Przemek 70 Posted April 12, 2021 Posted April 12, 2021 Hello, I install Kodi on Debian based Dietpi system [intel HP Mini PC]. There's Kodi version: 17.6. Debian 10, kernel 4.19.0-16. Emby addon log shows: The dependency on script.module.request version 2.3.0 could not be satisfied EmbyCon is installed but when I run it I have connection error. Do I have to get last Kodi version to make Emby works on it or is some other way to fix this? regards, Przemek
Luke 42237 Posted April 12, 2021 Posted April 12, 2021 Hi there, please attach the complete log file. thanks.
Przemek 70 Posted April 12, 2021 Author Posted April 12, 2021 Hi @LukeI don't know where to find full kodi log. In app there's only sentence I add in first post. regards, Przemek
Luke 42237 Posted April 12, 2021 Posted April 12, 2021 OK, thanks. Which addon did that log entry come from?
Przemek 70 Posted April 12, 2021 Author Posted April 12, 2021 I add repository: http://emby.kodi.media and there's Emby addon stable and beta. I tried both and there was the same dependency issue. Then I install EmbyCon and it installed OK but when I run it there's connection error only. No entry in Kodi log. regards.
Przemek 70 Posted April 12, 2021 Author Posted April 12, 2021 OK @Luke I find Kodi log: root@DietPi:~/.kodi/temp# cat kodi.log 22:40:53.880 T:139631773328128 NOTICE: special://profile/ is mapped to: special://masterprofile/ 22:40:53.880 T:139631773328128 NOTICE: ----------------------------------------------------------------------- 22:40:53.880 T:139631773328128 NOTICE: Starting Kodi from Debian (17.6 Debian package version: 2:17.6+dfsg1-4+b1). Platform: Linux x86 64-bit 22:40:53.880 T:139631773328128 NOTICE: Using Release Kodi from Debian x64 build 22:40:53.880 T:139631773328128 NOTICE: Kodi from Debian compiled from 2:17.6+dfsg1-4+b1 by GCC 8.2.0 for Linux x86 64-bit version 4.19.16 (267024) 22:40:53.880 T:139631773328128 NOTICE: Running on Debian GNU/Linux 10 (buster), kernel: Linux x86 64-bit version 4.19.0-16-amd64 22:40:53.880 T:139631773328128 NOTICE: FFmpeg version/source: 4.1.6-1~deb10u1 22:40:53.880 T:139631773328128 NOTICE: Host CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz, 4 cores available 22:40:53.880 T:139631773328128 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi 22:40:53.880 T:139631773328128 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi 22:40:53.880 T:139631773328128 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi/addons 22:40:53.880 T:139631773328128 NOTICE: special://masterprofile/ is mapped to: /root/.kodi/userdata 22:40:53.880 T:139631773328128 NOTICE: special://envhome/ is mapped to: /root 22:40:53.880 T:139631773328128 NOTICE: special://home/ is mapped to: /root/.kodi 22:40:53.880 T:139631773328128 NOTICE: special://temp/ is mapped to: /root/.kodi/temp 22:40:53.880 T:139631773328128 NOTICE: special://logpath/ is mapped to: /root/.kodi/temp 22:40:53.880 T:139631773328128 NOTICE: The executable running is: /usr/lib/x86_64-linux-gnu/kodi/kodi.bin 22:40:53.880 T:139631773328128 NOTICE: Local hostname: DietPi 22:40:53.880 T:139631773328128 NOTICE: Log File is located: /root/.kodi/temp//kodi.log 22:40:53.880 T:139631773328128 NOTICE: ----------------------------------------------------------------------- 22:40:53.887 T:139631773328128 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files 22:40:53.887 T:139631773328128 ERROR: DBus: Error org.freedesktop.systemd1.UnitMasked - Unit systemd-logind.service is masked. 22:40:53.888 T:139631773328128 ERROR: Previous line repeats 4 times. 22:40:53.888 T:139631773328128 WARNING: LogindUPowerSyscall - failed to inhibit sleep delay lock 22:40:53.889 T:139631773328128 NOTICE: load settings... 22:40:53.903 T:139631773328128 ERROR: PulseAudio: Failed to connect context 22:40:53.903 T:139631773328128 NOTICE: PulseAudio might not be running. Context was not created. 22:40:53.973 T:139631773328128 NOTICE: Found 1 Lists of Devices 22:40:53.973 T:139631773328128 NOTICE: Enumerated ALSA devices: 22:40:53.973 T:139631773328128 NOTICE: Device 1 22:40:53.973 T:139631773328128 NOTICE: m_deviceName : default 22:40:53.973 T:139631773328128 NOTICE: m_displayName : Default (HDA Intel PCH CX20632 Analog) 22:40:53.973 T:139631773328128 NOTICE: m_displayNameExtra: 22:40:53.973 T:139631773328128 NOTICE: m_deviceType : AE_DEVTYPE_PCM 22:40:53.973 T:139631773328128 NOTICE: m_channels : FL,FR,BL,BR 22:40:53.973 T:139631773328128 NOTICE: m_sampleRates : 44100,48000,96000,192000 22:40:53.973 T:139631773328128 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE 22:40:53.973 T:139631773328128 NOTICE: m_streamTypes : No passthrough capabilities 22:40:53.973 T:139631773328128 NOTICE: Device 2 22:40:53.973 T:139631773328128 NOTICE: m_deviceName : @:CARD=PCH,DEV=0 22:40:53.973 T:139631773328128 NOTICE: m_displayName : HDA Intel PCH 22:40:53.973 T:139631773328128 NOTICE: m_displayNameExtra: CX20632 Analog 22:40:53.973 T:139631773328128 NOTICE: m_deviceType : AE_DEVTYPE_PCM 22:40:53.973 T:139631773328128 NOTICE: m_channels : FL,FR,BL,BR 22:40:53.973 