Luke 42241 Posted August 19, 2014 Posted August 19, 2014 Installation Instructions See http://emby.media/download 2
two wire 2 Posted August 26, 2014 Posted August 26, 2014 I 'm using unRaid as my media server. and there is an unRaid forum explaining haw to install Docker. After I have installed Docker according to their instructins, will I be able to instal MB3 server on my unRaid server? Thanks
chuga 4 Posted August 27, 2014 Posted August 27, 2014 I believe there are two people working on mb3 docker....phaze (check unraid plugin design forum) and stevend in unraid docker forum. Good luck, I'm going to try it soon myself Chuga
airbillion 2 Posted August 27, 2014 Posted August 27, 2014 How do you run MB3? I followed the directions here: Running MediaBrowser Server: https://registry.hub...owser/mbserver/ But it does not run. Thanks!
Babin 0 Posted August 27, 2014 Posted August 27, 2014 How do you run MB3? I followed the directions here: Running MediaBrowser Server: https://registry.hub...owser/mbserver/ But it does not run. Thanks! I got the same problem here. I followed the instruction and nothing worked.
jseeman 0 Posted August 28, 2014 Posted August 28, 2014 I am able to get MB3 running in a docker container on my unraid system using the mediabrowser/mbserver container. It is working for Movies and TV. But crashes when I try to install the GameBrower 3 plugin: Below is the error in the docker start up log: Info, SqliteProviderInfoRepository, Opening /MBServer/ProgramData-Server/data/refreshinfo.dbMissing method .ctor in assembly data-0x2ab1f6e08010, type System.Windows.ThemeInfoAttributeCan't find custom attr constructor image: data-0x2ab1f6e08010 mtoken: 0x0a00000c* Assertion at class.c:5597, condition `!mono_loader_get_last_error ()' not metStacktrace:at <0xffffffff>at DynamicInstanceProducer12.GetInstance (object[]) <0x004cf>at SimpleInjector.CompilationHelpers/<>c__DisplayClass1b`1.b__1a () <0x00022>at SimpleInjector.InstanceProducer.GetInstance () <0x000a0>at SimpleInjector.Container.GetInstanceFromProducer (SimpleInjector.InstanceProducer,System.Type) <0x00037>at SimpleInjector.Container.GetInstanceForType (System.Type) <0x0002f>at SimpleInjector.Container.GetInstance (System.Type) <0x00057>at MediaBrowser.Common.Implementations.BaseApplicationHost`1.CreateInstanceSafe (System.Type) <0x0003b>at System.Linq.Enumerable/c__Iterator10`2.MoveNext () <0x0017c>at System.Linq.Enumerable/c__Iterator1E`1.MoveNext () <0x0020f>at System.Linq.Enumerable/c__Iterator0`1.MoveNext () <0x00234>at System.Collections.Generic.List`1.AddEnumerable (System.Collections.Generic.IEnumerable`1) <0x0008a>at System.Collections.Generic.List`1..ctor (System.Collections.Generic.IEnumerable`1) <0x000c7>at System.Linq.Enumerable.ToList (System.Collections.Generic.IEnumerable`1) <0x0003b>at MediaBrowser.Common.Implementations.BaseApplicationHost`1.GetExports (bool) <0x001df>at MediaBrowser.Common.Implementations.BaseApplicationHost`1.FindParts () <0x00087>at MediaBrowser.ServerApplication.ApplicationHost.FindParts () <0x0002f>at MediaBrowser.Common.Implementations.BaseApplicationHost`1/c__async0.MoveNext () <0x0088a>at (wrapper unbox) MediaBrowser.Common.Implementations.BaseApplicationHost`1/c__async0.MoveNext () <0xffffffff>at System.Threading.Tasks.AwaiterActionContinuation.Execute () <0x0007e>at System.Threading.Tasks.Task.ProcessCompleteDelegates () <0x00053>at System.Threading.Tasks.Task.Finish () <0x00157>at System.Threading.Tasks.Task`1.TrySetResult (TResult) <0x000eb>at System.Runtime.CompilerServices.AsyncTaskMethodBuilder.SetResult () <0x0001b>at MediaBrowser.ServerApplication.ApplicationHost/c__async2.MoveNext () <0x064e3>at (wrapper unbox) MediaBrowser.ServerApplication.ApplicationHost/c__async2.MoveNext () <0xffffffff>at System.Threading.Tasks.AwaiterActionContinuation.Execute () <0x0007e>at System.Threading.Tasks.Task.ProcessCompleteDelegates () <0x00053>at System.Threading.Tasks.Task.Finish () <0x00157>at System.Threading.Tasks.WhenAllContinuation.Execute () <0x00237>at System.Threading.Tasks.Task.ProcessCompleteDelegates () <0x00053>at System.Threading.Tasks.Task.Finish () <0x00157>at System.Threading.Tasks.Task`1.TrySetResult (TResult) <0x000eb>at System.Threading.Tasks.TaskCompletionSource`1.TrySetResult (TResult) <0x00047>at System.Threading.Tasks.TaskCompletionSource`1.SetResult (TResult) <0x0001b>at System.Threading.Tasks.TaskExtensionsImpl.SetResult (System.Threading.Tasks.Task,System.Threading.Tasks.TaskCompletionSource`1) <0x0009b>at System.Threading.Tasks.TaskExtensionsImpl.m__2 (System.Threading.Tasks.Task,object) <0x0004f>at System.Threading.Tasks.TaskActionInvoker/ActionTaskObjectInvoke.Invoke (System.Threading.Tasks.Task,object,System.Threading.Tasks.Task) <0x0002e>at System.Threading.Tasks.Task.InnerInvoke () <0x00050>at System.Threading.Tasks.Task.ThreadStart () <0x0028b>at System.Threading.Tasks.Task.Execute () <0x00013>at System.Threading.Tasks.TaskScheduler.TryExecuteTask (System.Threading.Tasks.Task) <0x00057>at System.Threading.Tasks.TpScheduler.TryExecuteTaskInline (System.Threading.Tasks.Task,bool) <0x00043>at System.Threading.Tasks.TaskScheduler.RunInline (System.Threading.Tasks.Task,bool) <0x00029>at System.Threading.Tasks.Task.RunSynchronouslyCore (System.Threading.Tasks.TaskScheduler) <0x00097>at System.Threading.Tasks.TaskContinuation.Execute () <0x00097>at System.Threading.Tasks.Task.ContinueWith (System.Threading.Tasks.IContinuation,bool) <0x00055>at System.Threading.Tasks.Task.ContinueWithCore (System.Threading.Tasks.Task,System.Threading.Tasks.TaskContinuationOptions,System.Threading.Tasks.TaskScheduler) <0x000d7>at System.Threading.Tasks.Task.ContinueWith (System.Action`2,object,System.Threading.CancellationToken,System.Threading.Tasks.TaskContinuationOptions,System.Threading.Tasks.TaskScheduler) <0x000fb>at System.Threading.Tasks.TaskExtensionsImpl.Cont (System.Threading.Tasks.Task`1,System.Threading.Tasks.TaskCompletionSource`1) <0x0017b>at System.Threading.Tasks.TaskExtensionsImpl.m__1 (System.Threading.Tasks.Task`1,object) <0x0004f>at System.Threading.Tasks.TaskActionInvoker/ActionTaskObjectInvoke`1.Invoke (System.Threading.Tasks.Task,object,System.Threading.Tasks.Task) <0x00057>at