SuperRandy 0 Posted April 20, 2021 Posted April 20, 2021 Saludos, una molestia soy nuevo en esto y no encuentro la manera de actualizar mi Emby en mi freenas por el momento tengo la versión 4.2.1.0 de antemano muchas gracias por su apoyo No se cual es la manera de actualizarlo, si por medio de una maquina virtual o sell
Happy2Play 9811 Posted April 20, 2021 Posted April 20, 2021 (edited) 3 minutes ago, Luke said: 7 minutes ago, SuperRandy said: where can I download the emby par freenas update? Hi, FreeNAS setup instructions are on our website: https://emby.media/download.html Please let us know if this helps. Thanks, thanks. Reply from other posting. Edited April 20, 2021 by Happy2Play
SuperRandy 0 Posted April 20, 2021 Author Posted April 20, 2021 help for updating emby in freenas, the guidance they give is useless
SuperRandy 0 Posted April 20, 2021 Author Posted April 20, 2021 (edited) Quote Cheers, a bother I'm new to this and can't find a way to update my Emby on my freenas at the moment I have version 4.2.1.0 in advance thank you very much for your support I do not know what is the way to update it, if through a virtual machine or sell Edited April 20, 2021 by SuperRandy
Luke 42241 Posted April 25, 2021 Posted April 25, 2021 Hi there, what version of FreeNAS are you using?
