Paint 10 Posted April 26, 2021 Posted April 26, 2021 I am using the Emby app on two different 2020 Samsung TVs (75in Q90T and a 55in Samsung Frame TVs). I am finding that live TV or any other playback will work but after 5-15 minutes the stream will pause and stop. After a minute or so, it will kick me back to the Emby homescreen. I am then able to resume the playback at where the stream failed. I dont have these issues when using a Fire stick, only when using the EMBY app on the Samsung TVs.
Luke 42241 Posted April 27, 2021 Posted April 27, 2021 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
Paint 10 Posted May 1, 2021 Author Posted May 1, 2021 On 4/26/2021 at 10:07 PM, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks ! Ill post a full debug log soon. However, there is definitely an issue with the Emby app on Samsung TVs. I just brought my fire stick to test in the same house,wifi and Emby server-the fire stick works perfectly,while Samsung Emby app will freeze and stop playback every 5 to 20 minutes.
Happy2Play 9811 Posted May 1, 2021 Posted May 1, 2021 A guess but sounds like the two are using different playback methods ie one direct playing and the other transcoding.
Paint 10 Posted May 1, 2021 Author Posted May 1, 2021 2 minutes ago, Happy2Play said: A guess but sounds like the two are using different playback methods ie one direct playing and the other transcoding. The issue occurs on the Samsung emby app regardless of direct play or transcoding - after 5 to 20 minutes,the stream stops and the emby app times out for about 2-3 minutes. I then need to restart the stream. The firestick works with direct play or transcoding.
Happy2Play 9811 Posted May 1, 2021 Posted May 1, 2021 If it were a app issue I would expect more reports. But devs will have to look at logs showing the issue.
Paint 10 Posted May 1, 2021 Author Posted May 1, 2021 (edited) On 4/26/2021 at 10:07 PM, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks ! Here are the logs for watching Top Chef on a Samsung Q90t 75in (Bergen 1B basement from user Josh) with the latest app version 1.0.88. Playback just stops after a few minutes of watching and then app times out for a minute, then i am able to resume. If i watch via a firestick, i can watch for hours without any issues. embyserver.txt Edited May 1, 2021 by Paint
Paint 10 Posted May 1, 2021 Author Posted May 1, 2021 5 minutes ago, Paint said: Here are the logs for watching Top Chef on a Samsung Q90t 75in (Bergen 1B basement from user Josh) with the latest app version 1.0.88. Playback just stops after a few minutes of watching and then app times out for a minute, then i am able to resume. If i watch via a firestick, i can watch for hours without any issues. ffmpeg-transcode-14369fc4-0d50-460f-a6db-c118d1c67f38_1.txt 94.59 kB · 2 downloads ffmpeg-transcode-120b84c7-3836-44ba-8586-d828093b2bc5_1.txt 2.2 MB · 1 download embyserver.txt 31.87 MB · 1 download Im capturing another log now with debugging on and this time Top Chef is playing via direct play
SamES 1084 Posted May 2, 2021 Posted May 2, 2021 (edited) Please also attach any ffmpeg logs related to these playbacks and the media info for this movie Edited May 2, 2021 by SamES
Paint 10 Posted May 2, 2021 Author Posted May 2, 2021 Just now, SamES said: Please also attach any ffmpeg logs related to these playbacks and the media info for this movie There are no ffmepg playbacks for these since there is no transcoding. Today everything has been direct streaming. Ill capture one with transcoding and include a ffmpeg log
SamES 1084 Posted May 2, 2021 Posted May 2, 2021 Do you mean DirectStreaming or DirectPlaying? There is a difference.