System.Threading.Tasks.Task.InnerInvoke () <0x00050>at System.Threading.Tasks.Task.ThreadStart () <0x0028b>at System.Threading.Tasks.Task.Execute () <0x00013>at System.Threading.Tasks.TaskScheduler.TryExecuteTask (System.Threading.Tasks.Task) <0x00057>at System.Threading.Tasks.TpScheduler.TryExecuteTaskInline (System.Threading.Tasks.Task,bool) <0x00043>at System.Threading.Tasks.TaskScheduler.RunInline (System.Threading.Tasks.Task,bool) <0x00029>at System.Threading.Tasks.Task.RunSynchronouslyCore (System.Threading.Tasks.TaskScheduler) <0x00097>at System.Threading.Tasks.TaskContinuation.Execute () <0x00097>at System.Threading.Tasks.Task.ProcessCompleteDelegates () <0x00053>at System.Threading.Tasks.Task.Finish () <0x00157>at System.Threading.Tasks.Task.ThreadStart () <0x00623>at System.Threading.Tasks.Task.Execute () <0x00013>at System.Threading.Tasks.TpScheduler.TaskExecuterCallback (object) <0x00047>at (wrapper runtime-invoke) .runtime_invoke_void__this___object (object,intptr,intptr,intptr) <0xffffffff>Native stacktrace:mono() [0x4b73d8]/lib/x86_64-linux-gnu/libpthread.so.0(+0x10340) [0x2ab1f2e25340]/lib/x86_64-linux-gnu/libc.so.6(gsignal+0x39) [0x2ab1f3069f89]/lib/x86_64-linux-gnu/libc.so.6(abort+0x148) [0x2ab1f306d398]mono() [0x638575]mono() [0x6386b6]mono() [0x5298e6]mono(mono_class_get_full+0xe2) [0x52a0c2]mono(mono_class_from_name+0xfe) [0x52a4ae]mono(mono_class_from_typeref+0x190) [0x529d00]mono() [0x54c44d]mono() [0x54c54d]mono(mono_get_method_full+0x9d) [0x54ca7d]mono() [0x464b9c]mono() [0x421e2e]mono() [0x4253cd]mono() [0x425ecb]mono() [0x4b845b][0x40b0a166]Debug info from gdb:=================================================================Got a SIGABRT while executing native code. This usually indicatesa fatal error in the mono runtime or one of the native librariesused by your application.=================================================================Aborted (core dumped),> The command finished successfully! Once I delete GameBrowser.dll from the plugins directory MB3 starts again with out issue. Any ideas on what is causing this error? Thanks
Luke 42241 Posted August 29, 2014 Author Posted August 29, 2014 @@Redshirt - i pushed a fix to the GB repo. Please publish when you have a chance. Thanks.
LeftForPlex 8 Posted August 29, 2014 Posted August 29, 2014 Same issue here, Gamebrowser installed breaks it for me as well. I also cannot seem to browse network shares to add media?
LeftForPlex 8 Posted August 29, 2014 Posted August 29, 2014 (edited) So I have gotten it to run, but it appears my media scan always stops at 51.8%. Sometimes the container quits running as well. Is the server log the best log to look at for this? I did see this in Syslog: Aug 29 09:33:53 Tower kernel: active_anon:203416 inactive_anon:18646 isolated_anon:0 Aug 29 09:33:53 Tower kernel: active_file:239 inactive_file:139 isolated_file:0 Aug 29 09:33:53 Tower kernel: unevictable:9 dirty:20 writeback:0 unstable:0 Aug 29 09:33:53 Tower kernel: free:73697 slab_reclaimable:33729 slab_unreclaimable:10907 Aug 29 09:33:53 Tower kernel: mapped:12460 