Frank27 0 Posted April 14, 2021 Posted April 14, 2021 Hola, os ha pasado alguna vez en emby que con emby conect no te accede al servidor y tienes que meter la ip manualmente? sabe alguien por que pasa y como solucionarlo? gracias
Carlo 4561 Posted April 14, 2021 Posted April 14, 2021 This could happen if your WAN IP has just recently changed. Emby will adjust but it's not instant.
Luke 42241 Posted April 15, 2021 Posted April 15, 2021 Hi, yes it may take a few hours. Are you still having an issue?
Frank27 0 Posted April 16, 2021 Author Posted April 16, 2021 On 4/15/2021 at 4:03 AM, Luke said: Hi, yes it may take a few hours. Are you still having an issue? Yes, even if it takes several hours / days ... it still does not work, I know several people who also experience the same thing and we do not know the reason why
Carlo 4561 Posted April 16, 2021 Posted April 16, 2021 Hi, Try removing the Emby Connect username, save, add back EC username and save again. See if that works.
Luke 42241 Posted April 16, 2021 Posted April 16, 2021 Are you sure they are signing in with Emby Connect? Perhaps they are just entering the server address manually, in which case, they would need to do that again.
