nireins1981 0 Posted April 17, 2021 Posted April 17, 2021 Hi together, i use the Emby App on all my apple TV 4k and it runs good. However, when I want to fast-forward a film, it happens at a very high speed. With a tap or swipe, about 120 seconds or more are fast forwarded. I tried to somehow reduce this in the settings, unfortunately without success. Am I doing something wrong? Is it wanted like that? greetings
Luke 42241 Posted April 25, 2021 Posted April 25, 2021 Hi there, we're looking into improving it. Thanks for reporting.
manfredell2 2 Posted April 25, 2021 Posted April 25, 2021 There's another issue here: When I use the original Apple Remote a tap fast forwards (too much) but then continues playing BUT when I use an alternate command (Logitech harmony or others) it just fast forwards and does not stop forwarding (I have to hit play for it to start playing but then I have forwarded ages). The same on Plex works fine and just jumps forward no matter which command I use. There should be a setting in Emby to be able to define the fast forward action: forward/rewind x seconds.....
Luke 42241 Posted April 25, 2021 Posted April 25, 2021 10 hours ago, manfredell2 said: There's another issue here: When I use the original Apple Remote a tap fast forwards (too much) but then continues playing BUT when I use an alternate command (Logitech harmony or others) it just fast forwards and does not stop forwarding (I have to hit play for it to start playing but then I have forwarded ages). The same on Plex works fine and just jumps forward no matter which command I use. There should be a setting in Emby to be able to define the fast forward action: forward/rewind x seconds..... That's helpful. Thanks for the info.
LightMoon 1 Posted August 28, 2021 Posted August 28, 2021 Hi Luke, Any road maps for this? It’s been almost 4 months
bbking67 1 Posted November 22, 2021 Posted November 22, 2021 I'm also having this problem... otherwise the apple tv client is good. My Android and Fire TV boxes all fast forward perfectly. Is there a way I can use a universal remote to fix the behaviour? It would be nice if pressing the right direction just shot forward 10 seconds (or a configurable amount). Please fix this!
Skillz001 0 Posted January 12, 2022 Posted January 12, 2022 I fixed this on my new Apple TV 4K by disabling the MPV player (for some reason that was enabled by default). You can change that setting in (Settings -> Playback Settings -> Enable MPV) and unchecking the box. Hope that helps anyone that has this issue. The crazy transport speed was the only thing making me want to use a different app.
Luke 42241 Posted January 12, 2022 Posted January 12, 2022 Hi, yes the issue is with our mpv player option. We're looking into it. Thanks.
