dagset1 0 Posted April 26, 2021 Posted April 26, 2021 I am using Windows 10. Emby see's and accesses my 2 internal drives with no problem. However Emby does not see my external drive. The drive is visible and accessible in File not explorer but not in Emby. Shre is turned on. What am I doing wrong.
Abobader 3485 Posted April 26, 2021 Posted April 26, 2021 Hello dagset1, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
simzy 3 Posted April 26, 2021 Posted April 26, 2021 If i remember right, i had this same issue at first, when i was adding the drives for the folders, i was manually typing in the drive letter then telling it to browse, also make sure that you actually have full permissions to the drive(s) for both read and write, that always helps.
Carlo 4561 Posted April 26, 2021 Posted April 26, 2021 4 minutes ago, dagset1 said: I am using Windows 10. Emby see's and accesses my 2 internal drives with no problem. However Emby does not see my external drive. The drive is visible and accessible in File not explorer but not in Emby. Shre is turned on. What am I doing wrong. Hi, do these drives have a drive letter in Emby? Are you running Emby as a service? If so try running it NOT as a service.
dagset1 0 Posted April 27, 2021 Author Posted April 27, 2021 ok, so my internal drives are C and D, the external drive is E as seen in the computer. When I open Emby and go to the Library to set up a new file all that is visible is C and D. To your question "Are you running Emby as a service? If so try running it NOT as a service." I am sorry I don't understand or know. I just downloaded Emby onto windows 10 and started using it. How do I check if it is a service or not and how do I run it as not a service?
Carlo 4561 Posted April 27, 2021 Posted April 27, 2021 If this is a new install it's not running as a service so disregard my question. Can you show us a screen shot where only C & D but no E drive show up from Emby? Thanks
Luke 42203 Posted April 27, 2021 Posted April 27, 2021 Hi, what exactly do you mean by "does not see" ? Where exactly is it not seen?
rbjtech 5337 Posted April 28, 2021 Posted April 28, 2021 Presumably it is not listing all the drives here ?
Luke 42203 Posted April 30, 2021 Posted April 30, 2021 On 4/28/2021 at 6:04 AM, rbjtech said: Presumably it is not listing all the drives here ? Understood. I'm asking the user to describe the problem in their own words. Thanks.
