BruceDavid 4 Posted April 26, 2021 Author Posted April 26, 2021 Thanks. 90% plus of the content is on the F drive. If I remove that from Emby, might I as well remove Emby from the PC and re-install (I have no plug-ins, etc.)? I would prefer not to have to rename the F drive to a different letter as it creates some non-Emby issues but, if necessary, I can do so. Is there a way to flush the DB? Thanks.
BruceDavid 4 Posted April 26, 2021 Author Posted April 26, 2021 As an update, I am scanning all files (have not removed the F drive, etc.) and it seems to be stalled on 90.1%
Happy2Play 9802 Posted April 26, 2021 Posted April 26, 2021 9 minutes ago, BruceDavid said: As an update, I am scanning all files (have not removed the F drive, etc.) and it seems to be stalled on 90.1% Scan percentage is deceiving, all you can do is check the log and see if items are still being processed.
BruceDavid 4 Posted April 26, 2021 Author Posted April 26, 2021 Thanks. The log is quite large, can you tell me what word or phrase I should search for? I tried "scan" and "library" (separately) but there were no results.
Happy2Play 9802 Posted April 26, 2021 Posted April 26, 2021 (edited) 12 minutes ago, BruceDavid said: Thanks. The log is quite large, can you tell me what word or phrase I should search for? I tried "scan" and "library" (separately) but there were no results. Your previous log show image extraction (bif) files, but ffprobe/ffmpeg or provider related. examples from your other log Info MediaProbeManager: ProcessRun 'ffprobe' Info App: ProcessRun 'quick-extract-imageseries' Info App: MovieDbProvider: Finding id Edited April 26, 2021 by Happy2Play
Luke 42203 Posted May 20, 2021 Posted May 20, 2021 Hi there @BruceDavid, are you still having an issue with this? Please try again with the newly released Emby Server 4.6 and let us know how that compares. Thanks !