T:139631773328128 NOTICE: m_sampleRates : 48000 22:40:53.973 T:139631773328128 NOTICE: m_dataFormats : AE_FMT_S32NE 22:40:53.973 T:139631773328128 NOTICE: m_streamTypes : No passthrough capabilities 22:40:53.973 T:139631773328128 NOTICE: Device 3 22:40:53.973 T:139631773328128 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0 22:40:53.973 T:139631773328128 NOTICE: m_displayName : HDA Intel PCH 22:40:53.973 T:139631773328128 NOTICE: m_displayNameExtra: HDMI #0 22:40:53.973 T:139631773328128 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 22:40:53.973 T:139631773328128 NOTICE: m_channels : FL,FR 22:40:53.973 T:139631773328128 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000 22:40:53.973 T:139631773328128 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW 22:40:53.973 T:139631773328128 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD 22:40:53.973 T:139631773328128 NOTICE: Device 4 22:40:53.973 T:139631773328128 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=1 22:40:53.973 T:139631773328128 NOTICE: m_displayName : HDA Intel PCH 22:40:53.973 T:139631773328128 NOTICE: m_displayNameExtra: SAM SAMSUNG on HDMI #1 22:40:53.973 T:139631773328128 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 22:40:53.973 T:139631773328128 NOTICE: m_channels : FL,FR 22:40:53.973 T:139631773328128 NOTICE: m_sampleRates : 32000,44100,48000 22:40:53.973 T:139631773328128 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW 22:40:53.973 T:139631773328128 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD 22:40:53.973 T:139631773328128 NOTICE: Device 5 22:40:53.973 T:139631773328128 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=2 22:40:53.973 T:139631773328128 NOTICE: m_displayName : HDA Intel PCH 22:40:53.973 T:139631773328128 NOTICE: m_displayNameExtra: HDMI #2 22:40:53.973 T:139631773328128 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 22:40:53.973 T:139631773328128 NOTICE: m_channels : FL,FR 22:40:53.973 T:139631773328128 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000 22:40:53.973 T:139631773328128 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW 22:40:53.973 T:139631773328128 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD 22:40:53.973 T:139631773328128 NOTICE: Device 6 22:40:53.973 T:139631773328128 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=3 22:40:53.973 T:139631773328128 NOTICE: m_displayName : HDA Intel PCH 22:40:53.973 T:139631773328128 NOTICE: m_displayNameExtra: HDMI #3 22:40:53.973 T:139631773328128 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 22:40:53.973 T:139631773328128 NOTICE: m_channels : FL,FR 22:40:53.973 T:139631773328128 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000 22:40:53.973 T:139631773328128 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW 22:40:53.973 T:139631773328128 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD 22:40:53.973 T:139631773328128 NOTICE: Device 7 22:40:53.973 T:139631773328128 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=4 22:40:53.973 T:139631773328128 NOTICE: m_displayName : HDA Intel PCH 22:40:53.973 T:139631773328128 NOTICE: m_displayNameExtra: HDMI #4 22:40:53.973 T:139631773328128 NOTICE: m_deviceType : AE_DEVTYPE_HDMI 22:40:53.973 T:139631773328128 NOTICE: m_channels : FL,FR 22:40:53.973 T:139631773328128 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000 22:40:53.973 T:139631773328128 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW 22:40:53.973 T:139631773328128 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD 22:40:53.974 T:139631773328128 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml) 22:40:53.974 T:139631773328128 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml) 22:40:53.974 T:139631773328128 NOTICE: Default Video Player: VideoPlayer 22:40:53.974 T:139631773328128 NOTICE: Default Audio Player: paplayer 22:40:53.974 T:139631773328128 NOTICE: Disabled debug logging due to GUI setting. Level 0. 22:40:53.974 T:139631773328128 NOTICE: Log level changed to "LOG_LEVEL_NORMAL" 22:40:53.974 T:139631773328128 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml 22:40:53.975 T:139631773328128 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml. 22:40:53.975 T:139631773328128 NOTICE: Loaded playercorefactory configuration 22:40:53.975 T:139631773328128 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml. 22:40:53.975 T:139631773328128 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping. 22:40:53.978 T:139631773328128 NOTICE: Running database version Addons27 22:40:54.013 T:139631773328128 NOTICE: ADDONS: Using repository repository.emby.kodi 22:40:54.013 T:139631773328128 NOTICE: ADDONS: Using repository repository.beta.emby.kodi 22:40:54.378 T:139631773328128 NOTICE: Checking resolution 16 22:40:54.454 T:139631773328128 NOTICE: Using visual 0x20 22:40:54.473 T:139631773328128 NOTICE: GL_VENDOR = Intel Open Source Technology Center 22:40:54.473 T:139631773328128 NOTICE: GL_RENDERER = Mesa DRI Intel(R) HD Graphics 630 (Kaby Lake GT2) 22:40:54.473 T:139631773328128 NOTICE: