Quality grouping gone?
I just realized that the chooser between download qualities are gone. I cant seem to figure out how to get my movies to group again.
Nevermind. The multiselect is not through the metadata manager it's through the webview/movie searcher thing.
Edited by pr3dict
Hi, why exactly did you think it was gone?
When I added another quality it didnt auto group them. I then went looking for the option and couldnt find it anywhere. Then remembered the multiselect thing is done in like the regular UI not through the dashboard or metadata manager etc.
Ok so you needed to group them manually first?
