factium.com:51940/emby/DisplayPreferences/dashboard?userId=ebe5c8d7440d44f79635f008043a8a3e&client=dashboard 2016-03-31 19:45:20.3683 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 9ms. http://me.factium.com:51940/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2016-03-30T19%3A44%3A44.679Z 2016-03-31 19:45:20.3745 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 21ms. http://me.factium.com:51940/emby/ScheduledTasks 2016-03-31 19:45:20.3998 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.4032 Info HttpServer: HTTP GET http://me.factium.com:51940/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/50.0.2661.49 Safari/537.36 2016-03-31 19:45:20.4067 Info HttpClient: HttpClientManager GET: https://api.github.com/repos/MediaBrowser/Emby/releases 2016-03-31 19:45:20.5026 Info HttpClient: HttpClientManager.GetTempFileResponse url: http://www.mb3admin.com/admin/service/MB3Packages.json 2016-03-31 19:45:20.5050 Info HttpServer: HTTP Response 200 to 172.17.0.1. Time: 105ms. http://me.factium.com:51940/emby/Packages/Updates?PackageType=UserInstalled First I would update to the latest version of Emby Server. Then try again, and if the issue persists please provide the complete log file. Thanks!
