JasePManning 0 Posted February 21, 2022 Posted February 21, 2022 The latest update looks great and works perfectly. I must remember to avoid future updates...
HomeMediaPlayer 1 Posted February 21, 2022 Posted February 21, 2022 12 hours ago, Luke said: @HomeMediaPlayer are you still having an issue with this? Hi, I upgraded to version 1.0.33. It doesn’t work the same way, it’s only willing to play one of 4 movies. So unfortunately worse than it was.
Luke 42239 Posted February 21, 2022 Posted February 21, 2022 1 hour ago, HomeMediaPlayer said: Hi, I upgraded to version 1.0.33. It doesn’t work the same way, it’s only willing to play one of 4 movies. So unfortunately worse than it was. What do you mean doesn't work the same way? Can we please look at an example? Thanks
HomeMediaPlayer 1 Posted February 21, 2022 Posted February 21, 2022 (edited) 2 hours ago, Luke said: What do you mean doesn't work the same way? Can we please look at an example? Thanks Don’t get mad, I upgraded the server, restarted the client completely, and I see it works fine, on the 2014 LG TV. So you no longer have to wait for hours to get started, although sometimes the previous error message still appears, but it can only be a momentary connection to the server, probably due to Wifi. I am pleased. There’s one thing, some movies don’t resume playing but start playing the movie from the beginning, no matter where you have the option to continue there. I don't know what it can be. I don't want to refresh anymore so that what is good doesn't spoil Will there be no special discount price for a LifeTime subscription? Edited February 21, 2022 by HomeMediaPlayer
JasePManning 0 Posted February 22, 2022 Posted February 22, 2022 20 hours ago, HomeMediaPlayer said: Don’t get mad, I upgraded the server, restarted the client completely, and I see it works fine, on the 2014 LG TV. So you no longer have to wait for hours to get started, although sometimes the previous error message still appears, but it can only be a momentary connection to the server, probably due to Wifi. I am pleased. There’s one thing, some movies don’t resume playing but start playing the movie from the beginning, no matter where you have the option to continue there. I don't know what it can be. I don't want to refresh anymore so that what is good doesn't spoil Will there be no special discount price for a LifeTime subscription? That's most likely due to the filetype. Some won't let you scan through them either. A type of MKV?
HomeMediaPlayer 1 Posted February 22, 2022 Posted February 22, 2022 24 minutes ago, JasePManning said: That's most likely due to the filetype. Some won't let you scan through them either. A type of MKV? Hello, Yes, a type MKV. But it works well on another TV (webos 4.4), where it continues the movie it started. webos 1.4 is not good at the moment.
