herstl22 1 Posted April 29, 2021 Posted April 29, 2021 The power was out yesterday and since then I can't connect with emby. It works fine local. The IP number is correct What can be the problem
Guest Posted April 29, 2021 Posted April 29, 2021 I would double-check your router settings and make sure the WAN is still the same.. It is unlikely in most cases if the electricity dropped out for awhile that you would wind up with the same exact IP address.. The router could have had an issue as well.. Those two things would be where I checked.
herstl22 1 Posted May 1, 2021 Author Posted May 1, 2021 (edited) It works. Somehow the IP address changed at the external connection Edited May 1, 2021 by herstl22
herstl22 1 Posted May 1, 2021 Author Posted May 1, 2021 5 minutes ago, Hxemby001 said: Glad to see its solved There is a other problem with emby. the music from the TV show like in plex is not playing in the Background
Guest Posted May 1, 2021 Posted May 1, 2021 Are you talking about theme music? There is an option to enable this feature ( by default it is on ), You have to set this up manually inside the media folders or you must install a plugin to get it to work.
herstl22 1 Posted May 1, 2021 Author Posted May 1, 2021 I enabled it. What is the name of the plugin. Aktiviere Titelmelodie is the theme.
Guest Posted May 1, 2021 Posted May 1, 2021 The plugin is in the Plugins Catalog inside Emby.. There are three of them that cover this area.. You will have to decide. I do this manually, if I choose to do it.
Luke 42237 Posted May 1, 2021 Posted May 1, 2021 You can also learn how to setup your own theme song files here: https://support.emby.media/support/solutions/articles/44001159179-theme-songs-videos
herstl22 1 Posted May 1, 2021 Author Posted May 1, 2021 1 hour ago, Luke said: You can also learn how to setup your own theme song files here: https://support.emby.media/support/solutions/articles/44001159179-theme-songs-videos Is there a way to get my money back for lifetime membership if let's say the terramaster is broken and U am not getting a new one?
Luke 42237 Posted May 2, 2021 Posted May 2, 2021 On 5/1/2021 at 2:00 PM, herstl22 said: Is there a way to get my money back for lifetime membership if let's say the terramaster is broken and U am not getting a new one? We're responding to your PM. Thanks.
herstl22 1 Posted May 3, 2021 Author Posted May 3, 2021 The IP number is new but it doesn't work at all. I am not happy with emby right now.
Guest Posted May 3, 2021 Posted May 3, 2021 Is the TerraMaster broken as stated above or is EMBY just not responding?
herstl22 1 Posted May 3, 2021 Author Posted May 3, 2021 emby can't connect with the server. Guess have to go back to kodi.
Guest Posted May 3, 2021 Posted May 3, 2021 (edited) So you can't hit the Server via Remote Connection/Domain Name? .. and KODI gets through just fine? There should be a way to get this working.. @cayars Edited May 3, 2021 by Guest
Carlo 4561 Posted May 3, 2021 Posted May 3, 2021 50 minutes ago, herstl22 said: emby can't connect with the server. Guess have to go back to kodi. We can help you with this but need a bit more description of what is, isn't working specifically in regard to remote connections. Do you have a domain? Using Emby Connect or just the URL of your server as shown in the Emby Console? Does canyouseeme.org show your port open? Does that site give you the same WAN IP as Emby shows?
herstl22 1 Posted May 3, 2021 Author Posted May 3, 2021 I use the wan ip what is showing in emby. canyouseeme.org does show me the same wan IP
Carlo 4561 Posted May 3, 2021 Posted May 3, 2021 If this used to work previous to the power outage it sounds like it would be something simple. I'm pretty used to looking for things like this so if you want another set of eye balls looking over your setup, send me a PM and we can do a remote support session and I can give you a hand. Carlo
herstl22 1 Posted May 3, 2021 Author Posted May 3, 2021 I didn't change anything at all. The settings are fine. I will have a look tomorrow again
Luke 42237 Posted May 4, 2021 Posted May 4, 2021 Hi @herstl22 are you still having an issue with this?
herstl22 1 Posted May 11, 2021 Author Posted May 11, 2021 I used plex and it works fine on it. What I would like is to sign in with my emby account without having to write the ip address in. I am sure it works but i don't now how
Carlo 4561 Posted May 11, 2021 Posted May 11, 2021 (edited) Hi, If you setup your account with the optional Emby Connect username and then logging using Emby Connect you shouldn't have to enter an IP as Emby Connect will find the server for you. Have you tried this? https://emby.media/support/articles/Emby-Connect.html Edited November 6, 2025 by GrimReaper KB article link updated
herstl22 1 Posted May 11, 2021 Author Posted May 11, 2021 No I did not. Plex has the title music in the backround. I know emby can that do as well but it doesn't work. I downloaded the plugins.
