gokuz 13 Posted April 14, 2021 Posted April 14, 2021 I have read a ton of past posts saying there's a "plus" button in collection. But I can't find it anywhere.
GrimReaper 4861 Posted April 14, 2021 Posted April 14, 2021 7 minutes ago, gokuz said: I have read a ton of past posts saying there's a "plus" button in collection. But I can't find it anywhere. Where are you looking for it?
gokuz 13 Posted April 14, 2021 Author Posted April 14, 2021 4 minutes ago, GrimReaper76 said: Where are you looking for it? Everywhere. I can't locate a "plus" button. How do you create custom collection?
GrimReaper 4861 Posted April 14, 2021 Posted April 14, 2021 (edited) 4 minutes ago, gokuz said: Everywhere. I can't locate a "plus" button. How do you create custom collection? On any item inside your Library (either on Poster in Library view or in Item Detail view), click "three-dot" menu, select "Add to Collection" in dropdown, on following screen either click "+ New Collection" or select existing one. Edited April 14, 2021 by GrimReaper76 Typo
gokuz 13 Posted April 14, 2021 Author Posted April 14, 2021 7 minutes ago, GrimReaper76 said: On any item inside your Library (either on Poster in Library view or in Item Detail view), click "three-dot" menu, select "Add to Collection" in dropdown, on following screen either click "+ New Collection" or select existing one. Cool, found it thanks! Another question, seems like Emby doesn't respect ASCII Sort order. I used "space" so I'd be on top. What order does emby use?
GrimReaper 4861 Posted April 14, 2021 Posted April 14, 2021 5 minutes ago, gokuz said: Cool, found it thanks! Another question, seems like Emby doesn't respect ASCII Sort order. I used "space" so I'd be on top. What order does emby use? Sort order of what? List of Collections inside Collections Library or Items inside a Collection?
gokuz 13 Posted April 14, 2021 Author Posted April 14, 2021 1 minute ago, GrimReaper76 said: Sort order of what? List of Collections inside Collections Library or Items inside a Collection? Sort title in terms of naming. ASCII Sort order, the top should be empty space.
Luke 42203 Posted April 14, 2021 Posted April 14, 2021 https://support.emby.media/support/solutions/articles/44001159487-collections
gokuz 13 Posted April 14, 2021 Author Posted April 14, 2021 1 minute ago, Luke said: https://support.emby.media/support/solutions/articles/44001159487-collections thanks, guess my googling sucks
GrimReaper 4861 Posted April 14, 2021 Posted April 14, 2021 1 minute ago, gokuz said: Sort title in terms of naming. ASCII Sort order, the top should be empty space. You can Edit Medatada on any Collection, there's a 'Sort title' field there there in which you can insert value for that collection to show placed as you want, i.e. on top or at the bottom.
gokuz 13 Posted April 15, 2021 Author Posted April 15, 2021 10 hours ago, GrimReaper76 said: You can Edit Medatada on any Collection, there's a 'Sort title' field there there in which you can insert value for that collection to show placed as you want, i.e. on top or at the bottom. How do I change it from [Oldest > Newest] to [Newest to Oldest]?
Happy2Play 9802 Posted April 15, 2021 Posted April 15, 2021 Currently there are only two options, Sortname or Releasedate. There is no ascending/descending.
gokuz 13 Posted April 15, 2021 Author Posted April 15, 2021 22 minutes ago, Happy2Play said: Currently there are only two options, Sortname or Releasedate. There is no ascending/descending. That's a huge bummer, would love to see more options, date added etc, as some collections are quite huge 30>
