WesMegatron 1 Posted April 18, 2021 Posted April 18, 2021 I am unable to login to my server from emby fire tv. However if I use the silk browser on the same Fire TV I am able to login fine. Here is the log that shows the failure from the emby app and then the success with the same account from the browser emberserver.txt
Carlo 4561 Posted April 18, 2021 Posted April 18, 2021 Try removing/deleting the server that shows up at login. Restart the app and see if you can login after that. If not try deleting app info from the system menu and trying again which should remove cached info.
ebr 16338 Posted April 18, 2021 Posted April 18, 2021 Make sure noting is installed on the Fire or network that could interfere - like a VPN.
Luke 42246 Posted April 20, 2021 Posted April 20, 2021 Hi @WesMegatron, are you still having an issue with this?
WesMegatron 1 Posted April 20, 2021 Author Posted April 20, 2021 Hello yes I am. There are no vpns installed. I am actually seeing the behavior on the fire tvs and a roku tv
WesMegatron 1 Posted April 20, 2021 Author Posted April 20, 2021 Cayars i have tried everything you suggested. Same issue
Carlo 4561 Posted April 20, 2021 Posted April 20, 2021 18 minutes ago, WesMegatron said: Cayars i have tried everything you suggested. Same issue Sorry to heat that. Are you using Emby Connect or logging in directly? Are these all local or remote connections?
WesMegatron 1 Posted April 20, 2021 Author Posted April 20, 2021 (edited) I have tried both. Neither works. This all has worked for over a year and just stopped working after I tried to change pw. I know the pw I am using is correct because I can login using a browser. These are all local connections Edited April 20, 2021 by WesMegatron
Carlo 4561 Posted April 20, 2021 Posted April 20, 2021 Any chance you could setup a "Carlo" account with access to a single (any) lib or something and PM your server IP/domain and a password so I can try to login? I'd offer remote assistance but there often isn't a lot I can do for non web clients remotely but not ruling that out.
Happy2Play 9813 Posted April 20, 2021 Posted April 20, 2021 (edited) @ebr@Luke would there be a issue with old server and newer client authentication? But don't necessarily know client version. Version: 4.3.1.0 2021-04-18 08:14:43.226 Error HttpServer: Error processing request *** Error Report *** Version: 4.3.1.0 Command line: /system/EmbyServer.dll -programdata /config -ffdetect /bin/ffdetect -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.19.41.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///system/System.Private.CoreLib.dll Processor count: 4 Program data path: /config Application directory: /system SQLitePCL.pretty.SQLiteException: Constraint: NOT NULL constraint failed: Tokens.DeviceId SQLitePCL.pretty.SQLiteException: Exception of type 'SQLitePCL.pretty.SQLiteException' was thrown. at SQLitePCL.pretty.SQLiteException.CheckOk(sqlite3 db, Int32 rc) at SQLitePCL.pretty.StatementImpl.MoveNext() at Emby.Server.Implementations.Security.AuthenticationRepository.Create(AuthenticationInfo info) at Emby.Server.Implementations.Session.SessionManager.GetAuthorizationToken(User user, String deviceId, String app, String appVersion, String deviceName) at Emby.Server.Implementations.Session.SessionManager.AuthenticateNewSessionInternal(AuthenticationRequest request, Boolean enforcePassword, CancellationToken cancellationToken) at MediaBrowser.Api.UserService.Post(AuthenticateUserByName request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: SQLitePCL.pretty TargetSite: Void CheckOk(SQLitePCL.sqlite3, Int32) Is there a point when client become incompatible with server version? Edited April 20, 2021 by Happy2Play 1
Solution Luke 42246 Posted April 20, 2021 Solution Posted April 20, 2021 @WesMegatron are you able to update to a newer version of emby server?
WesMegatron 1 Posted April 20, 2021 Author Posted April 20, 2021 Upgraded to the new version and that worked. Thank you for the help 1
