svyaznoy362 17 Posted April 16, 2021 Posted April 16, 2021 (edited) Привет, возможно адаптировать плагин jellyfin-plugin-kinopoisk для emby? https://github.com/LinFor/jellyfin-plugin-kinopoisk Edited April 16, 2021 by svyaznoy362
Carlo 4561 Posted April 20, 2021 Posted April 20, 2021 Not much info to read about it. What does this plugin do?
Luke 42239 Posted April 28, 2021 Posted April 28, 2021 Looks like it is a Movie metadata provider. Is MovieDb not sufficient?
svyaznoy362 17 Posted May 17, 2021 Author Posted May 17, 2021 Да все верно это поставщик метаданных фильмов. MovieDb достаточно, а можно попросить добавить отзывы к фильмам
Luke 42239 Posted August 8, 2021 Posted August 8, 2021 The reviews in your screenshot are not moviedb. Those are rotten tomatoes.
svyaznoy362 17 Posted August 10, 2021 Author Posted August 10, 2021 (edited) Люк, я не понял, можно ли добавить отзывы фильмов на ваш сервер? Edited August 12, 2021 by svyaznoy362
svyaznoy362 17 Posted August 10, 2021 Author Posted August 10, 2021 I would also like to ask you to display the names of the actors also in Cyrillic
Luke 42239 Posted August 14, 2021 Posted August 14, 2021 Hi, we get these names from MovieDb. I'm not sure they have them in Cyrillic. @Happy2Play do you know?
Happy2Play 9811 Posted August 14, 2021 Posted August 14, 2021 10 minutes ago, Luke said: Hi, we get these names from MovieDb. I'm not sure they have them in Cyrillic. @Happy2Play do you know? My understanding is currently no. #764 Add the ability to translate person biographies and names Translate cast crew - Talk — The Movie Database Translations of actors' names - Talk — The Movie Database But looks like something that is being worked on
svyaznoy362 17 Posted April 7, 2022 Author Posted April 7, 2022 Привет, что там с отзывами ? Не придумали?
VSider 3 Posted April 20, 2022 Posted April 20, 2022 Hello Luke and Emby team. Just encountered that movie metadata no longer fetched in my Emby due to the fact themoviedb.org is no longer available from Russia : The Amazon CloudFront distribution is configured to block access from your country. So I came up to this topic in search of possibility to use www.kinopoisk.ru as a source of metadata. What do you think, is it possible to use it with Emby somehow? PS. I already thought about putting Emby behind VPN, but streaming high bitrate video via VPN will be problematic.
VSider 3 Posted April 20, 2022 Posted April 20, 2022 omdb works (so far). However the data from omdb is quite poor (missing actors, english only descriptions, little images, etc.), without web-search capability. Kinopoisk on the other hand is well-administred resourse with lots of data, good web-interface, official api. But mostly in Russian.
slyfox 48 Posted May 2, 2022 Posted May 2, 2022 +1 Plex and Jellyfin have Kinopoisk plugins. Would be great to see Kinopoisk.ru available for Emby
svyaznoy362 17 Posted September 8, 2022 Author Posted September 8, 2022 Добавьте для России пожалуйста КиноПоиск , уж очень печально , что poster не всегда грузятся https://kinopoiskapiunofficial.tech/
jelum 36 Posted November 11, 2022 Posted November 11, 2022 Ссылка на плагин: https://github.com/luzmane/emby.kinopoisk.ru/releases Идёт тестирование перед возможным добавлением в каталог: 1
Luke 42239 Posted November 11, 2022 Posted November 11, 2022 1 hour ago, jelum said: Ссылка на плагин: https://github.com/luzmane/emby.kinopoisk.ru/releases Идёт тестирование перед возможным добавлением в каталог: Hi, thanks for sharing.
svyaznoy362 17 Posted November 14, 2022 Author Posted November 14, 2022 (edited) On 12.11.2022 at 00:05, jelum said: Ссылка на приложение: https://github.com/luzmane/emby.kinopoisk.ru/releases Идет тестирование перед возможным дополнением в каталоге: Привет. Спасибо за плагин. Есть пожелание , возможно добавить отзывы и отображение актёров на кириллице. В целом приложение отличное. Edited November 14, 2022 by svyaznoy362
jelum 36 Posted November 14, 2022 Posted November 14, 2022 Имена на кириллице - будут дубли с актёрами на английском из других источников. Как вариант, можно добавить флаг на каком языке отображать. Посмотрю Отзывы. Я не уверен, что они поддерживаются Emby. Ответь с картинкой, где они видны в Emby. @Luke do you know if Emby supports Movie review field? If yes, can you point direction. If no, is it possible to add a new field to Metadata and screen from plugin perspective?
Luke 42239 Posted November 14, 2022 Posted November 14, 2022 4 hours ago, jelum said: Имена на кириллице - будут дубли с актёрами на английском из других источников. Как вариант, можно добавить флаг на каком языке отображать. Посмотрю Отзывы. Я не уверен, что они поддерживаются Emby. Ответь с картинкой, где они видны в Emby. @Luke do you know if Emby supports Movie review field? If yes, can you point direction. If no, is it possible to add a new field to Metadata and screen from plugin perspective? Movie reviews are not currently supported, but I'd like to add them in future updates. Thanks. 1 1
jelum 36 Posted November 14, 2022 Posted November 14, 2022 @Luke, thanks @svyaznoy362, проверь настройки библиотеки (предпочтительные языки, приоритет плагина - если он стоит после другого, то просто дополняет пропущенные поля и т.п.), у меня без изменения кода отображаются имена актёров на русском языке. Роли на английском - такими они приходят от сторонних сервисов (и думаю, на кинопоиске они тоже на английском) 1
pavel3y 1 Posted January 22, 2023 Posted January 22, 2023 Подскажите, после установки нужно ли в настройках плагина прописать API? Если да, то какой? Где взять эти данные?
jelum 36 Posted January 23, 2023 Posted January 23, 2023 нет, надо выбрать тот api, с которым ты хочешь работать. детали - на странице плагина на гитхабе
alexpunga148 4 Posted April 1, 2023 Posted April 1, 2023 Не работает на Shield TV Pro 2019 embyserver.txt
svyaznoy362 17 Posted May 24, 2023 Author Posted May 24, 2023 (edited) @Like, hi. Please add the kinopoisk metadata selector to the repository. I've been using it for 6 months, I'm happy with everything, special thanks to the developer @jelum. Also, please implement the ability to add reviews, the developer can add them to this metadata selector, it's up to you. Thank you. https://github.com/luzmane/emby.kinopoisk.ru/releases Edited May 24, 2023 by svyaznoy362 1
