rbjtech 5341 Posted March 13, 2022 Posted March 13, 2022 14 hours ago, SamES said: Thanks for testing this out. How many internal sub streams did your sample have? 41 ! Quote Complete name : M:\Demos\Dolby Vision\The.Afterparty.S01E08.2160p.ATVP.WEB-DL.DDP5.1.Atmos.DV.MP4.x265-DVSUX.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (isom/mp42/dby1) File size : 6.37 GiB Duration : 35 min 31 s Overall bit rate mode : Variable Overall bit rate : 25.7 Mb/s Encoded date : UTC 2022-03-04 06:36:54 Tagged date : UTC 2022-03-04 06:36:54 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 35 min 31 s Bit rate : 24.9 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.125 Stream size : 6.17 GiB (97%) Default : Yes Alternate group : 1 Encoded date : UTC 2022-03-04 06:36:41 Tagged date : UTC 2022-03-04 06:37:03 Codec configuration box : hvcC+dvcC Audio ID : 2 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Codec ID : ec-3 Duration : 35 min 31 s Bit rate mode : Constant Bit rate : 768 kb/s Maximum bit rate : 811 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 195 MiB (3%) Title : English Language : English Service kind : Complete Main Default : Yes Alternate group : 1 Tagged date : UTC 2022-03-04 06:37:03 Complexity index : Not present / 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE Text #1 ID : 3 Format : Timed Text Codec ID : tx3g Duration : 34 min 48 s Bit rate mode : Variable Bit rate : 108 b/s Stream size : 27.5 KiB (0%) Title : English Language : English Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #2 ID : 4 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 139 b/s Stream size : 36.1 KiB (0%) Title : Arabic Language : Arabic Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #3 ID : 5 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 141 b/s Stream size : 36.6 KiB (0%) Title : Bulgarian Language : Bulgarian Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #4 ID : 6 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 95 b/s Stream size : 24.8 KiB (0%) Title : Chinese-Cantonese Language : Chinese Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #5 ID : 7 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 99 b/s Stream size : 25.7 KiB (0%) Title : Chinese-Simplified Language : Chinese Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #6 ID : 8 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 104 b/s Stream size : 27.0 KiB (0%) Title : Chinese-Traditional Language : Chinese Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #7 ID : 9 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 94 b/s Stream size : 24.4 KiB (0%) Title : Czech Language : Czech Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #8 ID : 10 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 100 b/s Stream size : 25.9 KiB (0%) Title : Danish Language : Danish Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #9 ID : 11 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 89 b/s Stream size : 23.1 KiB (0%) Title : Dutch Language : Dutch Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #10 ID : 12 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 96 b/s Stream size : 24.8 KiB (0%) Title : Estonian Language : Estonian Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #11 ID : 13 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 96 b/s Stream size : 24.8 KiB (0%) Title : Finnish Language : Finnish Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #12 ID : 14 Format : Timed Text Codec ID : tx3g Duration : 35 min 10 s Bit rate mode : Variable Bit rate : 95 b/s Stream size : 24.4 KiB (0%) Title : French Language : French Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #13 ID : 15 Format : Timed Text Codec ID : tx3g Duration : 35 min 10 s Bit rate mode : Variable Bit rate : 95 b/s Stream size : 24.4 KiB (0%) Title : French Language : French Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #14 ID : 16 Format : Timed Text Codec ID : tx3g Duration : 35 min 23 s Bit rate mode : Variable Bit rate : 98 b/s Stream size : 25.3 KiB (0%) Title : German Language : German Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #15 ID : 17 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 165 b/s Stream size : 42.9 KiB (0%) Title : Greek Language : Greek Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #16 ID : 18 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 138 b/s Stream size : 35.8 KiB (0%) Title : Hebrew Language : Hebrew Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #17 ID : 19 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 265 b/s Stream size : 68.7 KiB (0%) Title : Hindi Language : Hindi Forced : No Encoded date : UTC 2022-03-04 06:36:58 Tagged date : UTC 2022-03-04 06:37:03 Text #18 ID : 20 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 99 b/s Stream size : 25.8 KiB (0%) Title : Hungarian Language : Hungarian Forced : No Encoded date : UTC 2022-03-04 06:36:59 Tagged date : UTC 2022-03-04 06:37:03 Text #19 ID : 21 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 108 b/s Stream size : 28.0 KiB (0%) Title : Indonesian Language : Indonesian Forced : No Encoded date : UTC 2022-03-04 06:36:59 Tagged date : UTC 2022-03-04 06:37:03 Text #20 ID : 22 Format : Timed Text Codec ID : tx3g Duration : 35 min 23 s Bit rate mode : Variable Bit rate : 109 b/s Stream size : 28.3 KiB (0%) Title : Italian Language : Italian Forced : No Encoded date : UTC 2022-03-04 06:36:59 Tagged date : UTC 2022-03-04 06:37:03 Text #21 ID : 23 Format : Timed Text Codec ID : tx3g Duration : 35 min 30 s Bit rate mode : Variable Bit rate : 87 b/s Stream size : 22.6 KiB (0%) Title : Japanese Language : Japanese Forced : No Encoded date : UTC 2022-03-04 06:36:59 Tagged date : UTC 2022-03-04 06:37:03 Text #22 ID : 24 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 114 b/s Stream size : 29.5 KiB (0%) Title : Korean Language : Korean Forced : No Encoded date : UTC 2022-03-04 06:36:59 Tagged date : UTC 2022-03-04 06:37:03 Text #23 ID : 25 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 104 b/s Stream size : 27.1 KiB (0%) Title : Latvian Language : Latvian Forced : No Encoded date : UTC 2022-03-04 06:36:59 Tagged date : UTC 2022-03-04 06:37:03 Text #24 ID : 26 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 103 b/s Stream size : 26.7 KiB (0%) Title : Lithuanian Language : Lithuanian Forced : No Encoded date : UTC 2022-03-04 06:36:59 Tagged date : UTC 2022-03-04 06:37:03 Text #25 ID : 27 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 103 b/s Stream size : 26.6 KiB (0%) Title : Malay Language : Malay Forced : No Encoded date : UTC 2022-03-04 06:37:02 Tagged date : UTC 2022-03-04 06:37:03 Text #26 ID : 28 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 87 b/s Stream size : 22.5 KiB (0%) Title : Norwegian Language : Norwegian Forced : No Encoded date : UTC 2022-03-04 06:37:02 Tagged date : UTC 2022-03-04 06:37:03 Text #27 ID : 29 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 95 b/s Stream size : 24.7 KiB (0%) Title : Polish Language : Polish Forced : No Encoded date : UTC 2022-03-04 06:37:02 Tagged date : UTC 2022-03-04 06:37:03 Text #28 ID : 30 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 101 b/s Stream size : 26.2 KiB (0%) Title : Portuguese Language : Portuguese Forced : No Encoded date : UTC 2022-03-04 06:37:02 Tagged date : UTC 2022-03-04 06:37:03 Text #29 ID : 31 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 95 b/s Stream size : 24.6 KiB (0%) Title : Portuguese Language : Portuguese Forced : No Encoded date : UTC 2022-03-04 06:37:02 Tagged date : UTC 2022-03-04 06:37:03 Text #30 ID : 32 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 151 b/s Stream size : 39.1 KiB (0%) Title : Russian Language : Russian Forced : No Encoded date : UTC 2022-03-04 06:37:02 Tagged date : UTC 2022-03-04 06:37:03 Text #31 ID : 33 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 95 b/s Stream size : 24.8 KiB (0%) Title : Slovak Language : Slovak Forced : No Encoded date : UTC 2022-03-04 06:37:02 Tagged date : UTC 2022-03-04 06:37:03 Text #32 ID : 34 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 80 b/s