MAX92 93 Posted April 22, 2021 Posted April 22, 2021 Bonjour Est-il prévu dans la roadmap que l'on puisse aussi modifier la vitesse de lecture sur Android TV comme sur Android ? Merci
Carlo 4561 Posted April 23, 2021 Posted April 23, 2021 18 hours ago, MAX92 said: Hello Is there a plan in the roadmap that we can also change the reading speed on Android TV as on Android? Thank you Hi, are you referring to playback speed? If so this is already in the ATV Beta.
MAX92 93 Posted April 23, 2021 Author Posted April 23, 2021 @cayars Yes that's it. How could I install the Beta on my AndroidTV ? 1
Carlo 4561 Posted April 23, 2021 Posted April 23, 2021 You can join the beta and get it from the store or maybe easier to download and side load it if you know how (pretty easy). The latest beta is in the top post here:
MAX92 93 Posted April 23, 2021 Author Posted April 23, 2021 @cayarsthanks. Do you know how to join the beta from store ? On android tv store there is no option or I don't find it
Carlo 4561 Posted April 23, 2021 Posted April 23, 2021 32 minutes ago, MAX92 said: @cayarsthanks. Do you know how to join the beta from store ? On android tv store there is no option or I don't find it Here you go. Info in first post.
MAX92 93 Posted April 24, 2021 Author Posted April 24, 2021 @cayarsthanks a lot again. I install the version 2.0.07g but I can't find the option for playbackspeed. Could you help me ?
Carlo 4561 Posted April 24, 2021 Posted April 24, 2021 Sure, While playing back media brink up the OSD and select the cog icon all the way to the right. You should now have menu with about the 4th item saying Speed: Normal Clicking on that option will allow you to change it. Let us know how you make out.
MAX92 93 Posted April 24, 2021 Author Posted April 24, 2021 Like Android application but I don't have this menu. Only : - Mode d'affichage - Zoom - Répéter - Correction de la lecture - Statistisque pour nerds Not speed like on my Emby application on my smartphone. I install 2.0.07g version on my ANDROID TV. What I am missing ?
Carlo 4561 Posted April 24, 2021 Posted April 24, 2021 What I described is from Android ATV 2.0.0.7g Registered @ebr Any ideas?
Luke 42240 Posted April 25, 2021 Posted April 25, 2021 I think this option may not have been added to the android tv app yet but @ebr can confirm.
Carlo 4561 Posted April 25, 2021 Posted April 25, 2021 It's in the current beta so won't be long before it hits release. 1
Carlo 4561 Posted April 25, 2021 Posted April 25, 2021 Curious, in one of the above pictures with the client version is "Inscit". What would that translate to in English?
Carlo 4561 Posted April 25, 2021 Posted April 25, 2021 OK, that would likely be the same as "Registered" in English. I'm not sure why you don't see the Speed setting in 2.0.0.7. Have you tried looking specifically at mp4 or mkv files played back?
Carlo 4561 Posted April 25, 2021 Posted April 25, 2021 Good enough. Would you mind opening a new thread in the Android Beta section of the forum showing what you see when you click on the cog icon (without the speed menu)? That would be the best place IMHO to address this since it's in beta.