shmem:111331 pagetables:1580 bounce:0 Aug 29 09:33:53 Tower kernel: free_cma:0 Aug 29 09:33:53 Tower kernel: Node 0 DMA free:6268kB min:48kB low:60kB high:72kB active_anon:1844kB inactive_anon:960kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15984kB managed:15900kB mlocked:0kB dirty:0kB writeback:0kB mapped:20kB shmem:1532kB slab_reclaimable:4944kB slab_unreclaimable:664kB kernel_stack:240kB pagetables:24kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes Aug 29 09:33:53 Tower kernel: lowmem_reserve[]: 0 1554 1554 1554 Aug 29 09:33:53 Tower kernel: Node 0 DMA32 free:288520kB min:5016kB low:6268kB high:7524kB active_anon:811820kB inactive_anon:73624kB active_file:964kB inactive_file:616kB unevictable:36kB isolated(anon):0kB isolated(file):0kB present:2271024kB managed:1592692kB mlocked:36kB dirty:80kB writeback:0kB mapped:49820kB shmem:443792kB slab_reclaimable:129972kB slab_unreclaimable:42964kB kernel_stack:4528kB pagetables:6296kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:2403 all_unreclaimable? yes Aug 29 09:33:53 Tower kernel: lowmem_reserve[]: 0 0 0 0 Aug 29 09:33:53 Tower kernel: Node 0 Normal free:0kB min:0kB low:0kB high:0kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:20837460kB managed:1036kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes Aug 29 09:33:53 Tower kernel: lowmem_reserve[]: 0 0 0 0 Aug 29 09:33:53 Tower kernel: Node 0 DMA: 13*4kB (EM) 37*8kB (UEM) 44*16kB (EM) 23*32kB (UEM) 6*64kB (UEM) 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 1*4096kB ® = 6268kB Aug 29 09:33:53 Tower kernel: Node 0 DMA32: 37324*4kB (UEM) 17336*8kB (UER) 30*16kB (ER) 17*32kB ® 3*64kB ® 0*128kB 1*256kB ® 0*512kB 0*1024kB 0*2048kB 0*4096kB = 289456kB Aug 29 09:33:53 Tower kernel: Node 0 Normal: 0*4kB 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 0kB Aug 29 09:33:53 Tower kernel: 111700 total pagecache pages Aug 29 09:33:53 Tower kernel: 0 pages in swap cache Aug 29 09:33:53 Tower kernel: Swap cache stats: add 0, delete 0, find 0/0 Aug 29 09:33:53 Tower kernel: Free swap = 0kB Aug 29 09:33:53 Tower kernel: Total swap = 0kB Aug 29 09:33:53 Tower kernel: 5781117 pages RAM Aug 29 09:33:53 Tower kernel: 0 pages HighMem/MovableOnly Aug 29 09:33:53 Tower kernel: 5209106 pages reserved Aug 29 09:33:53 Tower kernel: [ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name Aug 29 09:33:53 Tower kernel: [ 1065] 0 1065 5401 612 15 0 -1000 udevd Aug 29 09:33:53 Tower kernel: [ 1293] 0 1293 1700 492 8 0 0 syslogd Aug 29 09:33:53 Tower kernel: [ 1297] 0 1297 1092 309 7 0 0 klogd Aug 29 09:33:53 Tower kernel: [ 1544] 1 1544 1855 397 7 0 0 rpc.portmap Aug 29 09:33:53 Tower kernel: [ 1548] 32 1548 3208 459 11 0 0 rpc.statd Aug 29 09:33:53 Tower kernel: [ 1558] 0 1558 1614 432 8 0 0 inetd Aug 29 09:33:53 Tower kernel: [ 1568] 0 1568 6231 805 15 0 -1000 sshd Aug 29 09:33:53 Tower kernel: [ 1575] 0 1575 48116 2567 96 0 0 ntpd Aug 29 09:33:53 Tower kernel: [ 1585] 0 1585 1095 384 6 0 0 acpid Aug 29 09:33:53 Tower kernel: [ 1597] 81 1597 4358 51 13 0 0 dbus-daemon Aug 29 09:33:53 Tower kernel: [ 1606] 0 1606 1616 407 8 0 0 crond