GL_VERSION = 3.0 Mesa 18.3.6 22:40:54.473 T:139631773328128 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30 22:40:54.473 T:139631773328128 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_stencil_export GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_gather GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_draw_indirect GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_precision GL_ARB_texture_compression_bptc GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_AMD_multi_draw_indirect GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shader_atomic_counters GL_ARB_shader_image_load_store GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_query_buffer_object GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_clear_buffer_object GL_ARB_compute_shader GL_ARB_copy_image GL_ARB_explicit_uniform_location GL_ARB_fragment_layer_viewport GL_ARB_framebuffer_no_attachments GL_ARB_invalidate_subdata GL_ARB_multi_draw_indirect GL_ARB_program_interface_query GL_ARB_robust_buffer_access_behavior GL_ARB_shader_image_size GL_ARB_shader_storage_buffer_object GL_ARB_stencil_texturing GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_texture_view GL_ARB_vertex_attrib_binding GL_KHR_debug GL_KHR_robustness GL_KHR_texture_compression_astc_ldr GL_ARB_buffer_storage GL_ARB_clear_texture GL_ARB_indirect_parameters GL_ARB_internalformat_query2 GL_ARB_multi_bind GL_ARB_query_buffer_object GL_ARB_seamless_cubemap_per_texture GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_stencil8 GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_framebuffer_fetch GL_EXT_shader_integer_mix GL_INTEL_performance_query GL_ARB_ES3_1_compatibility GL_ARB_clip_control GL_ARB_conditional_render_inverted GL_ARB_cull_distance GL_ARB_derivative_control GL_ARB_get_texture_sub_image GL_ARB_pipeline_statistics_query GL_ARB_shader_texture_image_samples GL_ARB_texture_barrier GL_ARB_transform_feedback_overflow_query GL_EXT_polygon_offset_clamp GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_robust_buffer_access_behavior GL_ARB_fragment_shader_interlock GL_ARB_post_depth_coverage GL_ARB_shader_atomic_counter_ops GL_ARB_shader_ballot GL_ARB_shader_clock GL_EXT_shader_samples_identical GL_KHR_no_error GL_KHR_texture_compression_astc_sliced_3d GL_NV_fragment_shader_interlock GL_MESA_shader_integer_functions GL_ARB_polygon_offset_clamp GL_ARB_texture_filter_anisotropic GL_EXT_shader_framebuffer_fetch_non_coherent GL_INTEL_shader_atomic_float_minmax 22:40:54.585 T:139631756269312 NOTICE: Running database version Addons27 22:40:54.585 T:139631756269312 NOTICE: Running database version ViewModes6 22:40:54.586 T:139631756269312 NOTICE: Running database version Textures13 22:40:54.587 T:139631756269312 NOTICE: Running database version MyMusic60 22:40:54.590 T:139631756269312 NOTICE: Running database version MyVideos107 22:40:54.591 T:139631756269312 NOTICE: Running database version TV29 22:40:54.592 T:139631756269312 NOTICE: Running database version Epg11 22:40:54.593 T:139631773328128 NOTICE: start dvd mediatype detection 22:40:54.607 T:139631773328128 ERROR: Couldn't load font name: font10(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.611 T:139631773328128 ERROR: Couldn't load font name: font12(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.611 T:139631773328128 ERROR: Couldn't load font name: font13(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.612 T:139631773328128 ERROR: Couldn't load font name: font14(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.613 T:139631773328128 ERROR: Couldn't load font name: font25_narrow(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.613 T:139631773328128 ERROR: Couldn't load font name: font27(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.614 T:139631773328128 ERROR: Couldn't load font name: font27_narrow(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.614 T:139631773328128 ERROR: Couldn't load font name: font37(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.615 T:139631773328128 ERROR: Couldn't load font name: font45(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.616 T:139631773328128 ERROR: Couldn't load font name: font60(notosans-regular.ttf), trying to substitute arial.ttf 22:40:54.617 T:139631773328128 ERROR: Couldn't load font name: font_clock(roboto-thin.ttf), trying to substitute arial.ttf 22:40:54.618 T:139631773328128 ERROR: Couldn't load font name: font_flag(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.619 T:139631773328128 ERROR: Couldn't load font name: font20_title(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.620 T:139631773328128 ERROR: Couldn't load font name: font25_title(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.620 T:139631773328128 ERROR: Couldn't load font name: font30_title(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.620 T:139631773328128 ERROR: Couldn't load font name: font32_title(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.621 T:139631773328128 ERROR: Couldn't load font name: