MAX92 93 Posted April 24, 2021 Author Posted April 24, 2021 2 hours ago, cayars said: Not in the pics you showed above. They look very similar. And now you see ?
Carlo 4561 Posted April 24, 2021 Posted April 24, 2021 What are we looking at? Is this tone mapped or played in 4K? If tone mapped have you tried switching:
MAX92 93 Posted April 24, 2021 Author Posted April 24, 2021 1 hour ago, cayars said: What are we looking at? Is this tone mapped or played in 4K? If tone mapped have you tried switching: We are looking a zoom of picture : left MPC, right EMBY. I don't understand what you mean "Is this tone mapped or played in 4K?" And I don't know where is the option Tone Mapping Algorithm. Sorry @cayars
Carlo 4561 Posted April 24, 2021 Posted April 24, 2021 Oh this is just a 1080 file or lower resolution?
Carlo 4561 Posted April 24, 2021 Posted April 24, 2021 SDR or HDR? But these are being played back on a 1080 TV or desktop or 4K desktop? Did these direct play or transcode? I ask because of the resolution being shown in your pictures.
MAX92 93 Posted April 24, 2021 Author Posted April 24, 2021 (edited) HDR played on my 1080 TV in direct play. This weekend, I will try it on my VideoProjector 4k. Do you want specific movie, scene, picture ? If I can.... Edited April 24, 2021 by MAX92
Carlo 4561 Posted April 24, 2021 Posted April 24, 2021 (edited) OK so here's the thing. If you are trying to play an HDR file on an SDR display it's going to need to be tone mapped or it will usually looked washed out. Some devices like a Shield or MiBox can tone map on the device. Emby 4.6 can tone map at the server side. Can you post a picture of what you see for this media down at the bottom of the detail screen? All the codec type info. Edited April 25, 2021 by cayars
Carlo 4561 Posted April 25, 2021 Posted April 25, 2021 So you're issue is HDR displayed on SDR displays it would seem. Beta Server 4.6 can do HDR to SDR tone mapping but will need client options before it's optimal. If you can get by on 1080 displays for now, you may not want to go down the 3rd party route as this will change shortly. With that said you still could adjust MPV options in the mpv config file and we have lots of threads on this here in the forums. Each person may need different settings so there isn't a set of one-stop shopping settings to use.
