mohoelx 12 Posted April 30, 2021 Posted April 30, 2021 I read somewhere that the T-Mobile fixed home wireless option does not allow port forwarding. Was wondering if there is anyone here that has tried to use that service with Emby and can either confirm or deny that Emby will work with that service...? Will not be able to try it for another month when I get back to the home base, but if it is known to not work, then there's no point. Thanks in advance!
pwhodges 2028 Posted April 30, 2021 Posted April 30, 2021 Well, admittedly at extra cost, a VPN is likely to be able to get around that. Paul
Carlo 4561 Posted April 30, 2021 Posted April 30, 2021 Unless they implement throttling and then it's game over for remote streaming.
BAlGaInTl 288 Posted May 3, 2021 Posted May 3, 2021 Can you set up the T-Mobile hardware as a dumb modem and use your own router?
