gregkodi 4 Posted April 23, 2021 Posted April 23, 2021 Hello, i just bought new synology 1621+ that will be replacing my old 718+. I am now in the migration process to the new box. I have added the package repository: https://synology.emby.media/ But the synology can't find 'Emby' package to install. Could that be because its not supported for DS1621+ ? Regards, Greg
Solution Happy2Play 9812 Posted April 23, 2021 Solution Posted April 23, 2021 Don't believe the repostitory has or will be used for awhile. Emby Server for Synology NAS - Emby Pretty sure it will be the 64-bit install. 1 1
gregkodi 4 Posted April 23, 2021 Author Posted April 23, 2021 Thgank you @Happy2Play I have downloaded it and installed the 64bit, everything works perfect!
