Carlo 4561 Posted April 14, 2021 Posted April 14, 2021 Did you restart all you equipment after getting new IPs? What IP does Emby Server show now? What IP does canyouseeme.org show? Are they the same IP is the question.
Meetteek 2 Posted April 14, 2021 Author Posted April 14, 2021 62.143.75.98 ja es ist dieselbe ja router wurde neu gestartet nachdem ich Ipv4 bekommen habe, habe die ports auch noch mal neu freigegeben.
Meetteek 2 Posted April 14, 2021 Author Posted April 14, 2021 (edited) Habe ebenfalls mit dem Programm "advance port scanner" meine Pc Ports gescheckt worauf Emby läuft. Port 135 (TCP) Microsoft Windows RPC Port 139 (TCP) Microsoft Windows netbios-ssn Port 445 (TCP) Port 1462 (TCP) Microsoft HTTPAPI httpd 2.0 SSDP/UPnP Port 5040 (TCP) Port 5357 (TCP) Microsoft HTTPAPI httpd 2.0 SSDP/UPnP Port 7680 (TCP) Port 8077 (TCP) Port 27036 (TCP) Valve Steam In-Home Streaming service TLSv1.2 PSK Port 49664 (TCP) Port 49665 (TCP) Port 49666 (TCP) Port 49667 (TCP) Port 49668 (TCP) Port 49669 (TCP) Port 65414 (TCP) Edited April 14, 2021 by Meetteek
Carlo 4561 Posted April 14, 2021 Posted April 14, 2021 I can tracert to your IP address so that looks promising. What does canyouseeme.org show now when you test connecting to port 8096?
Meetteek 2 Posted April 14, 2021 Author Posted April 14, 2021 Error: I could not see your service on 62.143.75.98 on port (8096) Reason: Connection timed out
Carlo 4561 Posted April 14, 2021 Posted April 14, 2021 I'd offer to remote in and take a look but I'm not sure I can help as I think this is likely an ISP or fritz box config issue which I likely can't help with. Well I suppose it wouldn't hurt. You want to give it a try?
Meetteek 2 Posted April 14, 2021 Author Posted April 14, 2021 (edited) So ich kann neus mitteilen .Eben einfach mal die ganze sache neu installiert . und nun funktioniert es. Warum , wieso keine ahnung. Freue mich sehr darüber das es Läuft ich bedanke mich für eure Hilfe vielleicht hat von euch jemand eine erklärung. Dauert die umstellung auf dual stack so lange ? Edit auf Canuseeme.org can ich den port nun auch sehen. Edited April 14, 2021 by Meetteek
Carlo 4561 Posted April 14, 2021 Posted April 14, 2021 It likely did take a while for it to go through. Either way congrats on getting it working! 1
Georg22 2 Posted November 27, 2021 Posted November 27, 2021 hallo ist das möglich das mein dashboard z.b mit port 8080 funktioniert und für meine freunde 8081 z.b wo kommt der port für feunde und wo kommt der port für dass dashboard
Luke 42241 Posted November 27, 2021 Posted November 27, 2021 5 hours ago, Georg22 said: hallo ist das möglich das mein dashboard z.b mit port 8080 funktioniert und für meine freunde 8081 z.b wo kommt der port für feunde und wo kommt der port für dass dashboard @Georg22 Hallo, Sie können Ihre öffentlich zugänglichen Ports in den Emby Server-Netzwerkeinstellungen konfigurieren: https://support.emby.media/support/solutions/articles/44001159601-hosting-settings Dabei müssen Sie möglicherweise auch die Portweiterleitung in Ihrem Router konfigurieren: https://support.emby.media/support/solutions/articles/44001849007-connectivity Bitte lassen Sie es uns wissen, wenn dies hilft. Vielen Dank.
Georg22 2 Posted November 28, 2021 Posted November 28, 2021 hallo Luke ich benutze dedicated server kein local netzwerk ich möchte nur wissen wo kommt der port für mein dashbaord und wo kommt der port für freunde. weil denn selben port zu nutzen für den panel und für denn benutzer finde ich nicht gut kannst du mir das kurzlich erklären in zwei schritten ich muss dann denn port im mein dedicated server öffnen z.b ein port für panel und eine port für freunde. thanks
Luke 42241 Posted December 1, 2021 Posted December 1, 2021 On 11/27/2021 at 8:51 PM, Georg22 said: hallo Luke ich benutze dedicated server kein local netzwerk ich möchte nur wissen wo kommt der port für mein dashbaord und wo kommt der port für freunde. weil denn selben port zu nutzen für den panel und für denn benutzer finde ich nicht gut kannst du mir das kurzlich erklären in zwei schritten ich muss dann denn port im mein dedicated server öffnen z.b ein port für panel und eine port für freunde. thanks https://support.emby.media/support/solutions/articles/44002137137-remote-setup Please let us know if this helps. Thanks.
netmenx 0 Posted March 6, 2022 Posted March 6, 2022 (edited) Edition Windows 11 Pro Version 21H2 Installiert am 20.02.2022 Betriebssystembuild 22000.527 Leistung Windows Feature Experience Pack 1000.22000.527.0 Hallo ich kan mich nicht verbinden mit meiner emby server von auf emby tv .warum ? firewall port 8096 on. Bei windows habe ich nie problem jetzt will nicht funktionieren .kann jemand helfen? Edited March 6, 2022 by netmenx
Luke 42241 Posted March 6, 2022 Posted March 6, 2022 8 minutes ago, netmenx said: Edition Windows 11 Pro Version 21H2 Installiert am 20.02.2022 Betriebssystembuild 22000.527 Leistung Windows Feature Experience Pack 1000.22000.527.0 Hallo ich kan mich nicht verbinden mit meiner emby server von auf emby tv .warum ? firewall port 8096 on. Bei windows habe ich nie problem jetzt will nicht funktionieren .kann jemand helfen? Hallo, was passiert genau, wenn du es versuchst? Wie genau versuchst du dich zu verbinden?
netmenx 0 Posted March 6, 2022 Posted March 6, 2022 aplictation emby tv über emby connect bin ich gemeldet aber findet meine server nicht.war immer so das abei starten emby auf tv oder handy mein server war sichtbar musste nur password schreiben und war ok jetzt verbindetnichts. ;(
Luke 42241 Posted March 6, 2022 Posted March 6, 2022 Hi, did you try entering your server address manually into the app instead?
Luke 42241 Posted March 8, 2022 Posted March 8, 2022 On 3/7/2022 at 7:31 AM, netmenx said: yes not work @netmenx what exactly did you do, what did you enter, and what exactly happened?
