Carlo 4561 Posted April 28, 2021 Posted April 28, 2021 Give me a couple of hours and I'm going to try and reproduce this for you specifically using Avatar with those 3 versions.
skidmarks 199 Posted April 28, 2021 Posted April 28, 2021 (edited) I set all this up, mind you a year ago, following the wiki. I did have to go into each 3D movie (edit metadata) and make sure 3D Format section was set. The file title was not triggering this to be set automatically. The other thing is to just add one set of backdrops. Other than that, i can remove some files and see if i can duplicate this issue... (i'm gonna be away for a few hours mowing earth fur) Edited April 28, 2021 by skidmarks
Carlo 4561 Posted April 28, 2021 Posted April 28, 2021 That is what I seem to remember as well. Either add the 3D first (only movie) so you can edit it easily or add them all, ungroup, set metadata for 3D version, then regroup.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 So, I just added a new movie, wasn't in my library before. Only 3D, and still not detected as 3D
Luke 42203 Posted April 28, 2021 Posted April 28, 2021 Have you compared your file naming to our supported 3d naming conventions? https://support.emby.media/support/solutions/articles/44001159102-movie-naming
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 Yes, like I've said many time, I even tried all of them regardless of how the movie was formatted. I even pasted the wiki itself to see that my current naming scheme is exactly what's on the wiki. I also tried the legacy tagging.
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 2 minutes ago, nodiaque said: So, I just added a new movie, wasn't in my library before. Only 3D, and still not detected as 3D Yes the there is some controversy of Multi-Versioning naming and 3D naming. This example is Multi-version naming scheme not 3D. Multi-version naming may/will require extra steps.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 All my other movie that are multi-version have the "name - 3d.mvc.mkv" tag, which is exactly what the 3d wiki for single and multi-version give as example:
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 (edited) moviename (year)-3D.sbs-720p.mkv moviename (year)-3D.mvc.mkv does not equal moviename (year) - 3D.sbs-720p.mkv moviename (year) - 3D.mvc.mkv A space on each side is the difference making it something else. Edited April 28, 2021 by Happy2Play
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 (edited) O_O so the example that says 3D can be combine with multi-version is wrong because it break the detection? Edited April 28, 2021 by nodiaque
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 1 minute ago, nodiaque said: O_O so the example that says 3D can be combine with multi-version is wrong because it brake the detection? Sort of as you can see 3D in the drop down list, but Emby has not truly identified it as 3D for filtering purposed.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 Oh... but it does filter out 4k and uhd this way. Should do all...
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 1 minute ago, nodiaque said: Oh... but it does filter out 4k and uhd this way. Should do all... Well that info is from media info not an additional tab saying it is 3D. If there were a media info tag then it would be different.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 Oh, I though it was from the file naming convention.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 For information, 3D detected on my latest with this form: The Secret Life of Pets (2016) - 3D-HSBS There is space between between the first -. Using a space between 3D and HSBS didn't work. Tried in a multi-version folder, didn't work
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 Just now, nodiaque said: Oh, I though it was from the file naming convention. No you can have almost anything, so "Movie - anything" is just a label. But filtering goes off of physical media info. 2 minutes ago, nodiaque said: For information, 3D detected on my latest with this form: The Secret Life of Pets (2016) - 3D-HSBS There is space between between the first -. Using a space between 3D and HSBS didn't work. Tried in a multi-version folder, didn't work For 3D identification to work you can't have spaces have spaces around the hyphen as that is mulit-versioning " - ". The Secret Life of Pets (2016)-3D-HSBS The Secret Life of Pets (2016).3D-HSBS
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 It is exactly like the example for multi-version folder with 3d As for the single file, with only 3D, it worked using a mix of the multi-version and 3d only, The Secret Life of Pets (2016) - 3D-HSBS.mkv this worked The Secret Life of Pets (2016) - 3D.HSBS.mkv this didn't I tried in the multi-version to do it without space The Secret Life of Pets (2016)-3D-HSBS.mkv didn't worked. I cannot get it to work in multi-version folder, and since everything with 3D always have a 1080p or 4k version of it also, I don't really care about single version. But in my original testing, I copied each example from the wiki 1 by 1, regardless of the true format, and in multi-version folder, the only thing it did is populate the drop down, never the filter like single version do.
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 But just tested C:\Users\Media\Desktop\Videos\Unset\The Secret Life of Pets 2\The Secret Life of Pets 2 - 3D HSBS.disc C:\Users\Media\Desktop\Videos\Unset\The Secret Life of Pets 2\The Secret Life of Pets 2 - 3D-HSBS.disc And both were shown as 3D
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 (edited) maybe because it's .disc? I'll try renaming edit: something I do see though is that in multi-version, if I do edit metadata, the filename on top is the first file that was scanned, not the one actually selected. Edited April 28, 2021 by nodiaque
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 3 minutes ago, nodiaque said: I tried in the multi-version to do it without space The Secret Life of Pets (2016)-3D-HSBS.mkv This can not be used in multi-version as it will make this item its own version not grouped do to naming scheme requirements ie space hyphen space.
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 2 minutes ago, nodiaque said: maybe because it's .disc? I'll try renaming edit: something I do see though is that in multi-version, if I do edit metadata, the filename on top is the first file that was scanned, not the one actually selected. extension is irrelevant.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 tried anyway, and no go, still not seeing avatar as 3D. I think it's because it's not the first file in the folder. Did you try that? Put a non 3D file in it, then add a 3D file in it.
nodiaque 62 Posted April 28, 2021 Author Posted April 28, 2021 By the way, if you guys are using media info to populate UHD, SD and HD, you can do the same with 3d movies
Happy2Play 9802 Posted April 28, 2021 Posted April 28, 2021 Well this is two different issues if you want to to talk about about media info file naming. Emby does uses ffmpeg/ffprobe to read embed tag/headers not MediaInfo. So do you want to talk about Emby naming scheme or Media info? One provides a display label in the UI the other is used for filtering components. So they will never be the same.
