jasonwilliams 37 Posted April 13, 2021 Posted April 13, 2021 Hello, I'm using Android on a Galaxy Tab S8 with Emby from the playstore and I have a problem when using Bluetooth audio. When trying to playback AC3 5.1 audio, I get the error "No Compatible Streams". The same media will play if I use the builtin speakers on the Galaxy Tab. It plays successfully on Bluetooth if I use the Web Client running in Chrome on the device. Is Bluetooth audio supported using the app? Thanks, Jason
Carlo 4561 Posted April 13, 2021 Posted April 13, 2021 Just to help understanding this. Do you already have BT audio working before you start Emby?
jasonwilliams 37 Posted April 13, 2021 Author Posted April 13, 2021 Hi cayars, Yes, BT is working generally on the device. I can playback with BT through the Emby Web Client. It is just the Playstore client for Emby that doesn't playback with BT audio. 1
Luke 42243 Posted April 15, 2021 Posted April 15, 2021 can you please supply an android app log? Thanks.
jasonwilliams 37 Posted April 15, 2021 Author Posted April 15, 2021 Hi Luke, Thank you. I have attached the log. d5dcb1bd-0df9-4825-b570-2aec29ca320f.log
Luke 42243 Posted April 15, 2021 Posted April 15, 2021 Hmm. Would you mind providing an android system bug report: https://developer.android.com/studio/debug/bug-report#bugreportdevice So basically you'll need to first enable developer options on your device, then open up the Emby app, recreate the problem, and then follow the steps in the link above to obtain a bug report. Then please attach that here. Thanks !
jasonwilliams 37 Posted April 15, 2021 Author Posted April 15, 2021 No worries. I've attached a report. I hope I did it correctly. bugreport-2021-04-15-15-56-13.zip
revengineer 142 Posted April 18, 2021 Posted April 18, 2021 (edited) @Luke Is this essentially the same issue that we are sorting out for my Live TV issues? v3.1.80 breaks live tv Edited April 18, 2021 by revengineer
Luke 42243 Posted April 18, 2021 Posted April 18, 2021 It might be but we don't know that for sure yet.
Luke 42243 Posted April 20, 2021 Posted April 20, 2021 Can you try this version: https://www.dropbox.com/s/u1obwrckg4lkjc8/emby-android-google-armeabi-v7a-release.apk?dl=0 Thanks.
revengineer 142 Posted April 21, 2021 Posted April 21, 2021 I have played TV for ~5 hours through Bluetooth and all seems to be working well. I will continue to test but am cautiously optimistic that the issue is resolved. Will keep you posted if something changes. 1
jasonwilliams 37 Posted April 21, 2021 Author Posted April 21, 2021 It's also working for me. I'm still testing different formats, but so far it has worked perfectly. I'll post again tomorrow after further testing to confirm. Thanks!! 1
jasonwilliams 37 Posted April 22, 2021 Author Posted April 22, 2021 Hi All, I spent the entire day endurance testing various types of media (FLAC, H.264, Live TV, MP3, BluRay) and the audio never fails. At this point I'd say the solution works! I'm a heavy user of the Android client, so I will update this thread if anything changes, but for now the solution is delivered. Thanks for the help! Jason 1
Luke 42243 Posted April 22, 2021 Posted April 22, 2021 Hi, version 3.1.92 has been pushed to the store to resolve this. Thanks. 1
revengineer 142 Posted April 22, 2021 Posted April 22, 2021 I have continued to test with and without Bluetooth and this version really seems solid again.