Stream size : 20.8 KiB (0%) Title : Slovenian Language : Slovenian Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #33 ID : 35 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 106 b/s Stream size : 27.6 KiB (0%) Title : Spanish Language : Spanish Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #34 ID : 36 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 105 b/s Stream size : 27.2 KiB (0%) Title : Spanish-EU Language : Spanish Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #35 ID : 37 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 101 b/s Stream size : 26.3 KiB (0%) Title : Swedish Language : Swedish Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #36 ID : 38 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 308 b/s Stream size : 79.8 KiB (0%) Title : Tamil Language : Tamil Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #37 ID : 39 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 280 b/s Stream size : 72.6 KiB (0%) Title : Telugu Language : Telugu Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #38 ID : 40 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 202 b/s Stream size : 52.4 KiB (0%) Title : Thai Language : Thai Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #39 ID : 41 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 105 b/s Stream size : 27.3 KiB (0%) Title : Turkish Language : Turkish Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #40 ID : 42 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 159 b/s Stream size : 41.3 KiB (0%) Title : Ukrainian Language : Ukrainian Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 Text #41 ID : 43 Format : Timed Text Codec ID : tx3g Duration : 35 min 24 s Bit rate mode : Variable Bit rate : 134 b/s Stream size : 34.7 KiB (0%) Title : Vietnamese Language : Vietnamese Forced : No Encoded date : UTC 2022-03-04 06:37:03 Tagged date : UTC 2022-03-04 06:37:03 1
Ceten 27 Posted March 13, 2022 Author Posted March 13, 2022 20 hours ago, rbjtech said: So I had a play today - and in summary, I can't appear to re-create the problem. I used a different file (but from the same scene-DVSUX) - so that may be the issue but I successfully - 1) Played back the original file on the LG Client using the LG Internal Speakers no issues - DV and Atmos triggered and played fine. NO SUBS - this forces a transcode. (subs were 'timed text - tx3g Codec ID in mediaInfo) 2) Demuxed the mp4 using mp4demuxer - into .265 and .ec3 - subs were saved with .DAT (?) 3) Remuxed the video and audio components above into a new .mp4 using mp4muxer - set DV profile as 5 (same as original) - no subs. 4) This new file played back just fine as well - triggering DV and Atmos. So - you can try doing the demux/remux to see if that fixes the issue (but you'll lose subs as I couldn't find a way to embed these - external .srt subs didn't appear to work either ) If you can upload the original file to dropbox or something (or pm me the magnet link) then I'm happy to try with that, but its looking like the file in it's original mux may not be compatible with the Emby wrapper of the LG Client ... Thanks for looking into it. I've watched numerous releases from the same group without issues like Yellowjackets, Foundation, Acapulco, The King's Man, Shang-Chi and the Legend of the Ten Rings and probably a few other movies in mp4 with DV and atmos from this or a different group. I can't see any clear difference between the files that work and those that don't. After playing a bit with mp4 demuxer and remuxer tools I managed to remux the Falcon and the Winter Soldier file I originally had issues with and thought that was just a one off, but then I got it with a different release of the same episode and other movies and series as well. I'll PM you some magnet links for files that had issues as they're quite big for Dropbox. 2
Ceten 27 Posted March 13, 2022 Author Posted March 13, 2022 (edited) deleted Edited March 13, 2022 by Ceten Disregard this post, posted multiple times due to forum error. If an admin could delete it that would be great.
