goenngoenn 2 Posted April 19, 2021 Posted April 19, 2021 Hey, theres some weird behaviour that started some days ago: When I let Auto organize do it's job it gets stuck at 10% and is working on my hard drive non stop. I don't know why it's doing that as everything was working fine before. I first tried to uninstall/reinstall the plug-in but that didn't help. I also noticed that all my settings have been saved so I guess there must be some configuration for auto organize that I couldn't find. In emby/plugins/ the autoorganize.dll is gone and in the configuration folder there's nothing that seems to store settings for autoorganize. Could someone help me out and tell me where autoorganize stores it's settings?
Carlo 4561 Posted April 19, 2021 Posted April 19, 2021 Hi, Have you tried removing the plugin, restart server, install plugin again and restart? If not, I would try that.
goenngoenn 2 Posted April 19, 2021 Author Posted April 19, 2021 1 hour ago, cayars said: Hi, Have you tried removing the plugin, restart server, install plugin again and restart? If not, I would try that. Just tried. It still has my saved settings from before and still gets stuck at 10%.
Happy2Play 9814 Posted April 19, 2021 Posted April 19, 2021 Config file not where I would expect it to be but it is in C:\Users\username\AppData\Roaming\Emby-Server\programdata\config. 1
Luke 42255 Posted April 19, 2021 Posted April 19, 2021 Perhaps it would be better to just go over an example: Thanks.
Happy2Play 9814 Posted April 19, 2021 Posted April 19, 2021 Almost sound like a bad configuration though.
Carlo 4561 Posted April 19, 2021 Posted April 19, 2021 That's what I was thinking as well. Either the config got corrupted on maybe there is a file "stuck" causing the issue.
goenngoenn 2 Posted April 20, 2021 Author Posted April 20, 2021 OK guys, I found the error. Inside my downloads folder there's also the incomplete downloads folder from sabnzbd. As autoorganize seems to scrape all those little archive files it seems to get stuck. I just changed the incomplete downloads folder to be outside of my actual download folder and now it works! Thanks to yall! 2
Carlo 4561 Posted April 20, 2021 Posted April 20, 2021 Thanks for the update and glad you got it working.
