ptr727 1 Posted April 15, 2021 Posted April 15, 2021 (edited) Hi, one reason I installed Emby alongside Plex was in hopes of Emby playing 50fps 1080p material, e.g. UK Top Gear Season 30. But, play, long time spinner, black screen, down arrow, timer is counting, looks like it is playing, but no video and no sound. Here is the similar report on Plex: https://forums.plex.tv/t/unable-to-playback-50fps-content-on-android-tv/659756/21 Other than 1000s and 1000s of `HttpClient: POST https://api.opensubtitles.org/xml-rpc` entries, I don't see anything in the server log. The same media plays instantly in the web browser, but fails to play on the Shield. Server log: attached Client log: Submitted: ~4:49pm PST Shield 2019 Pro name: Game Room User: Pieter Server name: Emby-Direct embyserver.50fps.debug.log Edited April 15, 2021 by ptr727 Logs
Luke 42246 Posted April 16, 2021 Posted April 16, 2021 Hi, as a test, can you try sideloading our standard android app and see how that compares? https://emby.media/emby-for-android.html Thanks.
Q-Droid 1011 Posted April 16, 2021 Posted April 16, 2021 There must be more to this issue because I play 1080p 50fps content very often. MotoGP and F1 that I watch on the Shield stream without any problems and as far as I can remember they are direct playing.
ptr727 1 Posted April 16, 2021 Author Posted April 16, 2021 5 minutes ago, Q-Droid said: There must be more to this issue because I play 1080p 50fps content very often. MotoGP and F1 that I watch on the Shield stream without any problems and as far as I can remember they are direct playing. Agree. Never used to have issues with 50fps material, first noticed the issue with Top Gear Season 30, could be related to a Shield update, could be an underlying tool update e.g. ffmpeg.
ptr727 1 Posted April 16, 2021 Author Posted April 16, 2021 (edited) 1 hour ago, Luke said: Hi, as a test, can you try sideloading our standard android app and see how that compares? https://emby.media/emby-for-android.html Thanks. I'll figure out how and report back. In the mean time, feel free to PM me for a reproducing media file. Edited April 16, 2021 by ptr727
ptr727 1 Posted April 16, 2021 Author Posted April 16, 2021 2 hours ago, Luke said: Hi, as a test, can you try sideloading our standard android app and see how that compares? https://emby.media/emby-for-android.html Thanks. Do I use the 64bit build on an nvidia shield 2019 pro? https://github.com/MediaBrowser/Emby.Releases/tree/master/android Is the vanilla android build equivalent to the TV build, I could not find daily/beta releases for TV, only old builds? https://github.com/MediaBrowser/Emby.Releases/tree/master/androidtv
ebr 16338 Posted April 16, 2021 Posted April 16, 2021 Hi. Unfortunately, I cannot see any playback in your log. Nothing you did wrong, just the Android system being difficult. The beta version changes a lot with playback so trying it would be a good place to start.
ptr727 1 Posted April 16, 2021 Author Posted April 16, 2021 Ok, I joined the Beta, will give it another try the weekend.
Carlo 4561 Posted April 16, 2021 Posted April 16, 2021 Just curious but in the ATV app what do you have set for "Enable Refresh Rate Switching" in Playback Settings?
ptr727 1 Posted April 16, 2021 Author Posted April 16, 2021 I enable refresh rate switching, in the Shield, not ATV. I've not tried without it on Emby, but on Plex I tried with refresh rate switching on/off, resolution switching on/off, no difference. Will try it out tonight when I test the Beta. I also have the same experience on three systems, two are LG TV's, and one is a Samsung TV, two are old Shield models, one is a new Shield Pro 2019 model, two go through a Marantz AVR, one goes direct to TV.
Carlo 4561 Posted April 16, 2021 Posted April 16, 2021 Lots of combinations to test with that setup. Have you check to see if you have other 50fps content? Other 50fps content might work perfectly which could indicate it has something to do with the encoding of this one series. Something to think about and test perhaps! 1
ptr727 1 Posted April 17, 2021 Author Posted April 17, 2021 I switched to the Beta server build and the Beta client, and it plays the content just fine Unless the Beta's cause me issues, I'll just stick with the Beta builds. Thanks for the help.
