CeeBee 1 Posted May 1, 2021 Posted May 1, 2021 If I open the emby app, it's logged in fine ... if I try playing anything directly from the Android TV home screen channels, it asks me to input password EVERY time.. Is this normal??
Solution ebr 16338 Posted May 1, 2021 Solution Posted May 1, 2021 Hi. What is the "login behavior" set to in the app start up settings? If it is set to "Show login screen" and the last logged in user has a password, then, yes that would be correct behavior.