rbjtech 5341 Posted March 14, 2022 Posted March 14, 2022 So the issue appears to be poorly muxed files. I've managed to re-create the issue myself using the same files as the OP, and they are all 24fps - not 23.976 as they should be. A remux using mp4muxer fails on them, while other files from the same source (but 23.976) re-mux ok. In summary, I think the source files are 'non-standard' in some way - thus the LG Client is having audio timing issues on them. Interestingly, the Android player via a Shield has no such issues. @SamES - I'm not sure if there is much that can be done here - other than perhaps a framerate Audio/Video mismatch in the Emby streaming pipeline on the LG Client ? - as when played on a USB stick, there are no such issues (according the OP, I have not tested this). 1
Ceten 27 Posted March 14, 2022 Author Posted March 14, 2022 16 minutes ago, rbjtech said: So the issue appears to be poorly muxed files. I've managed to re-create the issue myself using the same files as the OP, and they are all 24fps - not 23.976 as they should be. A remux using mp4muxer fails on them, while other files from the same source (but 23.976) re-mux ok. In summary, I think the source files are 'non-standard' in some way - thus the LG Client is having audio timing issues on them. Interestingly, the Android player via a Shield has no such issues. @SamES - I'm not sure if there is much that can be done here - other than perhaps a framerate Audio/Video mismatch in the Emby streaming pipeline on the LG Client ? - as when played on a USB stick, there are no such issues (according the OP, I have not tested this). I think you're onto something here. I checked the media info for some more mp4 files and all those with issues are indeed 24fps, all the ones without are 23.976. I just looked it up and apparently some streaming services like Disney+ which are the source for big part of these files with audio distortion now release files with 24fps: https://www.flatpanelshd.com/news.php?subaction=showfull&id=1629438832 . The Witcher also seems to be 24fps: https://discussions.apple.com/thread/250993105?page=2 . So I guess the framerate for the files is correct but there are issues with playback in the LG client? 1
rbjtech 5341 Posted March 14, 2022 Posted March 14, 2022 6 minutes ago, Ceten said: I think you're onto something here. I checked the media info for some more mp4 files and all those with issues are indeed 24fps, all the ones without are 23.976. I just looked it up and apparently some streaming services like Disney+ which are the source for big part of these files with audio distortion now release files with 24fps: https://www.flatpanelshd.com/news.php?subaction=showfull&id=1629438832 . The Witcher also seems to be 24fps: https://discussions.apple.com/thread/250993105?page=2 . So I guess the framerate for the files is correct but there are issues with playback in the LG client? Yep - 24fps is a 'valid' framerate - but I'm wondering if there is some sort of mismatch going on in the Emby LG Client - as per your observations and my testing - It's not immediately obvious that there is a problem until you get 2-3 mins in - THEN you get the audio breakup issue. I believe it's the same if you jump to a chapter - Audio is ok again (as it re-sync's the AV) but then again after 2-3 mins you get the audio breakup. So I'm thinking the AV are not keeping up with each other or the LG Client is timing it (or just the Audio) as 23.976 when infact its 24 fps.. 1
SamES 1084 Posted March 14, 2022 Posted March 14, 2022 So do you think these are files that are actually 23.976 fps but are being reported as 24 fps or are the actually 24 fps?
SamES 1084 Posted March 14, 2022 Posted March 14, 2022 5 hours ago, rbjtech said: @SamES - I'm not sure if there is much that can be done here - other than perhaps a framerate Audio/Video mismatch in the Emby streaming pipeline on the LG Client ? - as when played on a USB stick, there are no such issues (according the OP, I have not tested this). I doubt there is much we can do. We can't do much aside from give it a url for playback. Alternative is to try and detect and transcode, but that has a whole lot of other issues, so it doesn't fix anything. How quick/easy is it to fix these? The fact that mp4muxer also fails suggests this is more than just a cosmetic issue.
rbjtech 5341 Posted March 14, 2022 Posted March 14, 2022 6 minutes ago, SamES said: So do you think these are files that are actually 23.976 fps but are being reported as 24 fps or are the actually 24 fps? They should be valid 24fps files, as Disney+ uses 24fps, not 23.976 And they work perfectly fine in Emby Android TV and via USB on the LG (no Emby). So I think there may be an issue with the combination of Emby > HTTP > LG Client with 24fps - as the OP has said there are no issues with 23.976fps files with the same 4K HEVC DV profile 5 and EAC3 Atmos Audio tracks.