font36_title(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.622 T:139631773328128 ERROR: Couldn't load font name: font45_title(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.622 T:139631773328128 ERROR: Couldn't load font name: font52_title(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.623 T:139631773328128 ERROR: Couldn't load font name: font_MainMenu(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.623 T:139631773328128 ERROR: Couldn't load font name: WeatherTemp(notosans-bold.ttf), trying to substitute arial.ttf 22:40:54.624 T:139631773328128 ERROR: Couldn't load font name: Mono30(notomono-regular.ttf), trying to substitute arial.ttf 22:40:54.677 T:139631773328128 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList" 22:40:54.711 T:139631773328128 NOTICE: initialize done 22:40:54.711 T:139631773328128 NOTICE: Running the application... 22:40:54.713 T:139631773328128 NOTICE: starting zeroconf publishing 22:40:54.713 T:139631773328128 NOTICE: starting upnp client 22:40:54.718 T:139630166918912 NOTICE: ES: Starting UDP Event server on port 9777 22:40:54.718 T:139630166918912 NOTICE: UDP: Listening on port 9777 (ipv6 : false) 22:40:54.966 T:139630578882304 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|Unable to connect to 192.168.0.19:8096 : [Errno 111] Connection refused 22:41:35.918 T:139630578882304 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|HTTP response error: 400 Bad Request 22:45:45.421 T:139629898483456 ERROR: Previous line repeats 25 times. 22:45:45.421 T:139629898483456 ERROR: GetDirectory - Error getting 22:45:45.997 T:139629881698048 ERROR: Previous line repeats 6 times. 22:45:45.997 T:139629881698048 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeEncodeError'> Error Contents: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) Traceback (most recent call last): File "/root/.kodi/addons/plugin.video.embycon/default.py", line 18, in <module> main_entry_point() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/tracking.py", line 22, in wrapper value = func(*args, **kwargs) File "/root/.kodi/addons/plugin.video.embycon/resources/lib/functions.py", line 159, in main_entry_point check_server() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/server_detect.py", line 384, in check_server m.update(name) UnicodeEncodeError: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) -->End of Python script error report<-- 22:45:46.027 T:139631773328128 ERROR: GetDirectory - Error getting plugin://plugin.video.embycon/?content_type=video 22:45:46.028 T:139631773328128 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.embycon/?content_type=video) failed 22:45:46.056 T:139630561834752 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|HTTP response error: 400 Bad Request 22:46:06.087 T:139629890090752 ERROR: Previous line repeats 2 times. 22:46:06.088 T:139629890090752 ERROR: GetDirectory - Error getting 22:46:16.072 T:139630561834752 ERROR: Previous line repeats 2 times. 22:46:16.072 T:139630561834752 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|HTTP response error: 400 Bad Request 22:49:22.975 T:139629915268864 ERROR: Previous line repeats 18 times. 22:49:22.975 T:139629915268864 ERROR: EmbyCon.resources.lib.cache_images|ERROR|Kodi web server not enabled, can not cache images 22:49:26.157 T:139630561834752 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|HTTP response error: 400 Bad Request 22:49:44.877 T:139631773328128 ERROR: Previous line repeats 1 times. 22:49:44.877 T:139631773328128 WARNING: RunScript called for a non-script addon 'plugin.video.embycon'. This behaviour is deprecated. 22:49:44.962 T:139629898483456 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeEncodeError'> Error Contents: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) Traceback (most recent call last): File "/root/.kodi/addons/plugin.video.embycon/default.py", line 18, in <module> main_entry_point() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/tracking.py", line 22, in wrapper value = func(*args, **kwargs) File "/root/.kodi/addons/plugin.video.embycon/resources/lib/functions.py", line 87, in main_entry_point check_server(change_user=True, notify=False) File "/root/.kodi/addons/plugin.video.embycon/resources/lib/server_detect.py", line 384, in check_server m.update(name) UnicodeEncodeError: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) -->End of Python script error report<-- 22:49:46.168 T:139630561834752 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|HTTP response error: 400 Bad Request 22:54:46.957 T:139630561834752 ERROR: Previous line repeats 29 times. 22:54:46.957 T:139630561834752 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|HTTP response error 401 auth error, removing any saved passwords for user: fcdd00b86d5f306e5d4c1f02debe44ff 22:54:46.960 T:139630561834752 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|HTTP response error: 401 Unauthorized 22:54:56.964 T:139630561834752 ERROR: EmbyCon.resources.lib.downloadutils|ERROR|HTTP response error: 400 Bad Request 22:54:58.584 T:139630578882304 WARNING: CPythonInvoker(0, /root/.kodi/addons/plugin.video.embycon/service.py): the python script "/root/.kodi/addons/plugin.video.embycon/service.