Aug 29 09:33:53 Tower kernel: [ 1608] 0 1608 1614 25 8 0 0 atd Aug 29 09:33:53 Tower kernel: [ 1649] 0 1649 2782 591 10 0 0 xenstored Aug 29 09:33:53 Tower kernel: [ 1656] 0 1656 21167 475 15 0 0 xenconsoled Aug 29 09:33:53 Tower kernel: [ 1660] 0 1660 42170 1735 49 0 0 qemu-system-x86 Aug 29 09:33:53 Tower kernel: [ 1676] 0 1676 51920 2947 71 0 0 libvirtd Aug 29 09:33:53 Tower kernel: [ 7517] 0 7517 22264 875 17 0 0 emhttp Aug 29 09:33:53 Tower kernel: [ 7523] 0 7523 1617 436 8 0 0 agetty Aug 29 09:33:53 Tower kernel: [ 7524] 0 7524 1617 436 8 0 0 agetty Aug 29 09:33:53 Tower kernel: [ 7525] 0 7525 1617 433 8 0 0 agetty Aug 29 09:33:53 Tower kernel: [ 7526] 0 7526 1617 409 8 0 0 agetty Aug 29 09:33:53 Tower kernel: [ 7527] 0 7527 1617 436 8 0 0 agetty Aug 29 09:33:53 Tower kernel: [ 7528] 0 7528 1617 430 8 0 0 agetty Aug 29 09:33:53 Tower kernel: [ 3491] 0 3491 49063 1195 94 0 0 nmbd Aug 29 09:33:53 Tower kernel: [ 3493] 0 3493 68448 3552 128 0 0 smbd Aug 29 09:33:53 Tower kernel: [ 3514] 61 3514 7577 767 19 0 0 avahi-daemon Aug 29 09:33:53 Tower kernel: [ 3522] 0 3522 3185 410 11 0 0 avahi-dnsconfd Aug 29 09:33:53 Tower kernel: [ 3754] 0 3754 38192 105 16 0 0 shfs Aug 29 09:33:53 Tower kernel: [ 3764] 0 3764 856342 2435 111 0 0 shfs Aug 29 09:33:53 Tower kernel: [ 3881] 0 3881 59066 3763 64 0 0 qemu-dm Aug 29 09:33:53 Tower kernel: [ 3982] 0 3982 25563 116 23 0 0 xl Aug 29 09:33:53 Tower kernel: [ 4023] 0 4023 3831 453 12 0 0 rpc.mountd Aug 29 09:33:53 Tower kernel: [ 6955] 0 6955 111381 4010 36 0 0 docker Aug 29 09:33:53 Tower kernel: [ 8068] 0 8068 75218 4616 142 0 0 smbd Aug 29 09:33:53 Tower kernel: [ 8829] 0 8829 49178 2766 96 0 0 sshd Aug 29 09:33:53 Tower kernel: [ 8948] 0 8948 3346 874 10 0 0 bash Aug 29 09:33:53 Tower kernel: [14245] 99 14245 1336 20 6 0 0 start.sh Aug 29 09:33:53 Tower kernel: [14265] 99 14265 1136880 100436 389 0 0 mono Aug 29 09:33:53 Tower kernel: [14590] 0 14590 1204 373 6 0 0 tail Aug 29 09:33:53 Tower kernel: Out of memory: Kill process 14265 (mono) score 250 or sacrifice child Aug 29 09:33:53 Tower kernel: Killed process 14265 (mono) total-vm:4547520kB, anon-rss:401744kB, file-rss:0kB Aug 29 09:35:45 Tower php: /usr/local/sbin/DockerUpdate.php Aug 29 09:35:48 Tower php: Reloading status. Aug 29 09:35:48 Tower php: Warning: scandir(/boot/config/plugins/Docker): failed to open dir: No such file or directory in /usr/local/emhttp/plugins/dockerMan/DockerClient.php on line 24 Aug 29 09:35:48 Tower php: Aug 29 09:35:48 Tower php: Warning: scandir(): (errno 2): No such file or directory in /usr/local/emhttp/plugins/dockerMan/DockerClient.php on line 24 Aug 29 09:35:48 Tower php: Aug 29 09:35:48 Tower php: Warning: natcasesort() expects parameter 1 to be array, boolean given in /usr/local/emhttp/plugins/dockerMan/DockerClient.php on line 25 Aug 29 09:35:48 Tower php: Done. Aug 29 09:35:55 Tower php: /usr/bin/docker start mbserver Aug 29 09:35:56 Tower php: mbserver Thanks! Edited August 29, 2014 by Dravor
Redshirt 1487 Posted August 30, 2014 Posted August 30, 2014 GB has been updated. Built against todays dev server.
