JDizzy 21 Posted August 18, 2014 Posted August 18, 2014 (edited) Anyone using this with the new Helix.... I am trying but getting script errors. I am using a FireTV (or trying to find a usage for it).... Edited August 18, 2014 by JDizzy
Luke 42234 Posted September 6, 2014 Posted September 6, 2014 bump, any signs of kodimb3 on the horizon ? Yes of course, however it is alpha and we should not put our developers in a position of stress by expecting them to react to unstable changes made by other software components. Helix was in alpha on 8/18 and it still is today, therefore, there is no need to bump because nothing has changed. If you are already trying to use it as your everyday system then you have unrealistic expectations. 1
im85288 1493 Posted September 6, 2014 Posted September 6, 2014 Agreed, it's far too early to jump on the Helix bandwagon...I know there's some nice new features there such as a much improved PVR...but then the next question will be why our skins do not support Helix. Though as xnappo says, we need logs to even give an assessment.
KRA 39 Posted September 6, 2014 Posted September 6, 2014 (edited) Sorry guys, I was not using Helix, but as pointed out pvr devs are drinking the Helix juice now and has left Gotham city. That's why I asked, I had interest in testing and was wondering if MB3 plugin was working. So as it happens, I tested it now. Installed git version a few days old and version 0.9.5 was working fine. However when I added the repo listed here and it installed an update, that's when it stopped working. If anyone is interested this is the log output: (I have no idea who stephan is and /home/stephan is not on my system, but it seems to be coded into openelec somehow) OpenELEC:/ # ping 192.168.10.205 PING 192.168.10.205 (192.168.10.205): 56 data bytes 64 bytes from 192.168.10.205: seq=0 ttl=64 time=1.604 ms 23:20:42 T:140001631266560 NOTICE: -->Python Interpreter Initialized<-- 23:20:42 T:140001951258368 NOTICE: script.grab.fanart: Grab Fanart Service Started 23:20:43 T:140001631266560 NOTICE: XBMB3C InProgressUpdaterThread -> Log Level:0 23:20:43 T:140001631266560 NOTICE: XBMB3C RecentInfoUpdaterThread -> Log Level:0 23:20:43 T:140001329260288 NOTICE: Unable to connect to 192.168.10.205:8096 : [Errno 101] Network is unreachable 23:20:43 T:140001631266560 NOTICE: XBMB3C RandomInfoUpdaterThread -> Log Level:0 23:20:43 T:140001320867584 NOTICE: Unable to connect to 192.168.10.205:8096 : [Errno 101] Network is unreachable 23:20:43 T:140001631266560 NOTICE: XBMB3C NextUpUpdaterThread -> Log Level:0 23:20:43 T:140001035679488 NOTICE: Unable to connect to 192.168.10.205:8096 : [Errno 101] Network is unreachable 23:20:43 T:140001631266560 NOTICE: XBMB3C SuggestedUpdaterThread -> Log Level:0 23:20:43 T:140001027286784 NOTICE: Unable to connect to 192.168.10.205:8096 : [Errno 101] Network is unreachable 23:20:43 T:140001631266560 NOTICE: XBMB3C WebSocketThread -> Log Level:0 23:20:43 T:140001018894080 NOTICE: Unable to connect to 192.168.10.205:8096 : [Errno 101] Network is unreachable 23:20:43 T:140001631266560 NOTICE: XBMB3C LoadMenuOptionsThread -> Log Level:0 23:20:43 T:140001631266560 NOTICE: XBMB3C BackgroundRotationThread -> Log Level:0 23:20:43 T:140001010501376 NOTICE: XBMB3C WebSocketThread -> WebSocketThread getWebSocketPort urlopen : [Errno socket error] [Errno 101] Network is unreachable (http://192.168.10.205:8096/mediabrowser/System/Info?format=json) 23:20:43 T:140001631266560 NOTICE: XBMB3C ThemeMusicThread -> Log Level:0 23:20:43 T:140001631266560 NOTICE: XBMB3C InfoUpdaterThread -> Log Level:0 23:20:43 T:140001002108672 NOTICE: XBMB3C LoadMenuOptionsThread -> LoadMenuOptionsThread -> Error Parsing favourites.xml : [Errno 2] No such file or directory: '/storage/.xbmc/userdata/favourites.xml' 23:20:44 T:140000993715968 NOTICE: Unable to connect to 192.168.10.205:8096 : [Errno 101] Network is unreachable 23:20:44 T:140001631266560 NOTICE: XBMB3C Service -> starting monitor service 23:20:44 T:140000985323264 NOTICE: Unable to connect to 192.168.10.205:8096 : [Errno 101] Network is unreachable 23:20:44 T:140000893069056 NOTICE: XBMB3 -> HTTP Image Proxy Server Starting 23:20:49 T:140000985323264 NOTICE: Get User unable to connect to 192.168.10.205:8096 : [Errno 101] Network is unreachable 23:20:49 T:140001329260288 NOTICE: Previous line repeats 6 times. 