Paint 10 Posted May 2, 2021 Author Posted May 2, 2021 49 minutes ago, SamES said: Do you mean DirectStreaming or DirectPlaying? There is a difference. DirectPlaying e.g. no transcoding required for the stream
Paint 10 Posted May 2, 2021 Author Posted May 2, 2021 Here is a log of the issue from my upstairs 55in Frame TV ffmpeg-transcode-3c278f2b-e113-419c-87ec-65928cfb6103_1.txt embyserver (1).txt
SamES 1084 Posted May 2, 2021 Posted May 2, 2021 What hardware is your server on? I can see in the log that it is struggling to keep up, with transcoding speeds less than 1x which is the absolute minimum for playback 09:44:32.962 SegmentComplete=video:0 Index=19 Start=58.158100 End=61.161100 Duration=3.003000 offset_pts=0 start_pts=58158100 Frames=90 filename=hls/93D82D/93D82D_19.ts 09:44:32.962 [segment @ 0xb05700] Opening '/var/lib/emby-server/transcoding-temp/93D82D_20.ts.tmp' for writing 09:44:33.154 frame= 1851 fps= 31 q=29.0 size= 28978kB time=00:01:02.20 bitrate=4038.3kbits/s throttle=off speed=0.99x 09:44:33.755 frame= 1866 fps= 31 q=29.0 size= 29152kB time=00:01:02.78 bitrate=4023.1kbits/s throttle=off speed=0.99x 09:44:34.352 frame= 1885 fps= 31 q=29.0 size= 29404kB time=00:01:03.42 bitrate=4014.7kbits/s throttle=off speed=0.991x 09:44:34.962 frame= 1908 fps= 31 q=29.0 size= 29694kB time=00:01:04.09 bitrate=4009.3kbits/s throttle=off speed=0.992x 09:44:35.555 frame= 1918 fps= 31 q=29.0 size= 29831kB time=00:01:04.54 bitrate=3998.2kbits/s throttle=off speed=0.99x 09:44:36.105 frame= 1938 fps= 31 q=29.0 size= 30104kB time=00:01:05.21 bitrate=3991.0kbits/s throttle=off speed=0.992x 09:44:36.108 [segment @ 0xb05700] Opening '/var/lib/emby-server/transcoding-temp/93D82D.m3u8.tmp' for writing 09:44:36.108 SegmentComplete=video:0 Index=20 Start=61.161100 End=64.164100 Duration=3.003000 offset_pts=0 start_pts=61161100 Frames=90 filename=hls/93D82D/93D82D_20.ts 09:44:36.108 [segment @ 0xb05700] Opening '/var/lib/emby-server/transcoding-temp/93D82D_21.ts.tmp' for writing 09:44:36.606 frame= 1955 fps= 31 q=29.0 size= 30394kB time=00:01:05.72 bitrate=3996.3kbits/s throttle=off speed=0.992x 09:44:37.509 frame= 1972 fps= 31 q=29.0 size= 30582kB time=00:01:06.27 bitrate=3986.2kbits/s throttle=off speed=0.987x 09:45:32.896 frame= 1991 fps= 17 q=29.0 size= 30776kB time=00:01:06.94 bitrate=3969.1kbits/s throttle=off speed=0.533x 09:46:19.302 frame= 1992 fps= 12 q=29.0 size= 30784kB time=00:01:07.04 bitrate=3964.2kbits/s throttle=off speed=0.384x 09:46:19.511 [segment @ 0xb05700] Opening '/var/lib/emby-server/transcoding-temp/93D82D.m3u8.tmp' for writing 09:46:19.511 SegmentComplete=video:0 Index=21 Start=64.164100 End=67.167100 Duration=3.003000 offset_pts=0 start_pts=64164100 Frames=90 filename=hls/93D82D/93D82D_21.ts 09:46:19.511 [segment @ 0xb05700] Opening '/var/lib/emby-server/transcoding-temp/93D82D_22.ts.tmp' for writing 09:47:59.463 frame= 2106 fps=7.9 q=29.0 size= 32174kB time=00:01:10.72 bitrate=3916.6kbits/s throttle=off speed=0.253x
Happy2Play 9811 Posted May 2, 2021 Posted May 2, 2021 Not sure why the TV chokes and the FireTV does not, but the only difference in the transcode logs I see is FireTV transcodes the 20Mb stream at 20Mb and the TV is transcoding the 20Mb stream to 7Mb, assuming limit applied to the TV (TranscodeReasons=ContainerBitrateExceedsLimit).
Paint 10 Posted May 3, 2021 Author Posted May 3, 2021 I dont have any bitrate limits on. The server is a Intel Xeon 6240 Gold CPU (20C/40T) that does not have much load at all. I dont think transcoding is the issue. I have Enable throttling on, which I just turned off to see if that makes a difference. Transcoding thread count: is set to Auto
Paint 10 Posted May 3, 2021 Author Posted May 3, 2021 where else should I be checking to see if there are transcoding bitrate limits besides the transcoding page and each user's settings page? Both of the pages for my user are blank so I assume that means unlimited.
