Luke 42241 Posted June 28, 2021 Posted June 28, 2021 Unfortunately there's not much we can do to correct this. If they are direct playing then it is a problem with the browser video player on your device. The best we could do is offer a way to transcode them. Currently there are ways you can force that, such as lowering the in-app quality setting for example.
Alexwerilles 3 Posted June 29, 2021 Author Posted June 29, 2021 23 hours ago, Luke said: Unfortunately there's not much we can do to correct this. If they are direct playing then it is a problem with the browser video player on your device. The best we could do is offer a way to transcode them. Currently there are ways you can force that, such as lowering the in-app quality setting for example. So is it a problem with all Samsung smartphones? Because as I reported, this only happens with Samsung phones and the web version of Emby. Until version 4.5.0.50 of Emby, there was no problem. This problem started after this release (4.5.1)
Luke 42241 Posted June 29, 2021 Posted June 29, 2021 I understand you want to pin it on the emby update, but it could have started with an os update, browser update, etc. Or perhaps it's isolated to certain characteristics within a video file. But if it is direct playing as you say it is, then emby server is simply feeding the browser the original file as is.
