Apollo2021 0 Posted April 20, 2021 Posted April 20, 2021 Emby client for Android TV (v1.8.55g)crashed in Huawei HarmonyOS TV when startsup. It seems that the device might not have interface at URL content://android.media.tv/channel, so IllegalArgumentException was thrown. I can find the solution for same issue in Kodi. "[Android] fixed crash on harmony os TV. xbmc#19133 #19171" https://github.com/xbmc/xbmc/pull/19171 Please check and fix it, thank you.
Carlo 4561 Posted April 20, 2021 Posted April 20, 2021 Hi, the devs here may be able to work around this but this appears to be a HarmonyOS leanback issue which should get fixed at the source so it works correctly for all apps. So you may want to report to them as well. Thanks
Apollo2021 0 Posted April 20, 2021 Author Posted April 20, 2021 (edited) Thanks for your quick reply. I think HarmonyOS is different with Android, so it's difficult to add leanback or TIF support even if I try report the issue to them. ( Actually some user already reported this issue in the offical forum one years ago) Anyway, the Emby is important for me to explore and play the media in NAS. Could you please fix this issue in Emby side as KODI ? Thanks. Edited April 20, 2021 by Apollo2021
ebr 16338 Posted April 20, 2021 Posted April 20, 2021 Hi. I think we may have already fixed this a while ago (but it isn't in release yet). Can you please try the beta of the app?
Apollo2021 0 Posted April 22, 2021 Author Posted April 22, 2021 I tried the Beta version 2.0.06 on my device. The crash issue when start up has been fixed. But when I switched the Tab in Home screen, the app crashed frequently. I didn't test in other device. Anyway, i will test if the stable release version is available. Thanks a lot.
Apollo2021 0 Posted May 8, 2021 Author Posted May 8, 2021 Hi, I tested the latest Android TV release version (2.0.x). The app always crahsed when switch from "Favorite" to "Home" tab. I guess it is caused by access failure of interface like "URL content://android.media.tv/xxx". BTW. The mobile version works well in my device.
ebr 16338 Posted May 8, 2021 Posted May 8, 2021 8 hours ago, Apollo2021 said: The app always crahsed when switch from "Favorite" to "Home" tab. Hi. Can you please send a log from the app right after restarting after that crash? Thanks.
Apollo2021 0 Posted May 10, 2021 Author Posted May 10, 2021 On 5/8/2021 at 8:42 PM, ebr said: Hi. Can you please send a log from the app right after restarting after that crash? Thanks. Here is the log when crash happen. “Caused by: java.lang.IllegalArgumentException: Unknown URL content://android.media.tv/preview_program at android.content.ContentResolver.insert(ContentResolver.java:1840) at tv.emby.embyatv.integration.OreoChannelHelper.publishProgram(OreoChannelHelper.java:201) at tv.emby.embyatv.integration.OreoChannel.addNewProgram(OreoChannel.java:37)"
Apollo2021 0 Posted May 18, 2021 Author Posted May 18, 2021 On 5/10/2021 at 9:46 PM, ebr said: Thanks we'll try to trap that. Hello, ebr Will you fix this issue in next release? Or more logs is needed to locate the root cause? Best Regards.
ebr 16338 Posted May 18, 2021 Posted May 18, 2021 13 hours ago, Apollo2021 said: Hello, ebr Will you fix this issue in next release? Or more logs is needed to locate the root cause? Best Regards. This particular issue should already be addressed in the latest beta but there very well could be more on these devices that don't fully support the Android TV spec.
Apollo2021 0 Posted May 21, 2021 Author Posted May 21, 2021 On 5/18/2021 at 10:26 PM, ebr said: This particular issue should already be addressed in the latest beta but there very well could be more on these devices that don't fully support the Android TV spec. Hi, I tested the Android TV beta version 2.0.19, the crash still happen when switch from "Favorite" to "Home" tab. This is a key scenario, could you please check it again? Thanks.
