nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 In the end, all I want is for the movie, let it be single or multi-version, to be filtered automatically. If it's naming convention that must be used, so be it. I have no problem with Hd, SD and 4k movie but it doesn't work with 3D movie, I have to tag them manually in a multi-version folder, and it doesn't even tag the right one unless it's the first that was added. The only reason I talked about mediainfo is because of
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 1 minute ago, nodiaque said: let it be single or multi-version, to be filtered automatically So they have to be Identified as 3D. So if Emby fails to identify then you have to flag/tag it as 3D per the option in the UI. Now in a multi-version environment you have to split versions apart to apply the flag/tag to the proper version. But everything you have mentioned I have yet to reproduce. But can try more with exact example.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 (edited) I'm unsure what to tell you. 3D are new in my folders. So all my folder actually contain either 1080p and/or 4k movie. I always named them using the multi-version convention like you saw in the screenshot. Once I add a 3D movie in them, the only thing that happened was adding it to the dropdown list, even using the exact name you used, with no space. Only time it worked is when I created a new folder, added only the 3d movie, let it discover, then added the other in. This way, the main metadata file is a 3d and is detected properly. Let's do this. I have another 3D movie to add. The current folder for it look like this: As you can see, it follow the multi-version convention. I have a 3D movie to add to it. Normally, I would name it: Captain America The First Avenger (2011) - 3D-HSBS.mkv Is there another name you want me to give it? Edited April 28, 2021 by nodiaque
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 All I can say is if you split your multi-versions apart via the button does you 3D version show as 3D in the UI?
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 What do you mean split via the button?
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 2 minutes ago, nodiaque said: What do you mean split via the button? The button in Media Info section
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 (edited) Hmmm... where is that? edit: wait just found it Edited April 28, 2021 by nodiaque
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 2 minutes ago, nodiaque said: Hmmm... where is that? In the web client at the bottom of every itemdetail page.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 (edited) I tried with my Avatar and it didn't detect my 3d as 3d. File format is: Avatar Extended (2009) - 3D.mvc.mkv which is part of the multi-version edit: I removed everything from the avatar folder, deleted it and now doing a scan to remove it from the DB. I'll create it again using only the 3d movie first. Edited April 28, 2021 by nodiaque
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 (edited) ok, so now, with only avatar 3d in it, it detect as 3d using: Avatar Extended (2009) - 3D-mvc.mkv So the space aren't a problem. I'll add now the non 3d in Edited April 28, 2021 by nodiaque
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 Now, this is what I have: Unsure why you didn't had the "3D" part in your naming in front of them when you did the test. So yeah, it seems that it must be the main file to be detected as 3D (like the first file added). That's why my warcraft folder also display like that, but not my other where the non 3d file are the file for the metadata.
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 (edited) 6 minutes ago, nodiaque said: ok, so now, with only avatar 3d in it, it detect as 3d using: Avatar Extended (2009) - 3D-mvc.mkv I tried with 3d.mvc.mkv and it didn't work. I'll add now the non 3d in Yes there does appear to be a case issue in 3D.mvc vs 3d.mvc in this example. @Lukeis that by design? @cayarsthis maybe a issue in the kb as it is not completely true. Tags are case-insensitive, so both 3d and 3D will work. Edited April 28, 2021 by Happy2Play
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 I manage to have it work with 3d.mvc. But I toyed around, renamed it Avatar Extended (2009) - mvc.mkv When I did that, the metadata file changed for the Avatar Extended (2009) - 1080p.mkv one, lost the 3D tag. I renamed to Avatar Extended (2009) - 3D-mvc.mkv , 3D tag came back. When I do edit metadata, it reverted to the 3d-mvc file.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 Ok, just tried with another movie, The Meg. Filename was The Meg (2018) - 3d.mvc.mkv. I switched to The Meg (2018) - 3d-mvc.mkv Work. I also deleted all the -poster -folder that was associated with it. I think it's an old version of emby that were doing that
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 Ok.... I can't explain. Maybe there was corruption, I don't know. But now, without changing anything, Fantastic Beast is properly recognized as 3D, and the file name is Fantastic Beast And Where To Find Them (2016) - 3D.mvc.mkv
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 (edited) 6 minutes ago, nodiaque said: I manage to have it work with 3d.mvc. But I toyed around, renamed it Avatar Extended (2009) - mvc.mkv When I did that, the metadata file changed for the Avatar Extended (2009) - 1080p.mkv one, lost the 3D tag. I renamed to Avatar Extended (2009) - 3D-mvc.mkv , 3D tag came back. When I do edit metadata, it reverted to the 3d-mvc file. Yes I see minor quirk do to the Multi-version and 3D naming schemes. As Emby will now always identify as 3D in multi-version naming. So the only way to truly know is splitting apart and verifying. 4 minutes ago, nodiaque said: Ok, just tried with another movie, The Meg. Filename was The Meg (2018) - 3d.mvc.mkv. I switched to The Meg (2018) - 3d-mvc.mkv Work. I also deleted all the -poster -folder that was associated with it. I think it's an old version of emby that were doing that 2 minutes ago, nodiaque said: Ok.... I can't explain. Maybe there was corruption, I don't know. But now, without changing anything, Fantastic Beast is properly recognized as 3D, and the file name is Fantastic Beast And Where To Find Them (2016) - 3D.mvc.mkv It is about CASE as - 3d.mvc.ext does not work, but - 3D.mvc.ext does. Edited April 28, 2021 by Happy2Play
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 weird since The Meg did work with 3d and not 3D. And wiki does say it's not case sensitive
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 1 minute ago, nodiaque said: weird since The Meg did work with 3d and not 3D. And wiki does say it's not case sensitive You are changing context though, period vs dash. So they are different variables. Filename was The Meg (2018) - 3d.mvc.mkv I switched to The Meg (2018) - 3d-mvc.mkv
Carlo 4561 Posted April 28, 2021 Posted April 28, 2021 I was doing some remote support and just getting back to this and see this thread exploded with posts. I just moved over my Avatar to my multi-version non 3D library and have a scan going. I'll report back what I find as well. I have a seperate 3D as no one in my family except me has a 3D TV so I found it easier than explaining to others why they have side by side or over/under pictures of the same movie.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 Oh dam, that's complicated.... just tried adding captain america with Captain America The First Avenger (2011) - 3D HSBS.mkv didn't work. Gonna try with the -
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 (edited) 2 minutes ago, nodiaque said: Oh dam, that's complicated.... just tried adding captain america with Captain America The First Avenger (2011) - 3D HSBS.mkv didn't work. Gonna try with the - And if you used "3d hsbs" or "3d.hsbs" instead? Edited April 28, 2021 by Happy2Play
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 (edited) So didn't work Captain America The First Avenger (2011) - 3D-HSBS Trying Captain America The First Avenger (2011) - 3D.mvc which worked with Fantastic Beast Edited April 28, 2021 by nodiaque
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 I am guessing Luke has this hard coded with the kb specific variables (case sensitive).
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 nope. The metadata is still stuck to the 1080p file