23:20:49 T:140001329260288 NOTICE: HTTP response error: 400 Bad Request 23:20:49 T:140000993715968 NOTICE: Previous line repeats 3 times. 23:20:49 T:140000993715968 NOTICE: HTTP response error: 404 Not Found 23:20:49 T:140001027286784 NOTICE: HTTP response error: 400 ArgumentNullException 23:20:49 T:140001018894080 NOTICE: HTTP response error: 422 InvalidOperationException 23:20:49 T:140000867890944 NOTICE: Thread BackgroundLoader start, auto delete: false 23:20:56 T:140001018894080 NOTICE: HTTP response error: 422 InvalidOperationException 23:20:56 T:140001018894080 ERROR: Exception in thread Thread-5: Traceback (most recent call last): File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/SuggestedItems.py", line 67, in run self.updateSuggested() File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/SuggestedItems.py", line 98, in updateSuggested result = json.loads(jsonData) File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode ValueError: No JSON object could be decoded 23:20:56 T:140001027286784 NOTICE: HTTP response error: 400 ArgumentNullException 23:20:56 T:140001027286784 ERROR: Exception in thread Thread-4: Traceback (most recent call last): File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/NextUpItems.py", line 65, in run self.updateNextUp() File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/NextUpItems.py", line 97, in updateNextUp result = json.loads(jsonData) File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode ValueError: No JSON object could be decoded 23:20:56 T:140000993715968 NOTICE: HTTP response error: 404 Not Found 23:20:56 T:140000993715968 ERROR: Exception in thread Thread-8: Traceback (most recent call last): File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/BackgroundLoader.py", line 66, in run self.updateArtLinks() File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/BackgroundLoader.py", line 265, in updateArtLinks result01 = self.updateCollectionArtLinks() File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/BackgroundLoader.py", line 314, in updateCollectionArtLinks result = json.loads(jsonData) File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode ValueError: No JSON object could be decoded 23:20:56 T:140001320867584 NOTICE: HTTP response error: 400 Bad Request 23:20:56 T:140001320867584 ERROR: Exception in thread Thread-2: Traceback (most recent call last): File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/RecentItems.py", line 49, in run self.updateRecent() File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/RecentItems.py", line 90, in updateRecent result = json.loads(jsonData) File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode ValueError: No JSON object could be decoded 23:20:57 T:140001035679488 NOTICE: HTTP response error: 400 Bad Request 23:20:57 T:140001035679488 ERROR: Exception in thread Thread-3: Traceback (most recent call last): File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/RandomItems.py", line 48, in run self.updateRandom() File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/RandomItems.py", line 79, in updateRandom result = json.loads(jsonData) File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode ValueError: No JSON object could be decoded 23:20:57 T:140000985323264 NOTICE: HTTP response error: 400 Bad Request 23:20:57 T:140000985323264 ERROR: Exception in thread Thread-10: Traceback (most recent call last): File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/InfoUpdater.py", line 42, in run