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon4xbmc7MonitorE 22:54:58.764 T:139630570489600 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeEncodeError'> Error Contents: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) Traceback (most recent call last): File "/root/.kodi/addons/plugin.video.embycon/service.py", line 49, in <module> check_server() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/server_detect.py", line 384, in check_server m.update(name) UnicodeEncodeError: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) -->End of Python script error report<-- 22:55:06.646 T:139631773328128 ERROR: Control 55 in window 10025 has been asked to focus, but it can't 22:55:07.171 T:139630570489600 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeEncodeError'> Error Contents: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) Traceback (most recent call last): File "/root/.kodi/addons/plugin.video.embycon/default.py", line 18, in <module> main_entry_point() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/tracking.py", line 22, in wrapper value = func(*args, **kwargs) File "/root/.kodi/addons/plugin.video.embycon/resources/lib/functions.py", line 159, in main_entry_point check_server() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/server_detect.py", line 384, in check_server m.update(name) UnicodeEncodeError: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) -->End of Python script error report<-- 22:55:07.194 T:139631773328128 ERROR: GetDirectory - Error getting plugin://plugin.video.embycon/?content_type=video 22:55:07.194 T:139631773328128 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.embycon/?content_type=video) failed 22:55:24.581 T:139631773328128 ERROR: Control 55 in window 10025 has been asked to focus, but it can't 22:55:25.122 T:139631756269312 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeEncodeError'> Error Contents: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) Traceback (most recent call last): File "/root/.kodi/addons/plugin.video.embycon/default.py", line 18, in <module> main_entry_point() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/tracking.py", line 22, in wrapper value = func(*args, **kwargs) File "/root/.kodi/addons/plugin.video.embycon/resources/lib/functions.py", line 159, in main_entry_point check_server() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/server_detect.py", line 384, in check_server m.update(name) UnicodeEncodeError: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) -->End of Python script error report<-- 22:55:25.144 T:139631773328128 ERROR: GetDirectory - Error getting plugin://plugin.video.embycon/ 22:55:25.144 T:139631773328128 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.embycon/) failed 22:55:36.795 T:139631773328128 WARNING: RunScript called for a non-script addon 'plugin.video.embycon'. This behaviour is deprecated. 22:55:46.962 T:139631756269312 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeEncodeError'> Error Contents: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) Traceback (most recent call last): File "/root/.kodi/addons/plugin.video.embycon/default.py", line 18, in <module> main_entry_point() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/tracking.py", line 22, in wrapper value = func(*args, **kwargs) File "/root/.kodi/addons/plugin.video.embycon/resources/lib/functions.py", line 93, in main_entry_point check_server(force=True, change_user=True, notify=False) File "/root/.kodi/addons/plugin.video.embycon/resources/lib/server_detect.py", line 384, in check_server m.update(name) UnicodeEncodeError: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) -->End of Python script error report<-- 22:56:25.460 T:139631773328128 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM" 22:56:25.460 T:139631773328128 NOTICE: Enabled debug logging due to GUI setting. Level 2. 22:56:25.460 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 22:56:25.461 T:139631773328128 DEBUG: ------ Window Init () ------ 22:56:27.127 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:27.127 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:27.127 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:27.927 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:27.927 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:27.927 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:30.927 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:30.927 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:30.927 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:31.760 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 22:56:31.760 T:139631773328128 DEBUG: OnKey: return (0xf00d) pressed, action is Select 22:56:31.762 T:139631773328128 INFO: Loading skin file: FileBrowser.xml, load type: KEEP_IN_MEMORY 22:56:31.774 T:139631773328128 DEBUG: ------ Window Init (FileBrowser.xml) ------ 