Samsung Smart TV
Go to solution Solved by umair9,
Any reason why there is no effort being put into developing the app? I really like Emby my reason for purchasing the lifetime membership. I tried out Plex a couple of weeks ago and it is seamless on the Samsung TV. I was disappointed to see that Emby has not done the same.
I understand there are instructions to install the application manually which I've also failed on. In comparison to Plex - you don't have to go to the trouble to configure the install.
Super seamless - no joke
  • Solution
Ok, never mind. It seems to work. I just tried and sure enough it loads. I did not side load anything.
Thanks for the feedback !
