hideftv 0 Posted April 24, 2021 Posted April 24, 2021 Emby V4.5.4.0 on Qnap. Just switched from Schedules Direct to Emby Guide Data. All is well but for the ability to remove unwanted channels (without going into HDHOMERUN). When I click the checked channel in popup it simply closes the window and refreshes the guide. There is no delete option. Thanks.
Carlo 4561 Posted April 24, 2021 Posted April 24, 2021 Correct there is not a way to delete a channel as they get loaded automatically from the HDHomeRun. What you can do is bring up your HDHomeRun web interface and go to Channel Lineup http://<hdhomerun ip>/lineup.html "Yellow Star" or make a favorite every channel you want to import into Emby. Now in Emby go to your Live TV Setup, edit your tuner and check the "Restrict to channels marked as favorite" option. Click save and refresh your guide. Now only channels you want will be imported so you can get rid of home shopping channels or anything else you don't want. Let us know how you make out.
Luke 42237 Posted April 25, 2021 Posted April 25, 2021 Hi, regarding the mapping dialog, we'll add a button to clear the mapping in the upcoming 4.6 release. Thanks. 2
Luke 42237 Posted May 11, 2021 Posted May 11, 2021 Improved channel management coming in Emby Server 4.6: 1