22:56:33.161 T:139631773328128 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 22:56:33.161 T:139631773328128 DEBUG: OnKey: right (0xf083) pressed, action is Right 22:56:33.161 T:139631773328128 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 22:56:33.811 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:33.811 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:33.811 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:34.511 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 22:56:34.511 T:139631773328128 DEBUG: OnKey: return (0xf00d) pressed, action is Select 22:56:34.511 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 22:56:34.777 T:139631773328128 DEBUG: ------ Window Deinit (FileBrowser.xml) ------ 22:56:34.778 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 22:56:35.444 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:35.444 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:35.444 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:36.077 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:36.077 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:36.077 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:36.810 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:36.810 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:36.810 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:37.894 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 22:56:37.910 T:139631773328128 DEBUG: OnKey: return (0xf00d) pressed, action is Select 22:56:37.910 T:139631773328128 DEBUG: Activating window ID: 10050 22:56:38.227 T:139631773328128 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------ 22:56:38.227 T:139631773328128 DEBUG: ------ Window Init (EventLog.xml) ------ 22:56:38.227 T:139631773328128 DEBUG: CGUIMediaWindow::GetDirectory (events://) 22:56:38.227 T:139631773328128 DEBUG: ParentPath = [events://] 22:56:38.231 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 22:56:39.808 T:139631773328128 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 22:56:39.808 T:139631773328128 DEBUG: OnKey: left (0xf082) pressed, action is Left 22:56:39.808 T:139631773328128 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 22:56:41.216 T:139631773328128 DEBUG: Keyboard: scancode: 0x6f, sym: 0x0111, unicode: 0x0000, modifier: 0x0 22:56:41.216 T:139631773328128 DEBUG: OnKey: up (0xf080) pressed, action is Up 22:56:41.216 T:139631773328128 DEBUG: Keyboard: scancode: 0x6f, sym: 0x0111, unicode: 0x0000, modifier: 0x0 22:56:41.969 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 22:56:41.969 T:139631773328128 DEBUG: OnKey: return (0xf00d) pressed, action is Select 22:56:41.969 T:139631773328128 DEBUG: CGUIMediaWindow::GetDirectory (events://) 22:56:41.969 T:139631773328128 DEBUG: ParentPath = [] 22:56:41.970 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 22:56:41.971 T:139631773328128 DEBUG: CGUIMediaWindow::GetDirectory (events://) 22:56:41.971 T:139631773328128 DEBUG: ParentPath = [events://] 22:56:41.972 T:139631773328128 DEBUG: CGUIMediaWindow::GetDirectory (events://) 22:56:41.972 T:139631773328128 DEBUG: ParentPath = [events://] 22:56:43.116 T:139631773328128 DEBUG: Keyboard: scancode: 0x6f, sym: 0x0111, unicode: 0x0000, modifier: 0x0 22:56:43.116 T:139631773328128 DEBUG: OnKey: up (0xf080) pressed, action is Up 22:56:43.116 T:139631773328128 DEBUG: Keyboard: scancode: 0x6f, sym: 0x0111, unicode: 0x0000, modifier: 0x0 22:56:44.277 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:44.277 T:139631773328128 DEBUG: OnKey: up (0xf080) pressed, action is Up 22:56:44.317 T:139631773328128 DEBUG: Keyboard: scancode: 0x6f, sym: 0x0111, unicode: 0x0000, modifier: 0x0 22:56:44.384 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:44.384 T:139631773328128 DEBUG: OnKey: up (0xf080) pressed, action is Up 22:56:44.384 T:139631773328128 DEBUG: Keyboard: scancode: 0x6f, sym: 0x0111, unicode: 0x0000, modifier: 0x0 22:56:44.956 T:139631773328128 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 22:56:44.956 T:139631773328128 DEBUG: OnKey: left (0xf082) pressed, action is Left 22:56:44.956 T:139631773328128 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 22:56:45.017 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:45.017 T:139631773328128 DEBUG: OnKey: left (0xf082) pressed, action is Left 22:56:45.018 T:139631773328128 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 22:56:45.865 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:45.865 T:139631773328128 DEBUG: OnKey: left (0xf082) pressed, action is Left 22:56:45.865 T:139631773328128 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 22:56:45.894 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:45.894 T:139631773328128 DEBUG: OnKey: left (0xf082) pressed, action is Left 22:56:45.910 T:139631773328128 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 22:56:46.634 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:46.634 T:139631773328128 DEBUG: OnKey: left (0xf082) pressed, action is Left 22:56:46.634 T:139631773328128 