pducharme 0 Posted September 3, 2014 Posted September 3, 2014 (edited) Im also on unraid 6b8. Btw, i requested a banner on Twitter to use on docker apps page on unraid. Anyway i have an issue with your docker the initial scan never completes. Its stuck at 72% since 10hours. I tried removing actors and chapters from metadata settings (suggested by another unraid user). Any help will be appreciate as i bought the ipad and Android client already If i stop the docker and relaunch it, it goes a bit further but stuck again. Edited September 3, 2014 by pducharme
Luke 42241 Posted September 3, 2014 Author Posted September 3, 2014 Im also on unraid 6b8. Btw, i requested a banner on Twitter to use on docker apps page on unraid. Anyway i have an issue with your docker the initial scan never completes. Its stuck at 72% since 10hours. I tried removing actors and chapters from metadata settings (suggested by another unraid user). Any help will be appreciate as i bought the ipad and Android client already can you post the server log file? thanks.
pducharme 0 Posted September 3, 2014 Posted September 3, 2014 can you post the server log file? thanks. Where it will be on the docker appdata?
Luke 42241 Posted September 3, 2014 Author Posted September 3, 2014 there will be a logs sub-folder under the appdata folder
pducharme 0 Posted September 3, 2014 Posted September 3, 2014 there will be a logs sub-folder under the appdata folder Found it, there is 10 servers logs files, which one to send??
Luke 42241 Posted September 3, 2014 Author Posted September 3, 2014 whichever one is from when it got stuck.
pducharme 0 Posted September 3, 2014 Posted September 3, 2014 Found Anything special? I just restarted it, went from the 72.6% to 73.2%... Stucked again.
pducharme 0 Posted September 3, 2014 Posted September 3, 2014 can you post that log? Server Log? I already did yesterday? or are you talking about another one?
mezz64 14 Posted October 9, 2014 Posted October 9, 2014 Is anyone else having problems with the latest docker build? I can't get images to load in the webgui and have a bunch of libwebp.so errors in the logs. I'm running the container on unraid, but haven't done anything special. Here is an error sample. Full log is attached. 2014-10-08 17:03:52.5982 Error - DtoUtils: ServiceBase<TRequest>::Service Exception libwebp.so System.DllNotFoundException at (wrapper managed-to-native) Imazen.WebP.Extern.NativeMethods:WebPEncodeBGRA (intptr,int,int,int,single,intptr&) at Imazen.WebP.SimpleEncoder.Encode (System.Drawing.Bitmap b, Single quality, Boolean noAlpha, System.IntPtr& result, System.Int64& length) [0x00000] in <filename unknown>:0 at Imazen.WebP.SimpleEncoder.Encode (System.Drawing.Bitmap from, System.IO.Stream to, Single quality, Boolean noAlpha) [0x00000] in <filename unknown>:0 at MediaBrowser.Server.Implementations.Drawing.ImageProcessor+<ProcessImage>d__6.MoveNext () [0x00000] in <filename unknown>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x00000] in <filename unknown>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[System.String].GetResult () [0x00000] in <filename unknown>:0 at MediaBrowser.Api.Images.ImageService+<GetImageResult>d__10.MoveNext () [0x00000] in <filename unknown>:0 2014-10-08 17:03:52.5982 Error - HttpServer: Error processing request for /mediabrowser/Items/578848f6f3e7d50b34fba15936e3aac8/Images/Primary?height=400&width=267&tag=3e85b4e31a447701e058ceeb944c6fb0&quality=90&format=webp libwebp.so ServiceStack.HttpError No Stack Trace Available Log.txt