self.updateInfo() File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/InfoUpdater.py", line 74, in updateInfo result = json.loads(jsonData) File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode ValueError: No JSON object could be decoded 23:20:57 T:140001329260288 NOTICE: HTTP response error: 400 Bad Request 23:20:57 T:140001329260288 ERROR: Exception in thread Thread-1: Traceback (most recent call last): File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/threading.py", line 551, in __bootstrap_inner File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/InProgressItems.py", line 71, in run self.updateInProgress() File "/storage/.xbmc/addons/plugin.video.xbmb3c/resources/lib/InProgressItems.py", line 104, in updateInProgress result = json.loads(jsonData) File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/__init__.py", line 326, in loads File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 366, in decode File "/home/stephan/projects/openelec-master/build.OpenELEC-Generic.x86_64-devel/Python-2.7.3/.install_pkg/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode ValueError: No JSON object could be decoded Edited September 6, 2014 by KRA
xnappo 1611 Posted September 6, 2014 Posted September 6, 2014 Is that IP address right? 192.168.10.205:8096? It is just not finding the MB3 server. xnappo
KRA 39 Posted September 6, 2014 Posted September 6, 2014 (edited) that's why I added the ping output. telnet 192.168.10.205 8096 c HTTP/1.1 400 Bad Request Content-Type: text/html; charset=utf-8 Server: Mono-HTTPAPI/1.0 Date: Sat, 06 Sep 2014 22:19:32 GMT Content-Length: 52 Connection: close <h1>Bad Request (Invalid request line (parts).)</h1>Connection closed by foreign host Edited September 6, 2014 by KRA
KRA 39 Posted September 6, 2014 Posted September 6, 2014 (edited) From the same computer: telnet 192.168.10.205 8096 GET http://192.168.10.205:8096/mediabrowser/System/Info?format=json HTTP/1.0 HTTP/1.1 200 OK X-UA-Compatible: IE=Edge Vary: Accept X-Powered-By: ServiceStack/4.00 Unix/Mono Access-Control-Allow-Origin: * Access-Control-Allow-Methods: GET, POST, PUT, DELETE, OPTIONS Access-Control-Allow-Headers: Content-Type, Authorization, Range, X-MediaBrowser-Token Content-Type: application/json; charset=utf-8 Server: Mono-HTTPAPI/1.0 Date: Sat, 06 Sep 2014 22:27:30 GMT Content-Length: 1043 Connection: close {"OperatingSystem":"Unix 3.13.0.32","IsRunningAsService":false,"MacAddress":"00-0C-29-37-41-86","LocalAddress":"http://192.168.10.205:8096","HasPendingRestart":true,"IsNetworkDeployed":false,"InProgressInstallations":[],"WebSocketPortNumber":8096,"CompletedInstallations":[{"Id":"d5f0934f32e04263aebd6e6e4571b24c","Name":"Video Bookmarks","Version":"1.0.5360.41294","UpdateClass":"Release","PercentComplete":100}],"SupportsNativeWebSocket":true,"CanSelfRestart":false,"CanSelfUpdate":false,"FailedPluginAssemblies":[],"ProgramDataPath":"/home/hts/MB3/ProgramData-Server","ItemsByNamePath":"/home/hts/MB3/ProgramData-Server/ImagesByName","CachePath":"/mnt/NTFS/ts","LogPath":"/home/hts/MB3/ProgramData-Server/logs","InternalMetadataPath":"/home/hts/MB3/ProgramData-Server/data/metadata","TranscodingTempPath":"/mnt/NTFS/ts","HttpServerPortNumber":8096,"WanAddress":"http://********:8096","HasUpdateAvailable":false,"SupportsAutoRunAtStartup":false,"ServerName":"hts","Version":"3.0.5347.23908","Id":"07ea5db6-74a5-3ca4-1275-2bc70e2ec700"}Connection closed by foreign host Edited September 6, 2014 by KRA
KRA 39 Posted September 6, 2014 Posted September 6, 2014 Ignore the above. It's working again. I guess openelec boots into kodi to fast so the plugin was trying to connect before the wifi connection was established and thus failed. SO YES, PLUGIN SEEMS TO BE WORKING FINE WITH KODI GIT VERSION.
im85288 1493 Posted September 6, 2014 Posted September 6, 2014 Cool, you know there is an option in the openelec network settings to make it wait for a network connection before starting xbmc? I have to use it on one of my machines.
