TugboatBill 16 Posted April 14, 2021 Posted April 14, 2021 Hi, I'm trying to set up a RPi4 Libreelec to remotely access my Emby Server. I've had the server set up for a while and using a browser it can be connected to remotely. Everything works great! However today when I put together a RPi4 with Libreelec I can't get it to connect. Libreelec is v9.2.6 (Kodi 18.9.0). Emby server is 4.5.4.0 (Synology). In the connect to server box I have the host entered as http://MyRemoteEmbyServer.cf and port number to 80 (same as I use for remote access using a browser). After a short while I get "Unable to connect to the selected server" message. Under the addon (Emby for Kodi) settings I tried entering the Username, server name, and IP for the emby server address but that didn't seem to help. log-2021-04-14-22.39.15.zip
TugboatBill 16 Posted April 15, 2021 Author Posted April 15, 2021 I am testing this from my LAN. If I go to chrome and enter http://myremoteembyserver.cf I get the Emby Please sign in screen. Kodi (Librelec) still doesn't work. Does anyone have an idea as to what is different with using Kodi vs a browser when connecting over the internet?
quickmic 1709 Posted April 19, 2021 Posted April 19, 2021 (edited) Is Kodi connecting via internet or Lan? If Internet, does Kodi have access to Internet? Sound like a network issue. Do you use Embyconnect? Also you can try Emby next gen plugin Edited April 19, 2021 by quickmic
TugboatBill 16 Posted April 19, 2021 Author Posted April 19, 2021 (edited) I was able to get EmbyCon to work using https. However I was never able to get the Emby addon to work under this scenario. Edited April 19, 2021 by TugboatBill
