sereneden 0 Posted October 3, 2023 Posted October 3, 2023 (edited) Dear Sirs! Please let me know how it's possible to install this plugin at Emby server (based on Synology NAS). Thank you in advance! Edited October 3, 2023 by sereneden
svyaznoy362 17 Posted October 3, 2023 Author Posted October 3, 2023 1 minute ago, sereneden said: Уважаемые господа! Пожалуйста, дайте мне знать, как можно установить этот плагин на сервер Emby (на базе Synology NAS). Заранее спасибо! Скачать с гитхаба , положить по пути в Сино: /var/lib/emby/plugins Перезагрузить сино
sereneden 0 Posted October 3, 2023 Posted October 3, 2023 1 minute ago, svyaznoy362 said: Скачать с гитхаба , положить по пути в Сино: /var/lib/emby/plugins Перезагрузить сино Ясно, через putty. Спасибо огромное!
sereneden 0 Posted October 4, 2023 Posted October 4, 2023 18 hours ago, svyaznoy362 said: Скачать с гитхаба , положить по пути в Сино: /var/lib/emby/plugins Перезагрузить сино Такой папки нет. Возможно, что верная /var/packages/EmbyServer/var/plugins?
sereneden 0 Posted October 4, 2023 Posted October 4, 2023 2023-10-04 16:38:20.633 Error App: Error getting version number from /var/packages/EmbyServer/var/plugins/EmbyKinopoiskRu.dll Вот такая ошибка.
Carlo 4561 Posted October 5, 2023 Posted October 5, 2023 15 hours ago, sereneden said: 2023-10-04 16:38:20.633 Error App: Error getting version number from /var/packages/EmbyServer/var/plugins/EmbyKinopoiskRu.dll Вот такая ошибка. You should check with the creator of the plugin to see if it has been designed to work with Emby and if it has been tested.
svyaznoy362 17 Posted October 5, 2023 Author Posted October 5, 2023 (edited) Этот плагин прекрасно работает с synology, Ubuntu. Edited October 5, 2023 by svyaznoy362
jelum 36 Posted October 12, 2023 Posted October 12, 2023 (edited) On 10/4/2023 at 4:48 PM, sereneden said: 2023-10-04 16:38:20.633 Error App: Error getting version number from /var/packages/EmbyServer/var/plugins/EmbyKinopoiskRu.dll Вот такая ошибка. нужны логи старта emby. какая версия .net? Можно открыть issue на github - я получу извещение об этом Edited October 12, 2023 by jelum 1
svyaznoy362 17 Posted November 23, 2023 Author Posted November 23, 2023 (edited) On 11/14/2022 at 8:14 PM, Luke said: Обзоры фильмов в настоящее время не поддерживаются, но я хотел бы добавить их в будущих обновлениях. Спасибо. @Люк Add reviews and third-party trailers, since a lot of traders from YouTube are not available. I use the kinopoisk plugin and you can get all this there, the developer @jelum can add it, but you don’t want to add it. Also, please add the plugin to the plugins section, the plugin is great for Russian-speaking audiences. Edited November 23, 2023 by svyaznoy362
ruvid 1 Posted June 21, 2024 Posted June 21, 2024 Hi everyone, sorry for sputid question, but i cannot copy EmbyKinopoiskRu.dll file into /var/packages/EmbyServer/var/plugins. I saw a lot of manual and videos about root permission, but can't copy it: access denied. Throught Putty or WinSCP, after a lot of commands like sudi -i sudo synouser and etc. I also changed vi /etc/ssh/sshd_config and edit string with #PermitRootLogin prohibit-password on PermitRootLogin yes (then reboot) - not helped. Access denied. What my wrong? Help please
svyaznoy362 17 Posted June 21, 2024 Author Posted June 21, 2024 2 minutes ago, ruvid said: Привет всем, извините за банальный вопрос, но я не могу скопировать файл EmbyKinopoiskRu.dll в /var/packages/EmbyServer/var/plugins. Я видел много руководств и видеороликов о правах root, но не могу их скопировать: доступ запрещен. Через Putty или WinSCP, после множества команд вроде sudi -i sudo synouser и т. д. Я также изменил vi /etc/ssh/sshd_config и отредактировал строку с #PermitRootLogin запретить пароль на PermitRootLogin да (затем перезагрузился) - не помогло. Доступ запрещен. В чем моя ошибка? Помоги пожалуйста Привет , у тебя сервер на synology ?