mezz64 14 Posted October 10, 2014 Posted October 10, 2014 After looking into this a bit more I believe the issue is incorrect case in the paths that point to libwebp.so in the "MediaBrowser.Server.Mono.csproj" file. Specifically this section. I'm not well versed on proper procedures to put in a pull request on github or I would make the corrections myself. It would be appreciated if someone could correct this and kick off a new docker build. <ItemGroup> <None Include="..\thirdparty\libwebp\linux\x86\libwebp.so"> <Link>libwebp\linux\lib\libwebp.so</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\libwebp\linux\x86_64\libwebp.so"> <Link>libwebp\linux\lib64\libwebp.so</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\libwebp\osx\libwebp.5.dylib"> <Link>libwebp\osx\libwebp.5.dylib</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\mediainfo\osx\libmediainfo.dylib"> <Link>MediaInfo\osx\libmediainfo.dylib</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\sqlite3\linux\x86\3.8.2\libsqlite3.so.0.8.6"> <Link>sqlite3\linux\lib\libsqlite3.so.0.8.6</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\sqlite3\linux\x86_64\3.8.2\libsqlite3.so.0.8.6"> <Link>sqlite3\linux\lib64\libsqlite3.so.0.8.6</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\sqlite3\mac\universal\3.8.2\libsqlite3.0.dylib"> <Link>sqlite3\mac\libsqlite3.0.dylib</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="app.config" /> <None Include="Imazen.WebP.dll.config"> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="MediaBrowser.MediaInfo.dll.config"> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="packages.config" /> <None Include="System.Data.SQLite.dll.config"> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> </ItemGroup>
jose 73 Posted October 11, 2014 Posted October 11, 2014 After looking into this a bit more I believe the issue is incorrect case in the paths that point to libwebp.so in the "MediaBrowser.Server.Mono.csproj" file. Specifically this section. I'm not well versed on proper procedures to put in a pull request on github or I would make the corrections myself. It would be appreciated if someone could correct this and kick off a new docker build. <ItemGroup> <None Include="..\thirdparty\libwebp\linux\x86\libwebp.so"> <Link>libwebp\linux\lib\libwebp.so</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\libwebp\linux\x86_64\libwebp.so"> <Link>libwebp\linux\lib64\libwebp.so</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\libwebp\osx\libwebp.5.dylib"> <Link>libwebp\osx\libwebp.5.dylib</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\mediainfo\osx\libmediainfo.dylib"> <Link>MediaInfo\osx\libmediainfo.dylib</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\sqlite3\linux\x86\3.8.2\libsqlite3.so.0.8.6"> <Link>sqlite3\linux\lib\libsqlite3.so.0.8.6</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\sqlite3\linux\x86_64\3.8.2\libsqlite3.so.0.8.6"> <Link>sqlite3\linux\lib64\libsqlite3.so.0.8.6</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="..\thirdparty\sqlite3\mac\universal\3.8.2\libsqlite3.0.dylib"> <Link>sqlite3\mac\libsqlite3.0.dylib</Link> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="app.config" /> <None Include="Imazen.WebP.dll.config"> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="MediaBrowser.MediaInfo.dll.config"> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> <None Include="packages.config" /> <None Include="System.Data.SQLite.dll.config"> <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory> </None> </ItemGroup> I am having the same problem with Fedora 21 opening any page that uses webp images crashes the server.
Luke 42241 Posted October 14, 2014 Author Posted October 14, 2014 I've kicked off a new docker build. keep in mind we have some new dependencies that have not been incorporated into docker yet, but we'll get it in for the next server release. libwebp - 0.4.1 MediaInfo
