joshua4 12 Posted April 28, 2021 Posted April 28, 2021 Need extra settings for media content that don't have available primary posters. Emby will pull a screen grab from the video file if the meta data doesn't include a primary image. This is all done in the background with no options to change the behavior. No Poster content Option for using a generic placeholder Specify user-defined image to use Provide more options for screen grabs. Specify a location in the video or random location Also please don't take 5 years to implement thanks 1
ebr 16339 Posted April 28, 2021 Posted April 28, 2021 47 minutes ago, joshua4 said: with no options to change the behavior Hi. That isn't really correct... 47 minutes ago, joshua4 said: Option for using a generic placeholder Disable the screen grabber image provider in the library and that's what you'll get. 47 minutes ago, joshua4 said: Specify user-defined image to use You can do this now via "Edit Images" 47 minutes ago, joshua4 said: Provide more options for screen grabs. Specify a location in the video or random location This is the only one not possible now. I thought there was an existing FR for it but I cannot find it... 1
Luke 42246 Posted April 28, 2021 Posted April 28, 2021 Hi there, yes have you explored the settings for your libraries? After doing that, what would give you the impression of "no options"? Or did you just not explore them?
Bigmack3000 108 Posted April 28, 2021 Posted April 28, 2021 Offshoot of this, If possible, I would love if Emby would auto-crop poster screengrabs instead of squishing them into that box.
Guest Posted April 29, 2021 Posted April 29, 2021 (edited) Yeah changing the view helps this.. but when they are in the same Library with items that have posters doesn't look great unless you have thumbs downloaded.. for landscape poster. Currently the only other fix is to have the right filetypes that support it and embed your own poster image. Edited April 29, 2021 by Guest
Happy2Play 9814 Posted April 29, 2021 Posted April 29, 2021 6 hours ago, joshua4 said: This is all done in the background with no options to change the behavior. I assume you are talking about Emby inheriting other image types when a poster is not available? But as specific example could explain more.