ruvid 1 Posted June 21, 2024 Posted June 21, 2024 (edited) 7 minutes ago, svyaznoy362 said: Привет , у тебя сервер на synology ? Привет, О, на русском можно) да, synology оригинальная (DSM 7.2.1-69057 Update 5) Edited June 21, 2024 by ruvid
svyaznoy362 17 Posted June 21, 2024 Author Posted June 21, 2024 34 minutes ago, ruvid said: Привет, О, по-английски можно) да, Synology оригинальная (DSM 7.2.1-69057 Обновление 5) Try to drop it here and restart the server /volume1/@appdata/EmbyServer/plugins
ruvid 1 Posted June 21, 2024 Posted June 21, 2024 4 minutes ago, svyaznoy362 said: Try to drop it here and restart the server /volume1/@appdata/EmbyServer/plugins the same
Solution svyaznoy362 17 Posted June 21, 2024 Author Solution Posted June 21, 2024 15 minutes ago, ruvid said: одинаковый Try it through the scheduler
ruvid 1 Posted June 21, 2024 Posted June 21, 2024 32 minutes ago, svyaznoy362 said: Try it through the scheduler sorry for another stupid question, but how do it through the scheduler?)
ruvid 1 Posted June 23, 2024 Posted June 23, 2024 (edited) Hi all, may be this information helps to anybody: 1. Instead of i get root rights to user (not "root") - you need to use exactly "root" name when you ssh connect throught WinSCP. 2. I've copy file to /var/packages/EmbyServer/var/plugins (not in /volume1/@appdata/EmbyServer/plugins) 3. After you copy file, you need to change rights and "owner": owner - from "root" to "emby"; rights - from 0600 to 0644; 4. Then restart emby server. 5. Then turn off ssh Edited June 23, 2024 by ruvid 1
vobok 0 Posted July 4, 2024 Posted July 4, 2024 Помогите пожалуйста ни как не получается установить плагин emby.kinopoisk.ru! Система: Windows Server версия Jellyfin 10.9.7 Плагин EmbyKinopoiskRu v.1.25.2 Как я понял из инструкции: беру файл EmbyKinopoiskRu.dll (с https://github.com/luzmane/emby.kinopoisk.ru/releases) и кладу в папку: "C:\Program Files\Jellyfin\Server\plugins" перезагружаю Jellyfin Но ничего не происходит плагин не появляется
seanbuff 1356 Posted July 4, 2024 Posted July 4, 2024 14 minutes ago, vobok said: "C:\Program Files\Jellyfin\Server\plugins" reboot Jellyfin Hi, this community forum is dedicated only to Emby software. You don't appear to be running Emby, therefore your question should probably be directed elsewhere. Thanks. 1
svyaznoy362 17 Posted July 4, 2024 Author Posted July 4, 2024 (edited) 43 minutes ago, vobok said: Помогите пожалуйста ни как не получается установить плагин emby.kinopoisk.ru! Система: Windows Server версия Jellyfin 10.9.7 Плагин EmbyKinopoiskRu v.1.25.2 Как я понял из инструкции: беру файл EmbyKinopoiskRu.dll (с https://github.com/luzmane/emby.kinopoisk.ru/releases) и кладу в папку: "C:\Program Files\Jellyfin\Server\plugins" перезагружаю Jellyfin Но ничего не происходит, пожалуйста, не появляйтесь Для jellyfin надо прописать репозиторий , но для jellyfin проект не особо развивается. https://raw.githubusercontent.com/luzmane/jellyfin.kinopoisk.ru/manifest/manifest.json Edited July 4, 2024 by svyaznoy362
svyaznoy362 17 Posted June 2, 2025 Author Posted June 2, 2025 (edited) On 11/12/2022 at 12:05 AM, jelum said: Ссылка на плагин: https://github.com/luzmane/emby.kinopoisk.ru/releases Идет обсуждение перед возможным появлением в каталоге: @Luke The plugin appeared 3 years ago and works great, during all this time you still haven't implemented the ability to add reviews, the kinopoisk API has such an option. @jelum correct me, what should the developers do to make reviews available in the plugin. Edited June 2, 2025 by svyaznoy362
Luke 42239 Posted June 2, 2025 Posted June 2, 2025 11 hours ago, svyaznoy362 said: @Luke The plugin appeared 3 years ago and works great, during all this time you still haven't implemented the ability to add reviews, the kinopoisk API has such an option. @jelum correct me, what should the developers do to make reviews available in the plugin. reviews of what exactly?
svyaznoy362 17 Posted June 2, 2025 Author Posted June 2, 2025 3 minutes ago, Luke said: reviews of what exactly? https://emby.media/community/index.php?/topic/97117-kinopoisk/#findComment-1020475 1
jelum 36 Posted June 5, 2025 Posted June 5, 2025 On 6/2/2025 at 8:21 AM, svyaznoy362 said: @Luke The plugin appeared 3 years ago and works great, during all this time you still haven't implemented the ability to add reviews, the kinopoisk API has such an option. @jelum correct me, what should the developers do to make reviews available in the plugin. As far as I remember, it's a part of the Kinopoisk API, so it's doable
