Fragglerock 3 Posted May 6, 2021 Author Posted May 6, 2021 Since everything is working, I have no reason to go to a newer version. Considering the time that I had to spend checking the files and the correctness of the data (Auto Box Sets sometimes mixes the films in a collection, everything should be checked so as not to have any surprises). Why is the automatically installed version not the latest?
Fragglerock 3 Posted May 18, 2021 Author Posted May 18, 2021 Hello, I think I found the solution that works for sure: -uninstall everything (including files from Emby) -install the last basic version of Emby (I finally installed the latest stable version manually) -scan all movies and let Emby identify all films -install the Auto Box Sets plug-in then let the plug-in create all the collections. However, I am noticing some plug-in errors: - films are added by mistake in collections (ex: in the collection "captain america" the film "the captain" has been added) - films are mixed between collections (films from the first saga of "the planet of the apes" are mixed with the second) I hope it will help.
Luke 42240 Posted May 18, 2021 Posted May 18, 2021 34 minutes ago, Fragglerock said: However, I am noticing some plug-in errors: - films are added by mistake in collections (ex: in the collection "captain america" the film "the captain" has been added) - films are mixed between collections (films from the first saga of "the planet of the apes" are mixed with the second) I hope it will help. The movies probably are tagged with incorrect moviedb id's in Emby Server.
Fragglerock 3 Posted May 18, 2021 Author Posted May 18, 2021 The movies are tagged by Emby, so I had to check all the movies. But otherwise everything is working fine now. Thank you all for your help. 1
