LeidenSpain 33 Posted April 18, 2021 Posted April 18, 2021 Hi, I have some chapters of series in two parts, or concerts in several files, but the system by parts that is indicated in movies does not work or if it is indicated that it is series or music Quote Split video files (file stacking) The following are default stacking extensions that can be added to file names. # can be 1 through 9 or A through D. Stacking is supported for video files (but only when each video is in its own folder as in the example below) as well as dvd and blu-ray folder structures. Split videos require all parts be in the same movie folder with no other videos present in that folder. part# cd# dvd# pt# disk# disc# You can also use: moviename#.ext Where # can be A through D. For example, I have a concert like this: But with the latest beta it looks like this: That is the duration of the first file
ebr 16309 Posted April 18, 2021 Posted April 18, 2021 Hi. For something like multi-disc concerts, if you want them to remain as distinct parts, the best way would be to make them each their own movie and then you can put them in a collection if you want to display them together. If you want them to merge into one item, the best approach is to actually merge the files into one.
LeidenSpain 33 Posted April 18, 2021 Author Posted April 18, 2021 (edited) However, it is possible to do it in the movies category (Split video files) . Why not add the same possibility for the music and series category? Edited April 18, 2021 by LeidenSpain
ebr 16309 Posted April 18, 2021 Posted April 18, 2021 7 minutes ago, LeidenSpain said: Why not add the same possibility for the music and series category? Hi. We will probably eventually get there but these things require time and resources which are our main limits so we have to apply the resources to the highest impact activities that will help the largest groups of users and then get to smaller things as we can. So I'm giving you some options that should work better for you right now. Thanks. 1