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 22:56:47.287 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:47.287 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:47.292 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:47.863 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 22:56:47.863 T:139631773328128 DEBUG: OnKey: return (0xf00d) pressed, action is Select 22:56:47.864 T:139631773328128 DEBUG: CGUIMediaWindow::GetDirectory (events://) 22:56:47.864 T:139631773328128 DEBUG: ParentPath = [events://] 22:56:47.865 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 22:56:48.842 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 22:56:48.842 T:139631773328128 DEBUG: OnKey: return (0xf00d) pressed, action is Select 22:56:48.843 T:139631773328128 DEBUG: CGUIMediaWindow::GetDirectory (events://) 22:56:48.843 T:139631773328128 DEBUG: ParentPath = [events://] 22:56:48.844 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 22:56:50.522 T:139631773328128 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x001b, modifier: 0x0 22:56:50.674 T:139631773328128 DEBUG: OnKey: escape (0xf01b) pressed, action is PreviousMenu 22:56:50.674 T:139631773328128 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 22:56:50.993 T:139631773328128 DEBUG: ------ Window Deinit (EventLog.xml) ------ 22:56:50.993 T:139631773328128 DEBUG: CGUIWindowManager::PreviousWindow: Activate new 22:56:50.993 T:139631773328128 DEBUG: ------ Window Init (Settings.xml) ------ 22:56:50.994 T:139631773328128 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x0000, modifier: 0x0 22:56:51.691 T:139631773328128 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x001b, modifier: 0x0 22:56:51.825 T:139631773328128 DEBUG: OnKey: escape (0xf01b) pressed, action is PreviousMenu 22:56:51.825 T:139631773328128 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 22:56:52.143 T:139631773328128 DEBUG: ------ Window Deinit (Settings.xml) ------ 22:56:52.144 T:139631773328128 DEBUG: CGUIWindowManager::PreviousWindow: Activate new 22:56:52.144 T:139631773328128 DEBUG: ------ Window Init (Home.xml) ------ 22:56:52.144 T:139631773328128 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x0000, modifier: 0x0 22:56:53.943 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:53.943 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:53.943 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:54.027 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:54.027 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:54.027 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:54.677 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:54.677 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:54.677 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:54.777 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:54.777 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:54.777 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:55.411 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:55.411 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:55.411 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:56.077 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:56.077 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:56.077 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:57.298 T:139631773328128 DEBUG: Previous line repeats 1 times. 22:56:57.298 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:57.298 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:58.111 T:139631773328128 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 22:56:58.111 T:139631773328128 DEBUG: OnKey: right (0xf083) pressed, action is Right 22:56:58.111 T:139631773328128 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 22:56:58.775 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:56:58.775 T:139631773328128 DEBUG: OnKey: down (0xf081) pressed, action is Down 22:56:58.775 T:139631773328128 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 22:57:00.196 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 22:57:00.293 T:139631773328128 DEBUG: OnKey: return (0xf00d) pressed, action is Select 22:57:00.293 T:139631773328128 DEBUG: Activating window ID: 10025 22:57:00.610 T:139631773328128 DEBUG: ------ Window Deinit (Home.xml) ------ 22:57:00.612 T:139631773328128 DEBUG: ------ Window Init (MyVideoNav.xml) ------ 22:57:00.613 T:139631773328128 ERROR: Control 55 in window 10025 has been asked to focus, but it can't 22:57:00.614 T:139631773328128 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 22:57:00.628 T:139631773328128 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.embycon/?content_type=video) 22:57:00.628 T:139631773328128 DEBUG: ParentPath = [plugin://plugin.video.embycon/?content_type=video] 22:57:00.637 T:139630578882304 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.embycon] took 9 ms 22:57:00.637 T:139629906876160 DEBUG: StartScript - calling plugin EmbyCon('plugin://plugin.video.embycon/','4','?content_type=video') 22:57:00.638 T:139631756269312 DEBUG: Thread LanguageInvoker start, auto delete: false 22:57:00.638 T:139631756269312 INFO: initializing python engine. 