SGBVida 1 Posted April 27, 2021 Posted April 27, 2021 Hello, I used emby on docker right now and i want to migrate to k8s... With the following manifest i can deploy emby and access it: apiVersion: v1 kind: Service metadata: labels: app: emby-server name: emby-server namespace: media spec: ports: - name: http port: 8096 protocol: TCP - name: https port: 8920 protocol: TCP selector: app: emby-server --- apiVersion: apps/v1 kind: Deployment metadata: name: emby-server namespace: media spec: replicas: 1 selector: matchLabels: app: emby-server template: metadata: labels: app: emby-server spec: containers: - image: 'emby/embyserver:latest' imagePullPolicy: IfNotPresent livenessProbe: httpGet: path: /web/index.html port: 8096 timeoutSeconds: 30 name: emby-server ports: - containerPort: 8096 - containerPort: 8920 readinessProbe: httpGet: path: /web/index.html port: 8096 timeoutSeconds: 30 volumeMounts: - mountPath: /mnt/library name: media-library - mountPath: /mnt/perso name: media-library-perso volumes: - name: media-library nfs: path: /volume1/Data/k8s server: 192.168.x.x - name: media-library-perso nfs: path: /volume1/Data/k8s/Photos server: 192.168.x.x --- apiVersion: traefik.containo.us/v1alpha1 kind: IngressRoute metadata: name: emby-server namespace: media spec: entryPoints: - websecure routes: - kind: Rule match: Host(`emby-dev.xxxx.fr`) services: - name: emby-server port: 8096 tls: secretName: xxxxxxxxxx From this point i have 2 issues: - I can browse the folder (GUI) but he's empty and if i access it in cli and show the contents of the folder i can see my files. MY second problem is i can't reach a subfolder in the GUI. on my Nas i have many folders under /volume1/Data/k8s but i have an error if i try to add it: But i see then in cli: Did i miss something ?
SGBVida 1 Posted April 27, 2021 Author Posted April 27, 2021 Ok i found the problem... this is a permission problem! I mount the volume and check the permission, here it's 1024 forthe user and 100 for the group Now i need to update the deployment like this: apiVersion: apps/v1 kind: Deployment metadata: labels: argocd.argoproj.io/instance: media name: emby-server namespace: media spec: replicas: 1 selector: matchLabels: app: emby-server template: metadata: labels: app: emby-server spec: containers: - env: - name: UID value: '1024' - name: GID value: '100' image: 'emby/embyserver:latest' imagePullPolicy: IfNotPresent livenessProbe: httpGet: path: /web/index.html port: 8096 timeoutSeconds: 30 name: emby-server ports: - containerPort: 8096 - containerPort: 8920 readinessProbe: httpGet: path: /web/index.html port: 8096 timeoutSeconds: 30 volumeMounts: - mountPath: /mnt/library name: media-library volumes: - name: media-library nfs: path: /volume1/Data/k8s server: 192.168.x.x 1
Luke 42246 Posted April 27, 2021 Posted April 27, 2021 Glad you figured it out. Thanks for the feedback !
