eric.faes@gmail.com 2 Posted April 26, 2021 Posted April 26, 2021 Hi all All data is shown except artist info. Where can i check ?
Luke 42246 Posted April 26, 2021 Posted April 26, 2021 Hi there, can you please go over an example? What exactly isn't' showing? Thanks.
eric.faes@gmail.com 2 Posted April 27, 2021 Author Posted April 27, 2021 allready did this multiple times All is shown except artists, thats is always empty
eric.faes@gmail.com 2 Posted April 27, 2021 Author Posted April 27, 2021 example : All my music in my music folder is imported Alll info can be seen Only Artist info allways emty This is only with Emby running on FreeNAS/TrueNAS With the Emby windows version all is good.
Luke 42246 Posted April 28, 2021 Posted April 28, 2021 Hi, what about Album Artists? Are they showing?
eric.faes@gmail.com 2 Posted April 29, 2021 Author Posted April 29, 2021 no, same problem Tried to rebuild the entire thing by deleting everyting and setting up a new one. But the problem stays.
Luke 42246 Posted May 12, 2021 Posted May 12, 2021 Are your audio files tagged with artist information? Most likely they are not
eric.faes@gmail.com 2 Posted May 12, 2021 Author Posted May 12, 2021 Not all of them but out of the 5.000+ mostly are. It's only the TrueNAS version that has this problem. + How come in the windows 10 version of Emby (That i also have running with the same audiofiles) shows all the info nicely. Also Jellyfin in windows show all info.
eric.faes@gmail.com 2 Posted May 12, 2021 Author Posted May 12, 2021 Also strangly when checking a songs Metadata via TrueNAS server all info is empty When is check the same songs Metadat on the Windows server version all data is there.
eric.faes@gmail.com 2 Posted May 12, 2021 Author Posted May 12, 2021 Her's an example o f a song. Clearly the artist info is there
Luke 42246 Posted May 15, 2021 Posted May 15, 2021 Please try refreshing the metadata of that song, then attach the emby server log: Thanks.