22:57:00.642 T:139631756269312 DEBUG: CPythonInvoker(7, /root/.kodi/addons/plugin.video.embycon/default.py): start processing 22:57:00.646 T:139631756269312 DEBUG: -->Python Interpreter Initialized<-- 22:57:00.646 T:139631756269312 DEBUG: CPythonInvoker(7, /root/.kodi/addons/plugin.video.embycon/default.py): the source file to load is "/root/.kodi/addons/plugin.video.embycon/default.py" 22:57:00.646 T:139631756269312 DEBUG: CPythonInvoker(7, /root/.kodi/addons/plugin.video.embycon/default.py): setting the Python path to /root/.kodi/addons/plugin.video.embycon:/usr/share/kodi/addons/script.module.pil/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages 22:57:00.646 T:139631756269312 DEBUG: CPythonInvoker(7, /root/.kodi/addons/plugin.video.embycon/default.py): entering source directory /root/.kodi/addons/plugin.video.embycon 22:57:00.646 T:139631756269312 DEBUG: CPythonInvoker(7, /root/.kodi/addons/plugin.video.embycon/default.py): instantiating addon using automatically obtained id of "plugin.video.embycon" dependent on version 2.25.0 of the xbmc.python api 22:57:01.128 T:139631773328128 DEBUG: ------ Window Init (DialogBusy.xml) ------ 22:57:01.139 T:139631756269312 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<-- - NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS! Error Type: <type 'exceptions.UnicodeEncodeError'> Error Contents: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) Traceback (most recent call last): File "/root/.kodi/addons/plugin.video.embycon/default.py", line 18, in <module> main_entry_point() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/tracking.py", line 22, in wrapper value = func(*args, **kwargs) File "/root/.kodi/addons/plugin.video.embycon/resources/lib/functions.py", line 159, in main_entry_point check_server() File "/root/.kodi/addons/plugin.video.embycon/resources/lib/server_detect.py", line 384, in check_server m.update(name) UnicodeEncodeError: 'ascii' codec can't encode character u'\u017c' in position 10: ordinal not in range(128) -->End of Python script error report<-- 22:57:01.145 T:139631773328128 DEBUG: ------ Window Init (DialogNotification.xml) ------ 22:57:01.150 T:139631756269312 INFO: Python script stopped 22:57:01.150 T:139631756269312 DEBUG: Thread LanguageInvoker 139631756269312 terminating 22:57:01.161 T:139631773328128 ERROR: GetDirectory - Error getting plugin://plugin.video.embycon/?content_type=video 22:57:01.162 T:139631773328128 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.embycon/?content_type=video) failed 22:57:01.162 T:139631773328128 DEBUG: CGUIMediaWindow::GetDirectory () 22:57:01.162 T:139631773328128 DEBUG: ParentPath = [plugin://plugin.video.embycon/?content_type=video] 22:57:01.163 T:139631756269312 DEBUG: Thread BackgroundLoader start, auto delete: false 22:57:01.165 T:139631756269312 DEBUG: Thread BackgroundLoader 139631756269312 terminating 22:57:01.193 T:139631773328128 DEBUG: ------ Window Deinit (DialogBusy.xml) ------ 22:57:06.893 T:139631773328128 DEBUG: ------ Window Deinit (DialogNotification.xml) ------ 22:57:11.177 T:139631773328128 INFO: Python, unloading python shared library because no scripts are running anymore 22:57:11.183 T:139631773328128 DEBUG: UnloadExtensionLibs, clearing python extension libraries 22:57:30.638 T:139630578882304 DEBUG: Thread JobWorker 139630578882304 terminating (autodelete) 22:57:30.638 T:139630570489600 DEBUG: Thread JobWorker 139630570489600 terminating (autodelete) 22:57:30.638 T:139629915268864 DEBUG: Thread JobWorker 139629915268864 terminating (autodelete) 22:57:31.161 T:139629906876160 DEBUG: Thread JobWorker 139629906876160 terminating (autodelete) regards.
TeamB 2440 Posted April 12, 2021 Posted April 12, 2021 Kodi 17.6 is very old, EmbyCon may work but it is not supported officially, are you able to get a more up to date version of kodi? The above error is a Unicode text error, do you have Unicode characters in your emby server name? If so remove them and try again.
Przemek 70 Posted April 13, 2021 Author Posted April 13, 2021 (edited) Hi, @TeamB do You mean polish letters [like "ęąźżó"] in my username or password? My server name is dietpi so I don't think it's wrong. I also see in my emby cockpit that login attempt failed from my user. I think that is login from Kodi. If there is nothing I can do I will compile new Kodi from source for Debian. regards. Edited April 13, 2021 by Przemek
TeamB 2440 Posted April 13, 2021 Posted April 13, 2021 Yeah its probably the user name. Kodi 19 should be better as it is using python 3 and that handles Unicode strings better.
Solution Przemek 70 Posted April 13, 2021 Author Solution Posted April 13, 2021 Can You tell me is this guide OK: Kodi guide ? regards.
TeamB 2440 Posted April 13, 2021 Posted April 13, 2021 I am sorry but I don't know, I have never tried it
Przemek 70 Posted April 13, 2021 Author Posted April 13, 2021 I install that Kodi 19 nightly build and it works perfect Regards.