Happy2Play 9811 Posted May 3, 2021 Posted May 3, 2021 1 minute ago, Paint said: where else should I be checking to see if there are transcoding bitrate limits besides the transcoding page and each user's settings page? Both of the pages for my user are blank so I assume that means unlimited. The client playback/quality setting. Sometime Auto will do this but not familiar with TV Client.
Paint 10 Posted May 3, 2021 Author Posted May 3, 2021 Changed transcoding cores from auto to Max. Still having issues...here are the logs. I dont have any issues at all with the firestick...only the Samsung tv emby app. embyserver (2).txt ffmpeg-transcode-b986f2b9-a7f7-4fbd-b724-1ff595a810be_1.txt ffmpeg-transcode-8f50faec-2650-4c99-a49d-dadeed0451b9_1.txt ffmpeg-transcode-c07abb71-b5c4-463c-9c01-10e455feecca_1.txt ffmpeg-transcode-f0a8b414-e52d-4162-b72a-07449bc00101_1.txt ffmpeg-transcode-a1aeab4b-fa07-4ba2-983e-8ba28b19bfd4_1.txt
Paint 10 Posted May 3, 2021 Author Posted May 3, 2021 What's weird is if i ever had any transcoding or bandwidth issues with the firestick,it would pause and then restart when bandwidth or transcoding caught up. On the Samsung, the stream never restarts. I need to close the app and resume. If I do wait 5 minutes or so, it will resume playing the episode prior to the one I am watching. Im running this on a 20 core, 40 thread machine with ultra low load. I think the transcoding issue is a false flag....
Paint 10 Posted May 3, 2021 Author Posted May 3, 2021 Here are some more logs... ffmpeg-transcode-054dcfe0-d11c-448d-be39-62b473541344_1.txt ffmpeg-transcode-529f1310-3509-439c-b3ed-7491585fbb89_1.txt ffmpeg-transcode-b5ff985d-d3e6-48e5-bafa-466b8f56d5ec_1.txt ffmpeg-transcode-ad7ef79c-46c3-450e-a962-de355fd2e1d1_1.txt ffmpeg-transcode-3fbdae65-65f7-4e5c-8db3-5e163e029700_1.txt ffmpeg-transcode-2a055c9b-6ee2-4319-8142-fbd3ac7fdd7b_1.txt
SamES 1084 Posted May 3, 2021 Posted May 3, 2021 3 hours ago, Paint said: Im running this on a 20 core, 40 thread machine with ultra low load. I think the transcoding issue is a false flag.... You shouldn't be having transcoding issues with this processor, but if transcoding rate is not at least 1x then you're going to have issues. It should be transcoding faster than this. Do you have GPU/Hardware transcoding enabled?
Paint 10 Posted May 3, 2021 Author Posted May 3, 2021 8 hours ago, SamES said: You shouldn't be having transcoding issues with this processor, but if transcoding rate is not at least 1x then you're going to have issues. It should be transcoding faster than this. Do you have GPU/Hardware transcoding enabled? I have a nvidia 3080 in the machine but I have hardware encoding off set in Emby
SamES 1084 Posted May 3, 2021 Posted May 3, 2021 18 hours ago, Paint said: Here are some more logs... ffmpeg-transcode-054dcfe0-d11c-448d-be39-62b473541344_1.txt 67.34 kB · 0 downloads ffmpeg-transcode-529f1310-3509-439c-b3ed-7491585fbb89_1.txt 67.01 kB · 1 download ffmpeg-transcode-b5ff985d-d3e6-48e5-bafa-466b8f56d5ec_1.txt 131.89 kB · 0 downloads ffmpeg-transcode-ad7ef79c-46c3-450e-a962-de355fd2e1d1_1.txt 21.7 kB · 0 downloads ffmpeg-transcode-3fbdae65-65f7-4e5c-8db3-5e163e029700_1.txt 15.29 kB · 0 downloads ffmpeg-transcode-2a055c9b-6ee2-4319-8142-fbd3ac7fdd7b_1.txt 56 kB · 0 downloads So these logs look better. Did they play fine or still stop?