SamES 1084 Posted March 15, 2022 Posted March 15, 2022 Not sure if either of these help? LG TVs Will Now Automatically Disable the Dreaded Motion Smoothing for Prime Video (gizmodo.com.au) 24p content is unwatchable on my LG CX : OLED (reddit.com)
rbjtech 5341 Posted March 15, 2022 Posted March 15, 2022 Hi @SamES - on the Emby Client, can you confirm if it is actually using the LG playback engine as opposed to Exo for example ? If yes, then what are the differences between streaming the data in via HTTP vs loading it from local storage (USB) ? Is it possible that during the 'reconstruction' of the http stream for the LG player, it is not doing this correctly ? If this done from an existing LG Library/API ? if yes, then maybe the issue is actually with LG to fix - and there is nothing that Emby can do about this at this time. @Ceten the other alternative is to a) use a different client or b) maybe try to use a difference media source (but I suspect you'll get the same issue) 1
Ceten 27 Posted March 16, 2022 Author Posted March 16, 2022 I did some tests with more of these files and when playing from USB there were no issues. Is there a way to play the files directly from the Synology share instead of using the http stream to test if this makes a difference?
rbjtech 5341 Posted March 16, 2022 Posted March 16, 2022 1 hour ago, Ceten said: I did some tests with more of these files and when playing from USB there were no issues. Is there a way to play the files directly from the Synology share instead of using the http stream to test if this makes a difference? On the Android Shield yes (but that doesn't have an issue playing them anyway - but to note, my test WAS actually via SMB Direct (called 'File' mode), it was not via HTTP), however, on the LG App there is no way to do this. The Dev's will need to answer why the same file plays ok with the same 'player' via a direct USB (non Emby) - I find that odd too and that is what I was trying to explain above..
SamES 1084 Posted March 16, 2022 Posted March 16, 2022 5 minutes ago, rbjtech said: The Dev's will need to answer why the same file plays ok with the same 'player' via a direct USB (non Emby) - I find that odd too and that is what I was trying to explain above.. I can't really say why this would be the case. It's possible that the internal player has some capabilities that are not exposed to apps. 1
Ceten 27 Posted April 5, 2022 Author Posted April 5, 2022 So conclusion is this is an edge case which can't be solved and will give more issues in the future as more 24fps content becomes available? I guess I'll be better of just buying an Nvidia Shield. @rbjtech, it's been a while since I looked into it, can you tell me if the shield now has reliable refresh rate switching with the Emby app before I purchase one?
rbjtech 5341 Posted April 5, 2022 Posted April 5, 2022 9 minutes ago, Ceten said: So conclusion is this is an edge case which can't be solved and will give more issues in the future as more 24fps content becomes available? I guess I'll be better of just buying an Nvidia Shield. @rbjtech, it's been a while since I looked into it, can you tell me if the shield now has reliable refresh rate switching with the Emby app before I purchase one? Hi - I have used the Shield Pro (2019) as the primary player (with refresh rate switching) for my LG TV for the last couple of years with zero issues - All 23.976 and 24 fps HDR, DV, MKV & MP4 content has played just fine. For full disclosure, I use a Shield Pro > Denon AVR, I don't use the TV speakers - so the difference is you will be passing the Audio(+ Video) from the Shield to the TV, but I see no reason why this should cause you any issues. 1
Ceten 27 Posted April 5, 2022 Author Posted April 5, 2022 25 minutes ago, rbjtech said: Hi - I have used the Shield Pro (2019) as the primary player (with refresh rate switching) for my LG TV for the last couple of years with zero issues - All 23.976 and 24 fps HDR, DV, MKV & MP4 content has played just fine. For full disclosure, I use a Shield Pro > Denon AVR, I don't use the TV speakers - so the difference is you will be passing the Audio(+ Video) from the Shield to the TV, but I see no reason why this should cause you any issues. Thanks! Guess I'll be ordering a Shield Pro then, that will solve the support for TrueHD and PGS subs as well. I'd love to have a dedicated surround set again but our current home has no place to put a center speaker so tv audio will have to do for now. 1
